HS1DLW – HS1MLW
Taiwan Semiconductor
1A, 200V - 1000V High Efficient Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low profile package
Low power loss, high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
200 - 1000
V
IFSM
30
A
TJ MAX
175
°C
Package
SOD-123W
Configuration
Single die
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: SOD-123W
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.016g (approximately)
SOD-123W
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
HS1DLW HS1GLW HS1JLW HS1KLW HS1MLW UNIT
HDLW
HGLW
HJLW
HKLW
HMLW
Repetitive peak reverse voltage
VRRM
200
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
140
280
420
560
700
V
Forward current
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load
Junction temperature
IF
1
A
IFSM
30
A
TJ
- 55 to +175
°C
Storage temperature
TSTG
- 55 to +175
°C
1
Version: C2103
HS1DLW – HS1MLW
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
25
°C/W
Junction-to-ambient thermal resistance
RӨJA
80
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
HS1DLW
Forward voltage
(1)
Reverse current @ rated VR
(2)
HS1GLW
I = 1A, TJ = 25°C
HS1JLW F
HS1KLW
HS1MLW
TJ = 25°C
TJ = 125°C
VF
IR
TYP
MAX
UNIT
1.0
V
1.3
V
1.7
V
1
µA
150
µA
16
pF
7
pF
50
ns
75
ns
HS1DLW
HS1GLW
Junction capacitance
HS1JLW
1MHz, VR = 4.0V
CJ
HS1KLW
Reverse recovery time
HS1MLW
HS1DLW
HS1GLW
I = 0.5A, IR = 1.0A,
HS1JLW F
I = 0.25A
HS1KLW rr
HS1MLW
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
HS1xLW
SOD-123W
10,000 / Tape & Reel
Notes:
1. “x” defines voltage from 200V(HS1DLW) to 1000V(HS1MLW)
2
Version: C2103
HS1DLW – HS1MLW
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
HS1DLW - HS1JLW
CAPACITANCE (pF)
1
HS1KLW - HS1MLW
1
f=1.0MHz
Vsig=50mVp-p
0.1
25
55
85
115
145
175
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
1
TJ=25°C
0.01
10
40
50
60
70
80
90
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10 10
HS1MLW
UF1DLW
1
TJ=125°C
TJ=125°C
1
0.1
TJ=25°C
TJ=25°C
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.6 0.8 1.0 1.2 1.4 1.6 1.8
0.3
0.4
0.5
0.6
0.7
0.8
FORWARD VOLTAGE (V)
2.0
0.9
2.2
1
1.1
Fig.5 Maximum Non-Repetitive Forward Surge Current
40
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (uA)
Fig.4 Typical Forward Characteristics
100
0.1
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
AVERAGE FORWARD CURRENT (A)
2
8.3ms single half sine wave
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: C2103
1.2
HS1DLW – HS1MLW
PACKAGE OUTLINE DIMENSIONS
SOD-123W
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
YW
= Date Code
F
= Factory Code
Version: C2103
HS1DLW – HS1MLW
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: C2103
很抱歉,暂时无法提供与“HS1KLW RVG”相匹配的价格&库存,您可以联系我们找货
