CXT-PLA3SA12450AA
CXT-PLA3SA12450AA
    CISSOID
    Module
    CXT-PLA3SA12450AA
CXT-PLA3SA12450AA 数据手册
The Leader in High Temperature Semiconductor Solutions 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module CXT-PLA3SA12450A-Preliminary Datasheet Version: 1.9 General description CXT-PLA3SA12450A is a 3-phase 1200V/450A SiC MOSFET Intelligent Power Module integrating the power switches and the gate driver based on CISSOID HADES2® chipset. With its pin fin baseplate, this module addresses high power density water cooled converters offering a SiC power module designed for operation at high junction temperature (up to 175°C). This solution gives access to the full benefits of PUBLIC Doc. PDS-192038 V1.9 SiC technology to achieve high power density thanks to low switching losses and high temperature operation. The integration of the gate driver together with the power module give direct access to a fully validated and optimized solution in terms of switching speed and losses, robustness againt dI/dt and dV/dt and protection of the power stages (Desat, UVLO, AMC, SSD). WWW.CISSOID.COM 9-Dec-21 1 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Key Features • VDS breakdown voltage: 1200V • Single power supply (VCC): • Low RDSON typ 3.25mΩ 1: - • Max Continuous current: - • Max 125°C operating ambient temperature (gate driver) 450A typ. @ Tc=25°C 350A typ. @ Tc=90°C • Isolation (primary – secondary): • Thermal resistance (J2C): - - 0.13 °C/W typ. - - Eoff: 7.05 mJ - • Isolation (baseplate – power pins): 3600VAC @50Hz (1min) • Common mode transient immunity: - >50kV/µs • Dimensions: - 5V Schmitt trigger input Active-High (Active-Low as an option) • Open-drain fault reporting: • Switching frequency: 50kHz Max 2 - typ 11pF per phase • PWM input signal • Switching Energy@ 600V/300A: Eon: 8.42 mJ 3600VAC @50Hz (1min) • Parasitic capacitance: • Max 175°C operating junction temperature (power devices) - +12V to +18V 104(W) x 154(L) X 34(H) (all in mm) - per phase per side as an option • Turn-On/Off delay: 180ns typ. • Under voltage lockout (UVLO) - On VCC On internally generated secondary supplies • Desaturation protection • Weight: 590g • Soft Shutdown turn-off (SSD) • Negative gate drive (-3V) • Active Miller Clamping (AMC) • Gate-Source Short-circuit Protection 1 Package resistance excluded With Gate driver temperature derating from 25KHz to 50KHz (see curve at page 17) 2 Ordering Information Product Name CXT-PLA3SA12450A PUBLIC Doc. PDS-192038 V1.9 Ordering Reference CXT-PLA3SA12450AA WWW.CISSOID.COM Marking CXT-PLA3SA12450AA 9-Dec-21 2 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Block diagram VDCW+ VX-WT VREF FLT-WT VREF WH-WT X PWM-WT CLK DC/DC VDC- VCC WL-WT VH-WT VX-WT W VL-WT VH-WB GND VDC- VX-WB VL-WB VX-WB VREF FLT-WB VREF VH-WB X PWM-WB CLK VL-WB VDCV+ VX-VT VREF FLT-VT VDCW- VREF VH-VT X PWM-VT CLK DC/DC VDC- VCC VL-VT VH-VT VX-VT V VL-VT VH-VB GND VDC- VX-VB VL-VB VX-VB VREF FLT-VB VREF VH-VB X PWM-VB CLK VL-VB VDCU+ VX-UT VREF FLT-UT VDCV- VREF VH-UT X PWM-UT CLK DC/DC VL-UT VH-UT VDC- VCC VX-UT U VL-UT VH-UB GND VDCVL-UB FLT-UB VX-UB VX-UB VREF VREF VH-UB X PWM-UB CLK VL-UB PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM VDCU- 9-Dec-21 3 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Pinout3 “VDCU+, VDCV+, VDCW+”, “VDCU-, VDCV-, VDCW-” are not connected to each other internally 3 PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM 9-Dec-21 4 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Pinout (cnt’d) Interface Pin Pin name VDCU+ VDCUVDCV+ VDCVVDCW+ VDCWU V W Description U Phase positive power supply U Phase negative power supply V Phase positive power supply V Phase negative power supply W Phase positive power supply W Phase negative power supply Half-Bridge output U Half-Bridge output V Half-Bridge output W Pin 1 Pin 2 PWM-UT PWM-UB Pin 3 TEMP-U Pin 4 RSTN Pin 5 Pin 6 Pin 7 Pin 8 PWM-VT VDCM PWM-VB GND Pin 9 FLT-T-V Pin 10 GND Pin 11 FLT-B-U Pin 12 VCC Pin 13 