C2D10120D
C2D10120D
    WOLFSPEED
    TO247
    DIODE ARRAY SCHOTTKY 1200V TO247
C2D10120D 数据手册
C2D10120D VRRM = Silicon Carbide Schottky Diode Zero R ecovery® • • • • • • • IF (TC=135˚C) = 18 A** Rectifier Features 1200 V Qc = 56 nC** Package 1.2kV Schottky Rectifier Zero Reverse Recovery Current Zero Forward Recovery Voltage High-Frequency Operation Temperature-Independent Switching Behavior Extremely Fast Switching Positive Temperature Coefficient on VF TO-247-3 Benefits • • • • • Replace Bipolar with Unipolar Rectifiers Essentially No Switching Losses Higher Efficiency Reduction of Heat Sink Requirements Parallel Devices Without Thermal Runaway Applications • • • Switch Mode Power Supplies Power Factor Correction Motor Drives Part Number Package Marking C2D10120D TO-247-3 C2D10120 Maximum Ratings (TC=25°C unless otherwise specified) Symbol Parameter Test Conditions Repetitive Peak Reverse Voltage 1200 V VRSM Surge Peak Reverse Voltage 1200 V VDC DC Blocking Voltage 1200 V Continuous Forward Current (Per Leg/Device) 18/36 9/18 5/10 A TC=25˚C TC=135˚C TC=157˚C 30* A TC=25˚C, tP=10 ms, Half Sine Wave 100* A TC=25˚C, tP=10 µs, Pulse 138/276 60/120 W TC=25˚C TC=110˚C -55 to +175 ˚C 1 8.8 Nm lbfin IFRM Repetitive Peak Forward Surge Current IFSM Non-Repetitive Peak Forward Surge Current Ptot Power Dissipation (Per Leg/Device) TJ , Tstg Operating Junction and Storage Temperature TO-247 Mounting Torque 1 Unit VRRM IF * Value Per Leg, ** Per Device C2D10120D Rev. H M3 Screw 6-32 Screw Note Electrical Characteristics (Per Leg) Symbol Parameter Typ. Max. Unit Test Conditions VF Forward Voltage 1.6 2.6 1.8 3.0 V IR Reverse Current 50 100 200 1000 μA VR = 1200 V TJ=25°C VR = 1200 V TJ=175°C QC Total Capacitive Charge 28 nC VR = 1200 V, IF = 5 A di/dt = 500 A/μs TJ = 25°C C Total Capacitance 455 45 33 pF VR = 0 V, TJ = 25°C, f = 1 MHz VR = 200 V, TJ = 25˚C, f = 1 MHz VR = 400 V, TJ = 25˚C, f = 1 MHz Note IF = 5 A TJ=25°C IF = 5 A TJ=175°C Note: 1. This is a majority carrier diode, so there is no reverse recovery charge. Thermal Characteristics Symbol RθJC ** Parameter Thermal Resistance from Junction to Case Per Leg, * Typ. Unit 1.08** 0.54* °C/W Both Legs Typical Performance (Per Leg) 200 9 180 8 160 IR Reverse Current (μA) 10 IF Forward Current (A) 7 6 5 4 120 100 80 3 60 2 40 1 20 0 0 1.0 2.0 3.0 4.0 5.0 VF Forward Voltage (V) Figure 1. Forward Characteristics 2 140 C2D10120D Rev. H 0 0 500 1000 VR Reverse Voltage (V) Figure 2. Reverse Characteristics 1500 Typical Performance (Per Leg) 60.0 60 150 125 PTot (W) 40.0 40 Duty* Duty* Duty* Duty* Duty* Power Dissipation (W) 10% 20% 30% 50% 70% DC IF(PEAK) Peak Forward Current (A) Peak Forward Current 50 50.0 30.0 30 20 20.0 10 10.0 75 50 25 0 0.0 25 25 100 0 50 75 100 125 150 175 50 75 100 125 150 175 25 50 TC CaseCase Temperature Temperature(°C) 75 100 125 Tc Case Temperature (°C) TC ˚C * Frequency > 1KHz Figure 3. Current Derating Figure 4.Figure Capacitance 4. Power vs.Derating Reverse Voltage 400 350 300 C Capacitance (pF) Page 1 250 200 150 100 50 0 1 10 100 VR Reverse Voltage (V) Figure 5. Capacitance vs. Reverse Voltage 3 C2D10120D Rev. H 150 1000 175 Figure 6. Transient Thermal Impedance 4 C2D10120D Rev. H Package Dimensions Package TO-247-3 POS X Z W Inches Max Min Max A .605 .635 15.367 16.130 B .800 .831 20.320 21.10 C .780 .800 19.810 20.320 D .095 .133 2.413 3.380 E .046 .052 1.168 1.321 F .060 .095 1.524 2.410 G Y BB AA CC Millimeters Min .215 TYP 5.460 TYP H .175 .205 4.450 5.210 J .075 .085 1.910 2.160 K 6˚ 21˚ 6˚ 21˚ L 4˚ 6˚ 4˚ 6˚ M 2˚ 4˚ 2˚ 4˚ N 2˚ 4˚ 2˚ 4˚ P .090 .100 2.286 2.540 Q .020 .030 .508 .762 R 9˚ 11˚ 9˚ 11˚ S 9˚ 11˚ 9˚ 11˚ T 2˚ 8˚ 2˚ 8˚ U 2˚ 8˚ 2˚ 8˚ V .137 .144 3.487 3.658 W .210 .248 5.334 6.300 X .502 .557 12.751 14.150 Y .637 .695 16.180 17.653 Z .038 .052 0.964 1.321 AA .110 .140 2.794 3.556 BB .030 .046 0.766 1.168 CC .161 .176 4.100 4.472 Recommended Solder Pad Layout Part Number Package Marking C2D10120D TO-247-3 C2D10120 TO-247-3 Note: Recommended soldering profiles can be found in the applications note here: http://www.cree.com/power_app_notes/soldering 5 C2D10120D Rev. H Notes • RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product Documentation sections of www.cree.com. • REACh Compliance REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. • This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, air traffic control systems, or weapons systems. Copyright © 2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc. 6 C2D10120D Rev. H Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5451 www.cree.com/power
C2D10120D 价格&库存
很抱歉,暂时无法提供与“C2D10120D”相匹配的价格&库存,您可以联系我们找货
