CTB12-1200BW
CTB12-1200BW
    SENSATA(森萨塔)
    TO-220-3
    TRIAC ALTERNISTOR 1.2KV TO220AB
CTB12-1200BW 数据手册
Crydom Inc. 2475 Paseo de la Americas San Diego, CA 92154. USA +1 (877) 502 5500 Tel +1 (619) 210 1590 Fax www.crydom.com www.sensata.com CE Declaration of Conformity Declaration number: 01.152018C Manufacturer: Crydom Inc. 2475 Paseo de las Americas, Suite 201 San Diego, CA 92154 USA. Product: Solid State Relay Model (s): See attachment We declare under our sole responsibility that products listed below are in conformity with the requirements of the Low Voltage Directive LVD 2006/95/EC and 2014/35/EU recast, as well as the following harmonized standards: Quality Standard: Safety Standard: ISO 9001:2008; EN 60950-1:2006 + A11 + A1 + A12 + A2:2013 Sections 1.5; 1.7; 2.9; 2.10.5.3; 4.2; 4.5; 4.7. This Declaration of Conformity is no longer valid if: • Product is used or installed improperly; • Product is modified or changed in any other way; • Additional components other than approved accessories are integrated in the product. Date: January 15, 2018 Sincerely, Oscar Rivera Engineering Director Solid State Relays (Industrial Sensing) Crydom Inc. Crydom Inc. 2475 Paseo de la Americas San Diego, CA 92154. USA +1 (877) 502 5500 Tel +1 (619) 210 1590 Fax www.crydom.com www.sensata.com 84060001 Series; 84115501/84115502 Series; 84130105/84130105 Series; 84134/84135 Series; 84137/84140 Series; 1F25/3F20/3F20-4SST Filters; 40TP Series; 53TP/53DP/53RV Series; A12/D12 Series; A24/D24 Series; A48/D48 Series; AO/ASO Series; ASPF Series; C4IAC/C4OAC Series; C4ODCA; CC/CD Dual SSRs; CKR Series; CL Series; CMA/CMD Series; CMRA/CMRD Series; CMX100/CMXE100 Series; CMX200/CMXE200 Series; CN240 Series; CSD Series; CSW Series; CTR Series; CWA/CWD/CWU Series; CX/CXE Series; CY67009; D1D/D2D/D4D/D5D Series; D2W Series; D24XXD Series; D40-1A Series; DC60A/DC60SA Series; DC100/DC200 Series; DC400/DC500 Series; DPA Series; DR22 Series; DR45 Series; DR10D Series; DR24/DRD24 Series; DR48/DRD48 Series; DRA1/DRA4 Series; DRA3P/DRA3R Series; DRACN Series; DRC3 Series; DRH Series; DR-IAC Series; DRML1 Series; DR-OAC Series; DRMS48D Series; DRTX24 Series; DSD/DLD Series; ED06B/ED10/ED24 Series; EL Series; ELS Series; EZ Series; GA8 Series; GN0/GN3 Series; GNR Series; H10/H12/H16 Series; H12D48XXD Series; HA48/HD48 Series; HA60/HD60 Series; HAC/HDC60A Series; HDC100A/HDC200 Series; HPF Series; HSD2440 Series; HSP-1, -2, -5 Series; IAC5Q/IAC5AQ; IAC5/IAC24 Series; LPCV Series; LR600/LR1200 Series; LS240/LSE240 Series; MCBC/MCPC/MCSP Series; MCSS/MCST/MCTC Series; MCMX100 Series; MCX/MCXE Series; M-IAC5/M-IAC24 Series; M-OAC5/M-OAC24 Series; M-ODC5A/M-ODC5MA; M-ODC24A; MP/MPF Series; NTA/NTD Series; OAC5/OAC24 Series; ODC5A/ODC5MA; ODC24A; PCV Series; PF/PFE Series; PM22 Series; PMP Series; PSD Series; Quad Series SSRs; SDV/SDI Series; SM-IAC5/SM-IAC24 Series; SM-OAC5/SM-OAC24 Series; SM-ODC5A/SM-ODC5MA; SM-ODC24A; SMR Series; SPA Series; SPF/SPFE Series; SSC Series; SST Series; T Series; UPD Series; Crydom Inc. 2475 Paseo de la Americas San Diego, CA 92154. USA +1 (877) 502 5500 Tel +1 (619) 210 1590 Fax www.crydom.com www.sensata.com The following Solid State Relays, although compliant with the Low Voltage Directive, are out of the scope of the said directive, and therefore exempts: 84115503 Series; 84130104 Series; 84134750 Series; 84134870 Series; 84137750 Series; 84137870 Series; C4IDC Series; C4ODC; CKM Series; CMX60/CMXE60 Series; CN024/CN048 Series; D06D Series; DC60D Series; DC60S3 Series; DC60S5 Series; DC60S7 Series; DMO/DO Series; DP4R Series; DR06D Series; DR-IDC Series; DR-ODC Series; DRTX06 Series; ED06 Series; HDC60D/HDC100D Series; IAC5EQ; IDC5Q/IDC5BQ; IDC5/IDC24 Series; LVD75 Series; M-IDC5/M-IDC24 Series; M-ODC5/M-ODC5F; M-ODC5MC; M-ODC5ML/M-ODC24; MPDCD3 Series; MCMX60 Series; ODC5/ODC5F; ODC5MC/ODC5ML; ODC24/ODC24F; SM-IDC5 Series; SM-IDC24/SM-ODC24; SM-ODC5F/SM-ODC5ML; SM-ODC5/SM-ODC5MC;
CTB12-1200BW
PDF文档是关于Sensata Technologies公司Crydom Inc.生产的固态继电器(Solid State Relays)的合规性声明。
文档编号为01.152018C,声明日期为2018年1月15日。
文档列出了符合低压指令LVD 2006/95/EC和2014/35/EU修订版的固态继电器型号,并提到了相关的安全标准和质量标准,如EN 60950-1:2006和ISO 9001:2008。
文档中提到,如果产品使用或安装不当、产品被修改或以其他方式改变、或者集成了未经批准的附加组件,则合规性声明将不再有效。
文档还列出了多个固态继电器系列,包括但不限于84060001系列、84115501/84115502系列、84130105/841301050系列、84134/84135系列、84137/84140系列等。
这些继电器虽然符合低压指令,但声明指出它们不在该指令的范围内,因此被豁免。
文档没有提供具体的物料型号器件简介引脚分配参数特性功能详解应用信息
如果需要这些详细信息,可能需要查阅每个系列的具体产品数据手册或技术文档。
CTB12-1200BW 价格&库存
很抱歉,暂时无法提供与“CTB12-1200BW”相匹配的价格&库存,您可以联系我们找货
