BUK9K13-60RA
Dual N-channel 60 V, 12.5 mOhm logic level MOSFET in
LFPAK56D using Repetitive Avalanche technology
2 December 2020
Product data sheet
1. General description
Dual, logic level N-channel MOSFET in an LFPAK56D package, using Application Specific
(ASFET) repetitive avalanche silicon technology. This product has been designed and qualified to
AEC-Q101 for use in repetitive avalanche applications.
2. Features and benefits
Fully automotive qualified to AEC-Q101 at 175 °C
Repetitive Avalanche rated to 30 °C Tj rise:
• Tested to 1 Bn avalanche events
LFPAK copper clip package technology:
• High robustness and reliability
• Gull wing leads for high manufacturability and AOI
3. Applications
12 V, 24 V and 48 V automotive systems
Repetitive avalanche topologies
Engine control
Transmission control
Actuator and auxiliary loads
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
25 °C ≤ Tj ≤ 175 °C
60
V
ID
drain current
VGS = 5 V; Tmb = 25 °C; Fig. 2
40
A
Ptot
total power dissipation
Tmb = 25 °C; Fig. 1
64
W
VGS = 5 V; ID = 10 A; Tj = 25 °C; Fig. 14
6.1
10
12.5
mΩ
7.9
nC
Static characteristics FET1 and FET2
RDSon
drain-source on-state
resistance
Dynamic characteristics FET1 and FET2
QGD
gate-drain charge
ID = 10 A; VDS = 48 V; VGS = 5 V;
Tj = 25 °C; Fig. 16; Fig. 17
BUK9K13-60RA
Nexperia
Dual N-channel 60 V, 12.5 mOhm logic level MOSFET in LFPAK56D using Repetitive Avalanche
technology
5. Pinning information
Table 2. Pinning information
Pin
Symbol
Description
1
S1
source1
2
G1
gate1
3
S2
source2
4
G2
gate2
5
D2
drain2
6
D2
drain2
7
D1
drain1
8
D1
drain1
Simplified outline
8
7
6
Graphic symbol
5
D1 D1
S1
D2 D2
G1
S2
G2
mbk725
1
2
3
4
LFPAK56D; Dual
LFPAK (SOT1205)
6. Ordering information
Table 3. Ordering information
Type number
Package
BUK9K13-60RA
Name
Description
Version
LFPAK56D;
Dual LFPAK
plastic, single ended surface mounted package (LFPAK56D); 8
leads
SOT1205
7. Marking
Table 4. Marking codes
Type number
Marking code
BUK9K13-60RA
91360RA
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
25 °C ≤ Tj ≤ 175 °C
60
V
VDGR
drain-gate voltage
RGS = 20 kΩ
60
V
VGS
gate-source voltage
DC; Tj ≤ 175 °C
-10
10
V
-15
15
V
Pulsed; Tj ≤ 175 °C
[1] [2]
Ptot
Tmb = 25 °C; Fig. 1
64
W
ID
drain current
40
A
VGS = 5 V; Tmb = 100 °C; Fig. 2
33
A
pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3
190
A
IDM
peak drain current
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
Tsld(M)
peak soldering
temperature
260
°C
IS
source current
40
A
BUK9K13-60RA
Product data sheet
Tmb = 25 °C
All information provided in this document is subject to legal disclaimers.
2 December 2020
Nexperia B.V. 2020. All rights reserved
2 / 13
BUK9K13-60RA
Nexperia
technology
Symbol
ISM
Parameter
Conditions
Min
Max
Unit
peak source current
190
A
[3] [4]
[5]
75.2
mJ
[6] [7]
82
mJ
Avalanche ruggedness
EDS(AL)R
repetitive drain-source
avalanche energy
ID = 1.92 A; Vsup ≤ 60 V; RGS = 10 Ω; VGS
=10 V; Tj(rise) ≤ 30 °C; unclamped; Fig. 4;
Fig. 5; Fig. 6
Avalanche Ruggedness FET1 and FET2
EDS(AL)S
[1]
[2]
[3]
[4]
[5]
[6]
[7]
non-repetitive drainID = 40 A; Vsup ≤ 60 V; RGS = 50 Ω;
source avalanche energy VGS = 5 V; Tj(init) = 25 °C; unclamped;
Fig. 7
Accumulated Pulse duration up to 50 hours delivers zero defect ppm
Significantly longer life times are achieved by lowering Tj and or VGS.
Repetitive avalanche rating is limited by maximum junction temperature of 175 °C and junction rise of 30 °C
Refer to Fig. 5 for the limiting number of avalanche events
Refer to Fig. 6 Rdson at Vgs=5V will increase as a function of repetitive avalanche cycles
Refer to application note AN10273 for further information
Single-pulse avalanche rating limited by maximum junction temperature of 175 °C
03aa16
120
ID
(A)
Pder
003aak109
50
40
(1)
80
30
10
100
150
Tmb (°C)
Fig. 2.
