M1F THRU M7F
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT GENERAL RECTIFIER
Features
SMAF
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
0.106(2.70)
0.094(2.40)
0.063 (1.60)
0.051 (1.30)
Idea for printed circuit board
Glass passivated junction
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed
0.146(3.70)
0.130(3.30)
250℃/10 seconds at terminals
0.047(1.20)
0.035(0.90)
Mechanical Data
0.008(0.20)
0.005(0.12)
0.047(1.20)
0.031(0.80)
0.193(4.90)
0.173(4.40)
Case: JEDEC SMAF molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body
Mounting Position: Any
Weight : 0.00095ounce, 0.027 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=125℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
VRRM
VRMS
VDC
MDD
M1F
MDD
M2F
MDD
M3F
MDD
M4F
MDD
M5F
MDD
M6F
MDD
M7F
UNITS
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
I(AV)
1.0
A
IFSM
30
A
VF
1.10
V
IR
CJ
RJA
Operating junction and storage temperature range TJ,TSTG
5.0
50.0
15.0
μA
pF
80.0
℃/W
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
M1F THRU M7F
Typical Characterisitics
Fig.2 Typical Instaneous Reverse
Fig.1 Forward Current Derating Curve
Characteristics
1.2
Instaneous Reverse Current (μA)
100
Average Forward Current (A)
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz resistive
or inductive load
0.0
25
75
50
100
125
150
TJ=150°C
10
TJ=125°C
TJ=100°C
1.0
TJ=75°C
0.1
TJ=25°C
0.01
175
Junction Capacitance (pF)
1.0
25°
TJ=
10
0°C
C
TJ =
5°
12
TJ=
C
0.5
0.2
0.6
0.7
0.8
0.9
800
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
Instaneous Forward Current (A)
600
Instaneous Reverse Voltage (V)
Case Temperature (°C)
0.1
400
200
1.0
1.1
TJ=25°C
10
1
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
35
30
25
10
05
00
8.3 ms Single Half Sine Wave (JEDEC
Method)
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
M1F THRU M7F
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SMAF
E
F
B
A
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
P
D2
T
D1
C
W1
D
2.80
4.75
1.42
1.50
178.00
54.40
13.00
1.75
5.05
4.00
4.00
2.00
0.30
8.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMAF
REEL SIZE
7"
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
3,000
4.0
6,000
210*208*203
178
400*265*400
120,000
10.0
Suggested Pad Layout
Symbol
Unit (mm)
A
1.8
0.071
B
0.063
C
1.6
3.8
0.150
D
2.2
0.087
E
5.4
0.213
Unit (inch)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“M7F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.18172
- 200+0.06066
- 1500+0.03788
- 3000+0.03009
- 国内价格
- 50+0.04589
- 500+0.04044
- 3000+0.03500
- 6000+0.03321
- 24000+0.03164
- 51000+0.03081
- 国内价格
- 50+0.06350
- 500+0.05050
- 3000+0.04090
- 6000+0.03630
- 24000+0.03250
- 51000+0.03050
- 国内价格
- 1+0.02489
- 10+0.02394
- 100+0.02166
- 500+0.02052
- 国内价格
- 50+0.05829
- 600+0.04638
- 1200+0.04568
- 3000+0.03755
