SRAS20150 MNG
SRAS20150 MNG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-263(D²Pak)
    DIODE SCHOTTKY 150V 20A TO263AB
SRAS20150 MNG 数据手册
SRAS2020 – SRAS20150 Taiwan Semiconductor 20A, 20V - 150V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement Guard ring for overvoltage protection High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 20 A VRRM 20 - 150 V IFSM 330 A TJ MAX 150 °C 2 Package TO-263AB (D PAK) Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● 2 Case: TO-263AB (D PAK) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) 2 TO-263AB (D PAK) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SRAS 2020 SRAS 2020 SRAS 2030 SRAS 2030 SRAS 2040 SRAS 2040 SRAS 2050 SRAS 2050 SRAS 2060 SRAS 2060 SRAS 2090 SRAS 2090 SRAS 20100 SRAS 20100 VRRM 20 30 40 50 60 90 100 150 V VR(RMS) 14 21 28 35 42 63 70 105 V SYMBOL Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SRAS UNIT 20150 SRAS 20150 IF 20 A IFSM 330 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: M2103 SRAS2020 – SRAS20150 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 1.5 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) SRAS2020 SRAS2030 SRAS2040 SRAS2050 SRAS2060 SRAS2090 SRAS20100 SRAS20150 SRAS2020 SRAS2030 SRAS2040 SRAS2050 SRAS2060 SRAS2090 SRAS20100 SRAS20150 SRAS2020 SRAS2030 SRAS2040 SRAS2050 SRAS2060 SRAS2090 SRAS20100 SRAS20150 SRAS2020 SRAS2030 SRAS2040 SRAS2050 SRAS2060 SRAS2090 SRAS20100 SRAS20150 IF = 20A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.57 V - 0.70 V - 0.92 V - 1.02 V - 500 µA - 100 µA - 15 mA - 10 mA - - mA - - mA - 5 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) SRAS20x PACKAGE 2 TO-263AB (D PAK) PACKING 800 / Tape & Reel Notes: 1. “x” defines voltage from 20V(SRAS2020) to 150V(SRAS20150) 2 Version: M2103 SRAS2020 – SRAS20150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 20 CAPACITANCE (pF) 15 10 1000 5 0 f=1.0MHz Vsig=50mVp-p 100 25 50 75 100 125 150 0.1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) 0.1 TJ=75°C 0.01 TJ=25°C 0.001 30 40 50 60 70 80 90 100 100 10 SRAS2090 - 20100 10 1 SRAS2050 UF1DLW- 2060 SRAS2020 - 2040 TJ=125°C TJ=25°C 0.1 1 SRAS20150 0.01 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 360 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TJ=125°C 20 100 Fig.4 Typical Forward Characteristics 10 10 10 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 1 (A) AVERAGE FORWARD CURRENT (A) 25 330 8.3ms single half sine wave 300 270 240 210 180 150 120 90 60 30 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: M2103 1.2 SRAS2020 – SRAS20150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: M2103 SRAS2020 – SRAS20150 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS 2 TO-263AB (D PAK) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: M2103 SRAS2020 – SRAS20150 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: M2103
SRAS20150 MNG 价格&库存
很抱歉,暂时无法提供与“SRAS20150 MNG”相匹配的价格&库存,您可以联系我们找货
