A-GAGE MINI-ARRAY Two-Piece Measuring
Light Screen
Quick Start Guide
A-GAGE MINI-ARRAY Two-Piece Measuring Light Screen Configured for Vehicle Separation with 2 Discrete Outputs with EIA-485
Communication
This guide is designed to help you set up and install the A-GAGE MINI-ARRAY Two-Piece Measuring Light Screen. For complete
information on programming, performance, troubleshooting, dimensions, and accessories, please refer to the Instruction Manual at
www.bannerengineering.com. Search for p/n 117167 to view the Instruction Manual. Use of this document assumes familiarity with
pertinent industry standards and practices.
With Bracket Flanges “Out”
With Bracket Flanges “In”
L1
Y
L2
L3
75.1 mm
(2.95")
WARNING:
• Do not use this device for personnel protection
• Using this device for personnel protection could result in serious injury or death.
• This device does not include the self-checking redundant circuitry necessary to allow its use in
personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition.
Models
Sensor Scan Time 1
Distance Between Bracket Holes
Emitter/Receiver Models
Array Length (Y)
Housing Length
(L1)
L2
L3
Total
Beams
Interlaced
Scan 2
Straight
Scan
MAE616Q Emitter
MAR616NX485Q Receiver
143 mm (5.6 in)
231 mm (9.1 in)
262 mm (10.3 in)
205 mm (8.1 in)
8
1.4 ms
0.9 ms
MAE1216Q Emitter
MAR1216NX485Q Receiver
295 mm (11.62 in)
384 mm (15.1 in)
414 mm (16.3 in)
357 mm (14.1 in)
16
2.5 ms
1.5 ms
1 Worst-case response time is twice the scan time.
2 Scan time for Vehicle Separation scanning configuration.
Original Document
119169 Rev. F
27 August 2019
119169
Sensor Scan Time 1
Housing Length
(L1)
Array Length (Y)
L2
L3
Total
Beams
Interlaced
Scan 2
Straight
Scan
MAE1816Q Emitter
MAR1816NX485Q Receiver
448 mm (17.62 in)
536 mm (21.1 in)
567 mm (22.3 in)
510 mm (20.1 in)
24
3.6 ms
2.0 ms
MAE2416Q Emitter
MAR2416NX485Q Receiver
600 mm (23.62 in)
689 mm (27.1 in)
719 mm (28.3 in)
662 mm (26.1 in)
32
4.8 ms
2.6 ms
MAE3016Q Emitter
MAR3016NX485Q Receiver
752 mm (29.62 in)
841 mm (33.1 in)
871 mm (34.3 in)
815 mm (32.1 in)
40
5.9 ms
3.2 ms
MAE3616Q Emitter
MAR3616NX485Q Receiver
905 mm (35.62 in)
993 mm (39.1 in)
1024 mm (40.3 in)
967 mm (38.1 in)
48
7.0 ms
3.7 ms
MAE4216Q Emitter
MAR4216NX485Q Receiver
1057 mm (41.62 in)
1146 mm (45.1 in)
1176 mm (46.3 in) 1119 mm (44.1 in)
56
8.1 ms
4.3 ms
MAE4816Q Emitter
MAR4816NX485Q Receiver
1210 mm (47.62 in)
1298 mm (51.1 in)
1329 mm (52.3 in) 1272 mm (50.1 in)
64
9.2 ms
4.8 ms
MAE5416Q Emitter
MAR5416NX485Q Receiver
1362 mm (53.62 in)
1451 mm (57.1 in)
1481 mm (58.3 in) 1424 mm (56.1 in)
72
10.4 ms
5.4 ms
MAE6016Q Emitter
MAR6016NX485Q Receiver
1514 mm (59.62 in)
1603 mm (63.1 in)
1633 mm (64.3 in) 1577 mm (62.1 in)
80
11.5 ms
6.0 ms
MAE6616Q Emitter
MAR6616NX485Q Receiver
1667 mm (65.62 in)
1755 mm (69.1 in)
1786 mm (70.3 in) 1729 mm (68.1 in)
88
12.6 ms
6.5 ms
MAE7216Q Emitter
MAR7216NX485Q Receiver
1819 mm (71.62 in)
1908 mm (75.1 in)
1938 mm (76.3 in) 1881 mm (74.1 in)
96
13.7 ms
7.1 ms
Emitter and Receiver Wiring
Connect the emitter and receiver cables as shown.
