SST20B-600CW
SST20B-600CW
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    SST20B-600CW
SST20B-600CW 数据手册
SST20 Series Technical Data Data Sheet N2166, Rev.- SST20 Series 20A TRIACs Circuit Diagram TO-220A(Ins) TO-220B(Non-Ins) Description With high ability to withstand the shock loading of large current,SST20 series triacs provide high dv/dt rate with strong resistance to electromagnetic interface. With high commutation performances, 3 quadrants products especially recommended for use on inductive load. Maximum Ratings: Characteristics Symbol - Max. Units Tstg -40-150 ℃ Tj - -40-125 ℃ Repetitive peak off-state voltage(Tj=25℃) VDRM - 600/800 V Repetitive peak reverse voltage(Tj=25℃) VRRM - 600/800 V Non repetitive surge peak Off-state voltage VDSM - VDRM +100 V Non repetitive peak reverse voltage VRSM - VRRM +100 V 20 A 200 A Storage junction temperature range Operating junction temperature range RMS on-state current Non repetitive surge peak on-state current (full cycle, F=50Hz) I2t value for fusing (tp=10ms) Critical rate of rise of on-state current (IG=2×IGT) Peak gate current Average gate power dissipation Peak gate power I(TRMS) ITSM Condition TO-220A(Ins)(TC=70℃) TO-220B(Non-Ins)(TC=90℃) - 2 It - 200 A2 s dI/dt - 100 A/μs IGM 4 A PG(AV) - 1 W PGM - 10 W  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SST20 Series Technical Data Data Sheet N2166, Rev.- Electrical Characteristics(Tj=25℃ unless otherwise specified) 3 Quadrants Symbol IGT VGT VGD Test Condition VD =12V RL =33Ω VD =VDRM Tj =125℃ RL =3.3KΩ IG =1.2IGT IH IT =100mA VD=2/3VDRM Gate Open Tj =125℃ BW CW 50 35 Unit Ⅰ-Ⅱ-Ⅲ MAX Ⅰ-Ⅱ-Ⅲ MAX 1.3 V Ⅰ-Ⅱ-Ⅲ MIN 0.2 V Ⅰ-Ⅲ IL dV/dt Value Quadrant Ⅱ mA 70 60 90 70 MAX 60 50 mA MIN 1000 500 V/μs MAX mA 4 Quadrants Symbol Test Condition Quadrant Value Unit 50 mA MAX 70 1.3 V ALL MIN 0.2 V Ⅰ-Ⅲ-Ⅳ Ⅱ MAX 70 90 mA Ⅰ-Ⅱ-Ⅲ IGT VD =12V RL=33Ω Ⅳ ALL VGT VGD VD =VDRM Tj =125℃ RL =3.3KΩ MAX IL IG =1.2IGT IH IT =100mA MAX 60 mA VD=2/3VDRM Gate Open Tj=125℃ MIN 500 V/μs dV/dt Static Characteristics Symbol VTM IDRM IRRM Parameter ITM =28A tp=380μs VD =VDRM VR =VRRM Tj=25℃ Value(MAX) Unit 1.5 V Tj=25℃ 5 μA Tj=125℃ 2.5 mA Condition Value Units TO-220A(Ins) 1.9 ℃/W TO-220B(Non-Ins) 1.1 ℃/W Thermal Resistances Symbol Rth(j-c) Junction to case(AC)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SST20 Series Technical Data Data Sheet N2166, Rev.- Ordering Information S ST 20 A -800 BW SMC Diode Solutions BW: IGT1-3 ≤ 50mA CW: IGT1-3 ≤ 35mA Triacs IT(RMS):20A 600:VDRM/VRRM ≥ 600V 800:VDRM/VRRM ≥ 800V A: TO-220A(Ins) B:TO-220B(Non-Ins) Device SST20A-800CW, SST20A-800BW, SST20A-600CW, SST20A-600BW SST20B-800CW, SST20B-800BW, SST20B-600CW, SST20B-600BW Package TO-220A(Ins) TO-220B(Non-Ins) Shipping 50pcs/ Tube 50pcs/ Tube Marking Diagram Where XXXXX is YYWWL SST20A-800BW SST20B-800BW YY WW L = Part name = Part name = Year = Week = Lot Number Mechanical Dimensions TO-220A(Ins) SYMBOL Millimeters Min. A B C C2 C3 D E F G H L1 L2 L3 V1 4.40 0.61 0.46 1.21 2.40 8.60 9.60 6.55 28.0 1.14 2.65 Typ. 2.54 3.75 45° Inches Max. Min. 4.60 0.88 0.70 1.32 2.72 9.70 10.4 6.95 0.173 0.024 0.018 0.048 0.094 0.339 0.378 0.258 29.8 1.102 1.70 2.95 0.045 0.104  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Typ. 0.1 0.148 45° Max. 0.181 0.035 0.028 0.052 0.107 0.382 0.409 0.274 1.173 0.067 0.116 SST20 Series Technical Data Data Sheet N2166, Rev.- Mechanical Dimensions TO-220B(Non-Ins) SYMBOL Millimeters Min. A B C C2 C3 D E F G H L1 L2 L3 V1 4.40 0.61 0.46 1.21 2.40 8.60 9.60 6.20 28.0 1.14 2.65 Typ. 2.54 3.75 45° Inches Max. Min. 4.60 0.88 0.70 1.32 2.72 9.70 10.4 6.60 0.173 0.024 0.018 0.048 0.094 0.339 0.378 0.244 29.8 1.102 1.70 2.95 0.045 0.104 Typ. 0.1 0.148 45° Max. 0.181 0.035 0.028 0.052 0.107 0.382 0.409 0.260 1.173 0.067 0.116 Ratings and Characteristics Curves FIG.1 Maximum power dissipation versus RMS on-state current FIG.2: RMS on-state current versus case temperature P(w) 30 IT(RMS) (A) 30 25 25 20 20 15 15 10 10 5 5 0 0 4 8 IT(RMS) (A) 12 16 20 FIG.3: Surge peak on-state current versus number of cycles 250 0 0 α=180° TO-220B(Non-Ins) TO-220A(Ins) Tc (℃) 25 50 75 100 125 4 5 FIG.4: On-state characteristics (maximum values) ITM (A) 200 ITSM (A) t=20ms One cycle 200 100 Tj=Tjmax 150 100 50 0 1 10  China - Germany - Korea - Singapore - United States  Tj=25℃  http://www.smc-diodes.com - sales@ smc-diodes.com  Number of cycles 10 100 1000 1 0 1 2 VTM (V) 3 20 20 15 15 10 10 Technical Data 5 Data Sheet N2166, Rev.0 0 4 8 TO-220B(Non-Ins) SST20 Series TO-220A(Ins) 5 IT(RMS) (A) 12 16 20 FIG.3: Surge peak on-state current versus number of cycles Tc (℃) 0 0 25 50 75 100 125 4 5 FIG.4: On-state characteristics (maximum values) ITM (A) 200 ITSM (A) 250 t=20ms 100 One cycle 200 Tj=Tjmax 150 10 100 Tj=25℃ 50 0 1 Number of cycles 10 100 1000 FIG.5: Non-repetitive surge peak on-state current for a sinusoidal pulse with width tp
SST20B-600CW 价格&库存
很抱歉,暂时无法提供与“SST20B-600CW”相匹配的价格&库存,您可以联系我们找货
