MUR1610CT, MUR1615CT,
MUR1620CT, MUR1640CT,
MUR1660CT
SWITCHMODE]
Power Rectifiers
These state−of−the−art devices are a series designed for use in
switching power supplies, inverters and as free wheeling diodes.
Features
Ultrafast 35 and 60 Nanosecond Recovery Times
175°C Operating Junction Temperature
Popular TO−220 Package
Epoxy Meets UL 94 V−0 @ 0.125 in
High Temperature Glass Passivated Junction
High Voltage Capability to 600 V
Low Leakage Specified @ 150°C Case Temperature
Current Derating @ Both Case and Ambient Temperatures
Pb−Free Packages are Available*
http://onsemi.com
ULTRAFAST RECTIFIERS
16 AMPERES, 100−600 VOLTS
1
2, 4
3
4
Mechanical Characteristics:
• Case: Epoxy, Molded
• Weight: 1.9 Grams (Approximately)
• Finish: All External Surfaces Corrosion Resistant and Terminal
Leads are Readily Solderable
Lead Temperature for Soldering Purposes:
260°C Max. for 10 Seconds
TO−220AB
CASE 221A
PLASTIC
1
2
3
MARKING DIAGRAM
AY WW
U16xxG
AKA
A
Y
WW
U16xx
*For additional information on our Pb−Free strategy and soldering details, please
download the ON Semiconductor Soldering and Mounting Techniques
Reference Manual, SOLDERRM/D.
G
KA
Assembly Location
Year
Work Week
Device Code
xx = 10, 15, 20, 40 or 60
= Pb−Free Package
= Diode Polarity
ORDERING INFORMATION
See detailed ordering and shipping information in the package
dimensions section on page 6 of this data sheet.
© Semiconductor Components Industries, LLC, 2008
September, 2008 − Rev. 7
1
Publication Order Number:
MUR1620CT/D
MUR1610CT, MUR1615CT, MUR1620CT, MUR1640CT, MUR1660CT
MAXIMUM RATINGS
MUR16
Rating
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Rectified Forward Current
Total Device, (Rated VR), TC = 150°C
Peak Rectified Forward Current
(Rated VR, Square Wave, 20 kHz), TC = 150°C
Per Leg
Total Device
Per Diode Leg
Nonrepetitive Peak Surge Current
(Surge applied at rated load conditions halfwave, single phase, 60 Hz)
Operating Junction Temperature and Storage Temperature
Symbol
10CT
15CT
20CT
40CT
60CT
Unit
VRRM
VRWM
VR
100
150
200
400
600
V
IF(AV)
8.0
16
A
IFM
16
A
IFSM
100
A
TJ, Tstg
*65 to +175
°C
Stresses exceeding Maximum Ratings may damage the device. Maximum Ratings are stress ratings only. Functional operation above the
Recommended Operating Conditions is not implied. Extended exposure to stresses above the Recommended Operating Conditions may affect
device reliability.
THERMAL CHARACTERISTICS (Per Diode Leg)
Parameter
Symbol
Maximum Thermal Resistance, Junction−to−Case
Value
Unit
RqJC
3.0
2.0
Symbol
1620
1640
1660
0.895
0.975
1.00
1.30
1.20
1.50
°C/W
ELECTRICAL CHARACTERISTICS (Per Diode Leg)
Characteristic
Maximum Instantaneous Forward Voltage (Note 1)
(iF = 8.0 A, TC = 150°C)
(iF = 8.0 A, TC = 25°C)
vF
Maximum Instantaneous Reverse Current (Note 1)
(Rated DC Voltage, TC = 150°C)
(Rated DC Voltage, TC = 25°C)
iR
Maximum Reverse Recovery Time
(IF = 1.0 A, di/dt = 50 A/ms)
(IF = 0.5 A, IR = 1.0 A, IREC = 0.25 A)
trr
1. Pulse Test: Pulse Width = 300 ms, Duty Cycle ≤ 2.0%
http://onsemi.com
2
250
5.0
500
10
35
25
60
50
Unit
V
mA
ns
100
IR, REVERSE CURRENT ( mA)
70
50
30
TJ = 175°C
100°C
10
TJ = 175°C
100°C
0.8
0.4
0.2
0.08
0.04
0.02
25°C
7.0
25°C
40
60
5.0
80
100
140
120
180 200
160
VR, REVERSE VOLTAGE (VOLTS)
Figure 2. Typical Reverse Current, Per Leg*
3.0
* The curves shown are typical for the highest voltage device in the
voltage grouping. Typical reverse current for lower voltage selections
can be estimated from these same curves if VR is sufficiently below
rated VR.
