CP82C89
CP82C89
    L3HARRIS
    DIP20
    BUS ARBITER/CONTINUOUS SIGNAL GE
CP82C89 数据手册
82C89 Data Sheet September 4, 2015 CMOS Bus Arbiter Features The Intersil 82C89 Bus Arbiter is manufactured using a selfaligned silicon gate CMOS process (Scaled SAJI IV). This circuit, along with the 82C88 bus controller, provides full bus arbitration and control for multi-processor systems. The 82C89 is typically used in medium to large 80C86 or 80C88 systems where access to the bus by several processors must be coordinated. The 82C89 also provides high output current and capacitive drive to eliminate the need for additional bus buffering. • Pin Compatible with Bipolar 8289 Static CMOS circuit design insures low operating power. The advanced Intersil SAJI CMOS process results in performance equal to or greater than existing equivalent products at a significant power savings. Ordering Information PART NUMBER PART MARKING TEMP. RANGE (°C) PACKAGE PKG. DWG. # CP82C89 CP82C89 (No longer available or supported) 0 to +70 20 Ld PDIP E20.3 CP82C89Z* CP82C89Z (Note) (No longer available or supported) 0 to +70 20 Ld PDIP (Pb-free) E20.3 MD82C89/B MD82C89/B FN2980.3 • Performance Compatible with: - 80C86/80C88 . . . . . . . . . . . . . . . . . . . . . . . . . (5/8MHz) • Provides Multi-Master System Bus Control and Arbitration • Provides Simple Interface with 82C88/8288 Bus Controller • Synchronizes 80C86/8086, 80C88/8088 Processors with Multi-Master Bus • Bipolar Drive Capability • Four Operating Modes for Flexible System Configuration • Low Power Operation - ICCSB. . . . . . . . . . . . . . . . . . . . . . . . . . . . . .10A (Max) - ICCOP . . . . . . . . . . . . . . . . . . . . . . . . . 1mA/MHz (Max) • Operating Temperature Ranges - C82C89 . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to +70°C - M82C89 . . . . . . . . . . . . . . . . . . . . . . . . -55°C to +125°C • Pb-Free Plus Anneal Available (RoHS Compliant) Pinout 82C89 (PDIP, CERDIP) TOP VIEW -55 to +125 20 Ld CERDIP F20.3 NOTE: Intersil Pb-free plus anneal products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte tin plate termination finish, which are RoHS compliant and compatible with both SnPb and Pb-free soldering operations. Intersil Pb-free products are MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020. *Pb-free PDIPs can be used for through hole wave solder processing only. They are not intended for use in Reflow solder processing applications. 1 S2 1 20 VCC IOB 2 19 S1 SYSB/RESB 3 18 S0 RESB 4 17 CLK BCLK 5 16 LOCK INIT 6 15 CRQLCK BREQ 7 14 ANYRQST BPRO 8 13 AEN BPRN 9 12 CBRQ GND 10 11 BUSY CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 1-888-INTERSIL or 1-888-468-3774 | Intersil (and design) is a registered trademark of Intersil Americas LLC Copyright Intersil Americas LLC 1997, 2006, 2015. All Rights Reserved All other trademarks mentioned are the property of their respective owners. 82C89 Functional Diagram ARBITRATION S2 S1 80C86/ 80C88 STATUS S0 LOCK CLK CRQLCK RESB ANYRQST CONTROL/ STRAPPING OPTIONS STATUS MULTIBUS INTERFACE IOB CBRQ LOCAL BUS INTERFACE AEN SYSB/ RESB +5V MULTIBUS™ COMMAND SIGNALS BUSY DECODER CONTROL INIT BCLK BREQ BPRN BPRO GND SYSTEM SIGNALS MULTIBUS™ is an Intel Corp. trademark. Pin Description PIN SYMBOL NUMBER TYPE DESCRIPTION VCC 20 VCC: The +5V Power supply pin. A 0.1F capacitor between pins 10 and 20 is recommended for decoupling. GND 10 GROUND. S0, S1, S2 1, 18-19 I STATUS INPUT PINS: The status input pins from an 80C86, 80C88 or 8089 processor. The 82C89 decodes these pins to initiate bus request and surrender actions. (See Table 1). CLK 17 I CLOCK: From the 82C84A or 82C85 clock chip and serves to establish when bus arbiter actions are initiated. LOCK 16 I LOCK: A