TEMP-V Pin 14 Pin 15 Pin 16 Pin 17 VCC PWM input high-side phase U PWM input low-side phase U Phase U temperature measurement output Reset signal (active low); while low, forces all PWM to inactive state PWM input high-side phase V DC BUS voltage monitoring output PWM input low-side phase V Gate driver negative power supply Phase V fault output or 3 phase high-side fault output Gate driver negative power supply Phase U fault output or 3 phase low-side fault output Gate driver positive power supply Phase V temperature measurement output Gate driver positive power supply GND FLT-W Pin 18 TEMP-W Pin 19 Pin 20 PWM-WT PWM-WB POWER CONTROL PUBLIC Doc. PDS-192038 V1.9 Gate driver negative power supply Phase W fault output Phase W temperature measurement output PWM input high-side phase W PWM input low-side phase W WWW.CISSOID.COM 9-Dec-21 5 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Max Absolute Ratings “SiC Power MOSFET’s” Parameter Symbol Drain – Source Voltage VDS MOSFET Continuous Drain Current Pulsed Drain Current Junction temperature Case and Storage temperatures Stray Inductance ID IDpulse Tj TC,TSTG LStray Package resistance @ 25°C4 Clearance distance Creepage distance CTI-Comparative Tracking Index Mounting Torque Weight 4 MP MBP g Condition Tj=25°C Tj=175°C VGS =15V, TC=25°C, Tj15 mm min 175 4 2 590 N-m N-m g Package resistance temperature coefficient: 0.39%/°C PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM 9-Dec-21 6 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Max Absolute Ratings “Gate Driver” Parameter VCC-GND PWM-XT/PWM-XB/RSTN wrt GND FLT-B-U/ FLT-T-V/FLT-W wrt GND Min. -0.5 -0.5V -0.5V 175 CTI-Comparative Tracking Index Junction Temperature Storage and Operating Temperature ESD Rating (Human Body Model) between VCC/GND/PWM-XT/PWM-XB/RSTN/FLT-X pins5 -40 1.5 Max. 18 5.5 18 Units V V V 175 125 °C °C kV Max. Units Isolation Parameter VDCX+/VDCX-/U/V/W wrt to VCC/GND/PWMXT/PWM-XB/FLT-X Any of “VDCX+/VDCX/U/V/W/VCC/GND/PWMXT/PWM-XB/FLT-X wrt to baseplate Parasitic capacitance Condition Min. AC @50Hz (for 1mn) Typ. 3600 V @ 1000VDC >1 GΩ Between high-side and primary (per phase) 11 pF DC Bus Voltage Monitoring Parameter Symbol DC BUS voltage monitoring output Condition VDCM Typ Unit 0.0033*Diff(VDCV+,VDCU-) V Temperature Monitoring Parameter Temperature monitoring output NTC resistance Symbol TEMP-U TEMP-V TEMP-W NTCR Condition Typ Unit NTCR (Ohm)*5/( NTCR (Ohm)+1500) V 5000 Ω TNTC=25°C Steinhart-Hart Coefficients for NTCR versus Temperature computation: 1/(TNTC-273.15) = A+B*ln(R)+C*ln3(R) TNTC< (273.15+25)K TNTC> (273.15+25)K A 9.931*10-4 9.923*10-4 B 2.658*10-4 2.664*10-4 C 1.563*10-7 1.496*10-7 5 Because of functional isolation requirement between «VDCX+/VDCX-/U/V/W» and « VCC/GND/PWM-XT/PWMXB/FLT-X » pins, no ESD performance can be guaranteed between those 2 pin groups. PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM 9-Dec-21 7 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Electrical Characteristics ”Power module” Unless otherwise stated: (VCC-GND)=15V, TC=25°C. Bold underlined values indicate values over the whole temperature range (-40°C < TJ < +175°C). “SiC Power MOSFET’s” Parameter Symbol Condition Tj=25°C ; IDS = 0.02A; VDS = VGS Threshold voltage VTH Tj=175°C ; IDS = 0.02A; VDS = VGS VGS =-3V, VDS=1200V, Tj=25°C Drain cut-off current IDSS VGS =-3V, VDS =1200V, Tj=175°C VGS =15V, ID=300A, Tj=25°C Static drain-to-source reRDSon sistance6 VGS =15V, ID=300A, Tj=175°C Breakdown drain-to-source VBRDS VGS =-3V; IDS = 500 µA voltage (DC characterization) Input capacitance CISS VGS =0VDC, VDS =600VDC f = 100 kHz Output capacitance COSS VAC = 25mV Feedback capacitance CRSS Turn-on delay time Td(ON) Rise time Tr Turn-off delay time Td(OFF) VDS=600V; VGS= -3/15V; IDS = 300A; L = 50µH Fall time Tf Turn-On Switching Energy Eon Turn-Off Switching Energy Eoff Gate to Source Charge QGS Tj=25°C ;VDS= 600V; Gate to Drain Charge QGD IDS = 300A; VGS = -3/15V Total Gate Charge QG