CCS050M12CM2
CCS050M12CM2
    WOLFSPEED
    Module
    CCS050M12CM2
CCS050M12CM2 数据手册
CCS050M12CM2 VDS 1.2 kV 1.2kV, 25mΩ All-Silicon Carbide Six-Pack (Three Phase) Module C2M MOSFET and Z-RecTM Diode ESW, Total @ 50A, 150 C RDS(on) Features • • • • • • 25 mΩ Package Ultra Low Loss Zero Reverse Recovery Current Zero Turn-off Tail Current High-Frequency Operation Positive Temperature Coefficient on VF and VDS(on) Cu Baseplate, AlN DBC System Benefits • • • • • 1.7 mJ ˚ Enables Compact and Lightweight Systems High Efficiency Operation Ease of Transistor Gate Control Reduced Cooling Requirements Reduced System Cost Applications • • • • • • Solar Inverters UPS and SMPS Induction Heating Regen Drives 3-Phase PFC Motor Drives Part Number Package Marking CCS050M12CM2 Six-Pack CCS050M12CM2 Maximum Ratings (TC = 25˚C unless otherwise specified) Symbol 2,Rev. E Value Unit Test Conditions VDS Drain - Source Voltage 1.2 kV VGS Gate - Source Voltage -10/+25 V Absolute maximum values VGS Gate - Source Voltage -5/+20 V Recommended operational values ID S050M12CM Datasheet: CC Parameter ID(pulse) IF IFSM TJ TC ,TSTG 87 Continuous Drain Current 59 Pulsed Drain Current 250 Continuous Diode Forward Current Non-Repetitive Diode Forward Surge Current 102 62 A A A 400 A Junction Temperature -40 to +150 ˚C Case and Storage Temperature Range -40 to +125 ˚C VGS = 20 V, TC = 25 ˚C VGS = 20 V, TC = 90 ˚C Pulse width tP limited by Tjmax Notes Fig. 26 Fig. 28 VGS = -5 V, TC = 25 ˚C VGS = -5 V, TC = 90 ˚C VGS = -5 V, TC = 110 ˚C, tP = 10 ms, Half Sine Pulse, Visol Case Isolation Voltage 5.0 kV AC, 50 Hz, 1 min LStray Stray Inductance 30 nH Measured from pins 25-26 to 27-28 PD Power Dissipation 312 W TC = 25 ˚C, TJ ≤ 150 ˚C Subject to change without notice. www.cree.com Fig. 27 1 Electrical Characteristics (TC = 25˚C unless otherwise specified) Symbol Parameter V(BR)DSS Drain - Source Breakdown Voltage VGS(th) Gate Threshold Voltage IDSS Zero Gate Voltage Drain Current IGSS Gate-Source Leakage Current RDS(on) Min. Typ. Max. 1.2 kV 2.3 V 1.6 2 On State Resistance Unit Test Conditions VGS, = 0 V, ID = 250 µA VD = VG, ID = 2.5 mA VDS = 10 V, ID = 2.5 mA, TJ = 150 ˚C 250 μA VDS = 1.2 kV, VGS = 0V 100 nA VGS = 25 V, VDS = 0V 25 36 43 63 22 mΩ VGS = 20 V, IDS = 50 A VGS = 20 V, IDS = 50 A, TJ = 150 ˚C VDS = 20 V, IDS = 50 A Figs. 4-7 gfs Transconductance Ciss Input Capacitance 2.810 Coss Output Capacitance 0.393 Crss Reverse Transfer Capacitance 0.014 Eon Turn-On Switching Energy 1.1 mJ EOff Turn-Off Switching Energy 0.6 mJ Internal Gate Resistance 1.5 Ω f = 1 MHz, VAC = 25 mV QGS Gate-Source Charge 32 QGD Gate-Drain Charge 30 nC VDD= 800 V, ID= 50 A Fig. 15 QG Total Gate Charge 180 td(on) Turn-on delay time 21 ns Rise time 30 ns Turn-off delay time 50 ns Figs. 20-25 Fall time 19 ns VDD = 800V, RLOAD = 8 Ω VGS = +20/-2V, RG = 3.8 Ω TJ = 25 ˚C Note: IEC 60747-8-4 Definitions RG (int) tr td(off) tf S Note 21 VSD Diode Forward Voltage QC Total Capacitive Charge nF 1.5 1.8 2.0 2.3 0.28 V VDS = 20 V, ID = 50 A, TJ = 150 ˚C Fig. 8 VDS = 800 V, VGS = 0 V f = 1 MHz, VAC = 25 mV Figs. 16,17 VDD = 600 V, VGS = +20V/-5V ID = 50 A, RG = 20 Ω Load = 200 μH TJ = 150 ˚C Note: IEC 60747-8-4 Definitions Fig. 18 IF = 50 A, VGS = 0 Figs. 10-11 IF = 50 A, TJ = 150 ˚C μC Thermal Characteristics Symbol Parameter Min. Typ. Max. RthJCM Thermal Resistance Juction-to-Case for MOSFET 0.37 0.40 RthJCD Thermal Resistance Juction-to-Case for Diode 0.42 0.43 Unit ˚C/W Test Conditions Note Tc = 90 ˚C, PD = 150 W Tc = 90 ˚C, PD = 130 W NTC Characteristics Symbol R25 Delta R/R P25 B25/50 Condition Typ. TC = 25 °C Max. 5 TC = 100 °C, R100 = 481 Ω kΩ ±5 TC = 25 °C 3380 Additional Module Data 2 Condition W Weight M Mounting Torque % mW R2 = R25 exp[B25/50(1/T2-1/(298.15K))] Symbol Unit CCS050M12CM2,Rev. E Max Unit 180 g 5 Nm Test Condition To heatsink K Typical Performance 200 160 120 80 VGS = 10 V 40 0 3 6 9 12 Drain-Source Voltage, VDS (V) 15 On Resistance, RDS On (p.u.) Drain Current, IDS (A) VGS = 10 V 80 9 12 Drain-Source Voltage, VDS (V) 9 12 15 Conditions: IDS = 50 A VGS = 20 V tp < 50 µs 1.4 1.2 1.0 0.8 0.6 0.4 0.0 6 6 Drain-Source Voltage, VDS (V) 0.2 VGS = 5 V 3 3 Figure 2. Typical Output Characteristics TJ = 25 ˚C 1.6 40 15 -50 -25 0 25 50 75 Junction Temperature, TJ (°C) 100 125 150 Figure 3. Typical Output Characteristics TJ = 150 ˚C Figure 4. Normalized On-Resistance vs. Temperature 60 100 Conditions: VGS = 20 V tp < 50 µs Conditions: IDS = 50 A tp < 50 µs 90 80 TJ = 150 °C On Resistance, RDS On (mΩ) 50 On Resistance, RDS On (mΩ) 0 1.8 VGS = 15 V 0 VGS = 10 V VGS = 5 V VGS = 20 V 120 0 80 2.0 Conditions: TJ = 150 °C tp < 50 µs 160 120 0 Figure 1. Typical Output Characteristics TJ = -40 ˚C 200 VGS = 15 V 40 VGS = 5 V 0 VGS = 20 V Conditions: TJ = 25 °C tp < 50 µs VGS = 15 V Drain Current, IDS (A) Drain Current, IDS (A) 160 200 VGS = 20 V Conditions: TJ = -40 °C tp < 50 µs TJ = 125 °C 40 30 TJ = 25 °C TJ = -40 °C 20 10 70 TJ = -40 °C 60 50 TJ = 150 °C 40 TJ = 25 °C 30 20 10 0 0 25 50 Drain Source Current, IDS (A) 75 100 Figure 5. Normalized On-Resistance vs. Drain Current For Various Temperatures 3 CCS050M12CM2,Rev. E 0 12 13 14 15 16 17 Gate Source Voltage, VGS (V) 18 19 Figure 6. Normalized On-Resistance vs. Gate-Source Voltage for Various Temperatures 20 Typical Performance 100 80 VGS = 12 V 70 60 50 VGS = 14 V 40 VGS = 16 V 30 VGS = 18 V 20 VGS = 20 V TJ = 150 °C Conditions: tp < 50 µs Drain-Source Current, IDS (A) 90 On Resistance, RDS On (mΩ) 100 Conditions: IDS = 50 A tp < 50 µs 80 60 TJ = 25 °C 40 TJ = -40 °C 20 10 0 -50 -25 0 25 50 75 Junction Temperature, TJ (°C) 100 125 0 150 Figure 7. On-Resistance vs. Temperature