processor generated signal which when activated (low) prevents the arbiter from surrendering the multimaster system bus to any other bus arbiter, regardless of its priority. CRQLCK 15 I COMMON REQUEST LOCK: An active low signal which prevents the arbiter from surrendering the multi-master system bus to any other bus arbiter requesting the bus through the CBRQ input pin. RESB 4 I RESIDENT BUS: A strapping option to configure the arbiter to operate in systems having both a multi-master system bus and a Resident Bus. Strapped high, the multi-master system bus is requested or surrendered as a function of the SYSB/RESB input pin. Strapped low, the SYSB/RESB input is ignored. ANYRQST 14 I ANY REQUEST: A strapping option which permits the multi-master system bus to be surrendered to a lower priority arbiter as if it were an arbiter of higher priority (i.e., when a lower priority arbiter requests the use of the multi-master system bus, the bus is surrendered as soon as it is possible). When ANYRQST is strapped low, the bus is surrendered according to Table A in Design Information. If ANYRQST is strapped high and CBRQ is activated, the bus is surrendered at the end of the present bus cycle. Strapping CBRQ low and ANYRQST high forces the 82C89 arbiter to surrender the multi-master system bus after each transfer cycle. Note that when surrender occurs BREQ is driven false (high). IOB 2 I IO BUS: A strapping option which configures the 82C89 Arbiter to operate in systems having both an IO Bus (Peripheral Bus) and a multi-master system bus. The arbiter requests and surrenders the use of the multi-master system bus as a function of the status line, S2. The multi-master system bus is permitted to be surrendered while the processor is performing IO commands and is requested whenever the processor performs a memory command. Interrupt cycles are assumed as coming from the peripheral bus and are treated as an IO command. AEN 13 O ADDRESS ENABLE: The output of the 82C89 Arbiter to the processor’s address latches, to the 82C88 Bus Controller and 82C84A or 82C85 Clock Generator. AEN serves to instruct the Bus Controller and address latches when to three-state their output drivers. INIT 6 I INITIALIZE: An active low multi-master system bus input signal used to reset all the bus arbiters on the multimaster system bus. After initialization, no arbiters have the use of the multi-master system bus. 2 FN2980.3 September 4, 2015 82C89 Pin Description PIN SYMBOL (Continued) NUMBER TYPE DESCRIPTION SYSB/RESB 3 I SYSTEM BUS/RESIDENT BUS: An input signal when the arbiter is configured in the System/Resident Mode (RESB is strapped high) which determines when the multi-master system bus is requested and multi-master system bus surrendering is permitted. The signal is intended to originate from a form of address-mapping circuitry, such as a decoder or PROM attached to the resident address bus. Signal transitions and glitches are permitted on this pin from 1 of T4 to 1 of T2 of the processor cycle. During the period from 1 of T2 to 1 of T4, only clean transitions are permitted on this pin (no glitches). If a glitch occurs, the arbiter may capture or miss it, and the multi-master system bus may be requested or surrendered, depending upon the state of the glitch. The arbiter requests the multi-master system bus in the System/Resident Mode when the state of the SYSB/RESB pin is high and permits the bus to be surrendered when this pin is low. CBRQ 12 I/O COMMON BUS REQUEST: An input signal which instructs the arbiter if there are any other arbiters of lower priority requesting the use of the multi-master system bus. The CBRQ pins (open-drain output) of all the 82C89 Bus Arbiters which surrender to the multi-master system bus