IS31IO7326-QFLS4-TR
IS31IO7326-QFLS4-TR
    LUMISSIL
    WQFN24
    IC INTERFACE SPECIALIZED 24QFN
IS31IO7326-QFLS4-TR 数据手册
IS31IO7326 DEBOUNCED 8×8 KEY-SCAN CONTROLLER January 2012 GENERAL DESCRIPTION FEATURES The IS31IO7326 is a 64 key, key-scan controller. It offloads the burden of keyboard scanning from the host processor. The IS31IO7326 supports keypad matrix of up to 8×8. Key press and release events are encoded into a byte format and loaded into a key event register for retrieval by the host processor.       The IS31IO7326 integrates a debounce function which rejects false or transient key switch activities. The _______ interrupt output (INT) is used to signify if there are any keypad activities. To minimize power, the IS31IO7326 automatically enters a low power standby mode when there is no keypad, I/O, or host activity. 2.4V to 5.5V operation 400kHz I2C serial interface Available for multi-key press detect Low 0.3μA (typ.) standby current Operate in -40°C to +125°C Pb-free 4mm × 4mm QFN-24 package APPLICATIONS   Keypad of QWERTY type phones PDAs, games, and other handheld applications The IS31IO7326 is available in a Pb-free 4mm × 4mm QFN-24 package. TYPICAL APPLICATION CIRCUIT VBattery 100k VBattery 21 PP0 VCC PP1 1 F 0.1 F PP2 PP3 VDD 4.7k 4.7k PP4 4.7k PP5 19 20 Micro Controller 22 23 PP6 SCL SDA IS31IO7326 OD0 RST OD1 OD3 9 AD0 AD1 GND Figure 1 Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 3 4 14 15 16 17 5 INT OD2 24 2 PP7 100k 18 1 OD4 OD5 OD6 OD7 6 7 8 10 11 12 13 Typical Application Circuit 1 IS31IO7326 PIN CONFIGURATION Package Pin Configuration (Top View) QFN-24 PIN DESCRIPTION No. Pin 1~4, 14~17 PP0~PP7 Output ports. 5~8, 10~13 OD0~OD7 Input ports. 9 GND Ground. 18 AD0 Address setting. 19 SCL I2C serial clock. 20 SDA I2C serial data. 21 VCC Power supply voltage. 22 _______ INT Interrupt output, active low. 23 ________ Reset input, active low. 24 Description RST AD1 Address setting. Thermal Pad Connect to GND. Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 2 IS31IO7326 ORDERING INFORMATION Industrial Range: -40°C to +125°C Order Part No. Package QTY/Reel IS31IO7326-QFLS4-TR QFN-24, Lead-free 2500 Copyright  ©  2011  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in  such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 3 IS31IO7326 ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at any input pin (Except PP0-PP7) ________ -0.3V ~ +6.0V -0.3V ~ VCC+0.3V -0.3V ~ +6.0V -0.3V ~ VCC+0.3V ±100mA 120mA 10mA 10mA _______ SCL, SDA, AD, RST, INT, OD0-OD3 PP0–PP3 PP source output current PP/OD sink current SDA sink current _______ INT sink current Continuous power dissipation (TA = 70°C) 24-Pin QFN (Derate 33.2mW/°C over 70°C) Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA Solder information, vapor phase (60s) infrared (15s) ESD HBM 2.65W +150°C -65°C ~ +150°C -40°C ~ +125°C 215°C 220°C ±4kV Note: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS TA= -40°C ~ +125°C, VCC = 2.4V ~ 5.5V, unless otherwise noted. Typical values are at TA = 25°C, VCC = 3.3V. (Note 1) Symbol Parameter Condition Min. VCC Supply voltage VPOR Power-on-reset voltage VCC falling Standby current (Interface idle) Supply current (Interface running) SCL,SDA and other digital inputs at VCC fSCL = 400kHz other digital inputs at VCC ISTB I+ Typ. Max. Units 5.5 V 2.35 V 0.3 1.9 μA 6.5 25 μA 2.4 VIH Logic “1” input voltage VIL Logic “0” input voltage 1.4 V 0.4 V +0.2 μA ________ IIH, IIL SDA, SCL, AD0, AD1, RST , OD0~OD7 at VCC or GND Input leakage current -0.2 Input capacitance CIN VOL ________ SDA, SCL, AD0, AD1, RST, OD0~OD7, PP0~PP7 Logic “0” output voltage PP0~PP7 _______ (Note 2) 10 VCC = 2.5V, ISINK = 10mA 200 VCC = 3.3V, ISINK = 15mA 240 VCC = 5.0V, ISINK = 20mA 250 180 VOLINT Output low-voltage INT ISINK = 5mA tSCAN Time to scan key matrix completely Configuration Register bit SD = 0 16 Configuration Register bit SD = 1 9 _______ pF Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 mV mV ms 4 IS31IO7326 TIMING CHARACTERISTICS TA = -40°C ~ +125°C, VCC = 2.4V ~ 5.5V, unless otherwise noted. Typical values are at TA = 25°C, VCC = 3.3V. (Note 3) Symbol Parameter Condition Min. Typ. Max. Units 400 kHz fSCL Serial-clock frequency tBUF Bus free time between a STOP and a START condition 1.3 μs tHD, STA Hold time (repeated) START condition 0.6 μs tSU, STA Repeated START condition setup time 0.6 μs tSU, STO STOP condition setup time 0.6 μs tHD, DAT Data hold time tSU, DAT Data setup time 100 ns tLOW SCL clock low period 1.3 μs tHIGH SCL clock high period Rise time of both SDA and SCL signals, receiving Fall time of both SDA and SCL signals, receiving 0.7 μs tR tF tF, TX tSP 