TSS42U RGG
TSS42U RGG
    TAIWANSEMICONDUCTOR(台湾半导体)
TSS42U RGG 数据手册
TSS42U/TSS43U Taiwan Semiconductor Small Signal Product Surface Mount Schottky Barrier FEATURES - Designed for mounting on small surface - Extremely thin/leadless package - Low capacitance - Low forward voltage drop - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 0603 MECHANICAL DATA - Case: 0603 - Terminal: Gold plated, solderable per MIL-STD-750, method 2026 - Polarity : Indicated by cathode band - Weight : 0.003 g (approximately) - Marking code: TSS42U: BD TSS43U: BE MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER SYMBOL VALUE UNIT VRRM 30 V VR 30 V VR(RMS) 21 V IO 200 mA Repetitive Peak Forward Current IFRM 500 mA Non-Repetitive Peak Forward Surge Current Pulse Width = 8.3 ms (Single Half-Wave) IFSM 4.0 A Power Dissipation PD 150 mW Repetitive Peak Reverse Voltage Reverse Voltage RMS Reverse Voltage Average Forward Current Forward Voltage Reverse Leakage Current TSS42U/43U IF = 200 mA TSS42U IF = 10 mA 1.00 0.40 VF TSS42U IF = 50 mA TSS43U IF = 2 mA 0.33 TSS43U VR = 25 V IF = 15 mA 0.45 Typical Capacitance Between Terminals ( VR=1V, f=1.0MHz ) Reverse Recovery Time (Note 1) Thermal Resistance (Junction to Ambient) Operation Junction Temperature Range Storage Temperature Range 0.65 V IR 0.5 μA CJ 10 pF trr 5 ns RθJA 667 °C/W TJ -55 to +125 °C TSTG -55 to +125 °C Note 1: Test conditions : IF = IR = 10 mA, Irr = 0.1 × IR, RL = 100 Ω Version: D1601 TSS42U/TSS43U Taiwan Semiconductor RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) Fig.1 Forward Characteristics Fig. 2 Reverse Characteristics 1000 1000 125°C 100 100 Reverse Current (μA) Forward current (mA) 125°C 75°C 10 25°C 1 75°C 10 1 25°C 0.1 -25°C 0.1 Fig. 2 0.01 0 0.2 0.4 0.6 0.8 0 10 20 30 40 25oC Reverse Voltage (V) Forward Voltage (V) 75oC 16 120 Mounting on glass epoxy PCBs 14 f=1MHz Average Forward Current (%) Capacitance Between Terminals (pF) 125oC Fig. 4 Current Derating Curve Fig. 3 Capacitance Between Terminals Characteristics 12 10 8 6 4 2 100 80 Fig. 3 60 40 Fig. 4 20 0 0 0 5 10 15 20 25 Reverse Voltage (V) 30 35 0 25 50 75 100 125 150 Ambient Temperature (°C) Version: D1601 TSS42U/TSS43U Taiwan Semiconductor Small Signal Product ORDERING INFORMATION PART NO. PACKING CODE TSS4xU (Note 1, 2) RG PACKING CODE SUFFIX PACKAGE PACKING 0603 4K / 7" Reel G Note 1: "x" is Device Code from "2" - "3". Note 2: Whole series with green compound EXAMPLE EXAMPLE PART NO. TSS42U RGG PART NO. PACKING CODE TSS42U RG PACKING CODE DESCRIPTION SUFFIX G Green compound PACKAGE OUTLINE DIMENSION 0603 DIM. Unit (mm) Unit (inch) Min Typ. Max Min Typ. Max L 1.60 - 1.80 0.063 - 0.071 W 0.80 - 1.00 0.031 - 0.039 T 0.70 - 0.85 0.028 - 0.033 C - 0.45 - - 0.018 - D - 0.70 - - 0.028 - Version: D1601 TSS42U/TSS43U Taiwan Semiconductor Small Signal Product Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version: D1601
TSS42U RGG 价格&库存
很抱歉,暂时无法提供与“TSS42U RGG”相匹配的价格&库存,您可以联系我们找货
TSS42U RGG
  • 4000+0.722024000+0.09383
  • 12000+0.6186512000+0.08040
库存:22762
TSS42U RGG
  • 1+3.528521+0.45854
  • 10+2.1778810+0.28302
  • 50+1.5674850+0.20370
  • 100+1.36728100+0.17768
  • 500+1.01413500+0.13179
库存:22762
TSS42U RGG
  • 1+2.23258
  • 10+1.39065
  • 100+0.94554
  • 500+0.72802
  • 1000+0.65244
  • 2000+0.58525
  • 4000+0.52547
  • 8000+0.51661
TSS42U RGG
    TSS42U RGG
    • 1+2.393871+0.31109
    • 10+1.4912810+0.19380
    • 100+1.01390100+0.13176
    • 500+0.78086500+0.10148
    • 1000+0.699121000+0.09086
    • 2000+0.627822000+0.08159
    • 4000+0.563474000+0.07323
    • 8000+0.551308000+0.07165