upon request are connected together. The Bus Arbiter running the current transfer cycle will not itself pull the CBRQ line low. Any other arbiter connected to the CDRQ line can request the multi-master system bus. The arbiter presently running the current transfer cycle drops its BREQ signal and surrenders the bus whenever the proper surrender conditions exist. Strapping CBRQ low and ANYRQST high allows the multi-master system bus to be surrendered after each transfer cycle. See the pin definition of ANYRQST. BCLK 5 I BUS CLOCK: The multi-master system bus clock to which all multi-master system bus interface signals are synchronized. BREQ 7 O BUS REQUEST: An active low output signal in the Parallel Priority Resolving Scheme which the arbiter activates to request the use of the multi-master system bus. BPRN 9 I BUS PRIORITY IN: The active low signal returned to the arbiter to instruct it that it may acquire the multi-master system bus on the next falling edge of BCLK. BPRN active indicates to the arbiter that it is the highest priority requesting arbiter presently on the bus. The loss of BPRN instructs the arbiter that it has lost priority to a higher priority arbiter. BPRO 8 O BUS PRIORITY OUT: An active low output signal used in the serial priority resolving scheme where BPRO is daisy-chained to BPRN of the next lower priority arbiter. BUSY 11 I/O BUSY: An active low open-drain multi-master system bus interface signal used to instruct all the arbiters on the bus when the multi-master system bus is available. When the multi-master system bus is available the highest requesting arbiter (determined by BPRN) seizes the bus and pulls BUSY low to keep other arbiters off of the bus. When the arbiter is done with the bus, it releases the BUSY signal, permitting it to go high and thereby allowing another arbiter to acquire the multi-master system bus. Functional Description The 82C89 Bus Arbiter operates in conjunction with the 82C88 Bus Controller to interface 80C86, 80C88 processors to a multi-master system bus (both the 80C86 and 80C88 are configured in their max mode). The processor is unaware of the arbiter’s existence and issues commands as though it has exclusive use of the system bus. If the processor does not have the use of the multi-master system bus, the arbiter prevents the Bus Controller (82C88), the data transceivers and the address latches from accessing the system bus (e.g. all bus driver outputs are forced into the high impedance state). Since the command sequence was not issued by the 82C88, the system bus will appear as “Not Ready” and the processor will enter wait states. The processor will remain in Wait until the Bus Arbiter acquires the use of the multi-master system bus whereupon the arbiter will allow the bus controller, the data transceivers, and the address latches to access the system. Typically, once the command has been issued and a data transfer has taken place, a transfer acknowledge (XACK) is returned to the processor to indicate “READY” from the 3 accessed slave device. The processor then completes its transfer cycle. Thus the arbiter serves to multiplex a processor (or bus master) onto a multi-master system bus and avoid contention problems between bus masters. Arbitration Between Bus Masters In general, higher priority masters obtain the bus when a lower priority master completes its present transfer cycle. Lower priority bus masters obtain the bus when a higher priority master is not accessing the system bus. A strapping option (ANYRQST) is provided to allow the arbiter to surrender the bus to a lower priority master as though it were a master of higher priority. If there are no other bus masters requesting the bus, the arbiter maintains the bus so