GC50MPS12-247
GC50MPS12-247
    GENESICSEMICONDUCTOR
    TO-247-2
    GC50MPS12-247
GC50MPS12-247 数据手册
GC50MPS12-247 1200V 50A SiC Schottky MPS™ Diode TM Silicon Carbide Schottky Diode VRRM = IF (TC = 147°C) = QC = Features • • • • • • • • Package Low VF for High Temperature Operation Enhanced Surge and Avalanche Robustness Superior Figure of Merit QC/IF Low Thermal Resistance Low Reverse Leakage Current Temperature Independent Fast Switching Positive Temperature Coefficient of VF High dV/dt Ruggedness Case RoHS TO-247-2 Advantages • • • • • • • • 1200 V 50 A 267 nC K REACH A Applications Improved System Efficiency High System Reliability Optimal Price Performance Reduced Cooling Requirements Increased System Power Density Zero Reverse Recovery Current Easy to Parallel without Thermal Runaway Enables Extremely Fast Switching • • • • • • • • Electric Vehicles and Fast Chargers Solar Inverters Train Auxiliary Power Supplies High frequency Converters Motor Drives Induction Heating and Welding Uninterruptible Power Supplies Pulsed Power Absolute Maximum Ratings (At TC = 25°C Unless Otherwise Stated) Parameter Repetitive Peak Reverse Voltage Continuous Forward Current Symbol VRRM IF Non-Repetitive Peak Forward Surge Current, Half Sine Wave IF,SM Repetitive Peak Forward Surge Current, Half Sine Wave IF,RM Non-Repetitive Peak Forward Surge Current i2t Value Non-Repetitive Avalanche Energy Diode Ruggedness Power Dissipation Operating and Storage Temperature Rev 21/Jul IF,MAX ∫i2dt EAS dV/dt PTOT T j , T stg Conditions TC = 100°C, D = 1 TC = 135°C, D = 1 TC = 147°C, D = 1 TC = 25°C, tP = 10 ms TC = 150°C, tP = 10 ms TC = 25°C, tP = 10 ms TC = 150°C, tP = 10 ms TC = 25°C, tP = 10 µs TC = 25°C, tP = 10 ms L = 0.7 mH, IAS = 50 A VR = 0 ~ 960 V TC = 25°C Values 1200 90 62 50 500 400 300 210 2500 1250 899 200 510 -55 to 175 Latest Version at: www.genesicsemi.com/sic-schottky-mps/GC50MPS12-247/GC50MPS12-247.pdf Unit V Note A Fig. 4 A A A A2s mJ V/ns W °C Fig. 3 Page 1 of 7 GC50MPS12-247 1200V 50A SiC Schottky MPS™ Diode TM Electrical Characteristics Parameter Symbol Diode Forward Voltage VF Reverse Current IR Total Capacitive Charge QC Switching Time tS Total Capacitance C Conditions Min. IF = 50 A, Tj = 25°C IF = 50 A, Tj = 175°C VR = 1200 V, Tj = 25°C VR = 1200 V, Tj = 175°C VR = 400 V VR = 800 V IF ≤ IF,MAX dIF/dt = 200 A/µs VR = 400 V VR = 800 V VR = 1 V, f = 1MHz VR = 800 V, f = 1MHz Values Typ. 1.5 1.9 4 54 184 267 Max. 1.8 20 Unit Note V Fig. 1 µA Fig. 2 nC Fig. 7 < 10 ns 3046 178 pF Fig. 6 Unit Note °C/W g Nm Fig. 9 Thermal/Package Characteristics Parameter Symbol Thermal Resistance, Junction - Case Weight Mounting Torque Rev 21/Jul RthJC WT TM Conditions Screws to Heatsink Min. Values Typ. 0.29 6.0 Max. 1.1 Latest Version at: www.genesicsemi.com/sic-schottky-mps/GC50MPS12-247/GC50MPS12-247.pdf Page 2 of 7 GC50MPS12-247 1200V 50A SiC Schottky MPS™ Diode Figure 1: Typical Forward Characteristics I F = f(VF,Tj); tP = 250 µs Figure 3: Power Derating Curves PTOT = f(TC ); Tj = 175°C Rev 21/Jul TM Figure 2: Typical Reverse Characteristics I R = f(VR,Tj) Figure 4: Current Derating Curves (Typical VF) I F = f(TC ); D = tP/T; Tj ≤ 175°C; fSW > 10kHz Latest Version at: www.genesicsemi.com/sic-schottky-mps/GC50MPS12-247/GC50MPS12-247.pdf Page 3 of 7 GC50MPS12-247 1200V 50A SiC Schottky MPS™ Diode Figure 5: Current Derating Curves (Maximum VF) I F = f(TC ); D = tP/T; Tj ≤ 175°C; fSW > 10kHz Figure 7: Typical Capacitive Charge vs Reverse Voltage Characteristics QC = f(VR); f = 1MHz Rev 21/Jul TM Figure 6: Typical Junction Capacitance vs Reverse Voltage Characteristics C = f(VR); f = 1MHz Figure 8: Typical Capacitive Energy vs Reverse Voltage Characteristics EC = f(VR); f = 1MHz Latest Version at: www.genesicsemi.com/sic-schottky-mps/GC50MPS12-247/GC50MPS12-247.pdf Page 4 of 7 GC50MPS12-247 1200V 50A SiC Schottky MPS™ Diode TM Figure 9: Transient Thermal Impedance Zth,jc = f(tP,D); D = tP/T Figure 10: Forward Curve Model Forward Curve Model Equation: I F = (VF - VBI)/RDIFF (A) Built-In Voltage (VBI): VBI(Tj) = m × Tj + n (V) m = -0.00123 (V/°C) n = 0.995 (V) Differential Resistance (RDIFF): 1/RDIFF RDIFF(Tj) = a × Tj2 + b × Tj + c (Ω) a = 2.38e-07 (Ω/°C2) b = 3.38e-05 (Ω/°C) c = 0.01 (Ω) VBI Forward Power Loss Equation: PLOSS = VBI(Tj) × I AVG + RDIFF(Tj) × I RMS2 I F = f(VF,Tj) Rev 21/Jul Latest Version at: www.genesicsemi.com/sic-schottky-mps/GC50MPS12-247/GC50MPS12-247.pdf Page 5 of 7 GC50MPS12-247 1200V 50A SiC Schottky MPS™ Diode TM Package Dimensions TO-247-2 Package Outline 0.190 (4.83) 0.205 (5.21) 0.620 (15.75) 0.635 (16.13) 0.170 (4.32) 0.216 (5.49) 0.530 (13.46) 0.557 (14.16) 0.059 (1.50) 0.098 (2.49) 0.085 (2.16) 0.108 (2.75) 0.212 (5.39) 0.244 (6.20) 0.047 (1.19) 0.238 (6.04) 0.248 (6.30.) 0.819 0.831 (20.80) (21.10) 0.640 (16.25) 0.695 (17.65) Ø 0.140 (3.56) Ø 0.144 (3.65) Ø 0.283 (7.19) REF 0.161 (4.10) 0.173 (4.40) 0.780 0.800 (19.81) (20.32) 0.075 (1.91) 0.094 (2.39) 0.044 (1.12) 0.052 (1.33) 0.214 (5.44) BSC. Recommended Solder Pad Layout 0.022 (0.55) 0.027 (0.69) 0.090 (2.29) 0.100 (2.55) Package View Case (K) 0.120 (3.05) 0.428 (10.88) 0.08 (2.03) K A NOTE 1. CONTROLLED DIMENSION IS INCH. DIMENSION IN BRACKET IS MILLIMETER. 2. DIMENSIONS DO NOT INCLUDE END FLASH, MOLD FLASH, MATERIAL PROTRUSIONS. Rev 21/Jul Latest Version at: www.genesicsemi.com/sic-schottky-mps/GC50MPS12-247/GC50MPS12-247.pdf Page 6 of 7 GC50MPS12-247 1200V 50A SiC Schottky MPS™ Diode TM Compliance RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS 2), as adopted by EU member states on January 2, 2013 and amended on March 31, 2015 by EU Directive 2015/863. RoHS Declarations for this product can be obtained from your GeneSiC representative. REACH Compliance REACH substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a GeneSiC representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67) is also available upon request. Disclaimer GeneSiC Semiconductor, Inc. reserves right to make changes to the product specifications and data in this document without notice. GeneSiC disclaims all and any warranty and liability arising out of use or application of any product. No license, express or implied to any intellectual property rights is granted by this document. Unless otherwise expressly indicated, GeneSiC products are not designed, tested or authorized for use in life-saving, medical, aircraft navigation, communication, air traffic control and weapons systems, nor in applications where their failure may result in death, personal injury and/or property damage. Related Links • SPICE Models: https://www.genesicsemi.com/sic-schottky-mps/GC50MPS12-247/GC50MPS12-247_SPICE.zip • PLECS Models: https://www.genesicsemi.com/sic-schottky-mps/GC50MPS12-247/GC50MPS12-247_PLECS.zip • CAD Models: https://www.genesicsemi.com/sic-schottky-mps/GC50MPS12-247/GC50MPS12-247_3D.zip • Evaluation Boards: https://www.genesicsemi.com/technical-support • Reliability: https://www.genesicsemi.com/reliability • Compliance: https://www.genesicsemi.com/compliance • Quality Manual: https://www.genesicsemi.com/quality Revision History • Rev 21/Jul: Updated with most recent test data • Supersedes: Rev 19/Apr, Rev 20/Apr, Rev 20/Aug www.genesicsemi.com/sic-schottky-mps/ Rev 21/Jul Copyright© 2021 GeneSiC Semiconductor Inc. All Rights Reserved. Published by GeneSiC Semiconductor, Inc. 43670 Trade Center Place Suite 155, Dulles, VA 20166; USA Page 7 of 7
GC50MPS12-247
物料型号:GC50MPS12-247
器件简介:这是一个硅碳化物肖特基二极管,具有1200V的重复峰值反向电压(VRRM)和50A的连续正向电流(IF)。
引脚分配:文档中没有提供具体的引脚分配图,但这个型号的二极管通常使用TO-247-2封装。
参数特性: - 正向电压(VF)在50A和25°C时的最小、典型和最大值分别为1.5V、1.8V和20V。 - 反向电流(IR)在1200V和25°C时的值为4mA,在1200V和175°C时的值为54mA。 - 总电容电荷(Qc)在特定的条件下为267nC。 - 开关时间(ts)在400V时小于10纳秒。
功能详解: - 低正向电压,适合高温操作。 - 增强的浪涌和雪崩鲁棒性。 - 优越的品质因数Q/Ic。 - 低热阻。 - 低反向漏电流。 - 温度无关的快速开关特性。 - 正温度系数的正向电压。 - 高dV/dt鲁棒性。
应用信息: - 电动汽车和快速充电器。 - 太阳能逆变器。 - 列车辅助电源。 - 高频转换器。 - 电机驱动。 - 感应加热和焊接。 - 不间断电源。 - 脉冲电源。
封装信息: - 封装类型为TO-247-2。 - 提供RoHS和REACH合规性声明。
GC50MPS12-247 价格&库存
很抱歉,暂时无法提供与“GC50MPS12-247”相匹配的价格&库存,您可以联系我们找货