2.0
IF(AV) , AVERAGE POWER DISSIPATION (WATTS)
i F , INSTANTANEOUS FORWARD CURRENT (AMPS)
400
200
80
40
4.0
2.0
1.0
0.7
0.5
0.3
0.2
0.1
0.2 0.3
0.4
0.5
0.6
0.7
0.8
0.9
1.0
1.1
1.2
10
RATED VR APPLIED
9.0
8.0
7.0
6.0
5.0
dc
4.0
3.0
2.0
SQUARE WAVE
1.0
vF, INSTANTANEOUS VOLTAGE (VOLTS)
145
150
Figure 1. Typical Forward Voltage, Per Leg
155
160
165
170
175
180
TC, CASE TEMPERATURE (°C)
14
PF(AV) , AVERAGE POWER DISSIPATION (WATTS)
IF(AV) , AVERAGE FORWARD CURRENT (AMPS)
Figure 3. Current Derating, Case, Per Leg
RqJA = 16°C/W
RqJA = 60°C/W
(NO HEATSINK)
12
dc
10
8.0
SQUARE WAVE
6.0
4.0
dc
2.0
SQUARE WAVE
60
80
100
120
140
160
180
200
10
TJ = 175°C
9.0
8.0
SQUARE WAVE
7.0
dc
6.0
5.0
4.0
3.0
2.0
1.0
2.0
3.0
4.0
5.0
6.0
7.0
8.0
9.0
TA, AMBIENT TEMPERATURE (°C)
IF(AV), AVERAGE FORWARD CURRENT (AMPS)
Figure 4. Current Derating, Ambient, Per Leg
Figure 5. Power Dissipation, Per Leg
http://onsemi.com
3
10
MUR1640CT
70
50
100°C
TJ = 175°C
25°C
10
800
400
200
TJ = 175°C
80
40
4.0
2.0
150°C
100°C
0.8
0.4
0.2
0.08
0.04
0.02
25°C
7.0
50
5.0
150
200
250
350
300
400
450 500
Figure 7. Typical Reverse Current, Per Leg*
3.0
can be estimated from these curves if VR is sufficiently below rated
VR.
2.0
30
100
1.0
0.7
0.5
0.3
0.2
0.1
0.4
0.8
0.6
1.2
1.0
1.4
1.6
10
RATED VR APPLIED
9.0
8.0
7.0
6.0
5.0
dc
4.0
3.0
2.0
SQUARE WAVE
1.0
145
150
Figure 6. Typical Forward Voltage, Per Leg
155
160
165
170
175
180
14
Figure 8. Current Derating, Case, Per Leg
RqJA = 16°C/W
RqJA = 60°C/W
(NO HEATSINK)
12
10
dc
8.0
6.0
SQUARE WAVE
4.0
dc
2.0
SQUARE WAVE
60
80
100
120
140
160
180
200
10
TJ = 175°C
9.0
SQUARE WAVE
dc
8.0
7.0
6.0
5.0
4.0
3.0
2.0
1.0
2.0
3.0
4.0
5.0
6.0
7.0
8.0
9.0
Figure 9. Current Derating, Ambient, Per Leg
Figure 10. Power Dissipation, Per Leg
http://onsemi.com
4
10
MUR1660CT
100
70
50
30
100°C
10
25°C
TJ = 150°C
100°C
25°C
7.0
100
300
200
5.0
400
600
500
Figure 12. Typical Reverse Current, Per Leg*
3.0
rated VR.