long as its processor has not entered the HALT State. The arbiter will not voluntarily surrender the system bus and has to be forced off by another master’s bus request, the HALT State being the only exception. Additional strapping options permit other modes of operation wherein the multi-master system bus is surrendered or requested under different sets of conditions. FN2980.3 September 4, 2015 82C89 Priority Resolving Techniques Since there can be many bus masters on a multi-master system bus, some means of resolving priority between bus masters simultaneously requesting the bus must be provided. The 82C89 Bus Arbiter provides several resolving techniques. All the techniques are based on a priority concept that at a given time one bus master will have priority above all the rest. There are provisions for using parallel priority resolving techniques, serial priority resolving techniques, and rotating priority techniques. BCLK BREQ BPRN 1 2 4 3 BUSY FIGURE 2. HIGHER PRIORITY ARBITER OBTAINING THE BUS FROM A LOWER PRIORITY ARBITER NOTES: Parallel Priority Resolving 1. Higher priority bus arbiter releases BUSY. The parallel priority resolving technique uses a separate bus request line BREQ for each arbiter on the multi-master system bus, see Figure 1. Each BREQ line enters into a priority encoder which generates the binary address of the highest priority BREQ line which is active. The binary address is decoded by a decoder to select the corresponding BPRN (Bus Priority In) line to be returned to the highest priority requesting arbiter. The arbiter receiving priority (BPRN true) then allows its associated bus master onto the multi-master system bus as soon as it becomes available (i.e., the bus is no longer busy). When one bus arbiter gains priority over another arbiter it cannot immediately seize the bus, it must wait until the present bus transaction is complete. Upon completing its transaction the present bus occupant recognizes that it no longer has priority and surrenders the bus by releasing BUSY. BUSY is an active low “OR” tied signal line which goes to every bus arbiter on the system bus. When BUSY goes inactive (high), the arbiter which presently has bus priority (BPRN true) then seizes the bus and pulls BUSY low to keep other arbiters off of the bus. See waveform timing diagram, Figure 2. Note that all multimaster system bus transactions are synchronized to the bus clock (BCLK). This allows the parallel priority resolving circuitry or any other priority resolving scheme employed to settle. 2. Higher priority bus arbiter then acquires the bus and pulls BUSY down. Serial Priority Resolving The serial priority resolving technique eliminates the need for the priority encoder-decoder arrangement by daisychaining the bus arbiters together, connecting the higher priority bus arbiter’s BPRO (Bus Priority Out) output to the BPRN of the next lower priority. See Figure 3. BPRN BUS ARBITER 1 BPRN BUS ARBITER 3 74HC148 PRIORITY ENCODER • • • • BREQ BPRO BPRN BUS ARBITER 4 BPRO BPRN BREQ BUS BPRN ARBITER 2 BUS ARBITER 3 BPRO BPRN BUS ARBITER BPRO 2 BREQ   CBRQ 74HC138 3 TO 8 ENCODER   BUSY   FIGURE 3. SERIAL PRIORITY RESOLVING •• •• BUS ARBITER 1 3. Lower priority bus arbiter releases BUSY. 4. Higher priority bus arbiter then acquires the bus and pulls BUSY down. BPRN NOTE: The number of arbiters that may be daisy-chained together in the serial priority resolving scheme is a function of BCLK and the propagation delay from arbiter to arbiter. Normally, at 10MHz only 3 arbiters may be daisychained. BREQ • • • • CBRQ BUSY BUS ARBITER BPRN 4 Rotating Priority Resolving FIGURE 1. PARALLEL PRIORITY RESOLVING TECHNIQUE 4 The rotating priority resolving technique is similar to that of the parallel