UGA8120
Taiwan Semiconductor
8A, 1200V High Efficient Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High junction temperature up to 175°C
Negligible leakage sustain the high operation temperature
Very low stored charge and its soft recovery minimize ringing and
electrical noise to reduce power loss in associated MOSFET or
IGBT
High capability for high di/dt operation.
High surge current capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
8
A
VRRM
1200
V
IFSM
80
A
TJ MAX
175
°C
Package
TO-220AC
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: TO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.85g (approximately)
TO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
UGA8120
UNIT
UGA8120
Repetitive peak reverse voltage
VRRM
1200
V
Reverse voltage, total rms value
VR(RMS)
840
V
Forward current
Surge peak forward current 8.3ms single half sine
wave superimposed on rated load
Junction temperature
IF
8
A
IFSM
80
A
TJ
-55 to +175
°C
Storage temperature
TSTG
-55 to +175
°C
1
Version: D2103
UGA8120
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
2.3
°C/W
Junction-to-case resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 8A, TJ = 25°C
(2)
Reverse recovery time
Reverse recovery charges
TJ = 25°C
TJ = 125°C
IF = 0.5A, IR = 1.0A
Irr = 0.25A
IF = 1A, dIF/dt = -100A/µs,
VR = 30V, TJ = 25°C
IF = 8A, dIF/dt = -200A/µs,
VR = 400V, TJ = 25°C
VR = 400V, TJ = 125°C
SYMBOL
TYP
MAX
UNIT
VF
2.8
V
1
5
µA
5
100
µA
trr
35
50
ns
trr
50
70
ns
Qrr
165
nC
IRM
11
16
A
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
UGA8120
TO-220AC
50 / Tube
UGA8120H
TO-220AC
50 / Tube
Notes:
1. “H” means AEC-Q101 qualified
2
Version: D2103
UGA8120
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
8
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
10
6
4
10
2
50
75
100
125
150
f=1.0MHz
Vsig=50mVp-p
1
175
0.1
1
CASE TEMPERATURE (°C)
0.1
TJ=25°C
0.001
10
40
50
60
70
80
90
100
1010
1
UF1DLW
TJ=125°C
TJ=125°C
TJ=25°C
10.1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
TJ=25°C
0.01
Pulse width 300μs
Pulse width
1% duty cycle
0.001
0.1
0.5 1 0.6
0.7 1.6 0.8
0.20.30.4 0.4
0.6 0.8
1.2 1.4
1.8 0.9
2 2.2 12.4 1.1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
90
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (uA)
Fig.4 Typical Forward Characteristics
10
0.01
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
10
80
70
60
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: D2103
1.2
UGA8120
PACKAGE OUTLINE DIMENSIONS
TO-220AC
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: D2103
UGA8120
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: D2103
很抱歉,暂时无法提供与“UGA8120 C0G”相匹配的价格&库存,您可以联系我们找货
