TSM8588CS
Taiwan Semiconductor
Complementary N & P-Channel Power MOSFET
FEATURES
KEY PERFORMANCE PARAMETERS
● Low gate charge for fast power switching
● 100% UIS and Rg tested
● Compliant to RoHS directive 2011/65/EU and in
accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
TYPE
VALUE
VDS
Q1
Q2
60
-60
103
122
180
220
4.4
4.6
RDS(on)
(max)
APPLICATIONS
● Building technologies
VGS = 10V
VGS = 4.5V
VGS = -10V
VGS = -4.5V
Q1
Q2
Q1
Q2
Qg
● DC Fan
UNIT
V
mΩ
nC
● Motor drives
SOP-8
Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Q1
Q2
UNIT
Drain-Source Voltage
VDS
60
-60
V
Gate-Source Voltage
VGS
±20
±20
V
TC = 25°C
Continuous Drain Current
Pulsed Drain Current
(Note 1)
(Note 2)
Single Pulse Avalanche Current
(Note 2)
Single Pulse Avalanche Energy
Total Power Dissipation
5
-4
2.5
-2
IDM
A
IAS
EAS
6.8
6.9
-7
7.4
A
mJ
5.7
5.7
1.1
1.1
1.4
1.4
0.3
0.3
ID
TA = 25°C
TC = 25°C
TC = 125°C
TA = 25°C
TA = 125°C
Operating Junction and Storage Temperature Range
PD
PD
A
W
W
TJ, TSTG
- 55 to +150
°C
SYMBOL
MAXIMUM
UNIT
Thermal Resistance – Junction to Case
RӨJC
22
Thermal Resistance – Junction to Ambient
RӨJA
88
THERMAL PERFORMANCE
PARAMETER
°C/W
Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. R ӨJC is guaranteed by design while RӨCA is
2
determined by the user’s board design. The RӨJA limit presented here is based on mounting on a 1 in pad of 2 oz copper.
1
Version: A1811
TSM8588CS
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Static
CONDITIONS
Drain-Source
VGS = 0V, ID = 250µA
Breakdown Voltage
VGS = 0V, ID = -250µA
Gate Threshold Voltage
SYMBOL
BVDSS
VGS = VDS, ID = 250µA
VGS(TH)
VGS = VDS, ID = -250µA
Gate-Source Leakage
VGS = ±20V, VDS = 0V
Current
Drain-Source Leakage
VGS = 0V, VDS = 60V
Current
VGS = 0V, VDS = -60V
IGSS
IDSS
VGS = 10V, ID = 2.5A
Drain-Source On-State
Resistance
(Note 3)
Dynamic
MAX
Q1
60
Q2
-60
Q1
1.2
1.8
2.5
Q2
-1
-1.5
-2.5
Q1
±100
nA
Q2
±100
nA
Q1
1
Q2
-1
74
103
86
122
135
180
170
220
Q1
10
Q2
5
Q1
9.4
Q2
9
Q1
4.4
Q2
4.6
Q1
1.8
Q2
1.2
Q1
2.3
Q2
2.4
Q1
527
Q2
436
Q1
31
Q2
32
Q1
4
Q2
11
Q1
0.5
1.8
3.6
Q2
5
17
34
Q1
Q2
5
3.4
Q1
Q2
21
21
Q1
10
Q2
21
Q1
17
Q2
26
Q2
VDS = 10V, ID = 2.5A
Transconductance
TYP
RDS(on)
VGS = -4.5V, ID = -1.7A
(Note 3)
MIN
Q1
VGS = 4.5V, ID = 2.3A
VGS = -10V, ID = -2A
Forward
TYPE
gfs
VDS = -10V, ID = -2A
UNIT
V
V
µA
mΩ
S
(Note 4)
Total Gate Charge
Total Gate Charge
Gate-Source Charge
Qg(VGS=10V)
Q1
VDS = 30V, ID = 2.5A
Qg(VGS=4.5V)
Q2
Qgs
VDS = -30V, ID = -2A
Gate-Drain Charge
Input Capacitance
Output Capacitance
Qgd
Q1
VGS = 0V, VDS = 30V
f = 1.0MHz
VGS = 0V, VDS = -30V
Capacitance
f = 1.0MHz
Switching
Coss
Q2
Reverse Transfer
Gate Resistance
Ciss
Crss
f = 1.0MHz
Rg
nC
pF
Ω
(Note 4)
Turn-On Delay Time
Turn-On Rise Time
Turn-Off Delay Time
Turn-Off Fall Time
td(on)
Q1
VGS = 10V, VDS = 30V,
tr
ID = 2.5A, RG = 2Ω
Q2
td(off)
VGS = -10V, VDS = -30V,
ID = -2A, RG = 2Ω
tf
2
ns
Version: A1811
TSM8588CS
PARAMETER
CONDITIONS
SYMBOL
TYPE
MIN
TYP
MAX
Q1
1
Q2
Q1
14
-1
Q2
11
Q1
10
Q2
6
UNIT
Source-Drain Diode
Forward Voltage
(Note 3)
Reverse Recovery Time
VGS = 0V, IS = 2.5A
VSD
VGS = 0V, IS = -2A
Q1
trr
IS = 2.5A, dI/dt = 100A/μs
Reverse Recovery
Q2
Charge
IS = -2A, dI/dt = 100A/μs
Qrr
V
ns
nC
Notes:
1. Current limited by package.
2. Q1 : L = 0.3mH, VGS = 10V, VDD = 30V, RG = 25Ω, IAS = 6.8A, Starting TJ = 25°C
Q2 : L = 0.3mH, VGS = -10V, VDD = -30V, RG = 25Ω, IAS = -7A, Starting TJ = 25°C
3. Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%.
