NCT5917W TR
NCT5917W TR
    NUVOTON(新唐)
    TSSOP8
    NCT5917W I2C/SMBUS 电平转换器
NCT5917W TR 数据手册
NCT5917W Nuvoton Level translating I2C-bus/SMBus Repeater Date: Oct./08/2012 Revision: 1.0 NCT5917W NCT5917W Datasheet Revision History PAGES DATES VERSION MAIN CONTENTS 1 2012/01/17 0.1 Draft version. 2 2012/05/15 0.5 Preliminary version. 1.0 Public release 3 2012/10/08 -I- Release Date: Oct., 2012 Version: 1.0 NCT5917W Table of Content1. GENERAL DESCRIPTION ......................................................................................................... 1 2. FEATURES ................................................................................................................................. 1 3. BLOCK DIAGRAM ...................................................................................................................... 2 4. PIN CONFIGURATION ............................................................................................................... 2 4.1 5. FUNCTIONAL DESCRIPTION.................................................................................................... 4 5.1 6. Pin Description.............................................................................................................................3 Enable Pin....................................................................................................................................7 ELECTRICAL CHARACTERISTICS ........................................................................................... 8 6.1 Absolute Maximum Ratings ........................................................................................................8 6.2 DC Characteristics ......................................................................................................................8 6.3 AC CHARACTERISTICS ........................................................................................................ 11 6.4 Test Information........................................................................................................................ 12 7. ORDER INSTRUCTION............................................................................................................ 13 8. TOP MARKING SPECIFICATION ............................................................................................ 13 9. TAPING SPECIFICATION ........................................................................................................ 13 10. PACKAGE DRAWING AND DIMENSIONS .............................................................................. 14 - II - Release Date: Oct., 2012 Version: 1.0 NCT5917W 1. GENERAL DESCRIPTION The NCT5917W is a CMOS integrated circuit that provides bidirectional level shifting between higher voltage (2.7 V to 5.5 V) and low voltage (down to 0.9 V) up to 400KHz for SMBus TM applications. While retaining all the operating modes and features of the I2C-bus system during the level shifts, it 2 also permits extension of the I C-bus by providing bidirectional buffering for both the data (SDA) and the clock (SCL) lines, thus enabling two buses of 400pF. The SDA and SCL pins are over voltage 5V tolerant and are high-impedance when the NCT5917W is unpowered. The NCT5917W drivers are not enabled unless VCCB is above 2.5 V and VCCA is above 0.8 V. The EN pin can also be used to turn the drivers on and off under system control. Caution should be observed to only change the state of the enable pin when the bus is idle. The output pull-down on the B-side internal buffer LOW is set for approximately 0.5 V, while the input threshold of the internal buffer is set about 70 mV lower (0.43 V). When the B-side I/O is driven LOW internally, the LOW is not recognized as a LOW by the input. This prevents a lock-up condition from occurring. The output pull-down on the A-side drives a hard LOW and the input level is set at 0.3VCCA to accommodate the need for a lower LOW level in systems where the low voltage side supply voltage is as low as 0.9 V. The NCT5917W is packaged in MSOP-8 type. 2. FEATURES  2 channels, bidirectional voltage level from 0.9V to 5.5V and from 2.7V to 5.5V  A side operating supply voltage VCCA range from 0.9V to 5.5V  B side operating supply voltage VCCB range from 2.7V to 5.5V  Isolates Input/output sides  I C® Compatible System Management bus (SMBus ) operated up to 400 KHz  High active’s enable input  5V tolerant I C-bus and active high enable pin  high-impedance for I C-bus pins in power-off (VCCA
NCT5917W TR
物料型号: - 型号:NCT5917W - 制造商:新唐科技(Nuvoton)
器件简介: - NCT5917W是一款CMOS集成电路,提供双向电平转换,适用于SMBusTM应用,能够在高达400KHz的频率下工作。 - 该器件在电平转换时保留I2C-bus系统的所有操作模式和特性,并允许通过为数据(SDA)和时钟(SCL)线路提供双向缓冲来扩展I2C-bus。
引脚分配: - VCCA(引脚1):A侧电源电压(0.9V至5.5V) - SCLA(引脚2):A侧的串行时钟总线 - SDAA(引脚3):A侧的串行数据总线 - GND(引脚4):电源地 - EN(引脚5):高电平有效的中继器使能输入 - SDAB(引脚6):B侧的串行数据总线 - SCLB(引脚7):B侧的串行时钟总线 - VCCB(引脚8):B侧电源电压(2.7V至5.5V)
参数特性: - 电源电压范围:VCCA为0.9V至5.5V,VCCB为2.7V至5.5V - 输入/输出电压范围:-0.5V至6.0V - 工作温度范围:-40℃至+85℃ - 电学特性包括:供电电流、高低电平供电电流、空闲状态下的供电电流、输入/输出电压电平、输入泄漏电流、输出电压、输入/输出电容等。
功能详解: - NCT5917W具有两个通道,支持从0.9V到5.5V和从2.7V到5.5V的双向电压级别。 - 支持I2C®兼容的系统管理总线(SMBusTM),最高可达400KHz。 - 具有高电平有效的使能输入。 - I2C-bus引脚和高电平使能引脚耐5V电压。 - 在断电时(VCCA<0.5或VCCB<2.7V),I2C-bus引脚呈现高阻态。
应用信息: - NCT5917W可用于需要电平转换的I2C-bus系统,如系统主设备和从设备可能在不同的电压级别上运行。 - 该器件还允许通过星型或串联配置连接多个NCT5917W,以实现多个节点之间的通信。
封装信息: - 封装类型:MSOP-8 - 封装尺寸:3 x 3mm - 标记规格:包含部件编号、组装跟踪代码、制造年份和周数、组装厂代码等信息。
NCT5917W TR 价格&库存
很抱歉,暂时无法提供与“NCT5917W TR”相匹配的价格&库存,您可以联系我们找货