for Various Gate-Source Voltages -3 -2.5 -2 -1.5 -1 -0.5 0 2 4 6 8 10 Gate-Source Voltage, VGS (V) 12 Figure 8. Transfer Characteristic for Various Junction Temperatures 0 -3 0 -2.5 -2 -1.5 -1 -0.5 0 0 VGS = -5 V Drain-Source Current, IDS (A) VGS = 0 V -25 -50 -75 Drain-Source Currnmt, IDS (A) VGS = -2 V -25 -50 -75 Conditions: TJ = -40 °C tp < 50 µs VGS = -2 V VGS = -5 V -100 Drain-Source Voltage, VDS (V) -2.5 -2 -1.5 -1 -0.5 VGS = 0 V -100 Drain-Source Voltage, VDS (V) Figure 10. Diode Characteristic at 25 ˚C Figure 9. Diode Characteristic at -40 ˚C -3 Conditions: TJ = 25 °C tp < 50 µs 0 -3 0 -2.5 -2 -1.5 -1 VGS = 0 V -0.5 0 0 VGS = 10 V -25 -50 VGS = 0 V VGS = -5 V -75 VGS = 20 V Drain-Source Voltage, VDS (V) Figure 11. Diode Characteristic at 150 ˚C CCS050M12CM2,Rev. E -25 VGS = 15 V -50 -75 Conditions: TJ = -40 °C tp < 50 µs Conditions: TJ = 150 °C tp < 50 µs VGS = -2 V 4 Drain-Source Current, IDS (A) Drain-Source Current, IDS (A) VGS = 5 V -100 -100 Drain-Source Voltage, VDS (V) Figure 12. 3rd Quadrant Characteristic at -40 ˚C Typical Performance -3 -2.5 -2 -1.5 -1 -0.5 0 -3 0 -2.5 -2 -1.5 VGS = 0 V -1 -0.5 0 0 VGS = 0 V -25 VGS = 10 V VGS = 15 V -50 VGS = 20 V -75 Drain-Source Current, IDS (A) Drain-Source Current, IDS (A) VGS = 5 V -25 VGS = 5 V VGS = 10 V -50 VGS = 15 V -75 Conditions: TJ = 25 °C tp < 50 µs -100 Drain-Source Voltage, VDS (V) Figure 14. 3rd Quadrant Characteristic at 150 ˚C 10000 Conditions: VDS = 800 V IDS = 50 A IGS = 10 mA 15 CISS 1000 Capacitance (pF) Gate-Source Voltage, VGS (V) 20 10 5 CRSS 10 Conditions: f = 1 MHz VAC = 25 mV 0 30 60 90 Gate Charge (nC) 120 150 1 180 50 100 150 200 250 Figure 16. Typical Capacitances vs. Drain-Source Voltage (0 - 250 V) 3.0 Conditions: VDD = 600 V TJ = 150 °C L = 200 µH RG = 20 Ohms VGS = +20V/-5V CISS 2.5 1000 Switching Loss (mJ) COSS 100 CRSS 10 Conditions: f = 1 MHz VAC = 25 mV 1 0 Drain-Source Voltage, VDS (V) 10000 Capacitance (pF) COSS 100 0 Figure 15. Typical Gate Charge Characteristics 0 Eon 2.0 Eoff 1.5 1.0 0.5 250 500 750 Drain-Source Voltage, VDS (V) Figure 17. Typical Capacitances vs. Drain-Source Voltage (0 - 1 kV) 5 -100 Drain-Source Voltage, VDS (V) Figure 13. 3rd Quadrant Characteristic at 25 ˚C -5 Conditions: TJ = 150 °C tp < 50 µs VGS = 20 V CCS050M12CM2,Rev. E 1000 0.0 0 25 50 75 100 Drain to Source Current, IDS (A) Figure 18. Inductive Switching Energy vs. Drain Current For VDS = 600V, RG = 20 Ω 125 Typical Performance 4.5 3.5 ton Eon Time, ton, tr, td(on) (ns) 4.0 Switching Loss (mJ) 100 Conditions: VDD = 800 V TJ = 150 °C L = 200 µH RG = 20 Ohms VGS = +20V/-5V 3.0 Eoff 2.5 2.0 1.5 td(on) tr Conditions: VGS: +20/-5V RG = 20 Ohms VDD = 800 V TJ = 25 °C 1.0 0.5 0.0 0 25 50 75 100 10 125 1 10 Figure 19. Inductive Switching Energy vs. Drain Current For VDS = 800 V, RG = 20 Ω Figure 20. Turn-on