SK52C – SK520C
Taiwan Semiconductor
5A, 20V - 200V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for overvoltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
5
A
VRRM
20 - 200
V
IFSM
120
A
TJ MAX
150
°C
APPLICATIONS
Package
DO-214AB (SMC)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.210g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current,
8.3ms single half sine-wave
superimposed on rated load
Critical rate of rise of off-state
voltage
Junction temperature
Storage temperature
SK SK SK SK SK SK
SK
SK
SK
UNIT
52C 53C 54C 55C 56C 59C 510C 515C 520C
SK
SK
SK
SK
SK
SK
SK
SK
SK
VRRM
40
50
60
90
100
150
200
V
VR(RMS)
14
21
28
35
42
63
70
105
140
V
IF
5
A
IFSM
120
A
dV/dt
10,000
V/µs
TJ
- 55 to +150
°C
TSTG
- 55 to +150
°C
1
Version: Q2102
SK52C – SK520C
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
17
°C/W
Junction-to-ambient thermal resistance
RӨJA
50
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current
(2)
@ rated VR
Reverse current
(2)
@ rated VR
Reverse current
(2)
@ rated VR
SK52C
SK53C
SK54C
SK55C
SK56C
SK59C
SK510C
SK515C
SK520C
SK52C
SK53C
SK54C
SK55C
SK56C
SK59C
SK510C
SK515C
SK520C
SK52C
SK53C
SK54C
SK55C
SK56C
SK59C
SK510C
SK515C
SK520C
SK52C
SK53C
SK54C
SK55C
SK56C
SK59C
SK510C
SK515C
SK520C
IF = 5A, TJ = 25°C
TJ = 25°C
SYMBOL
VF
TYP
MAX
UNIT
0.55
V
0.75
V
0.85
V
0.95
V
0.5
mA
0.3
mA
mA
10
mA
mA
mA
mA
5
mA
IR
TJ = 100°C
IR
TJ = 125°C
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
SK5xC
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 20V(SK52C) to 200V(SK520C)
2
Version: Q2102
SK52C – SK520C
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
SK52A - SK54A
5
SK55A - SK56A
CAPACITANCE (pF)
4
3
2
100
SK59A - SK520A
1
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
10
150
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
SK52C-SK54C
SK55C-SK520C
TJ=125°C
10
1
TJ=75°C
0.1
TJ=25°C
0.01
0.001
10
40
50
60
70
80
100
Fig.4 Typical Forward Characteristics
1000
90
100
100 10
SK55C - SK56C
10
1
UF1DLW
SK52C
- SK54C
TJ=125°C
TJ=25°C
SK515C - SK520C
0.1
1
SK59C - SK510C
0.01
0.1
0.001
0.1
0.3
0.5
0.7
0.3
0.4
0.5
0.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cyclePulse width
0.9
0.7
1.1
0.8
1.3
0.9
1.5
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
140
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.3 Typical Reverse Characteristics
100
10
REVERSE VOLTAGE (V)
(A)
AVERAGE FORWARD CURRENT (A)
6
120
8.3ms single half sine wave
100
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: Q2102
1.2
SK52C – SK520C
Fig.6 Typical Transient Thermal Characteristics
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: Q2102
SK52C – SK520C
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: Q2102
SK52C – SK520C
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: Q2102
很抱歉,暂时无法提供与“SK510C V7G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+12.098621+1.50807
- 10+7.6297710+0.95104
- 100+5.06346100+0.63115
- 国内价格 香港价格
- 1+3.332181+0.41535
