KTM-WP11181P
KTM-WP11181P
    SICK
    SEN CONTRAST PNP 12.5MM M8
KTM-WP11181P 数据手册
Product data sheet KTM-WP11181P KTM Prime CONTRAST SENSORS KTM-WP11181P | KTM Prime CONTRAST SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. KTM-WP11181P 1062199 Other models and accessories www.sick.com/KTM_Prime Illustration may differ Detailed technical data Features Dimensions (W x H x D) 12 mm x 31.5 mm x 21 mm Sensing distance 12.5 mm Sensing distance tolerance ± 3 mm Housing design (light emission) Small Light source LED, RGB 1) Wave length 470 nm, 525 nm, 625 nm Light emission Long side of housing Light spot size 1.5 mm x 6.5 mm Light spot direction Vertical 2) Receiving filters None Adjustment Teach-in button Teach-in mode 2-point teach-in static/dynamic + proximity to mark ET: Teach-in dynamic 1) 2)  Average service life: 100,000 h at TU = +25 °C.  In relation to long side of housing. Mechanics/electronics Supply voltage 12 V DC ... 24 V DC 1) Ripple ≤ 5 Vpp 2) 1) 2) 3) 4) 5) 6) 2  Limit values: DC 12 V (–10 %) ... DC 24 V (+20 %). Operation in short-circuit protected network max. 8 A.  May not exceed or fall below Uv tolerances.  Without load.  With light/dark ratio 1:1.  Signal transit time with resistive load.  Total current of all Outputs. REGISTRATION SENSORS | SICK Product data sheet | 2021-10-12 11:56:27 Subject to change without notice KTM-WP11181P | KTM Prime CONTRAST SENSORS Current consumption 3 < 30 s pressed. Example H I J K L M N O P Q R S T Release the teach-in button. Dark switching Yellow LED will illuminate, when emitted light is on the mark. Light switching Internal signal received Switching threshold Switching threshold Internal signal received Output Q Output Q Switching characteristics The optimum emitted light is selected automatically (at RGB variants). Static teach-in: light/dark setting is defined using teach-in sequence. Dynamic teach-in: switching output active on mark, if background is longer in the field of view during the teach-in. The switching threshold is set in the center between the background and the mark. If the button is pressed again within 10 s of the teach (> 20 ms < 10 s), the relative switching threshold is placed 75 % between mark (100 %) and background (0 %) (dotted line in Figure). Teach-in can also be performed using an external control signal. Keylock activation and deactivation: hold down teach-in button > 30 s. Teach-in failure: yellow LED indicator and the transmitted light of the sensor flashing quickly. For dynamic teach-in with ET signal (5 Hz) via switching output Q. 6 REGISTRATION SENSORS | SICK Product data sheet | 2021-10-12 11:56:27 Subject to change without notice KTM-WP11181P | KTM Prime CONTRAST SENSORS Setting the switching threshold (static) 1. Position mark 2. Position background Press and hold teach-in button > 1 < 3 s. Yellow LED flashes slowly. Press and hold teach-in button < 3 s. Yellow LED goes out. Sensing distance 110 100 90 80 70 Relative sensitivity in % 60 50 40 30 20 0 5 10 15 20 (0.20) (0.39) (0.59) (0.79) Sensing distance in mm (inch) Recommended accessories Other models and accessories www.sick.com/KTM_Prime Brief description Type Part no. BEF-W100-A 5311520 YF8U14050VA3XLEAX 2095889 Mounting brackets and plates Mounting bracket for wall mounting, stainless steel, mounting hardware included Plug connectors and cables Head A: female connector, M8, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m 2021-10-12 11:56:27 | Product data sheet  Subject to change without notice REGISTRATION SENSORS | SICK 7 KTM-WP11181P | KTM Prime CONTRAST SENSORS A B C D E F H I J K L M N O P Q R S T Brief description Head A: male connector, M8, 4-pin, straight Head B: Cable: unshielded 8 REGISTRATION SENSORS | SICK Type Part no. STE-0804-G 6037323 Product data sheet | 2021-10-12 11:56:27 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
KTM-WP11181P 价格&库存
很抱歉,暂时无法提供与“KTM-WP11181P”相匹配的价格&库存,您可以联系我们找货
