TSM300NB06DCR RLG
TSM300NB06DCR RLG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TDFN-8
TSM300NB06DCR RLG 数据手册
TSM300NB06DCR Taiwan Semiconductor Dual N-Channel Power MOSFET 60V, 25A, 30mΩ FEATURES KEY PERFORMANCE PARAMETERS ● Low RDS(ON) to minimize conductive losses PARAMETER VALUE UNIT VDS 60 V ● Low gate charge for fast power switching ● 100% UIS and Rg tested ● RoHS Compliant ● Halogen-free according to IEC 61249-2-21 RDS(on) (max) VGS = 10V 30 VGS = 7V 42.3 mΩ Qg APPLICATIONS 17 nC ● BLDC Motor Control ● Battery Power Management ● DC-DC Converter ● Secondary Synchronous Rectification PDFN56 Dual Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL LIMIT UNIT Drain-Source Voltage VDS 60 V Gate-Source Voltage VGS ±20 V Continuous Drain Current TC = 25°C (Note 1) ID TA = 25°C Pulsed Drain Current (Note 2) Single Pulse Avalanche Current (Note 2) Single Pulse Avalanche Energy Total Power Dissipation Total Power Dissipation TC = 25°C TC = 125°C TA = 25°C TA = 125°C Operating Junction and Storage Temperature Range 25 6 A IDM 100 A IAS EAS 12 22 A mJ PD PD 40 8 2 0.4 W W TJ, TSTG - 55 to +150 °C THERMAL PERFORMANCE PARAMETER SYMBOL MAXIMUM UNIT Junction to Case Thermal Resistance RӨJC 3.1 °C/W Junction to Ambient Thermal Resistance RӨJA 61 °C/W Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. R ӨJC is guaranteed by design while RӨCA is 2 determined by the user’s board design. The RӨJA limit presented here is based on mounting on a 1 in pad of 2 oz copper. 1 Version: A1908 TSM300NB06DCR Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MIN TYP MAX UNIT Static Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA BVDSS 60 -- -- V Gate Threshold Voltage VGS = VDS, ID = 250µA VGS(TH) 2.5 3.2 4.5 V Gate-Source Leakage Current VGS = ±20V, VDS = 0V IGSS -- -- ±100 nA -- -- 1 -- -- 100 -- 25 30 -- 29 42.3 gfs -- 24 -- Qg -- 17 -- Qg -- 12 -- Qgs -- 6 -- Qgd -- 4 -- Ciss -- 1079 -- Coss -- 68 -- Crss -- 16 -- Rg 0.7 2.4 4.8 td(on) -- 6 -- tr -- 3 -- td(off) -- 12 -- tf -- 2 -- VSD -- -- 1.2 V VGS = 0V, VDS = 60V Drain-Source Leakage Current IDSS VGS = 0V, VDS = 60V TJ = 125°C Drain-Source On-State Resistance VGS = 10V, ID = 6A (Note 3) VGS = 7V, ID = 5A Forward Transconductance Dynamic (Note 3) RDS(on) VDS = 10V, ID = 6A µA mΩ S (Note 4) VGS = 10V, VDS = 30V, Total Gate Charge ID = 6A Total Gate Charge VGS = 7V, VDS = 30V, Gate-Source Charge ID = 5A Gate-Drain Charge Input Capacitance VGS = 0V, VDS = 30V Output Capacitance f = 1.0MHz Reverse Transfer Capacitance Gate Resistance Switching f = 1.0MHz nC pF Ω (Note 4) Turn-On Delay Time Turn-On Rise Time VGS = 10V, VDS = 30V, Turn-Off Delay Time ID = 6A, RG = 2Ω Turn-Off Fall Time ns Source-Drain Diode Forward Voltage (Note 3) VGS = 0V, IS = 6A Reverse Recovery Time IS = 6A, trr -- 17 -- ns Reverse Recovery Charge dI/dt = 100A/μs Qrr -- 13 -- nC Notes: 1. 2. 3. 