TJ=25°C Short-circuit protection threshISCth TJ=175°C old Maximum short-circuit duration tSC Min 1.8 Typ 2.15 Max 3.5 Unit V 1.7 V 1 50 3.25 5.15 µA µA mΩ mΩ 4 1200 V 30 1.3 76 74 104 213 40 8.42 7.05 292 285 910 1145 750 nF nF pF ns ns ns ns mJ mJ nC nC nC 2 µs A A “SiC Reverse Diode” Parameter Diode Forward Voltage Symbol Condition Tj=25°C ; ISD = 300A; VGS =-3V VF Tj=175°C ; ISD = 300A; VGS =-3V Continuous Diode Forward Current Diode Pulse Current Typ 5.18 4.5 Max Unit V V ISD,DC VGS =-3V, Tf=25°C, Tj LOW Non Overlap delay LOW => HIGH PWM data path PWM frequency8 Duty cycle Anti-glitch filter window Propagation delay (PWM-XB/PWM-XT →U/V/W) (50% to 10%) Propagation delay (PWM-XB/PWM-XT → U/V/W) (50% to 10%) 50 100 500 kHz % ns 180 ns 600 ns 0 Direct Mode; excluding anti-glitch filter delay Local Mode; excluding anti-glitch filter delay Fault latching time Timer value (Primary or Secondary faults) Timer variation Under-voltage Lockout on VCC (UVLO_P) UVLO_P High Threshold UVLO_P Low Threshold Delay from UVLO_P detection to FLT-X @ fault level Under-voltage Lockout on secondaries gate driver supplies(UVLO_S) UVLO_S High Threshold UVLO_S Low Threshold Delay from UVLO_S detection to FLT-X @ fault level Desaturation detection (DESAT_H, DESAT_L) Desaturation Threshold wrt to power switch source Desaturation Blanking time Delay from Desaturation detection to FLT-X in fault state Soft Shutdown gate fall time VGS from 15V to 0V 8 14 -30 ms +25 % 9.75 8.2 V V 200 ns 16.8 15.5 V V 600 ns 4.6 1 V µs 600 ns 1 µs Please refer to section Gate driver temperature derating for operation above 25kHz (page 17) PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM 9-Dec-21 9 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Typical performances (per switch) Figure 1: Drain current vs VDS (VGS=15V, tp < 200µs)9 Figure 2: On-state drain source resistance vs. Drain current (VGS =15V, tp < 200µs)9 Figure 3: Normalized on-state drain source resistance (IDS=300A, VGS =15V, tp < 200µs)9 Figure 4: Drain current vs VGS voltage (VDS=20V, tp < 200µs) Figure 5 : 3rd quadrant characteristics (VGS=15V, tp < 200µs) 9 Figure 6: 3rd quadrant characteristics (VGS=3V, tp < 200µs) 9 9 Package resistance excluded PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM 9-Dec-21 10 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Typical performances (per switch) (cnt’d) Figure 7: Typical capacitances vs VDS (Tj=25°C ; f = 100 kHz, VAC =25mV) Figure 8 : Typical capacitances vs VDS (Tj=25°C ; f = 100 kHz, VAC =25mV) Figure 9:Threshold vs temp (IDS=20mA; VGS=VDS) Figure 10 : Switching Energy Figure 11 : Reverse Recovery Energy Figure 12 : Max dV/dt vs Drain current VDS IDS 10% VDS 10% VDS 10% IDS 10% IDS ESW (on) Figure 13 : Max Turn-off dI/dt vs Drain current PUBLIC Doc. PDS-192038 V1.9 ESW (on) Figure 14 : Switching energy computation WWW.CISSOID.COM 9-Dec-21 11 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Typical performances (per switch) (cnt’d) Figure 15: MOSFET Junction to Case Thermal Impedance Figure 16: Forward Bias Safe Operating Area (FBSOA) Figure 17 : Reverse Bias Safe Operating Area (RBSOA) Figure 18: Continuous Drain Current Derating vs Case temperature Figure 19 : Maximum Power Dissipation Derating vs Case temperature Figure 20 : Typical Output Current Capability vs Switching Frequency (Inverter Application) PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM 9-Dec-21 12 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Gate Driver Circuit Functionality Under-Voltage Lockout (UVLO) Description Main features of the CXT-PLA3SA12450A gate driver are: - Isolated data transmission (robust to high dV/dt) (data and fault) on both high and low side channels - Adjustable fault timer with automatic restart - Safe start-up sequence through monitoring of the main supply (UVLO) and of the voltage regulators output (through Power-Good function) - Permanent and programmable Under-Voltage Lockout (UVLO) monitoring on external and