priority resolving technique except that priority is dynamically re-assigned. The priority encoder is replaced by a more complex circuit which rotates priority between requesting arbiters thus allowing each arbiter an equal chance to use the multi-master system bus, over time. FN2980.3 September 4, 2015 82C89 Which Priority Resolving Technique To Use There are advantages and disadvantages for each of the techniques described above. The rotating priority resolving technique requires substantial external logic to implement while the serial technique uses no external logic but can accommodate only a limited number of bus arbiters before the daisy-chain propagation delay exceeds the multimaster’s system bus clock (BCLK). The parallel priority resolving technique is in general a good compromise between the other two techniques. It allows for many arbiters to be present on the bus while not requiring too much logic to implement. 82C89 Modes Of Operation There are two types of processors for which the 82C89 will provide support: An Input/Output processor (i.e. an NMOS 8089 IOP) and the 80C86, 80C88. Consequently, there are two basic operating modes in the 82C89 bus arbiter. One, the IOB (I/O Peripheral Bus) mode, permits the processor access to both an I/O Peripheral Bus and a multi-master system bus. The second, the RESB (Resident Bus mode), permits the processor to communicate over both a Resident Bus and a multi-master system bus. An I/O Peripheral Bus is a bus where all devices on that bus, including memory, are treated as I/O devices and are addressed by I/O commands. All memory commands are directed to another bus, the multi-master system bus. A Resident Bus can issue both memory and I/O commands, but it is a distinct and separate bus from the multi-master system bus. The distinction is that the Resident Bus has only one master, providing full availability and being dedicated to that one master. 5 The IOB strapping option configures the 82C89 Bus Arbiter into the IOB mode and the strapping option RESB configures it into the RESB mode. It might be noted at this point that if both strapping options are strapped false, the arbiter interfaces the processor to a multi-master system bus only (see Figure 4). With both options strapped true, the arbiter interfaces the processor to a multi-master system bus, a Resident Bus, and an I/O Bus. In the IOB mode, the processor communicates and controls a host of peripherals over the Peripheral Bus. When the I/O Processor needs to communicate with system memory, it does so over the system memory bus. Figure 5 shows a possible I/O Processor system configuration. The 80C86 and 80C88 processors can communicate with a Resident Bus and a multi-master system bus. Two bus controllers and only one Bus Arbiter would be needed in such a configuration as shown in Figure 6. In such a system configuration the processor would have access to memory and peripherals of both busses. Memory mapping techniques are applied to select which bus is to be accessed. The SYSB/RESB input on the arbiter serves to instruct the arbiter as to whether or not the system bus is to be accessed. The signal connected to SYSB/RESB also enables or disables commands from one of the bus controllers. A summary of the modes that the 82C89 has, along with its response to its status lines inputs, is shown in Table 1. FN2980.3 September 4, 2015 82C89 X1 X2 RDY2 82C84A/85 CLOCK GENERATOR AEN2 READY RDY1 AEN1 CLK VCC XACK MULTI-MASTER SYSTEM BUS 82C89 BUS ARBITER MULTI-MASTER CONTROL BUS ANYRQST READY CLK CLK VCC IOB S0-S2 RESB AEN S0 AD0-AD15 S1 A16-A19 S2 STATUS (S0, S1, S2) AEN 82C88 BUS CONTROLLER CLK IOB ALE DEN DT/R MULTI-MASTER SYSTEM COMMAND BUS OE STB ADDRESS LATCH 82C82/ 82C83H (2 OR 