GPA807HC0G
GPA807HC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-2
    DIODE GEN PURP 8A TO220AC
GPA807HC0G 数据手册
GPA801 – GPA807 Taiwan Semiconductor 8A, 50V - 1000V Standard Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High efficiency, Low VF High current capability High reliability High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 8 A VRRM 50 - 1000 V IFSM 150 A TJ MAX 150 °C Package TO-220AC Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● General purpose MECHANICAL DATA ● ● ● ● ● ● Case: TO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.80g (approximately) TO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM GPA 801 GPA 801 50 Reverse voltage, total rms value VR(RMS) 35 PARAMETER SYMBOL Marking code on the device GPA 802 GPA 802 100 GPA 803 GPA 803 200 GPA 804 GPA 804 400 GPA 805 GPA 805 600 GPA 806 GPA 806 800 70 140 280 420 560 GPA UNIT 807 GPA 807 1000 V 700 V Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Junction temperature IF 8 A IFSM 150 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: G2103 GPA801 – GPA807 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case thermal resistance SYMBOL TYP UNIT RӨJC 2.5 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage (1) Reverse current @ rated VR (2) Junction capacitance CONDITIONS SYMBOL TYP MAX UNIT IF = 8A, TJ = 25°C VF - 1.1 V - 5 µA - 100 µA 50 - pF TJ = 25°C TJ = 125°C 1MHz, VR = 4.0V IR CJ Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING GPA8x TO-220AC 50 / Tube GPA8xH TO-220AC 50 / Tube Notes: 1. “x” defines voltage from 50V(GPA801) to 1000V(GPA807) 2. “H” means AEC-Q101 qualified 2 Version: G2103 GPA801 – GPA807 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 8 CAPACITANCE (pF) 6 4 100 10 2 0 f=1.0MHz Vsig=50mVp-p 1 25 50 75 100 125 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 10 1 TJ=25°C 0.1 30 40 50 60 70 80 90 100 100 10 10 UF1DLW 1 TJ=125°C TJ=25°C 0.1 1 0.01 0.1 0.001 0.6 Pulse width 300μs 1% duty cycle Pulse width 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.8 0.4 1.0 0.5 1.2 1.4 0.6 0.7 0.8 1.6 0.9 1.8 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 180 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (uA) Fig.4 Typical Forward Characteristics 100 20 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 10 8.3ms single half sine wave 150 120 90 60 30 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: G2103 1.2 GPA801 – GPA807 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AC MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: G2103 GPA801 – GPA807 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: G2103
GPA807HC0G 价格&库存
很抱歉,暂时无法提供与“GPA807HC0G”相匹配的价格&库存,您可以联系我们找货