internally generated power switch supplies - Desaturation detection function with programmable blanking time and threshold protecting power switches in case of abnormal current levels - Soft-Shutdown transistor and control performing power device graceful shutdown in case of fault and so preventing too high dI/dt in the power stage - Flyback DC-DC converter (one per phase) with cycle-by-cycle current limit for short circuit protection - High-precision (typ 3%) high-level gate voltage generation - Single-ended Schmitt-trigger PWM inputs - Open-drain low-ohmic (typ. 25Ω) fault output - Support of 2 separate incoming PWM channels and of locally generated non-overlapped PWM signals (per phase) (configuration via jumper) - Configurable 500ns (typ) spike filter on incoming PWM signal for enhanced noise robustness - Anti-overlap protection on incoming PWM signals - Gate-2-Source short-circuit protection - Support of 100% duty-cycle PWM - Very low parasitic capacitance between secondaries and primary PUBLIC Doc. PDS-192038 V1.9 CXT-PLA3SA12450A gate driver board monitors constantly: - VCC power supply High-side secondary supplies (typ +15V/-3V) Low-side secondary supplies (typ +15V/-3V) At primary side, the monitored power supply is “VCC-GND”; to avoid oscillation when (VCC-GND) is close to the UVLO threshold, a hysteresis is implemented. At each secondary side, the monitored power supply is “VDD_L-VSS_L”/ “VDD_H-VSS_H”; to avoid oscillation when (VDD_x-VSS_x) is close to the UVLO threshold, a hysteresis is implemented. Refer to the chapter Fault Management for details about fault behavior and management. On-board power supplies The on-board isolated power supply (per phase) is a regulated flyback DC-DC converter providing both high-side and lowside channels with the positive and negative supply voltages required to drive the power FETs. It offers high voltage isolation between the channels, high dV/dt sustainability and very low parasitic capacitance. Cycle-by-cycle current monitoring at primary side is implemented to protect the board against short-circuit. High accuracy (typ 3%) is achieved on all secondary positive supplies. WWW.CISSOID.COM 9-Dec-21 13 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Interface towards controller Desaturation detection PWM inputs The purpose of the desaturation function is to detect that the voltage at the drain of the power switch, in “ON” state, is higher than a given threshold. This informs the logic part of the system about possible damage of the power arm (e.g. a short circuit at the arm level leading to an overcurrent in the power switch). PWM-XB and PWM-XT input interface is based on 5V Schmitt-Trigger input receivers and is Active High. Active Low is available as an option. CXT-PLA3SA12450A gate driver board implements 2 protection functions on the PWM data paths: - Anti-glitch: any negative or positive glitch on PWM-XB/PMW-XT signals smaller than a programmed value is ignored by the board; this is increasing immunity of incoming signals against external noise; the PWM signals are delayed by the corresponding antiglitch time tMINPW (ns)= 1* [CGLIx (pF)] - The desaturation threshold (voltage on transistor VDS) is configured by on-board resistors and can be tuned according to the table below. Rdesat value Anti-overlap: this circuit prevents PWM-XB and PMWH from being active at the same time. FAULT outputs 0KΩ 5KΩ 10KΩ 12KΩ Desat threshold (V) 25°C 125°C 1.18 1.47 2.6 2.87 4.01 4.27 4.6 4.83 (default) The output buffers operate as an opendrain driver with a very low Ron resistance (typ. 25Ω), enabling the use of low value pull-up resistance for increased noise immunity. An on-board 10k pull-up resistance (connected to internal 5V supply) is present on each fault output to ease initial testing. By default, there is one fault output per phase (one fault per side [top/bottom] is available as an option). 