SST06A-800BW
SST06A-800BW
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    SST06A-800BW
SST06A-800BW 数据手册
SST06 Series Technical Data Data Sheet N2164, Rev.- SST06 Series 6A TRIACs Circuit Diagram TO-220A(Ins) TO-220B(Non-Ins) Description With high ability to withstand the shock loading of large current, JST06 series triacs provide high dv/dt rate with strong resistance to electromagnetic interface. With high commutation performances, the products especially recommended for use on inductive load. Maximum Ratings: Characteristics Symbol - Max. Units Tstg -40-150 ℃ Tj - -40-125 ℃ Repetitive peak off-state voltage(Tj=25℃) VDRM - 800 V Repetitive peak reverse voltage(Tj=25℃) VRRM - 800 V Non repetitive surge peak Off-state voltage VDSM - VDRM +100 V Non repetitive peak reverse voltage VRSM - VRRM +100 V 6 A 60 A Storage junction temperature range Operating junction temperature range RMS on-state current Non repetitive surge peak on-state current (full cycle, F=50Hz) I2t value for fusing (tp=10ms) Critical rate of rise of on-state current (IG=2×IGT) Peak gate current Average gate power dissipation Peak gate power I(TRMS) ITSM Condition TO-220A(Ins)(TC=107℃) TO-220B(Non-Ins)(TC=100℃) - 2 It - 18 A2 s dI/dt - 50 A/μs IGM 2 A PG(AV) - 1 W PGM - 5 W  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SST06 Series Technical Data Data Sheet N2164, Rev.- Electrical Characteristics(Tj=25℃ unless otherwise specified) Symbol IGT Test Condition VD =12V RL =30Ω VGT VD =VDRM Tj =125℃ RL =3.3KΩ VGD IG =1.2IGT IH ITM =0.2A VD=2/3VDRM Gate Open Tj =125℃ BW CW MAX Ⅰ-Ⅱ-Ⅲ MAX 1.5 V Ⅰ-Ⅱ-Ⅲ MIN 0.2 V Ⅱ 50 35 Unit Ⅰ-Ⅱ-Ⅲ Ⅰ-Ⅲ IL dV/dt Value Quadrant mA 70 50 80 60 MAX 60 35 mA MIN 1000 400 V/μs MAX mA Static Characteristics Symbol VTM Parameter ITM =8.5A tp=380μs IDRM IRRM VD =VDRM VR =VRRM Value(MAX) Unit Tj=25℃ 1.5 V Tj=25℃ 5 μA Tj=125℃ 1 mA Value Units TO-220A(Ins) 3.3 ℃/W TO-220B(Non-Ins) 2.2 ℃/W Thermal Resistances Symbol Rth(j-c) Condition Junction to case(AC)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SST06 Series Technical Data Data Sheet N2164, Rev.- Ordering Information S ST 06 A -800 BW SMC Diode Solutions BW: IGT1-3 ≤ 50mA CW: IGT1-3 ≤ 35mA Triacs IT(RMS):6A 800:VDRM/VRRM ≥ 800V A: TO-220A(Ins) B:TO-220B(Non-Ins) Device SST06A-800CW, SST06A-800BW SST06B-800CW, SST06B-800BW Package TO-220A(Ins) TO-220B(Non-Ins) Shipping 50pcs/ Tube 50pcs/ Tube Marking Diagram Where XXXXX is YYWWL SST06A-800BW SST06B-800BW YY WW L = Part name = Part name = Year = Week = Lot Number Mechanical Dimensions TO-220A(Ins) SYMBOL Millimeters Min. A B C C2 C3 D E F G H L1 L2 L3 V1 4.40 0.61 0.46 1.21 2.40 8.60 9.60 6.55 28.0 1.14 2.65 Typ. 2.54 3.75 45° Inches Max. Min. 4.60 0.88 0.70 1.32 2.72 9.70 10.4 6.95 0.173 0.024 0.018 0.048 0.094 0.339 0.378 0.258 29.8 1.102 1.70 2.95 0.045 0.104  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Typ. 0.1 0.148 45° Max. 0.181 0.035 0.028 0.052 0.107 0.382 0.409 0.274 1.173 0.067 0.116 SST06 Series Technical Data Data Sheet N2164, Rev.- Mechanical Dimensions TO-220B(Non-Ins) SYMBOL Millimeters Min. A B C C2 C3 D E F G H L1 L2 L3 V1 Typ. 4.40 0.61 0.46 1.21 2.40 8.60 9.60 6.20 2.54 28.0 3.75 1.14 2.65 45° Inches Max. Min. 4.60 0.88 0.70 1.32 2.72 9.70 10.4 6.60 0.173 0.024 0.018 0.048 0.094 0.339 0.378 0.244 29.8 1.102 1.70 2.95 0.045 0.104 Typ. Max. 0.181 0.035 0.028 0.052 0.107 0.382 0.409 0.260 0.1 0.148 45° 1.173 0.067 0.116 Ratings and Characteristics Curves FIG.1: Maximum power dissipation versus RMS on-state current 9 FIG.2: RMS on-state current versus case temperature IT(RMS) (A) 8 P(w) α=180° TO-220B(Non-Ins) 6 6 4 TO-220A(Ins) 3 2 0 0 1.5 IT(RMS) (A) 3.0 4.5 6.0 7.5 0 Tc (℃) 0 25 50  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  75 100 125 SST06 Series Technical Data Data Sheet N2164, Rev.- FIG.3: Surge peak on-state current versus number of cycles 75 FIG.4: On-state characteristics (maximum values) ITSM (A) 60 ITM (A) t=20ms Tj=Tjmax One cycle 60 10 45 30 1 15 Tj=25℃ Number of cycles 10 100 0 1 1000 FIG.5: Non-repetitive surge peak on-state current for a sinusoidal pulse with width tp
SST06A-800BW 价格&库存
很抱歉,暂时无法提供与“SST06A-800BW”相匹配的价格&库存,您可以联系我们找货
SST06A-800BW
    • 1+4.10400
    • 200+1.64160
    • 500+1.58760
    • 1000+1.55520
