CSD10030A
CSD10030A
    WOLFSPEED
    TO-220-2
    DIODE SCHOTTKY 300V 10A TO220-2
CSD10030A 数据手册
PRELIMINARY CSD10030 ZERO RECOVERYTM RECTIFIER Features Benefits _________ • 300 Volt Schottky Rectifier • Replace Bipolar with Unipolar Rectifiers • Zero Reverse Recovery • Essentially No Switching Losses • Zero Forward Recovery • Higher Efficiency • High Frequency Operation • Reduction Of Heat Sink Requirements • Temperature Independent Switching Behavior • Parallel Devices without Thermal Runaway • Extremely Fast Switching • Positive Temperature Coefficient on VF Applications Package ______ ______ • Switch Mode Power Supplies • Power Factor Correction • Motor Drives • Output Rectification CSD10030A Maximum Ratings Parameter Symbol Value Unit Repetitive Peak Reverse Voltage VRRM 300 V Surge Peak Reverse Voltage VRSM 300 V DC Blocking Voltage VDC 300 V IF(AV) 10 A IFRM 40 A IFSM 200 A Ptot 79 W TJ , Tstg -55 to +175 °C Average Forward Current TC=150°C Repetitive Peak Forward Surge Current TC=25°C, tP=8.3ms, Half Sine Wave Non-Repetitive Peak Forward Surge Current TC=25°C, tP=10µs, Pulse Power Dissipation TC = 25 °C Operating Junction and Storage Temperature Page 1 • CSD10030, Rev B PRELIMINARY CSD10030 ELECTRICAL CHARACTERISTICS Parameter Symbol Forward Voltage IF = 10A TJ=25°C IF = 10A TJ=175°C Reverse Current VR = 300V TJ=25°C VR = 300V TJ=175°C Total Capacitive Charge VR = 300V,IF = 10A, di/dt = 500 A/µs, TJ = 25°C Total Capacitance VR = 0V, TJ = 25°C, f =1MHz VR = 150V, TJ = 25°C, f =1MHz VR = 300V, TJ = 25°C, f =1MHz Min Typ Max 1.2 1.4 1.4 1.8 50 200 1000 2000 VF IR Units V µA QC 11.5 nC C 660 62 58 pF NOTE: 1. This is a majority carrier diode, so there is no reverse recovery charge. THERMAL CHARACTERISTICS Characteristic Symbol Thermal Resistance from Junction to Case Min Typ Max °C/W 1.9 RθJC Units Typical Performance Figure 2. Reverse Characteristics 20 1000 18 900 16 800 14 TJ = 25°C TJ = 75°C TJ = 125°C TJ = 175°C 12 IR Reverse Current (uA) IF FORWARD CURRENT (A) Figure 1. Forward Characteristics 10 8 6 700 TJ = 250 C TJ = 750 C TJ = 1250 C 0 TJ = 150 C 0 TJ = 175 C 600 500 400 300 4 200 2 100 0 0 0.0 0.5 1.0 1.5 VF FORWARD VOLTAGE (V) Page 2 • CSD10030, Rev B 2.0 2.5 0 100 200 300 400 VR Reverse Voltage (V) 500 600 PRELIMINARY Figure 3. Current Derating CSD10030 Figure 4. Capacitance vs. Reverse Voltage 30 500 450 400 350 20 Capacitance (pF) IF(AV) Forward Current (A) 25 15 10 300 250 200 150 100 5 50 0 0 25 50 75 100 125 150 175 200 1 10 100 1000 VR Reverse Voltage (V) TC Case Temperture (°°C) Figure 5. Transient Thermal Impedance 1.00E+01 Zth [°C/W] 1.00E+00 1.00E-01 1.00E-02 1.00E-03 1.00E-07 1.00E-06 1.00E-05 1.00E-04 1.00E-03 1.00E-02 1.00E-01 1.00E+00 time [s] Page 3 • CSD10030, Rev B PRELIMINARY CSD10030 Package Dimensions Package TO-220-2 P F A POS Q J C B X S D E 1 2 Y T G U H V L M W N PIN 1 PIN 2 Part Number CSD10030A CASE Package TO-220-2 Page 4 • CSD10030, Rev B Marking CSD10030 A B C D E F G H J L M N P Q S T U V W X Y Inches Min Max .381 .391 .240 .250 .100 .120 .223 .227 .595 .615 .143 .147 1.105 1.115 .500 .510 R 0.197 .025 .035 .045 .055 .198 .202 .165 .185 .048 .052 4° 6° 4° 6° 4° 6° .094 .098 .018 .025 4.5° 5.5° .385 .405 Millimeters Min Max 9.677 9.931 6.096 6.350 2.540 3.048 5.664 5.766 15.113 15.621 3.632 3.734 28.067 28.321 12.700 12.954 R 5.004 .635 .889 1.143 1.397 5.029 5.131 4.191 4.699 1.219 1.321 4° 6° 4° 6° 4° 6° 2.387 2.489 .458 .635 4.5° 5.5° 9.779 10.287 PRELIMINARY CSD10030 Recommended solder pad layout. TO-220-2 This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, air traffic control systems, or weapons systems. Copyright © 2001-2004 Cree, Inc. All rights reserved. Permission is given to reproduce this document provided the entire document (including this copyright notice) is duplicated. The information in this document is subject to change without notice. Cree and the Cree logo are trademarks of Cree, Inc. Cree, Inc. Power Products 4600 Silicon Drive • Durham, NC 27703 • USA Tel: 919-313-5300 • Fax: 919-313-5451 www.cree.com Page 5 • CSD10030, Rev B This datasheet has been downloaded from: www.DatasheetCatalog.com Datasheets for electronic components.
CSD10030A 价格&库存
很抱歉,暂时无法提供与“CSD10030A”相匹配的价格&库存,您可以联系我们找货