15KΩ 20KΩ 5.42 6.84 5.66 7.06 At system level, the de-saturation detection should only be taken into account after a defined time following the low-to-high transition on the power device gate. This “blanking” time tDESAT_D is implemented and adjusted by an on-board capacitor CDESATD (68pF installed) and can be calculated as follows: tDESATD (ns)= 14* [CDESATD (pF) + 7] Isolated data transmission CXT-PLA3SA12450A gate driver board uses integrated digital isolators. Those devices provide isolation, immunity against high dV/dt and low parasitic capacitance. In case no power supply is present at the secondary side, a fault is generated at the primary side. PUBLIC Doc. PDS-192038 V1.9 The sensing of the power device drain voltage is performed through a high voltage sensing diode whom cathode is connected to the power switch drain and whom anode is connected to a current source (typ 2mA) and a sensing circuit. If after tDESAT_D time, the DESAT comparator output indicates that the transistor VDS level is higher than the programmed threshold value, an internal DESAT fault is generated. Refer to the chapter Fault Management for details about fault behavior and management. When the desaturation fault is detected, the power module gate is gracefully discharged thanks to the Soft-Shutdown circuit to avoid high dI/dt at power module turn-off WWW.CISSOID.COM 9-Dec-21 14 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Active Miller Clamping In case of high positive dV/dt and despite the negative drive of the power module gate, a parasitic turn-on of the gate could take place, inducing shoot-through current on the power arm. To prevent this, CXT-PLA3SA12450A gate driver board implements an Active Miller Clamping function by bypassing the gate resistance with a low ohmic path (implemented with a transistor) when the gate is driven negative. This transistor also helps to limit the amplitude of negative kick on the power module gate in case of negative dV/dt. Fault Management The primary fault state is combined with the faults returned by the secondary devices according to Table 1. Prim fault No No No No Yes High-side fault No No Yes Yes Yes or No FLT-X No fault Fault Fault Fault Fault Table 1: FAULT aggregation table At each of the secondary side, fault is generated by any of those situations: - Fault management is taking place on each phase independently. At primary side, fault is generated by any of those situations: Low-side fault No Yes No Yes Yes or No - Power supply is below the UVLO threshold Secondary voltage regulator (5V) output voltage is below the PowerGood threshold Desaturation situation is detected by the DESAT comparator Main power supply (VCC) is below the UVLO threshold Primary linear voltage regulator (generating the 5V output required by the on-board logic) is below the internal Power Good level Those faults are internally combined to generate a unique fault signal. This internal fault signal is latched for 14msec. While the fault is latched, the gate driver is turned off. At the transition between “no fault” and “fault” situation, the gate driver circuit is gracefully shut down. Those faults are internally combined to generate a unique fault signal. This internal fault signal is latched for 14msec. After the predefined latch time period, the gate driver circuit returns to normal operation: - While the fault is latched: - - Both FLT-X pins are tied to “0” Both power switches are turned off On board DC-DC is off - After the predefined latch time period, the phase controller will attempt to return to normal operation: - If the fault is still present, the phase will stay in the fault state till the fault disappears - If the fault disappeared (e.g. temporary UVLO situation), the phase will go out of FAULT state and return to normal operation (DC-DC turned on and data paths active); still, on the PWM path, transition to normal operation will happen on the next positive edge of the incoming PWM signal. PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM If the fault is still present, the