Datasheet
FM24C04U/05U
4K-Bit Standard 2-Wire Bus Interface Serial EEPROM
The FM24C04U/05U devices are 4096 bits of CMOS non-volatile electrically erasable memory.
These devices conform to all specifications in the Standard IIC 2-wire protocol. They are designed
to minimize device pin count and simplify PC board layout requirements.
The upper half (upper 2Kbit) of the memory of the FM24C05U can be write protected by
connecting the WP pin to VCC. This section of memory then becomes unalterable unless WP is
switched to VSS.
Rochester Electronics
Manufactured Components
Rochester branded components are
manufactured using either die/wafers
purchased from the original suppliers
or Rochester wafers recreated from the
original IP. All re-creations are done with
the approval of the Original Component
Manufacturer (OCM).
Parts are tested using original factory
test programs or Rochester developed
test solutions to guarantee product
meets or exceeds the OCM data sheet.
Quality Overview
• ISO-9001
• AS9120 certification
• Qualified Manufacturers List (QML) MIL-PRF-35835
• Class Q Military
• Class V Space Level
• Qualified Suppliers List of Distributors (QSLD)
• Rochester is a critical supplier to DLA and
meets all industry and DLA standards.
Rochester Electronics, LLC is committed to supplying
products that satisfy customer expectations for
quality and are equal to those originally supplied by
industry manufacturers.
The original manufacturer’s datasheet accompanying this document reflects the performance
and specifications of the Rochester manufactured version of this device. Rochester Electronics
guarantees the performance of its semiconductor products to the original OCM specifications.
‘Typical’ values are for reference purposes only. Certain minimum or maximum ratings may be
based on product characterization, design, simulation, or sample testing.
FOR REFERENCE ONLY
© 2019 Rochester Electronics, LLC. All Rights Reserved 05012019
To learn more, please visit www.rocelec.com
FM24C04U/05U – 4K-Bit Standard 2-Wire Bus
General Description
Features
electrically erasable memory. These devices conform to all specifications in the Standard IIC 2-wire protocol. They are designed to
■ Extended operating voltage 2.7V – 5.5V
■ 400 KHz clock frequency (F) at 2.7V - 5.5V
■ 200µA active current typical
10µA standby current typical
1µA standby current typical (L)
0.1µA standby current typical (LZ)
be write protected by connecting the WP pin to VCC. This section of
memory then becomes unalterable unless WP is switched to VSS.
■ IIC compatible interface
– Provides bi-directional data transfer protocol
■ Sixteen byte page write mode
– Minimizes total write time per byte
This communications protocol uses CLOCK (SCL) and DATA
I/O (SDA) lines to synchronously clock data between the master
(for example a microprocessor) and the slave EEPROM device(s).
The Standard IIC protocol allows for a maximum of 16K of
EEPROM memory which is supported by the Fairchild family in
2K, 4K, 8K, and 16K devices, allowing the user to configure the
memory as the application requires with any combination of
EEPROMs. In order to implement higher EEPROM memory
densities on the IIC bus, the Extended IIC protocol must be used.
(Refer to the FM24C32 or FM24C65 datasheets for more information.)
■ Self timed write cycle
Typical write cycle time of 6ms
■ Hardware Write Protect for upper half (FM24C05U only)
■ Endurance: 1,000,000 data changes
■ Data retention greater than 40 years
■ Packages available: 8-pin DIP, 8-pin SO, and 8-pin TSSOP
■ Available in three temperature ranges
- Commercial: 0° to +70°C
- Extended (E): -40° to +85C
- Automotive (V): -40° to +125°C
Fairchild EEPROMs are designed and tested for applications requiring high endurance, high reliability and low power consumption.
Block Diagram
VCC
VSS
WP
H.V. GENERATION
TIMING &CONTROL
START
STOP
LOGIC
SDA
CONTROL
LOGIC
SLAVE ADDRESS
REGISTER &
COMPARATOR
SCL
XDEC
A2
A1
E2PROM
ARRAY
WORD
ADDRESS
COUNTER
R/W
YDEC
CK
DATA REGISTER
DIN
© 2002 Fairchild Semiconductor International
FM24C04U/05U Rev. A.3
1
DOUT
www.fairchildsemi.com
FM24C04U/05U – 4K-Bit Standard 2-Wire Bus Interface Serial EEPROM
September 2002
Connection Diagrams
Dual-in-Line Package (N), SO Package (M8) and TSSOP Package (MT8)
NC
1
A1
2
8
VCC
7
NC
24C04
A2
3
6
SCL
VSS
4
5
SDA
See Package Number N08E, M08A and MTC08
Pin Names
A1,A2
Device Address Inputs
VSS
Ground
SDA
Serial Data I/O
SCL
Serial Clock Input
NC
No Connection
VCC
Power Supply
NC
1
A1
2
8
VCC
7
WP
24C05
A2
3
6
SCL
VSS
4
5
SDA
Pin Names
A1,A2
VSS
Ground
SDA
Serial Data I/O
SCL
Serial Clock input
WP
Write Protect
VCC
Power Supply
NC
No Connection
2
FM
24
C
XX
U
F
LZ
E
XXX
Letter
Description
N
M8
MT8
8-pin DIP
8-pin SOIC
8-pin TSSOP
Temp. Range
Blank
V
E
0 to 70°C
-40 to +125°C
-40 to +85°C
Voltage Operating Range
Blank
L
LZ
4.5V to 5.5V
2.7V to 5.5V
2.7V to 5.5V and
很抱歉,暂时无法提供与“FM24C04B-G”相匹配的价格&库存,您可以联系我们找货