0.9 (Note 3) μs (Note 4) 20 + 0.1Cb 300 ns (Note 4) 20 + 0.1Cb 300 ns Fall time of SDA transmitting (Note 4) 20 + 0.1Cb 250 ns Pulse width of spike suppressed (Note 5) 50 Cb Capacitive load for each bus line tW ________ ns 400 RST pulse width pF 500 ns 1 μs ________ ________ tRST RST rising to START condition setup time PORT AND INTERRUPT TIMING CHARACTERISTICS T = -40°C ~ +125°C, VCC = 2.4V ~ 5.5V, unless otherwise noted. Typical values are at TA = 25°C, VCC = 3.3V (Note 3) Symbol Parameter Condition Min. Typ. Max. Untis 4 μs tPV Port output data valid CL≤ 100pF tPSU Port input setup time CL≤ 100pF 0 μs tPH Port input hold time CL≤ 100pF 4 μs tIV _______ INT input data valid time CL≤ 100pF 4 μs tIR _______ CL≤ 100pF 4 μs INT reset delay time from acknowledge Note 1: All parameters are tested at TA = 25°C. Specifications over temperature are guaranteed by design. Note 2: Guaranteed by design. Note 3: A master device must provide a hold time of at least 300ns for the SDA signal (referred to VIL of the SCL signal) in order to bridge the undefined region of SCL’s falling edge. Note 4: Cb = total capacitance of one bus line in pF. ISINK ≤ 6mA. tR and tF measured between 0.3 × VCC and 0.7× VCC. Note 5: Input filters on the SDA and SCL inputs suppress noise spikes less than 50ns. Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 5 IS31IO7326 DETAILED DESCRIPTION I2C INTERFACE The IS31IO7326 uses a serial bus, which conforms to the I2C protocol, to control the chip’s functions with two wires: SCL and SDA. The IS31IO7326 has a 7-bit slave ____ address (A7:A1), followed by the R/W bit, A0. Set A0 to “0” for a write command and set A0 to “1” for a read command. The bit A2:A1 are selected by the connection of AD1/AD0 pin. The complete slave address is: Table 1 Slave Address: Bit A7:A3 A2 A1 A0 Default 10110 AD1 AD0 0/1 The SCL line is uni-directional. The SDA line is bi-directional (open-collector) with a pull-up resistor (typically 4.7kΩ). The maximum clock frequency specified by the I2C standard is 400kHz. In this discussion, the master is the microcontroller and the slave is the IS31IO7326. The timing diagram for the I2C is shown in Figure 3. The SDA is latched in on the stable high level of the SCL. When there is no interface activity, the SDA line should be held high. The “START” signal is generated by lowering the SDA signal while the SCL signal is high (Figure 4). The start signal will alert all devices attached to the I2C bus to check the incoming address against their own chip address. The 8-bit chip address is sent next, most significant bit first. Each address bit must be stable while the SCL level is high. Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 Following acknowledge of IS31IO7326, the register address byte is sent, most significant bit first. IS31IO7326 must generate another acknowledge indicating that the register address has been received. An 8-bit data byte is sent next, most significant bit first. Each data bit should be valid while the SCL level is stable high. After the data byte is sent, the IS31IO7326 must generate another acknowledge to indicate that the data was received. AD1/AD0 connects to VCC, AD1/AD0=1; AD1/AD0 connects to GND, AD1/AD0=0; Figure 2 After the last bit of the chip address is sent, the master checks for the IS31IO7326’s acknowledge. The master releases the SDA line high (through a pull-up resistor). Then the master sends an SCL pulse. If the IS31IO7326 has received the address correctly, then it holds the SDA line low during the SCL pulse. If the SDA line is not low, then the master should send a “STOP” signal (discussed later) and abort the transfer. The “STOP” signal ends the transfer. To signal “STOP”, the SDA signal goes high while the SCL signal is high (Figure 4). WRITING TO THE REGISTERS Transmit data to the IS31IO7326 by sending the device slave address and setting the LSB to “0”. The command byte is sent after the address and determines which registers receive the data following the command byte (Figure 2). READING PORT REGISTERS To read the device data, the bus master must first send ____ the IS31IO7326 address with the R/W bit set to “0”, followed by the command byte, which determines which register is accessed. After a restart, the bus master must then send the IS31IO7326 address with ____ the R/W bit set to “1”. Data from the register defined by the command byte is then sent from the IS31IO7326 to the master (Figure 6). Writing to IS31IO7326 6 IS31IO7326 SDA tSU ,D A T SCL S t LO W tSU ,STA t H D,DA T tH D,STA tH IGH tSU,STO t BU F P R tH D,STA tR tF Stop Condition Restart Condition Start Condition Interface Timing Figure 3 