4. Switching time is essentially independent of operating temperature.
ORDERING INFORMATION
ORDERING CODE
TSM8588CS RLG
PACKAGE
PACKING
SOP-8
2,500pcs / 13” Reel
3
Version: A1811
TSM8588CS
CHARACTERISTICS CURVES (Q1 N-Channel)
Output Characteristics
VGS=10V
VGS=7V
VGS=5V
VGS=4.5V
ID, Drain Current (A)
12
Transfer Characteristics
10
VGS=4V
15
VGS=3.5V
9
6
VGS=3V
3
8
6
25℃
4
150℃
2
3
On-Resistance vs. Drain Current
2
3
4
Gate-Source Voltage vs. Gate Charge
10
0.3
VGS, Gate to Source Voltage (V)
RDS(ON), Drain-Source On-Resistance (Ω)
1
VDS, Drain to Source Voltage (V)
0.25
0.2
0.15
VGS=4.5V
0.1
VGS=10V
0.05
6
9
12
VDS=30V
ID=2.5A
8
6
4
2
2.4
VGS=10V
ID=2.5A
2
1.8
1.6
1.4
1.2
1
0.8
0.6
0.4
-75
-50
-25
50
75
6
8
10
On-Resistance vs. Gate-Source Voltage
100
125
150
RDS(on), Drain-Source On-Resistance (Ω)
On-Resistance vs. Junction Temperature
2.2
4
Qg, Gate Charge (nC)
(Normalized)
-55℃
2
0.3
0.25
0.2
0.15
ID=2.5A
0.1
0.05
4
5
6
7
8
9
10
TJ, Junction Temperature (°C)
4
Version: A1811
TSM8588CS
BVDSS vs. Junction Temperature
Capacitance vs. Drain-Source Voltage
C, Capacitance (pF)
600
BVDSS (Normalized)
Drain-Source Breakdown Voltage
700
CISS
500
400
300
200
CRSS
100
COSS
ID=1mA
1.1
1
0.9
0.8
40
50
60
-75
-25
50
75
100 125 150
Maximum Safe Operating Area, Junction-to-Case
Source-Drain Diode Forward Current vs. Voltage
100
IS, Reverse Drain Current (A)
100
RDS(ON)
-50
10
1
0.1
SINGLE PULSE
RӨJC=22°C/W
TC=25°C
10
150℃
25℃
-55℃
1
0.1
0.01
0.1
1
10
0.2
100
0.4
0.6
0.8
1
1.2
VSD, Body Diode Forward Voltage (V)
Normalized Thermal Transient Impedance, Junction-to-Case
Normalized Effective Transient
Thermal Impedance, ZӨJC
10
SINGLE PULSE
RӨJC=22°C/W
1
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single
0.1
0.01
0.0001
0.001
0.01
Notes:
Duty = t1 / t2
TJ = TC + PDM x ZӨJC x RӨJC
0.1
1
t, Square Wave Pulse Duration (sec)
5
Version: A1811
TSM8588CS
CHARACTERISTICS CURVES (Q2 P-Channel)
VGS=-10V
VGS=-9V
VGS=-8V
VGS=-7V
VGS=-6V
VGS=-5V
VGS=-4.5V
9
10
-ID, Drain Current (A)
12
VGS=-4V
6
VGS=-3.5V
3
VGS=-3V
8
6
4
25℃
2
150℃
2
3
4
2
3
4
-VGS, Gate to Source Voltage (V)
10
0.4
-VDS, Drain to Source Voltage (V)
0.35
0.3
0.25
VGS=-4.5V
0.2
0.15
VGS=-10V
0.1
0.05
VDS=-30V
ID=-2A
8
6
4
2
6
9
12
VGS=-10V
ID=-2A
1.6
1.4
1.2
1
0.8
0.6
0.4
-75
-50
-25
50
75
6
8
10
2
100
125
150
1.8
4
(Normalized)
-55℃
0.3
0.25
0.2
ID=-2A
0.15
0.1
0.05
4
5
6
7
8
9
10
6
Version: A1811
TSM8588CS
BVDSS (Normalized)
600
C, Capacitance (pF)
500
CISS
400
300
200
CRSS
100
COSS
1.2
ID=-1mA
1.1
1
0.9
0.8
40
50
-75
60
-50
50
75
100 125 150
100
-IS, Reverse Drain Current (A)
100
RDS(ON)
-25
10
1
0.1
SINGLE PULSE
RӨJC=22°C/W
TC=25°C
10
150℃
1
25℃
-55℃
0.1
0.01
0.1
1
10
0.2
100
0.4
0.6
0.8
1
1.2
-VSD, Body Diode Forward Voltage (V)
10
SINGLE PULSE
RӨJC=22°C/W
1
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single
0.1
0.01
0.0001
0.001
0.01
Notes:
Duty = t1 / t2
0.1
1
7
Version: A1811
TSM8588CS
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
SOP-8
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
TSM8588
YWWLF
Y
WW
L
F
= Year Code
= Week Code (01~52)
= Lot Code (1~9,A~Z)
= Factory Code
8
Version: A1811
TSM8588CS
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
9
Version: A1811
