SR4060PT C0G
SR4060PT C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO247
    DIODE ARRAY SCHOTTKY 60V TO247AD
SR4060PT C0G 数据手册
SR4020PT – SR40100PT Taiwan Semiconductor 40A, 20V - 100V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● ● PARAMETER VALUE UNIT IF 40 A VRRM 20 - 100 V IFSM 400 A TJ MAX 125, 150 °C Package TO-247AD (TO-3P) Configuration Dual dies Switching mode power supply (SMPS) Adapters Monitor DC to DC converters TV MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-247AD (TO-3P) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Mounting torque: 1.13 N⋅m maximum Polarity: As marked Weight: 6.10g (approximately) TO-247AD (TO-3P) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value SR SR SR SR SR SR SR SYMBOL 4020 4030 4040 4050 4060 4090 40100 UNIT PT PT PT PT PT PT PT SR SR SR SR SR SR SR 4020 4030 4040 4050 4060 4090 40100 PT PT PT PT PT PT PT VRRM 20 30 40 50 60 90 100 V VR(RMS) 14 21 28 35 42 63 70 V Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Junction temperature IF 40 A IFSM 400 A Storage temperature TSTG TJ -55 to +125 -55 to +150 -55 to +150 1 °C °C Version: H2103 SR4020PT – SR40100PT Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 1.2 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) Reverse current @ rated VR (2) per diode SR4020PT SR4030PT SR4040PT SR4050PT SR4060PT SR4090PT SR40100PT SR4020PT SR4030PT SR4040PT SR4050PT SR4060PT SR4090PT SR40100PT SR4020PT SR4030PT SR4040PT SR4050PT SR4060PT SR4090PT SR40100PT SR4020PT SR4030PT SR4040PT SR4050PT SR4060PT SR4090PT SR40100PT IF = 20A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.90 V - 1000 µA - 500 µA - 30 mA - 20 mA - - mA - - mA - 10 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SR40xPT TO-247AD (TO-3P) 30 / Tube SR40xPTH TO-247AD (TO-3P) 30 / Tube Notes: 1. “x” defines voltage from 20V(SR4020PT) to 100V(SR40100PT) 2. “H” means ACE-Q101 qualified 2 Version: H2103 SR4020PT – SR40100PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 SR4050PT-40100PT 40 SR4020PT-4040PT CAPACITANCE (pF) 30 SR4020PT-4040PT 20 1000 SR4050PT-40100PT 100 10 0 25 50 75 100 125 f=1.0MHz Vsig=50mVp-p 10 150 0.1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C 1 TJ=75°C 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 10 100 Fig.4 Typical Forward Characteristics 10 90 100 100010 SR4090PT-40100PT SR4050PT-4060PT UF1DLW 100 1 SR4020PT-4040PT TJ=125°C 10 0.1 1 0.01 TJ=25°C Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 0.3 0.4 0.5 0.6 0.7 0.8 0.9 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.0 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 500 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics 0.1 1 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 50 8.3ms single half sine wave 400 300 200 100 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: H2103 1.2 SR4020PT – SR40100PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: H2103 SR4020PT – SR40100PT Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-247AD (TO-3P) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: H2103 SR4020PT – SR40100PT Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: H2103
SR4060PT C0G 价格&库存
很抱歉,暂时无法提供与“SR4060PT C0G”相匹配的价格&库存,您可以联系我们找货