gate driver is kept turned off till the fault disappears If the fault disappeared (e.g. temporary UVLO situation), normal operation will resume on the next positive edge of incoming PWM signal 9-Dec-21 15 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet RSTN (Reset) behaviour While in Low-State, pin RSTN forces all PWM input signals to “0”, turning off all SiC MOSFET gates in Direct mode and turning off the High-Side SiC MOSFET and keeping Low-Side SiC MOSFET on in Local Mode Protections CXT-PLA3SA12450A gate driver is protected on each channel against: - Gate overvoltage Gate undervoltage Gate-source permanent circuit When in Local Mode, an on-board capacitance (Cnovd) defines the non-overlap delay according to following formula: tNOV_D (ns)=5.5 * CNOVD (pF) Board power dissipation Current consumption of the CXTPLA3SA12450A gate driver board (VCC=15V; VDCX+=0V) can be computed as follows: 𝐼𝑖𝑛 = 170𝑚𝐴 + 8.4 ∗ 𝐹𝑠 Where: short- - Non-Overlap Generation CXT-PLA3SA12450A gate driver board offers 2 modes of operation: - - Direct Mode: PWM-XB and PWMXT are generated independently outside CXT-PLA3SA12450A gate driver board. In this case, proper non overlapping must be generated externally. Local Mode: PWM-XB and PWMXT are generated from one input signal (PWM-XT) and proper non overlapping timing is managed locally on each phase of CXTPLA3SA12450A gate driver board (cfr Figure 21) PWM-XT G_HS G_LS tNOV_D Iin: Input current (in mA) (wrt to VCC = 15V) Fs: Switching frequency (in kHz) The duty cycle of the PWM-XB/PWM-XT signals has almost no influence on the current consumption (assuming PWM-XB and PWM-XT duty cycles are complementary). To stay within specifications of the internal secondary voltages, the maximum average Iin current should be 1000 mA (for VCC =15V). Temperature measurement Temperature of each phase is measured using an NTC resistance mounted on the power module DBC. The NTC resistance variation with respect to temperature is reported in Figure 22: NTC resistance vs tempand obeys to the formula provided in section Max Absolute Ratings. tNOV_D Figure 21: Local Mode operation The choice between those 2 modes of operation is made via the 2 pin header jumper JP1 (located at primary side, one per phase): - JP1 ON: Local mode JP1 OFF: Direct mode Figure 22: NTC resistance vs temp PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM 9-Dec-21 16 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet The NTC resistance value is converted into an analog voltage fed to the connector pins TEMP-U, TEMP-V, TEMP-W. Figure 23: TEMP-X voltage vs tempshows the relationship between TEMP-X voltage and NTC temperature. 5 4.5 Cooler circuit pressure drop Cissoid offers a reference cooler kit (ordering code: ACC-PLA1008) enabling fast prototying and validation by customers. The graph below reports the pressure drop in function of the cooling fluid flow rate (fluid temperature: 60°C, fluid: 50% ethylene glycol, 50% water TEMP-X pin voltage (V) 4 3.5 3 2.5 2 1.5 1 0.5 0 -55 -5 45 95 145 195 Temperature (°C) Figure 23: TEMP-X voltage vs temp Gate driver temperature derating Figure 25: Pressure drop in cooling circuit The CXT-PLA3SA12450A gate driver has been designed to operate at 125°C ambient upto 25kHz switching frequency. Above 25 kHz, a derating according to the graph below needs to be applied. Figure 24: Gate driver temperature derating PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM 9-Dec-21 17 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Timing Diagrams Figure 26 illustrates the CXT-PLA3SA12450A gate driver board low-side driver dynamic behavior in normal operation and fault conditions. Normal Case PWM-XB 1 Fault UVLO Normal Case 6 2 7 G_LS UVLO 3 FLT-X Internal timer 4 Normal Case PWM-XB 1 tFLTD 5 FAULT Desat Normal Case 3 7 8 G_LS D_LS tDESATD DESAT BLANK tDESATD FLT-X 2 4 Internal timer 5 tFLTD 6 Figure 26: Timing diagram CXT-PLA3SA12450A low-side gate driver behaviour In Normal operation In DESAT