3) PROCESSOR LOCAL BUS MULTI-MASTER SYSTEM ADDRESS BUS MULTI-MASTER SYSTEM BUS 80C86 CPU XCVR DISABLE OE DT/R TRANSCEIVER 82C86H/ 82C87H (2) MULTI-MASTER SYSTEM DATA BUS FIGURE 4. TYPICAL MEDIUM COMPLEXITY CPU SYSTEM 6 FN2980.3 September 4, 2015 82C89 AEN1 82C84A/85 CLOCK RDY1 RDY2 XACK(I/O BUS) XACK MULTI-MASTER SYSTEM BUS 82C89 BUS ARBITER READY CLK AEN2 CLK READY S0-S2 CLK 8089 IOP I/O BUS PROCESSOR LOCAL BUS OE STB ADDRESS LATCH 82C82/ 82C83H (2 OR 3) OE I/O DATA BUS STATUS (S0, S1, S2) ANYRQST AEN AEN 82C88 BUS CONTROLLER I/O COMMAND BUS I/O ADDRESS BUS VCC IOB RESB T TRANSCEIVER 82C86H/ 82C87H (2) CLK ALE IOB PDEN DEN DT/R OE STB ADDRESS LATCH 82C82/ 82C83H (2 OR 3) OE MULTI-MASTER SYSTEM COMMAND BUS VCC XCVR DISABLE MULTI-MASTER SYSTEM ADDRESS BUS MULTI-MASTER SYSTEM BUS AD0-AD15 S0 A16-A19 S2 MULTI-MASTER CONTROL BUS T TRANSCEIVER 82C86H/ 82C87H (2) MULTI-MASTER SYSTEM DATA BUS FIGURE 5. TYPICAL MEDIUM COMPLEXITY IOB SYSTEM 7 FN2980.3 September 4, 2015 82C89 AEN2 AEN1 82C84A/85 CLOCK XACK RESIDENT BUS XACK MULTI MASTER SYSTEM BUS RDY2 RDY1 READY CLK READY CLK STATUS S0-S2 80C86 CPU 82C89 S0 BUS S1 ARBITER S2 MULTI MASTER SYSTEM BUS CONTROL RESB IOB ANYRQST SYSB/ RESB AEN CLK AD0-AD15 A16-A19 CEN AEN RESIDENT BUS AEN S0-S2 82C88 CLK RESIDENT COMMAND BUS PROM OR DECODER OR CMOS HPL (NOTE) DT/R ALE DEN DEN ALE STB OE OE STB OE T TRANSCEIVER 82C86H/ 82C87H (2) RESIDENT DATA BUS MULTI MASTER SYSTEM COMMAND BUS DT/R ADDR LATCH 82C82/ 82C83H (2 OR 3) RESIDENT ADDRESS BUS S0-S2 82C88 CLK IOB ADDR LATCH 82C82/ 82C83H (2 OR 3) T MULTI MASTER SYSTEM BUS CEN VCC MULTI MASTER SYSTEM ADDRESS BUS OE TRANSCEIVER 82C86H/ 82C87H (2) MULTI MASTER SYSTEM DATA BUS FIGURE 6. 82C89 BUS ARBITER SHOWN IN SYSTEM - RESIDENT BUS CONFIGURATION NOTE: By adding another 82C89 arbiter and connecting its AEN to the 82C88 whose AEN is presently grounded, the processor could have access to two multi-master buses. 8 FN2980.3 September 4, 2015 82C89 TABLE 1. SUMMARY OF 82C89 MODES, REQUESTING AND RELINQUISHING THE MULTI-MASTER SYSTEM BUS SINGLE LINES FROM 80C86 OR 80C88 OR 8088 RESB MODE ONLY IOB = HIGH, RESB = HIGH IOB MODE RESB MODE IOB = LOW, RESB = HIGH S2 S1 S0 IOB MODE ONLY IOB = LOW RESB = LOW I/O Commands 0 0 0 0 0 1 0 1 0 X X X † † † X X X X X X X X X † † † Halt 0 1 1 X X X X X X Memory Commands 1 1 1 0 0 1 0 1 0† † † † † † † X X X † † † X X X † † † Idle 1 1 1 X X X X X X SYSB/RESB = HIGH SYSB/RESB = LOW SYSB/RESB = HIGH SYSB/RESB = LOW SINGLE BUS MODE IOB = HIGH RESB = LOW NOTES: 1. X = Multi-Master System Bus is allowed to be Surrendered. 2. † = Multi-Master System Bus is Requested. PIN STRAPPING MODE MULTI-MASTER SYSTEM BUS REQUESTED** SURRENDERED* Single Bus Multi-Master Mode IOB = High RESB = Whenever the processor’s status lines go Low active HLT + TI • CBRQ + HPBRQ ‡ RESB Mode Only IOB = High RESB = SYSB/RESB + High • High ACTIVE STATUS (SYSB/RESB = Low + TI) • CBRQ + HLT + HPBRQ IOB Mode Only IOB = Low RESB = Low Memory Commands (I/O Status + TI) • CBRQ + HLT + HPBRQ IOB Mode RESB Mode IOB = Low RESB = High (Memory Command) • (SYSB/RESB = High) (I/O Status Commands) + SYSB/RESB = Low) • CBRQ + HPBRQ + HLT NOTES: * LOCK prevents surrender of Bus to any other arbiter, CRQLCK prevents surrender of Bus to any lower priority arbiter. ** Except for HALT and Passive or IDLE Status. ‡ HPBRQ, Higher priority Bus request or BPRN = 1. 1. IOB Active Low. 2. RESB Active High. 3. + is read as “OR” and • as “AND” 4. TI = Processor Idle Status S2, S1, S0 = 111 5. HLT = Processor Halt Status S2, S1, S0 = 011 9 FN2980.3 September 4, 2015 82C89 Absolute Maximum Ratings Thermal Information Supply Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +8.0V Input, Output or I/O Voltage . . . . . . . . . . . . GND -0.5V to VCC +0.5V ESD Classification . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Class 1 Thermal Resistance (Note 1) JA (°C/W) JC (°C/W) CERDIP Package. . . . . . . . . . . . . . . . . 80 20 PDIP Package* . . . . . . . . . . . . . . . . . . 75 N/A Storage Temperature Range . . . . . . . . . . . . . . . . . .-65°C to +150°C Maximum Junction Temperature Ceramic Package. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +175°C Plastic Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +150°C Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . +300°C Operating Conditions Operating Voltage Range. . . . . . . . . . . . . . . . . . . . . . +4.5V to +5.5V Operating Temperature Range C82C89 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to +70°C M82C89 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-55°C to +125°C *Pb-free PDIPs can be used for through hole wave solder processing only. They are not intended for use in Reflow solder processing applications. Die Characteristics Gate Count . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .200 Gates CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 1. JA is measured with the component mounted on a high effective thermal conductivity test board in free air. See Tech Brief TB379 for details. DC Electrical Specifications VCC = 5.0V ± 10%; TA = 0°C to +70°C (C82C89); TA = -55°C to +125°C (M82C89) SYMBOL PARAMETER TEST CONDITIONS VIH Logical One Input Voltage C82C89, M82C89, Note 1 VIL Logical Zero Input Voltage Note 1 MIN MAX UNITS 2.0 2.2 - V V - 0.8 V VIHC CLK Logical One Input Voltage 0.7 VCC - V VILC CLK Logical Zero Input Voltage - 0.2 VCC V VOL Output Low Voltage BUSY, CBRQ IOL = 20mA - 0.45 V AEN IOL = 16mA - 0.45 V BPRO, BREQ IOL = 8mA - 0.45 V Open-Drain VOH1 Output High Voltage BUSY, CBRQ VOH2 Output High Voltage IOH = -2.5mA 3.0 - V All Other Outputs IOH = -100A VCC -0.4 - V II Input Leakage Current VIN = GND or VCC, DIP Pins 1-6, 9, 14-19 -1.0 1.0 A IO I/O Leakage VO = GND or VCC, DIP Pins 11-12 -10.0 10.0 A ICCSB Standby Power Supply VCC = 5.5V, VIN = VCC or GND, Outputs Open - 10 A ICCOP Operating Power Supply Current VCC = 5.5V, Outputs Open, Note 2 - 1 mA/MHz NOTES: 1. Does not apply to IOB, RESB, or ANYRQST. These are strap options and should be held to VCC or GND. 2. Maximum current defined by CLK or BCLK, whichever has the highest operating frequency Capacitance TA = +25°C SYMBOL CIN COUT CIO PARAMETER Input Capacitance Output Capacitance I/O Capacitance 10 TEST CONDITIONS FREQ = 1MHz, all measurements are referenced to device GND TYPICAL UNITS 10 pF 10 pF 15 pF FN2980.3 September 4, 2015 82C89 AC Electrical Specifications VCC = 5.0V 10%; GND = 0V: TA = 0°C to +70°C (C82C89); TA = -55°C to +125°C (M82C89) SYMBOL PARAMETER MIN MAX UNIT TEST CONDITIONS (1) TCLCL CLK Cycle Period 125 - ns Note 3 (2) TCLCH CLK Low Time 55 - ns Note 3 (3) TCHCL CLK High Time 35 - ns Note 3 (4) TSVCH Status Active Setup 65 TCLCL-10 ns Note 3 (5) TSHCL Status Inactive Setup 50 TCLCL-10 ns Note 3 (6) THVCH Status Inactive Hold 10 - ns Note 3 (7) THVCL Status Active Hold 10 - ns Note 3 (8) TBYSBL BUSY Setup to BCLK 20 - ns Note 3 (9) TCBSBL CBRQ Setup to BCLK 20 - ns Note 3 (10) TBLBL BCLK Cycle Time 100 - ns Note 3 (11) TBHCL BCLK High Time 30 0.65 (TBLBL) ns Note 3 (12) TCLLL1 LOCK Inactive Hold 10 - ns Note 3 (13) TCLLL2 LOCK Active Setup 40 - ns Note 3 (14) TPNBL BPRN to BCLK Setup Time 20 - ns Note 3 (15) TCLSR1 SYSB/RESB Setup 0 - ns Note 3 (16) TCLSR2 SYSB/RESB Hold 30 - ns Note 3 (17) TIVIH Initialization Pulse Width 675 - ns Note 3 (18) TBLBRL BCLK to BREQ Delay - 35 ns Note 3 (19) TBLPOH BCLK to BPRO - 35 ns Note 1 and 3 (20) TPNPO BPRN to BPRO Delay - 22 ns Note 1 and 3 (21) TBLBYL BCLK to BUSY Low - 60 ns