START and STOP Conditions Figure 4 Figure 5 Figure 6 Start Condition Acknowledge Signal Reading I/O Ports of IS31IO7326 KEY PRESS/RELEASE KEY PRESS/RELEASE INT 16ms (6ms/8ms) 9ms (3ms/4ms) _______ Figure 7 Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 I N T Timing 7 IS31IO7326 REGISTER DEFINITION Table 2 Register Function Address Name Function Default Table 08h Configuration Register 0001 0000 3 10h Key Status Register Configure the keypad scan function Contains the information of the key events 0000 0000 4 Table 4 10h Key Status Register Table 3 08h Configuration Register Bit D7 D6:D5 D4 D3 D2 D1:D0 Bit D7 D6 D5:D0 Name Reserved ACI DE SD LE LT Name DN KS KM Default 0 00 1 0 0 00 Default 0 0 000000 The Configuration Register is used to configure the keypad scan function. The Key Status Register contains the information of the key events that have been debounced (see the Table 5 of the key mapping). _______ ACI Auto Clear INT 00 Auto clear INT disabled 01 Auto clear INT in 5ms 10 Auto clear INT in 10ms DE 0 1 Input Port Filter Enable Input port filter disable Input port filter enable SD 0 1 Key Scan Debounce Time Double debounce time (6ms, 8ms) Normal debounce time (3ms, 4ms) LE 0 1 Long-pressed Key Detect Enable Disable Enable LT 00 01 10 11 Long-pressed Key Detect Delay Time 20ms 40ms 1s 2s _______ _______ DN 0 1 Indicate Data Number One key event to report More than one key to report KS 0 1 Key State Key released Key pressed KM Key Mapping _______ Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 KM denotes which of the 64 keys have been debounced and the keys are numbered as shown in the Table 5. When the Key Status Register is read over (DN=0), the _______ register is set to “0000 0000”, and the INT is cleared. 8 IS31IO7326 Table 5 Key Mapping (D5:D0) PP0 PP1 PP2 PP3 PP4 PP5 PP6 PP7 OD0 000000 000001 000010 000011 000100 000101 000110 000111 OD1 001000 001001 001010 001011 001100 001101 001110 001111 OD2 010000 010001 010010 010011 010100 010101 010110 010111 OD3 011000 011001 011010 011011 011100 011101 011110 011111 OD4 100000 100001 100010 100011 100100 100101 100110 100111 OD5 101000 101001 101010 101011 101100 101101 101110 101111 OD6 110000 110001 110010 110011 110100 110101 110110 110111 OD7 111000 111001 111010 111011 111100 111101 111110 111111 Examples _______ 1. If the key PP1-OD3 pressed only, and other keys keep released state, the INT asserts, the data in Key Status Register would be “0101 1001”; _______ 2. If the key PP4-OD6 released only, and other keys keep released state, the INT asserts, the data in Key Status Register would be “0011 0100”; _______ 3. If the key PP2-OD4 and PP3-OD7 are pressing, then PP2-OD4 released, the INT asserts, the first data in Key Status Register would be “1010 0010”, the second data would be “0111 1011”. Then judge the MSB (bit DN) in _______ the second data is “0”. Data has read over, and INT goes to high. _______ We must read over the data in Key Status Register when the I N T asserts. When judge the MSB (bit DN) in the data is “0”, stop reading the Key Status Register. If there are some keys connected to the same OD port pressing at the same time, IS31IO7326 only can detect the first pressed key and others will ignore. Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 9 IS31IO7326 APPLICATION INFORMATION INPUT AND OUTPUT PORT STRUCTURE A 100kΩ pull-up resistor will force input port high at VBattery. If a change of the state of the keypad is detected, the keypad would be scanned thrice between the debounce delay. When the state changes have been reliably captured, the key event(s) are encoded and V+ written to temporary key status registers. The INT asserts when the key event(s) is (are) stored. Reading the Key Status Register reports the key events in the order of lowest encoding value to the highest (see Output _______ PP0~PP7 Dirver _______ Table 5). The INT will remain low until all of the key events are read, with one exception: When the _______ Auto-Clear INT is enabled, if all of the key event data _______ GND Figure 8 Output Port Structure is not read before the programmed time, the INT will return high after the programmed time. However the temporary key status registers will remain unchanged and the key event data may continue to be read until another key event is detected. DEBOUNCE When the bit SD of the Configuration Register (08h) is set to “0” and there is a change of the state of the keypad, the keypad scans first and stores the data in temporary registers, then waits for about 6ms (3ms) and scans again, then waits for another 8ms (4ms) and scans a final time. If the results are the same, the data is