WTL16P-34161120A00
WTL16P-34161120A00
    SICK
    SENSOR PROXIMITY 500MM NPN/PNP
WTL16P-34161120A00 数据手册
Product data sheet WTL16P-34161120A00 W16 SMALL PHOTOELECTRIC SENSORS WTL16P-34161120A00 | W16 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WTL16P-34161120A00 1218945 Other models and accessories www.sick.com/W16 Illustration may differ Detailed technical data Features Device type Photoelectric sensors Sensor/ detection principle Photoelectric proximity sensor, Background suppression LineSpot technology Dimensions (W x H x D) 20 mm x 55.7 mm x 42 mm Housing design (light emission) Rectangular Sensing range max. 10 mm ... 500 mm 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) 3 mm x 30 mm (200 mm) Wave length 635 nm Adjustment Teach-Turn adjustment BluePilot: For setting the sensing range IO-Link For configuring the sensor parameters and Smart Task functions Indication LED blue BluePilot: sensing range indicator LED green Operating indicator 1) 2) 2  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-11-19 20:08:52 Subject to change without notice WTL16P-34161120A00 | W16 SMALL PHOTOELECTRIC SENSORS Static: power on Flashing: IO-Link mode LED yellow Status of received light beam Static on: object present Static off: object not present Pin 2 configuration External input, Teach-in, switching signal Special applications Detecting perforated objects Special features Line-shaped light spot 1) 2)  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple
WTL16P-34161120A00 价格&库存
很抱歉,暂时无法提供与“WTL16P-34161120A00”相匹配的价格&库存,您可以联系我们找货