Note 3 (22) TBLBYH BCLK to BUSY Float - 35 ns Note 2 and 3 (23) TCLAEH CLK to AEN High - 65 ns Note 3 (24) TBLAEL BCLK to AEN Low - 40 ns Note 3 (25) TBLCBL BCLK to CBRQ Low - 60 ns Note 3 (26) TBLCBH BCLK to CBRQ Float - 40 ns Note 2 and 3 (27) TOLOH Output Rise Time - 20 ns From 0.8V to 2.0V, Note 4 (28) TOHOL Output Fall Time - 12 ns From 2.0V to 0.8V, Note 4 (29) TILIH Input Rise Time - 20 ns From 0.8V to 2.0V (30) TIHIL Input Fall Time - 20 ns From 2.0V to 0.8V NOTES: 1. BCLK generates the first BPRO wherein subsequent BPRO changes lower in the chain are generated through BPRON. 2. Measured at 0.5V above GND. 3. All AC parameters tested as per AC test load circuits. Input rise and fall times are driven at 1ns/V. 4. Except BUSY and CBRQ. 11 FN2980.3 September 4, 2015 82C89 AC Test Load Circuits BUSY, CBRQ LOAD CIRCUIT AEN LOAD CIRCUIT 2.5V 2.9V 102 OUTPUT FROM DEVICE UNDER TEST 2.9V 249.6 157.2 OUTPUT FROM DEVICE UNDER TEST TEST POINT 100pF (NOTE) NOTE: BPRO, BREQ LOAD CIRCUIT OUTPUT FROM DEVICE UNDER TEST TEST POINT 100pF (NOTE) TEST POINT 100pF (NOTE) Includes Stray and Jig Capacitance AC Testing Input, Output Waveform INPUT OUTPUT VIH +0.4V VOH 1.5V 1.5V AC Testing: Inputs are driven at VIH +0.4V for a logic “1” and VIL -0.4V for a logic “0”. The clock is driven at VCC -0.4V and 0.4V. Timing measurements are made at 1.5V for both a logic “1” and “0”. VOL VIL -0.4V Burn-In Circuits MD82C89 CERDIP VCC R2 F7 F13 F14 F12 F0 VCC VCC/2 R2 R2 R2 R2 R1 R1 R1 R2 F8 C1 1 20 2 19 3 18 4 17 5 6 7 15 14 8 13 9 12 10 12 16 R2 R2 R2 F6 F5 F0 R2 R2 R2 F9 F10 F11 R1 R1 VCC/2 R1 11 FN2980.3 September 4, 2015 82C89 Die Characteristics DIE DIMENSIONS: GLASSIVATION: 92.9 x 95.7 x 19 1 mils Type: Nitrox Thickness: 10kÅ 2kÅ METALLIZATION: WORST CASE CURRENT DENSITY: Type: Si - Al Thickness: 11kÅ ±2kÅ 1.8 x 105 A/cm2 Metallization Mask Layout S0 S1 VCC S2 IOB SYSB/RESB 82C89 RESB CLK BCLK ANYRQST LOCK INIT CRQLCK ANYRQST 13 AEN CBRQ BUSY GND BPRN BPRO BREQ FN2980.3 September 4, 2015 82C89 Revision History The revision history provided is for informational purposes only and is believed to be accurate, but not warranted. Please go to the web to make sure that you have the latest revision. DATE REVISION September 4, 2015 FN2980.3 CHANGE - Ordering Information Table on page 1. - Added Revision History and About Intersil sections. About Intersil Intersil Corporation is a leading provider of innovative power management and precision analog solutions. The company's products address some of the largest markets within the industrial and infrastructure, mobile computing and high-end consumer markets. For the most updated datasheet, application notes, related documentation and related parts, please see the respective product information page found at www.intersil.com. You may report errors or suggestions for improving this datasheet by visiting www.intersil.com/ask. Reliability reports are also available from our website at www.intersil.com/support. All Intersil U.S. products are manufactured, assembled and tested utilizing ISO9001 quality systems. Intersil Corporation’s quality certifications can be viewed at www.intersil.com/design/quality Intersil products are sold by description only. Intersil Corporation reserves the right to make changes in circuit design, software and/or specifications at any time without notice. Accordingly, the reader is cautioned to verify that data sheets are current before placing orders. Information furnished by Intersil is believed to be accurate and reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries. For information regarding Intersil Corporation and its products, see www.intersil.com 14 FN2980.3 September 4, 2015
CP82C89 价格&库存
很抱歉,暂时无法提供与“CP82C89”相匹配的价格&库存,您可以联系我们找货