Receiver Output 1: (OUT1) is an open-collector transistor switch rated at 30 V dc maximum, 150 mA maximum. It is protected
against overload and short circuits.
Receiver Alarm: (ALARM) is an open-collector transistor switch rated at 30 V dc maximum, 150 mA maximum. It is protected
Both outputs can be configured as NPN (current sinking) or PNP (current sourcing).
2
www.bannerengineering.com - Tel: + 1 888 373 6767
P/N 119169 Rev. F
16–30 V dc
16–30 V dc
DC Power
Supply
P.S. V +
P.S. V –
SYNC +
SYNC –
DC Power
Supply
bn
bu
bn
bu
pk
pk
wh
wh
P.S. V +
bn
bn
P.S. V–
P.S. V –
bu
bu
SYNC +
SYNC +
pk
pk
SYNC –
SYNC –
wh
wh
P.S. V+
OUT2/ALARM
EIA 485 +
EIA 485 –
SHIELD
gy
ye
rd
gn
ye
no
connection
Load 1
OUT1
rd
gn
Load 2
OUT2/ALARM
to external
EIA-485
device terminal
EIA 485 +
EIA 485 –
bare
SHIELD
SHIELD
Receiver
P.S. V–
SYNC +
SYNC –
gy
gy
OUT1
P.S. V+
Emitter
gy
Load 1
ye
no
connection
Load 2
rd
to external
EIA-485
device terminal
gn
bare
Receiver
Figure 1. NPN Wiring Diagram
ye
rd
gn
SHIELD
Emitter
Figure 2. PNP Wiring Diagram
Specifications
Supply Voltage and Power
16 V dc to 30 V dc; maximum power 12 watts
Sensor Scan Time
Supply Protection Circuitry
Protected against reverse polarity and transient voltages
Cable Connections
Emitter and receiver cables may not exceed 80 m (250 ft) each
150 mm (6.5 inch) PVC cable with M12/Euro-style quick disconnect
Quick disconnect cordsets available separately
Discrete Output Configuration
Two discrete outputs: Output 1 and Output 2
Outputs can be configured as either open collector NPN or PNP transistors.
For the vehicle separation application, the outputs are factory configured as
NPN outputs.
Discrete Output (either NPN or PNP) Ratings
Rated at 30 V dc max, 150 mA max load, short circuit protected
OFF-State Leakage Current: < 10 μA at 30 V dc
ON-State Saturation Voltage: < 1 V dc at 10 mA, < 1.5 V dc at 150 mA
Status Indicators
Emitter: Red LED lights for proper operation
Receiver: Green – sensors aligned (> 3x excess gain); Yellow – marginal
alignment (1x-3x excess gain); Red – sensors misaligned or beam(s) blocked
Environmental Rating
IEC IP65
UL Type 1 enclosure
Serial Data Outputs
EIA-485 interface
Baud rate 9600, 19.2 K, 38.4 K
8 data bits, 1 start bit, 1 stop bit, no parity
Construction
Aluminum housing with black anodized finish; acrylic lens cover
Controller Programming
Via EIA-485 to Banner Sensors GUI software
Operating Conditions
–40 °C to +70 °C (–40 °F to +158 °F)
95% maximum relative humidity (non-condensing)
Emitter/Receiver Range
Sensors < 1220 mm (4 ft) long: 16.5 m (55 ft)
Sensors ≥ 1220 mm (4 ft) long: 13.5 m (45 ft)
Application Notes
The emitter and receiver sync lines (pink and white wires) will be damaged if
connected to the power supply
The receiver EIA-485 interface (red and green wires) will be damaged if
Minimum Object Sensitivity
Interlaced Mode: 25.4 mm (1.0 in) 3, 4
Other Scan Modes: 38.1 mm (1.5 in)4
3
4
Certifications
Assumes sensing is in middle one-third of scanning range.
Requires minimum separation of emitter/receiver of 0.9 m (3 ft).
P/N 119169 Rev. F
3
Banner Engineering Corp. Limited Warranty
Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or
replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not
cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product.
THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF
MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE.
This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO
BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES
RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT,
STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE.
Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously
manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the
product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will
void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at
any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to:
For patent information, see www.bannerengineering.com/patents.
© Banner Engineering Corp. All rights reserved
很抱歉,暂时无法提供与“MAR7216NX485Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+18461.916831+2393.01592