Fig. 1.
Normalized total power dissipation as a
function of mounting base temperature
BUK9K13-60RA
Product data sheet
75
100
125
150 175
Tmb (°C)
200
Continuous drain current as a function of
2 December 2020
50
3 / 13
BUK9K13-60RA
Nexperia
technology
ID
(A)
003aak108
103
Limit RDSon = VDS / ID
102
tp = 10 us
100 us
10
DC
1 ms
1
10 ms
100 ms
10-1
10-1
1
102
10
VDS (V)
103
Tmb = 25°C; IDM is a single pulse
Fig. 3.
IAL
(A)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
aaa-031580
102
aaa-031583
1010
No.
events
109
10
1
10-3
10-2
10-1
1
tAL (ms)
108
10
Tj is limited to 175 °C and Tj(rise) is limited to 30 °C
Repetitive avalanche rating; avalanche current
as a function of avalanche time
% Increase of Rdson at 5V Vgs
Fig. 4.
Fig. 5.
1
10
102
EDS(AL) per event (mJ)
Repetitive avalanche rating; maximum number
of avalanche events as a function of avalanche
energy
aaa-032338
50
40
30
Fig. 6.
1
10
% of cycle limit
102
Percentage Rdson at 5V increase as a function of avalanche cycles
BUK9K13-60RA
Product data sheet
2 December 2020
4 / 13
BUK9K13-60RA
Nexperia
technology
IAL
(A)
aaa-030544
102
10
1
10-3
10-2
10-1
1
tAL (ms)
10
Tj (init) = 25 °C
Fig. 7.
Single pulse avalanche rating; avalanche current as a function of avalanche time
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance from Fig. 8
junction to mounting
base
Conditions
2.36
K/W
Rth(j-a)
thermal resistance from Minimum footprint; mounted on a
junction to ambient
printed circuit board
95
K/W
003aaj748
10
Zth(j-mb)
(K/W)
δ = 0.5
1
0.2
0.1
0.05
10-1
P
0.02
δ=
single shot
Fig. 8.
10-5
10-4
10-3
10-2
T
t
tp
10-2
10-6
tp
T
10-1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
BUK9K13-60RA
Product data sheet
2 December 2020
5 / 13
BUK9K13-60RA
Nexperia
technology
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = -55 °C
54
V
ID = 250 µA; VGS = 0 V; Tj = 25 °C
60
V
gate-source threshold
voltage
ID = 1 mA; VDS=VGS; Tj = 25 °C; Fig. 12;
Fig. 13
1.4
1.7
2.1
V
ID = 1 mA; VDS=VGS; Tj = 175 °C;
Fig. 12
0.5
V
ID = 1 mA; VDS=VGS; Tj = -55 °C; Fig. 12
2.45
V
VDS = 60 V; VGS = 0 V; Tj = 25 °C
0.02
1
µA
VDS = 60 V; VGS = 0 V; Tj = 175 °C
500
µA
VGS = -10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = 10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
6.1
10
12.5
mΩ
VGS = 5 V; ID = 10 A; Tj = 175 °C;
Fig. 14; Fig. 15
22
28.3
mΩ
VGS = 10 V; ID = 10 A; Tj = 25 °C;
Fig. 14
5.4
9
11.2
mΩ
22.4
nC
5.2
nC
7.9
nC
2215
2953
pF
225
270
pF
116
159
pF
13
ns
22.1
ns
V(BR)DSS
VGS(th)
IDSS
IGSS
RDSon
drain leakage current
gate leakage current
resistance
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
30.5
ns
tf
fall time
21.8
ns
VDS = 25 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; Fig. 18
VDS = 48 V; RL = 5 Ω; VGS = 5 V;
RG(ext) = 5 Ω; Tj = 25 °C
Source-drain diode FET1 and FET2
VSD
source-drain voltage
IS = 10 A; VGS = 0 V; Tj = 25 °C; Fig. 19
0.78
1.2
V
trr
reverse recovery time
22.7
ns
Qr
recovered charge
IS = 10 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 30 V; Tj = 25 °C
18.9
nC
BUK9K13-60RA
Product data sheet
2 December 2020
6 / 13
BUK9K13-60RA
Nexperia
technology
ID
(A)
003aak102
40
10 V
4.5 V
003aak101
50
RDSon
(mΩ)
2.8 V
32
40
VGS = 2.6 V
24
30
16
2.4 V
8
10
2.2 V
2
3
VDS (V)
4
6
8
VGS (V)
10
Tj = 25 °C; tp = 300 μs
Fig. 9.