2.0
TJ = 150°C
400
200
80
40
4.0
2.0
0.8
0.4
0.2
0.08
0.04
0.02
1.0
0.7
0.5
0.3
0.2
0.1
0.6
0.4
0.8
1.0
1.2
1.4
1.6
1.8
10
RATED VR APPLIED
9.0
8.0
7.0
6.0
5.0
dc
4.0
3.0
2.0
SQUARE WAVE
1.0
145
150
Figure 11. Typical Forward Voltage, Per Leg
155
160
165
170
175
180
10
RqJA = 16°C/W
RqJA = 60°C/W
(NO HEATSINK)
9.0
dc
8.0
Figure 13. Current Derating, Case, Per Leg
7.0
6.0
SQUARE WAVE
5.0
4.0
dc
3.0
2.0
SQUARE WAVE
1.0
60
80
100
120
140
160
180
200
14
13
12
11
10
9.0
8.0
7.0
6.0
5.0
4.0
3.0
2.0
1.0
SQUARE WAVE
TJ = 175°C
dc
2.0
3.0
4.0
5.0
6.0
7.0
8.0
9.0
Figure 14. Current Derating, Ambient, Per Leg
Figure 15. Power Dissipation, Per Leg
http://onsemi.com
5
10
r(t), TRANSIENT THERMAL RESISTANCE (NORMALIZED)
1.0
D = 0.5
0.5
0.2
0.1
0.1
0.05
ZqJC(t) = r(t) RqJC
P(pk)
0.05
D CURVES APPLY FOR POWER
PULSE TRAIN SHOWN
READ TIME AT T1
t1
0.01
t2
0.02
TJ(pk) - TC = P(pk) ZqJC(t)
DUTY CYCLE, D = t1/t2
SINGLE PULSE
0.01
0.01
0.02
0.05
0.1
0.2
0.5
1.0
2.0
5.0
10
100
200
500
1000
t, TIME (ms)
Figure 16. Thermal Response
1000
C, CAPACITANCE (pF)
MUR1620CT THRU 1660CT
MUR1605CT THRU 1615CT
300
TJ = 25°C
100
30
10
1.0
10
100
Figure 17. Typical Capacitance, Per Leg
Device
MUR1610CT
MUR1610CTG
MUR1615CT
MUR1615CTG
MUR1620CT
MUR1620CTG
MUR1640CT
MUR1640CTG
MUR1660CT
MUR1660CTG
Package
Shipping†
TO−220
TO−220
(Pb−Free)
TO−220
TO−220
(Pb−Free)
TO−220
TO−220
(Pb−Free)
50 Units / Rail
TO−220
TO−220
(Pb−Free)
TO−220
TO−220
(Pb−Free)
†For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specifications Brochure, BRD8011/D.
http://onsemi.com
6
PACKAGE DIMENSIONS
TO−220
CASE 221A−09
ISSUE AF
−T−
B
F
SEATING
PLANE
C
T
S
4
DIM
A
B
C
D
F
G
H
J
K
L
N
Q
R
S
T
U
V
Z
A
Q
U
1 2 3
H
K
Z
L
R
V
NOTES:
1. DIMENSIONING AND TOLERANCING PER ANSI
Y14.5M, 1982.
2. CONTROLLING DIMENSION: INCH.
3. DIMENSION Z DEFINES A ZONE WHERE ALL
BODY AND LEAD IRREGULARITIES ARE
ALLOWED.
J
G
D
N
INCHES
MIN
MAX
0.570
0.620
0.380
0.405
0.160
0.190
0.025
0.035
0.142
0.161
0.095
0.105
0.110
0.155
0.014
0.025
0.500
0.562
0.045
0.060
0.190
0.210
0.100
0.120
0.080
0.110
0.045
0.055
0.235
0.255
0.000
0.050
0.045
----0.080
MILLIMETERS
MIN
MAX
14.48
15.75
9.66
10.28
4.07
4.82
0.64
0.88
3.61
4.09
2.42
2.66
2.80
3.93
0.36
0.64
12.70
14.27
1.15
1.52
4.83
5.33
2.54
3.04
2.04
2.79
1.15
1.39
5.97
6.47
0.00
1.27
1.15
----2.04
SWITCHMODE is a trademark of Semiconductor Components Industries, LLC.
ON Semiconductor and
are registered trademarks of Semiconductor Components Industries, LLC (SCILLC). SCILLC reserves the right to make changes without further notice
to any products herein. SCILLC makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does SCILLC assume any liability
arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages.
“Typical” parameters which may be provided in SCILLC data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All
operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. SCILLC does not convey any license under its patent rights
nor the rights of others. SCILLC products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications
intended to support or sustain life, or for any other application in which the failure of the SCILLC product could create a situation where personal injury or death may occur. Should
Buyer purchase or use SCILLC products for any such unintended or unauthorized application, Buyer shall indemnify and hold SCILLC and its officers, employees, subsidiaries, affiliates,
and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death
associated with such unintended or unauthorized use, even if such claim alleges that SCILLC was negligent regarding the design or manufacture of the part. SCILLC is an Equal
Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner.
PUBLICATION ORDERING INFORMATION
LITERATURE FULFILLMENT:
Literature Distribution Center for ON Semiconductor
P.O. Box 5163, Denver, Colorado 80217 USA
Phone: 303−675−2175 or 800−344−3860 Toll Free USA/Canada
Fax: 303−675−2176 or 800−344−3867 Toll Free USA/Canada
Email: orderlit@onsemi.com
N. American Technical Support: 800−282−9855 Toll Free
USA/Canada
Europe, Middle East and Africa Technical Support:
Phone: 421 33 790 2910
Japan Customer Focus Center
Phone: 81−3−5773−3850
http://onsemi.com
7
ON Semiconductor Website: www.onsemi.com
Order Literature: http://www.onsemi.com/orderlit
For additional information, please contact your local
Sales Representative
MUR1620CT/D
