S5GB – S5MB
Taiwan Semiconductor
5A, 400V - 1000V Standard Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low forward voltage drop
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
5
A
VRRM
400 - 1000
V
IFSM
200
A
TJ MAX
150
°C
Package
DO-214AA (SMB)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Monitor
TV
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.090g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
S5GB S5JB S5KB S5MB UNIT
S5GB
S5JB
S5KB S5MB
Repetitive peak reverse voltage
VRRM
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
280
420
560
700
V
Forward current
Surge peak forward current, 8.3ms single half
sine-wave superimposed on rated load
Surge peak forward current, 1.0ms single half
IF
TJ = 25°C
TJ = 125°C
TJ = 25°C
IFSM
TJ = 125°C
5
A
200
A
150
A
540
A
290
A
Junction temperature
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: D2102
S5GB – S5MB
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
47
°C/W
Junction-to-lead thermal resistance
RӨJL
13
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 5A, TJ = 25°C
(2)
Junction capacitance
TJ = 25°C
TJ = 125°C
1MHz, VR = 4.0V
SYMBOL
TYP
MAX
UNIT
VF
1.1
V
10
μA
250
μA
40
pF
IR
CJ
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
S5xB
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. "x" defines voltage from 400V(S5GB) to 1000V(S5MB)
2
Version: D2102
S5GB – S5MB
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
5
CAPACITANCE (pF)
4
3
2
10
1
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
150
1
10
100
LEAD TEMPERATURE(°C)
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
Fig.4 Typical Forward Characteristics
100
TJ=125°C
10
1
TJ=25°C
0.1
10
0.1
40
50
60
70
80
90
100
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
100
100 10
TJ=125°C
TJ=125°C
10
TJ=25°C
0.1
TJ=25°C
10.01
0.001
0.3
0.1
0.5
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
UF1DLW
1
(A)
AVERAGE FORWARD CURRENT (A)
6
0.6
0.4
0.7
0.5
0.8
0.6
0.9
0.7
1
Pulse width
Pulse Width=300μs
1% Duty Cycle
0.8
0.9
1
1.1
1.1
1.2
1.3
1.4
FORWARD VOLTAGE (V)
3
Version: D2102
1.2
S5GB – S5MB
Fig.5 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
240
8.3ms single half sine wave
200
160
120
80
40
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: D2102
S5GB – S5MB
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: D2102
S5GB – S5MB
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: D2102
很抱歉,暂时无法提供与“S5GBHM4G”相匹配的价格&库存,您可以联系我们找货