Timing vs. Drain Current 1000 Time, ton, tr, td(on) (ns) Time, toff, tf, td(off (ns) 10000 1000 toff td(off) 100 10 tf Conditions: VGS: +20/-5V RG = 20 Ohms VDD = 800 V TJ = 25 °C 1 10 Figure 21. Turn-off Timing vs. Drain Current 10000 1 10 Figure 22. Turn-on Timing vs. External Gate Resistor toff tr tr td(on) Conditions: VGS: +20/-5V RG = 20 Ohms VDD = 800 V RLoad = 16 Ohms 10 100 Gate Resistance, RG (Ohms) Figure 23. Turn-off Timing vs. External Gate Resistor 6 100 Gate Resistance, RG (Ohms) Time, ton, tr, td(on) (ns) Time, toff, tf, td(off (ns) 10 10 1 td(on) ton td(off) 100 tr ton 100 Conditions: VGS: +20/-5V RLoad = 16 Ohms VDD = 800 V TJ = 25 °C 1000 Conditions: VGS: +20/-5V RLoad = 16 Ohms VDD = 800 V TJ = 25 °C 100 100 Drain-Source Current, IDS (A) 100 Drain-Source Current, IDS (A) Drain to Source Current, IDS (A) CCS050M12CM2,Rev. E 10 0 20 40 60 80 100 Junction Temperature, TJ (°C) 120 140 Figure 24. Turn-on Timing vs. Junction Temperature 160 Typical Performance 100 Drain-Source Continous Current, IDS (DC) (A) Time, toff, tf, td(off (ns) 1000 toff td(off) 100 tf 10 Conditions: VGS: +20/-5V RG = 20 Ohms VDD = 800 V RLoad = 16 Ohms 0 20 60 80 100 Junction Temperature, TJ (°C) 120 140 70 60 50 40 30 20 10 160 350 Conditions: TJ ≤ 150 °C -20 250 200 150 100 -40 -20 0 20 40 60 80 100 Case Temperature, TC (°C) 120 140 120 140 160 100 µs 10.00 100 ms 1.00 0.10 Conditions: TC = 25 °C D = 0, Parameter: tp 0.1 1 10 100 1000 Drain-Source Voltage, VDS (V) Figure 28. MOSFET Safe Operating Area Diode Junction-Case Thermal Response, Zth JC (°C/W) MOSFET Junction-Case Thermal Response, Zth JC (°C/W) 100 1 D = 50% D = 30% D = 10% D = 5% D = 2% D = 1% D = 0.5% tp D = 0.2% 10E-6 100E-6 1E-3 10E-3 100E-3 1 10 Figure 29. MOSFET Junction to Case Thermal Impedance CCS050M12CM2,Rev. E D = 90% D = 70% D = 50% D = 30% 0.1 D = 10% D = 5% 0.01 D = 2% D = 1% D = 0.5% tp D = 0.2% Single Pulse T Single Pulse 1E-6 D = tp / T Time (s) 7 80 1 ms 160 D = 90% D = 70% 0.001 60 Limited by RDS On 1 0.01 40 Case Temperature, TC (°C) 1 µs Figure 27. Maximum Power Dissipation (MOSFET) Derating vs Case Temperature 0.1 20 10 µs 50 0 0 100.00 Drain-Source Current, IDS (A) 300 -40 Figure 26. Continous Drain Current Derating vs Case Temperature Figure 25. Turn-on Timing vs. Junction Temperature Maximum Dissipated Power, Ptot (W) 80 0 40 Conditions: TJ ≤ 150 °C 90 0.001 1E-6 10E-6 D = tp / T T 100E-6 1E-3 10E-3 100E-3 1 10 Time (s) Figure 30. Diode Junction to Case Thermal Impedance Typical Performance NTC Resistance (Ohms) 100000 10000 1000 100 10 -50 -25 0 25 50 75 NTC Temperature (°C) 100 125 150 Figure 31. NTC Resistance vs NTC Temperature Figure 32. Resistive Switching Time Description Creepage and Clearance Data Distance Creepage Clearance Minimum Distance Between Two High Voltage Pins 11.9 mm 6.5 mm Distance Between