4. Silicon limited current only. L = 0.3mH, VGS = 10V, VDD = 25V, RG = 25Ω, IAS = 12A, Starting TJ = 25°C Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%. Switching time is essentially independent of operating temperature. ORDERING INFORMATION ORDERING CODE PACKAGE PACKING TSM300NB06DCR RLG PDFN56 Dual 2,500pcs / 13” Reel 2 Version: A1908 TSM300NB06DCR Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Transfer Characteristics 30 25 25 ID, Drain Current (A) ID, Drain Current (A) Output Characteristics 30 VGS=10V VGS=9V VGS=8V VGS=7V VGS=6V VGS=5.5V 20 15 10 VGS=5V 5 20 15 25℃ 10 -55℃ 5 150℃ 0 0 0 1 2 3 4 0 On-Resistance vs. Drain Current 3 4 5 6 Gate-Source Voltage vs. Gate Charge 0.05 10 VGS, Gate to Source Voltage (V) RDS(ON), Drain-Source On-Resistance (Ω) 2 VGS, Gate to Source Voltage (V) VDS, Drain to Source Voltage (V) 0.045 0.04 0.035 VGS=7V 0.03 0.025 VGS=10V 0.02 0.015 0.01 VDS=30V ID=6A 8 6 4 2 0 0 10 20 30 0 2.5 VGS=10V ID=6A 1.5 1 0.5 0 -75 -50 -25 0 25 50 75 10 15 20 100 125 150 On-Resistance vs. Gate-Source Voltage RDS(on), Drain-Source On-Resistance (Ω) On-Resistance vs. Junction Temperature 2 5 Qg, Gate Charge (nC) ID, Drain Current (A) RDS(on), Drain-Source On-Resistance (Normalized) 1 TJ, Junction Temperature (°C) 0.06 0.055 0.05 0.045 0.04 0.035 ID=6A 0.03 0.025 0.02 0.015 0.01 5 6 7 8 9 10 VGS, Gate to Source Voltage (V) 3 Version: A1908 TSM300NB06DCR Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) BVDSS vs. Junction Temperature Capacitance vs. Drain-Source Voltage 1200 BVDSS (Normalized) Drain-Source Breakdown Voltage C, Capacitance (pF) 1400 CISS 1000 800 600 400 CRSS 200 COSS 1.2 ID=1mA 1.1 1 0.9 0.8 0 0 10 20 30 40 50 -75 60 Maximum Safe Operating Area, Junction-to-Case -25 0 25 50 75 100 125 150 Source-Drain Diode Forward Current vs. Voltage 100 IS, Reverse Drain Current (A) 1000 ID, Drain Current (A) -50 TJ, Junction Temperature (°C) VDS, Drain to Source Voltage (V) 100 RDS(ON) 10 1 SINGLE PULSE RӨJC=3.1°C/W TC=25°C 0.1 10 150℃ 25℃ -55℃ 1 0.1 0.1 1 10 100 0.2 0.4 0.6 0.8 1 1.2 VSD, Body Diode Forward Voltage (V) VDS, Drain to Source Voltage (V) Normalized Thermal Transient Impedance, Junction-to-Case Normalized Effective Transient Thermal Impedance, ZӨJC 10 SINGLE PULSE RӨJC=3.1°C/W 1 Duty=0.5 Duty=0.2 Duty=0.1 Duty=0.05 Duty=0.02 Duty=0.01 Single 0.1 0.01 0.0001 0.001 Notes: Duty = t1 / t2 TJ = TC + PDM x ZӨJC x RӨJC 0.01 0.1 t, Square Wave Pulse Duration (sec) 4 Version: A1908 TSM300NB06DCR Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) PDFN56 Dual SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM TSC 300NB06D YWWLF Y WW L F = Year Code = Week Code (01~52) = Lot Code (1~9,A~Z) = Factory Code 5 Version: A1908 TSM300NB06DCR Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: A1908
TSM300NB06DCR RLG 价格&库存
很抱歉,暂时无法提供与“TSM300NB06DCR RLG”相匹配的价格&库存,您可以联系我们找货
TSM300NB06DCR RLG
  • 1+11.18745
  • 10+8.10911
  • 15+7.64196
  • 75+6.99515
TSM300NB06DCR RLG
  • 1+15.254711+1.98239
  • 10+9.6442610+1.25330
  • 50+7.2250450+0.93892
  • 100+6.44322100+0.83732
  • 500+5.06853500+0.65867
库存:7488
TSM300NB06DCR RLG
    TSM300NB06DCR RLG
      TSM300NB06DCR RLG
        TSM300NB06DCR RLG
        • 2500+4.147492500+0.53898
        • 7500+3.700957500+0.48095
        库存:7488