fault situation On PWM-XB rising edge (1), rising edge is generated on G_LS (after propagation delay through CXT-PLA3SA12450A gate driver board). After rising edge on G_LS, low-side power module is turned ON and midpoint node is going to “0” state (voltage equals to Ron * current flowing through the power device). D_LS node is also pulled down and after blanking time (tDESAT_D), no desaturation fault is detected and FAULTL remains high. On PWM-XB rising edge (3), rising edge is generated on G_LS (after propagation delay through CXT-PLA3SA12450A gate driver board) After rising edge on G_LS, low-side power module is turned ON; because of a desaturation fault, D_LS node does not reach its normal “0” level. Thanks to the DESAT comparator, CXT-PLA3SA12450A gate driver board detects this fault situation and turns off gracefully G_LS. Power device is turned off. FAULTL signal is pulled down. Fault is cleared after fault timer expiry. On PWM-XB falling edge (2), falling edge is generated on G_LS (after propagation delay through CXT-PLA3SA12450A gate driver board) After falling edge on G_LS, the low-side power device is turned OFF. PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM 9-Dec-21 18 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet In UVLO fault situation Glossary UVLO status is monitored inside the secondary devices (and inside primary device as well; for clarity, only secondary UVLO situation is described here). When UVLO comparator (5) detects an under-voltage situation, G_LS is gracefully shut down FAULTL signal is pulled down. Fault is cleared after fault timer expiry. Name D_HS S_HS G_HS D_LS S_LS G_LS PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM Description Drain of any high-side switch Source of any high-side switch Gate of any high-side switch Drain of any low-side switch Source of any low -side switch Gate of any low -side switch 9-Dec-21 19 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Mechanical drawing PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM 9-Dec-21 20 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Physical dimensions (mm) Base plate material: AlSiC Power pins finish: Ni Gate driver control pins finish: Au Gate driver control connector: Molex 87831-2020 Item Baseplate fixing screws DC Bus Power connector bolts Phase power connector bolts Gate driver female counter connector board-2-cable Gate driver female counter connector board-2-board PUBLIC Doc. PDS-192038 V1.9 Recommended reference M4x10 ISO 7380-2 A2 TX M6x12 ISO 7380-2-A2-TX M6x12 ISO 7380-2-A2-TX Comments Assumes min 0.7 mm DC power connector thickness Assumes min 1.6 mm phase connector thickness Molex 51110 SERIES Molex 78787-2054(Tin) or 79107-7009(Gold). WWW.CISSOID.COM 9-Dec-21 21 of 22 3-Phase 1200V/450A SiC MOSFET Intelligent Power Module Preliminary Datasheet Contact & Ordering CISSOID S.A. Headquarters and contact EMEA: CISSOID S.A. – Rue Francqui, 3 – 1435 Mont Saint Guibert - Belgium T : +32 10 48 92 10 – F : +32 10 88 98 75 Email : sales@cissoid.com Sales Representatives: Visit our website: http://www.cissoid.com Disclaimer Neither CISSOID, nor any of its directors, employees or affiliates make any representations or extend any warranties of any kind, either express or implied, including but not limited to warranties of merchantability, fitness for a particular purpose, and the absence of latent or other defects, whether or not discoverable. In no event shall CISSOID, its directors, employees and affiliates be liable for direct, indirect, special, incidental or consequential damages of any kind arising out of the use of its circuits and their documentation, even if they have been advised of the possibility of such a damage. The circuits are provided “as is”. CISSOID has no obligation to provide maintenance, support, updates, or modifications. PUBLIC Doc. PDS-192038 V1.9 WWW.CISSOID.COM 9-Dec-21 22 of 22
CXT-PLA3SA12450AA 价格&库存
很抱歉,暂时无法提供与“CXT-PLA3SA12450AA”相匹配的价格&库存,您可以联系我们找货
