10A10-T/B
10A10-T/B
    MDD(辰达半导体)
    R-6
10A10-T/B 数据手册
PART CODE: R610A10000AA0A SPECIFICATION SHEET SPECIFICATION SHEET NO. N0310-R610A10000AA0A DATE Mar. 10, 2021 REVISION A0 DESCRIPITION Axial Lead General Purpose Silicon Rectifier, R-6 series, 10A10 Type 2 Pins Reverse Voltage 1000V Max. Forward Current 10.0A Max. Operating Temp. Range -55°C ~+150°C Package in AMMO Pack, 5000pcs/Tape, Tape/Box RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER MDD 10A10 – T/B PART CODE R610A10000AA0A VENDOR APPROVE Issued/Checked/Approved DATE: March 10, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com R610A10000AA0A PART CODE: GENERAL PURPOSE SILICON RECTIFIER R6 SERIES MAIN FEATURE • The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 • Fast switching for high efficiency • High forward surge current capability • High temperature soldering guaranteed, 250 °C/10 seconds at terminals • Low reverse leakage APPLICATION • For printed circuit board RFQ PART CODE GUIDE Request For Quotation R6 10A10000 A A0A 1 2 3 4 1) R6: Axial Lead General Purpose Silicon Rectifier, 2 Pins, R-6 series 2) 10A10000: Type code for original part number 10A10-T/B 3) A: Package code, Package in AMMO Pack, 5000pcs/Tape, Tape/Box 4) A0A: Specification code for Reverse Voltage 1000V Max. Forward Current 10.0A Max. MORE ITEMS AVAILABLE R66A050000A605 R66A010000A610 R66A080000A680 R66A100000A60A R68A050000A805 R68A010000A810 R68A080000A880 R68A100000A80A R610A05000AA05 R610A01000AA10 R610A08000AA80 R610A10000AA0A NextGen Components, Inc. R66A020000A620 R66A040000A640 R66A060000A660 R68A020000A820 R68A040000A840 R68A060000A860 R610A02000AA20 R610A04000AA40 R610A06000AA60 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: R610A10000AA0A GENERAL PURPOSE SILICON RECTIFIER R6 SERIES DIMENSION (Unit: Inch/mm) Image for reference Marking: 10A10 R-6 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: R610A10000AA0A GENERAL PURPOSE SILICON RECTIFIER R6 SERIES MECHANICAL DATA Case Terminals Polarity Mounting Position Weight per piece JEDEC R-6 molded plastic body Solder plated, Solderable per MIL-STD-750, Method 2026 Polarity symbol marking on case Any 0.072 Ounce, 2.239 grams VALUE UNITS MAX. RATING & CHARACTERISTICS Parameter SYMBOLS Min. Typical Max. Repetitive peak reverse voltage V RRM 1000 Volts RMS voltage V RMS 700 Volts DC blocking voltage V DC 1000 Volts Average forward output rectified current I AV 10.0 A at TL= 60°C I FSM Peak forward surge current 8.3ms single half 600 A sine-wave superimposed on rated load (JEDEC Method) Instantaneous forward voltage at 10.0A VF 1.0 Volts DC reverse current at rated DC IR 10 µA 100 µA blocking voltage TA=25℃ TA=100℃ Junction capacitance (Note 2) CJ 150 pF Thermal resistance (Note 3) R QJA 10 °C/W Operating junction temperature range Storage temperature range TJ -50 +150 °C T STG -50 +150 °C Note 1. Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. 2. Measured at 1.0MHz and applied reverse voltage of 4.0Voltage 3. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length, PCB. Mounted. NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: R610A10000AA0A GENERAL PURPOSE SILICON RECTIFIER R6 SERIES RELIABILITY Number Experiment Items Experiment Method And Conditions Reference Documents 1 Solder Resistance Test Test 260°C± 5°C for 10 ± 2 sec. Immerse body into solder 1/16” ± 1/32" MIL-STD-750D METHOD-2031.2 2 Solderability Test 230°C ±5°C for 5 sec. MIL-STD-750D METHOD-2026.1 0 3 Pull Test 1 kg in axial lead direction for 10 sec. MIL-STD-750D METHOD-2036.4 4 Bend Test 0.5Kg Weight Applied To Each Lead, Bending Arcs 90 °C ± 5 °C For 3 Times MIL-STD-750D METHOD-2036.4 5 High Temperature Reverse Bias Test TA=100°C for 1000 Hours at VR=80% Rated VR MIL-STD-750D METHOD-1038.4 6 Forward Operation Life Test TA=25°C Rated Average Rectified Current MIL-STD-750D METHOD-1027.3 7 Intermittent Operation Life Test On state: 5 min with rated IRMS Power Off state: 5 min with Cool Forced Air. On and off for 1000 cycles. MIL-STD-750D METHOD-1036.3 8 Pressure Cooker Test 15 PSIG, TA=121°C, 4 hours MIL-S-19500 APPENOIXC 9 Temperature Cycling Test -55°C~+125°C; 30 Minutes For Dwelled Time 5 minutes for transferred time. Total: 10 cycles. MIL-STD-750D METHOD-1051.7 10 Thermal Shock Test 0°C for 5 minutes., 100°C for 5minutes, Total: 10 cycles MIL-STD-750D METHOD-1056.7 11 Forward Surge Test 8.3ms Single Sale Sine-wave One Surge. MIL-STD-750D METHOD-4066.4 12 Humidity Test TA=65°C, RH=98% for 1000 hours. MIL-STD-750D METHOD-1021.3 13 High Temperature Storage life Test 150°C for 1000 Hours MIL-STD-750D METHOD-1031.5 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: R610A10000AA0A GENERAL PURPOSE SILICON RECTIFIER R6 SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: R610A10000AA0A GENERAL PURPOSE SILICON RECTIFIER R6 SERIES AMMO BOX (Unit: mm) • All Devices are packed in accordance with EIA standard RS-296-D and specifications. • Each component lead shall be sandwiched between taps for A minimum of 3.2 mm (0.126”) Item Symbol R-6 Uni(mm) R-6 Unit (Inch) Component Alignment Z 1.2 Max. 0.048 Max. Tape Width T 6.0 +/- 0.4 0.236 +/- 0.016 Exposed Adhesive E 0.8 Max. 0.032 Max. Body Eccentricity L1 – L2 1.0 Max. 0.040 Max. Component Pitch A (2.0mm/10 pitch) A 10.0 0.197 Component Pitch B (2.0mm/10 pitch) B 52.4 1.023 Component Pitch A (2.0mm/20 pitch) - - - Component Pitch B (2.0mm/20 pitch) - - - Box Length L 450.0 +/- 5.0 17.72 +/- 0.197 Box Width W 215.0 +/- 5.0 8.46 +/- 0.197 Box Height H 250.0 +/- 5.0 9.84 +/- 0.197 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: R610A10000AA0A GENERAL PURPOSE SILICON RECTIFIER R6 SERIES AMMO PACK IN TAPE/BOX (Unit: mm) Case Code R-6 Qty. Per Reel (pcs) Component Space (mm) Tape Space (mm) Inner Box L*W*H (mm) Carton size L*W*H (mm) Qty. Per Carton (pcs) G. W 500 10 52.4 198*86*21 450*215*250 5,000 7.45 (kg) DISCLAIMER NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
10A10-T/B 价格&库存
很抱歉,暂时无法提供与“10A10-T/B”相匹配的价格&库存,您可以联系我们找货
