SK515C V7G
SK515C V7G
    TAIWANSEMICONDUCTOR(台半)
    DO214AB
    DIODE SCHOTTKY 5A 150V DO-214AB
SK515C V7G 数据手册
SK52C – SK520C Taiwan Semiconductor 5A, 20V - 200V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement Guard ring for overvoltage protection High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 5 A VRRM 20 - 200 V IFSM 120 A TJ MAX 150 °C APPLICATIONS ● ● ● ● Package DO-214AB (SMC) Configuration Single die Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AB (SMC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.210g (approximately) DO-214AB (SMC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Critical rate of rise of off-state voltage Junction temperature Storage temperature SK SK SK SK SK SK SK SK SK UNIT 52C 53C 54C 55C 56C 59C 510C 515C 520C SK SK SK SK SK SK SK SK SK 52C 53C 54C 55C 56C 59C 510C 515C 520C VRRM 20 30 40 50 60 90 100 150 200 V VR(RMS) 14 21 28 35 42 63 70 105 140 V IF 5 A IFSM 120 A dV/dt 10,000 V/µs TJ - 55 to +150 °C TSTG - 55 to +150 °C 1 Version: Q2102 SK52C – SK520C Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 17 °C/W Junction-to-ambient thermal resistance RӨJA 50 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current (2) @ rated VR Reverse current (2) @ rated VR Reverse current (2) @ rated VR SK52C SK53C SK54C SK55C SK56C SK59C SK510C SK515C SK520C SK52C SK53C SK54C SK55C SK56C SK59C SK510C SK515C SK520C SK52C SK53C SK54C SK55C SK56C SK59C SK510C SK515C SK520C SK52C SK53C SK54C SK55C SK56C SK59C SK510C SK515C SK520C IF = 5A, TJ = 25°C TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.75 V - 0.85 V - 0.95 V - 0.5 mA - 0.3 mA - 20 mA - 10 mA - - mA - - mA - - mA - 5 mA IR TJ = 100°C IR TJ = 125°C IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING SK5xC DO-214AB (SMC) 3,000 / Tape & Reel Notes: 1. “x” defines voltage from 20V(SK52C) to 200V(SK520C) 2 Version: Q2102 SK52C – SK520C Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 SK52A - SK54A 5 SK55A - SK56A CAPACITANCE (pF) 4 3 2 100 SK59A - SK520A 1 f=1.0MHz Vsig=50mVp-p 0 25 50 75 100 125 10 150 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) SK52C-SK54C SK55C-SK520C TJ=125°C 10 1 TJ=75°C 0.1 TJ=25°C 0.01 0.001 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 1000 90 100 100 10 SK55C - SK56C 10 1 UF1DLW SK52C - SK54C TJ=125°C TJ=25°C SK515C - SK520C 0.1 1 SK59C - SK510C 0.01 0.1 0.001 0.1 0.3 0.5 0.7 0.3 0.4 0.5 0.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cyclePulse width 0.9 0.7 1.1 0.8 1.3 0.9 1.5 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 140 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics 100 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 6 120 8.3ms single half sine wave 100 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: Q2102 1.2 SK52C – SK520C Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 100 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: Q2102 SK52C – SK520C Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AB (SMC) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: Q2102 SK52C – SK520C Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: Q2102
SK515C V7G 价格&库存
很抱歉,暂时无法提供与“SK515C V7G”相匹配的价格&库存,您可以联系我们找货
SK515C V7G
  • 1+10.562941+1.26281
  • 10+7.0928610+0.84796
  • 100+4.94329100+0.59098
库存:761
SK515C V7G
  • 1+10.739511+1.28392
  • 10+7.2060710+0.86149
  • 100+5.02213100+0.60040
库存:761
