RB500V-40
Taiwan Semiconductor
Small Signal Product
Low VF SMD Schottky Barrier Diode
FEATURES
- Low power loss, high current capability, low VF
- Surface mount device type
- Moisture sensitivity level (MSL): 1
- Packing code with suffix "G" means
green compound (halogen-free)
SOD-323F
MECHANICAL DATA
- Case: Flat lead SOD-323F small outline plastic package
- Terminal: Matte tin plated, lead free,
solderable per MIL-STD-202, Method 208 guaranteed
- High temperature soldering guaranteed : 260°C/10s
- Polarity: Indicated by cathode band
- Weight: 4.85 ± 0.5 mg
- Marking Code: S9
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
Power Dissipation
PD
200
mW
Peak Reverse Voltage
VRM
45
V
Reverse Voltage
VR
40
V
Mean Forward Current
IO
0.1
A
IFSM
1.0
Non-Repetitive Peak Forward Surge Current
60Hz for 1 Cyc.
Thermal Resistance (Junction to Ambient)
(Note)
Junction and Storage Temperature Range
RθJA
500
TJ ,TSTG
-40 to +125
A
o
C/W
o
C
SYMBOL
MIN
MAX
UNIT
Reverse Breakdown Voltage
IR = 100 μA
V(BR)
45
V
Forward Voltage
IF = 10 mA
VF
0.45
V
Reverse Leakage Current
VR = 10 V
IR
1
μA
VR = 10V , f = 1.0 MHz
CJ
6.0
pF
PARAMETER
Junction Capacitance
Note: Valid provided that electrodes are kept at ambient temeprature.
Document Number: DS_S1412013
Version: C14
RB500V-40
RATINGS AND CHARACTERISTICS CURVES
Fig. 1 Forward Current Derating Curve
IO, Average Rectified Current (mA)
120
100
80
60
40
50
75
100
125
150
IF, Instantaneous Forward Current (mA)
Fig. 2 Typical Forward Characteristics
100
10
TA=125°C
TA=75°C
TA=25°C
TA=-25°C
1
0.1
TA, Ambient Temperature (oC)
600
800
1000
Fig. 4 Total Capacitance VS. Reverse
Fig. 3 Typical Reverse Characteristics
100
1000
f=1MHz
TA=125°C
100
10
CT, Total Capacitance (pF)
IR, Instantaneous Reverse Current (μA)
400
VF, Instantaneous Forward Voltage (V)
TA=75°C
1
TA=25°C
0.1
0.01
VR, Instantaneous Reverse Voltage (V)
40
10
1
10
15
30
35
40
VR, Reverse Voltage (V)
Version: C14
RB500V-40
ORDERING INFORMATION
PART NO.
PACKING
PACKING CODE
SUFFIX (Note 1)
CODE
SUFFIX
PART NO.
RB500V-40
-xx
RR
R9
G
PACKAGE
SOD-323F
PACKING
3,000 / 7" Reel
10,000 / 13" Reel
Note 1: Part No. Suffix „-xx “ would be used for special requirement
EXAMPLE
PART NO.
PART NO.
RB500V-40 RR
RB500V-40
RR
RB500V-40 RRG
RB500V-40
RR
G
Multiple manufacture
source
Green compound
RB500V-40-B0 RRG
RB500V-40
RR
G
Defined manufacture
source
Green compound
SUFFIX
-B0
PACKING CODE
PACKING CODE
PREFERRED P/N
SUFFIX
DESCRIPTION
source
Version: C14
RB500V-40
PACKAGE OUTLINE DIMENSIONS
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.15
1.35
0.045
0.053
B
2.30
2.80
0.091
0.110
C
0.25
0.40
0.010
0.016
D
1.60
1.80
0.063
0.071
E
0.80
1.10
0.031
0.043
F
0.05
0.25
0.002
0.010
SUGGEST PAD LAYOUT
Unit (mm)
Unit (inch)
Typ.
Typ.
A
0.63
0.025
B
0.83
0.033
C
1.60
0.063
D
2.86
0.113
DIM.
Version: C14
RB500V-40
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied,to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or seling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: C14
很抱歉,暂时无法提供与“RB500V-40 RRG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.028761+0.26224
- 10+1.2535610+0.16204
- 100+0.77702100+0.10044
- 500+0.56795500+0.07342
- 1000+0.500131000+0.06465
- 国内价格 香港价格
- 3000+0.413523000+0.05346
- 6000+0.369756000+0.04780
- 9000+0.347419000+0.04491
- 15000+0.3223015000+0.04166
- 21000+0.3074121000+0.03974
- 30000+0.2929330000+0.03787
