SST130U-600D
SST130U-600D
    SMCDIODESOLUTIONS(桑德斯)
    TO92-3
    600V 0.8A TO-92 3-QUAD TRIAC
SST130U-600D 数据手册
SST130U-600D Technical Data Data Sheet N2040, Rev.- SST130U-600D 0.8A TRIACs Circuit Diagram TO-92 Description With low holding and latching current, SST130 series triacs are especially recommended for use on middle and small resistance type power load. Maximum Ratings: Characteristics Storage junction temperature range Symbol Condition Max. Units Tstg - -40 - 150 ℃ Tj - -40 - 125 ℃ Repetitive peak off-state voltage (Tj=25℃) VDRM - 600 V Repetitive peak reverse voltage (Tj=25℃) VRRM - 600 V Non repetitive surge peak off-state voltage VDSM - VDRM+100 V Non repetitive peak reverse voltage VRSM - VRRM+100 V RMS on-state current I(TRMS) TO-92(TC=50℃) 0.8 A 400 A - 880 A2 s Ⅰ-Ⅱ-Ⅲ 50 Ⅳ 20 1 A 0.1 W 1 W Operating junction temperature range Non repetitive surge peak on-state current (full cycle, F=50Hz) I2t value for fusing (tp=10ms) Critical rate of rise of on-state current (IG =2×IGT) ITSM I2t dI/dt - Peak gate current IGM Average gate power dissipation PGM - PG(AV) - Peak gate power  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  A/us SST130U-600D Technical Data Data Sheet N2040, Rev.- Electrical Characteristics(Tj=25℃ unless otherwise specified) Symbol Test Condition Ⅰ-Ⅱ-Ⅲ IGT VD=12V Ⅳ VGT VD=VDRM Tj=125℃ RL=3.3KΩ VGD IG=1.2IGT IH IT=100mA VD=2/3VDRM Gate Open Tj=125℃ MAX D T 5 5 10 5 Unit mA ALL MAX 1.3 V ALL MIN 0.2 V Ⅰ-Ⅲ-Ⅳ IL dV/dt Value Quadrant Ⅱ 10 5 20 15 MAX 7 5 mA MIN 30 10 V/μs MAX mA Static Characteristics Symbol Condition Max. IT=1.1A tp=380μs,Tj=25℃ VD=VDRM VR=VRRM, Tj=25℃ VD=VDRM VR=VRRM, Tj=125℃ VTM IDRM IRRM Units 1.5 5 100 V μA μA Value Units 75 ℃/W Thermal Resistances Symbol Condition Rth(j-c) Junction to case(AC) TO-92 Ordering Information S ST 130 U -600 D SMC Diode Solutions D:IGT1-3 ≤ 5mA IGT4 ≤ 10mA Triacs IT(RMS):0.8A 600:VDRM/VRRM ≥ 600V U:TO-92 Device Package Shipping SST130U-600D TO-92 2000pcs/ reel SST130U-600DTR TO-92 2000pcs/ reel  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SST130U-600D Technical Data Data Sheet N2040, Rev.- Marking Diagram Where XXXXX is YYWWL SST130U-600D YY WW L = Part name = Year = Week = Lot Number Mechanical Dimensions TO-92 Millimeters Inches SYMBO L Min. Typ. Max. Min. Typ. Max. A B C D E F G H J K N P 4.45 4.32 3.18 0.407 0.60 0.36 12.70 2.04 1.86 1.1 1.27 2.30 - 5.20 5.33 4.19 0.533 0.80 0.50 15.0 2.66 2.06 0.175 0.170 0.125 0.016 0.024 0.014 0.500 0.080 0.073 0.043 0.050 0.091 - 0.205 0.210 0.165 0.021 0.031 0.020 0.591 0.105 0.081 V - - 4.3 - - 0.169 Ratings and Characteristics Curves FIG.1: Maximum power dissipation versus RMS on-state current FIG.2: RMS on-state current versus case temperature P(w) 1.2 IT(RMS) (A) 1.2 1.0 1.0 0.8 0.8 0.6 0.6 0.4 0.4 0.2 0.2 0 0 0.2 IT(RMS) (A) 0.4 0.6 0.8 1.0 0 α=180° TO-92 Tc (℃) 0 25 50 75  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  100 125 SST130U-600D Technical Data Data Sheet N2040, Rev.- FIG.3: Surge peak on-state current versus number of cycles 10.5 FIG.4: On-state characteristics (maximum values) ITSM (A) 10 ITM (A) t=20ms One cycle 9 Tj=Tjmax 7.5 6 1 4.5 3 Tj=25℃ 1.5 0 1 Number of cycles 100 10 1000 FIG.5: Non-repetitive surge peak on-state current for a sinusoidal pulse with width tp
SST130U-600D 价格&库存
很抱歉,暂时无法提供与“SST130U-600D”相匹配的价格&库存,您可以联系我们找货