Output characteristics; drain current as a
Fig. 10. Drain-source on-state resistance as a function
function of drain-source voltage; typical values
of gate-source voltage; typical values
aaa-016783
120
ID
(A)
100
003aah025
3
VGS(th)
(V)
2.5
max
80
2
60
1.5
40
1
typ
175°C
Tj = 25°C
2
3
4
VGS (V)
0.5
5
Fig. 11. Transfer characteristics; drain current as a
function of gate-source voltage; typical values
BUK9K13-60RA
Product data sheet
min
120
Tj (° C)
180
Fig. 12. Gate-source threshold voltage as a function of
2 December 2020
7 / 13
BUK9K13-60RA
Nexperia
technology
003aah026
10-1
ID
(A)
10
003aak107
50
RDSon
(mΩ)
-2
2.6 V
2.8 V
40
min
10-3
typ
max
30
10-4
10
3V
4.5 V
VGS = 10 V
10-6
2
V GS (V)
10
15
30
35
ID (A)
40
Fig. 13. Sub-threshold drain current as a function of
gate-source voltage
Fig. 14. Drain-source on-state resistance as a function
of drain current; typical values
003aaj816
2.4
VDS
a
ID
1.6
VGS(pl)
0.8
VGS(th)
VGS
QGS2
QGS1
120
Tj ( °C)
QGS
180
QGD
QG(tot)
003aaa508
Fig. 16. Gate charge waveform definitions
Fig. 15. Normalized drain-source on-state resistance
factor as a function of junction temperature
BUK9K13-60RA
Product data sheet
2 December 2020
8 / 13
BUK9K13-60RA
Nexperia
technology
VGS
(V)
003aak104
10
8
003aak105
104
C
(pF)
Ciss
VDS = 14 V
103
6
Coss
4
48 V
102
Crss
2
40
QG (nC)
10
10-1
50
10
VDS (V)
102
Fig. 18. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
Fig. 17. Gate-source voltage as a function of gate
charge; typical values
IS
(A)
1
003aak106
40
30
175°C
0.4
Tj = 25°C
0.6
0.8
1
VSD (V)
1.2
Fig. 19. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values
BUK9K13-60RA
Product data sheet
2 December 2020
9 / 13
BUK9K13-60RA
Nexperia
technology
11. Package outline
Plastic single ended surface mounted package LFPAK56D; 8 leads
E
SOT1205
A
A
b1
c1
L1
mounting
base
D
H
D1
D2
L
1
2
3
e
b
(8x)
4
w
X
c
A
E1
E2
A1
C
θ
Lp
detail X
A
max 1.05
nom
min 1.02
mm
5 mm
scale
Dimensions
Unit
y C
D(1) D1(1)
D2
(ref)
E(1) E1(1)
4.4
0.25 0.30 4.70 4.55
3.5
5.30
1.8
0.85
4.1
0.19 0.24 4.45 4.35
3.4
4.95
1.6
0.60
A1
b
b1
0.1
0.50
0.0
0.35
c
c1
E2
e
1.27
H
L
L1
Lp
6.2
1.3
0.55 0.85
5.9
0.8
0.30 0.40
w
y
0.25
0.1
Note
1. Plastic or metal protrusions of 0.2 mm maximum per side are not included.
Outline
version
References
IEC
JEDEC
JEITA
θ
8°
0°
sot1205_po
European
projection
Issue date
14-08-21
14-10-28
SOT1205
Fig. 20. Package outline LFPAK56D; Dual LFPAK (SOT1205)
BUK9K13-60RA
Product data sheet
2 December 2020
10 / 13
BUK9K13-60RA
Nexperia
technology
12. Soldering
Footprint information for reflow soldering of LFPAK56D package
SOT1205
5.85
0.57
0.025
0.57
0.7
1.97
0.65
1.27
1.9
3.325
3.175
3.2
2.0
1.275
0.8
1.875
2.1
2.7
1.0
3.85
3.975
0.025
1.1
1.15
0.65
1.27
1.1
1.44
solder land
solder land plus solder paste
solder paste deposit
solder resist
occupied area
Dimensions in mm
Issue date
0.7
14-07-28
20-04-20
sot1205_fr
Fig. 21. Reflow soldering footprint for LFPAK56D; Dual LFPAK (SOT1205)
BUK9K13-60RA
Product data sheet
2 December 2020
11 / 13
BUK9K13-60RA
Nexperia
technology
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
13. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
BUK9K13-60RA
Product data sheet
2 December 2020
12 / 13
BUK9K13-60RA
Nexperia
technology
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 2
9. Thermal characteristics............................................... 5
10. Characteristics............................................................ 6
11. Package outline........................................................ 10
12. Soldering................................................................... 11
13. Legal information......................................................12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 2 December 2020
BUK9K13-60RA
Product data sheet
2 December 2020
13 / 13
