SS215
SS215
    GOODWORK(固得沃克)
    SMA(DO-214AC)
    50uA@150V 150V单920mV@2A 2A SMA(DO-214AC)肖特基势垒二极管
SS215 数据手册
SS215 SS220 THRU 2.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS VOLTAGE RANGE 150 to 200 Volts CURRENT 2.0 Ampere FEATURES DO-214AA(SMB) * Ideal for surface mount applications * Easy pick and place * Built-in strain relief * Low forward voltage drop .155(3.94) .130(3.30) .083(2.11) .075(1.91) .185(4.70) .160(4.06) MECHANICAL DATA .012(0.31) .006(0.15) * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Metallurgically bonded construction * Polarity: Color band denotes cathode end * Mounting position: Any * Weight: 0.093 grams .096(2.44) .083(2.13) .008 MAX. (.203) .220(5.59) .200(5.08) .050(1.27) .030(0.76) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current SS215 SS220 150 105 150 200 140 200 at TL=100 C Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 2.0A Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Typical Junction Capacitance (Note1) Typical Thermal Resistance R JL (Note 2) Operating Temperature Range TJ Storage Temperature Range TSTG A 50 A V mA 2 170 -65 -65 V V V 2.0 0.92 0.02 Ta=100 C UNITS 12 +150 +150 mA PF C/W C C NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Lead Vertical PC Board Mounting 0.375"(9.5mm) Lead Length. REV 1.0 2017 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (SS215 THRU SS220) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD 50 2.0 1.6 1.2 0.8 0.4 0 0 20 40 60 80 100 120 140 160 180 200 LEAD TEMPERATURE,( C) FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT INSTANTANEOUS FORWARD CURRENT,(A) AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 2.4 10 3.0 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 PEAK FORWARD SURGE CURRENT,(A) 50 .01 40 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 30 8.3ms Single Half Tj=25 C Sine Wave 20 JEDEC method 10 FIG.5 - TYPICAL REVERSE 0 CHARACTERISTICS 1 5 50 10 100 100 NUMBER OF CYCLES AT 60Hz REVERSE LEAKAGE CURRENT, (mA) FIG.4-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE,(pF) 700 600 500 400 300 200 10 Tj=100 C 1.0 .1 Tj=25 C 100 0 .01 .05 .1 .5 1 REVERSE VOLTAGE,(V) 5 10 50 100 .01 0 20 40 60 80 100 120 140 PERCENTAGE RATED PEAK REVERSE VOLTAGE REV 1.0 2017 JAN PAGE:2/2
SS215 价格&库存
很抱歉,暂时无法提供与“SS215”相匹配的价格&库存,您可以联系我们找货
SS215
  • 1+0.17625
  • 100+0.16375
  • 300+0.15125
  • 500+0.13875
  • 2000+0.13250
  • 5000+0.12875
SS215
  • 10+0.21496
  • 100+0.16786
  • 300+0.14170
  • 2000+0.12600
  • 4000+0.11245
  • 8000+0.10507
库存:4473
SS215
  • 1+0.10730
库存:780