latched into the temporary key status registers and _______ Figure 9 Input Port Structure the INT asserted. Otherwise, the scan is halted and the device returns to standby mode. No data is latched _______ POWER-ON RESET The IS31IO7326 contains an integral power-on-reset circuit that ensures all registers are reset to a known state on power-up. When VCC rises above 2.4V, the circuit releases the registers and the I2C interface for normal operation. When VCC drops to less than VPOR, the IS31IO7326 resets all register contents to the default value. ________ RST I2C RESET CONTROL ________ The active-low RST input voids any I2C transaction involving the IS31IO7326, forcing the IS31IO7326 into the I2C STOP condition. A reset does not affect the interrupt output. into the temporary key status registers and the INTis not asserted. LONG-PRESSED KEY DETECT When the bit LE of the Configuration Register (08h) is set to “0”, this function is disabled. When LE is set to “1”, this function is enabled. When a key is pressed for a long period of time, the chip automatically scans _______ again after the INT is deasserted. When the key is still _______ pressed, the INT asserts again and the key event is latched into the temporary key status registers. The scanning continues until all of the keys are released. _______ The delay time between the INT deasserting to the next scan beginning is set by the Configuration Register (08h) bits LT. _______ STANDBY MODE KEY EVENT INTERRUPT (INT) When the serial interface is idle, the IS31IO7326 automatically enters standby mode, drawing minimal supply current. Once there is key event code latched in the temporary key status registers, the device produces an interrupt KEYPAD AUTO SCAN _______ _______ signal to the MCU on the INT pin. When the INT is asserted, any keypad state changes are ignored. The _______ The IS31IO7326 can support an 8×8 matrix keypad scan. The 8 input ports (OD ports) need a 100kΩ pull-up resistor for each column, the 8 output ports (PP ports) for the rows pull low in standby mode. Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 INT will remain low until all of the key events are read, _______ with one exception: When the Auto-Clear INT is enabled, if all of the key event data is not read before _______ the programmed time, the INT will return high after 10 IS31IO7326 the programmed time. However the temporary key status registers will remain unchanged and the key event data may continue to be read until another key event is detected. After all of the key events have been read, the device returns to standby mode waiting for the next scan. _______ AUTO-CLEAR INT FUNCTION When the ACI bits of the Configuration Register (08h) are set to “01” or “10”, this function is enabled. Setting the ACI bits to “00” disables the function. When THE INPUT PORT FILTER The bit DE of the Configuration Register (08h) is used to enable the input port filter. When DE is set to “0”, the input port filter is disabled, and the chip responds to any changes at the input port. When DE is set to “1”, the input port filter is enabled and any glitch shorter than 100ns is filtered. If the input pulse width is greater than 100ns, the chip responds (Figure 10). _______ enabled, the INT would be cleared in 5ms or 10ms after it asserts if there is no read of the Key Status Register. The data in the temporary key status _______ registers does not change when the INT goes low. The Key Status Register can be read regardless of whether _______ _______ the INT is high or not. However, when the INT is cleared and there is new key event activity before the old key event data is read, the temporary key status _______ registers are rewritten and the INT asserts again. In this case, the previous key event data is lost and only the new key event(s) can be read. Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 Figure 10 Input port debounce function 11 IS31IO7326 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 11 Classification profile Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 12 IS31IO7326 TAPE AND REEL INFORMATION Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 13 IS31IO7326 PACKAGE INFORMATION QFN-24 Note: All dimensions in millimeters unless otherwise stated. Lumissil Microsystems – www.lumissil.com Rev. A, 12/19/2011 14
IS31IO7326-QFLS4-TR 价格&库存
很抱歉,暂时无法提供与“IS31IO7326-QFLS4-TR”相匹配的价格&库存,您可以联系我们找货
IS31IO7326-QFLS4-TR
  • 2500+6.483712500+0.81137
库存:1246
IS31IO7326-QFLS4-TR
  • 1+13.164961+1.64746
  • 10+9.5817610+1.19906
  • 25+8.6863325+1.08701
  • 100+7.70915100+0.96472
  • 250+7.24162250+0.90622
  • 500+6.96006500+0.87098
  • 1000+6.728371000+0.84199
库存:1246