High Voltage Pin and Isolated Baseplate 15.6 mm 15.6 mm Distance Between High Voltage Pin and Mounting Bolt’s Head 19.1 mm 8.6 mm Distance Between High Voltage Pin and Isolated NTC Pin 16.7 mm 11.8 mm 8 CCS050M12CM2,Rev. E Package Dimensions (mm) This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, air traffic control systems, or weapons systems. Copyright © 2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks and Z-Rec is a trademark of Cree, Inc. 9 CCS050M12CM2,Rev. E Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5451 www.cree.com/power Recommendations for PCB mounting stand-offs In order to mount the PCB onto the module, it is recommended to use four PCB mounting stand-offs by using self-tapping screws. Following is the recommended self-tapping screw with its torque requirements: > Ejot DELTA PT WN 5451 K25x8 : Mmax = 0.4Nm ± 10% Installation of self-tapping screws can be done both by hand or by using an electric screw driver. For an electric screw driver the recommended maximum speed is 300 RPM. (Note: Do not use pneumatic screw driver to install self-tapping screws). The recommended effective length of screw threads entering the PCB mounting stand-offs should be in between 4mm to 6.5mm range. (Note: Self-tapping screws must be inserted straight into the PCB mounting stand-offs) PCB mounting stand-offs (Marked Red) This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, air traffic control systems, or weapons systems. Copyright © 2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks and Z-Rec is a trademark of Cree, Inc. 10 CCS050M12CM2,Rev. E Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5451 www.cree.com/power Notes • RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product Documentation sections of www.cree.com. • REACh Compliance REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. • This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, air traffic control systems. Module Application Note: The SiC MOSFET module switches at speeds beyond what is customarily associated with IGBT based modules. Therefore, special precautions are required to realize the best performance. The interconnection between the gate driver and module housing needs to be as short as possible. This will afford the best switching time and avoid the potential for device oscillation. Also, great care is required to insure minimum inductance between the module and link capacitors to avoid excessive VDS overshoots. Please Refer to application note: Design Considerations when using Cree SiC Modules Part 1 and Part 2. [CPWR-AN12, CPWR-AN13] Copyright © 2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc. 11 CCS050M12CM2,Rev. E Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5451 www.cree.com/power
CCS050M12CM2 价格&库存
很抱歉,暂时无法提供与“CCS050M12CM2”相匹配的价格&库存,您可以联系我们找货
