NJM8191F-TE1
NJM8191F-TE1
    JRC(⽇本无线)
    SOT23-5
    SINGLE CHANNEL LOW POWER COMPARA
NJM8191F-TE1 数据手册
NJM8190/NJM8191 Single Channel Low power Comparator ■FEATURES(V+=5V, V-=0V, Ta=25°C) ■GENERAL DESCRIPTION ●Guaranteed Temperature -40℃ to +125℃ The NJM8190/NJM8191 are single comparators ●Input Offset Voltage 3mV max. designed specifically to operate wide range of supply ●Supply Current 0.5mA max. voltage and temperature. ●Operating Voltage +2V to +36V or ±1V to ±18V These comparators featured low input offset voltage ●Integrated EMI filter of 3mV max. low supply current of 0.5mA max. DC ●Low-level Output Voltage 80mV typ.(Isink = 4mA) ●Response Time 1.3µs typ. characteristics are also 100% tested and guaranteed ●Open Collector Output from -40 to 125℃. ●GND sencing The NJM8190/NJM8191 are available in DFN6-G1(1616) ●Internal ESD protection Human Body Model ±2000V typ. of small size Package, significantly reducing the required ●Package portable application's board area. NJM8190 SOT-23-5, SC-88A NJM8191 SOT-23-5, SC-88A, DFN6-G1(ESON6-G1) ■PIN CONFIGURATION Parts NJM8190F Number Package SOT-23-5 Outline NJM8190F3 NJM8191F NJM8191F3 NJM8191KG1 SC-88A SOT-23-5 SC-88A DFN6-G1(*) OUTPUT 1 Pin Function 5 V+ -INPUT 1 5 V+ 4 +INPUT +INPUT 3 V+ N.C. V- 2 V- 2 -INPUT 3 (Top View) (Top View) (Top View) 4 OUTPUT OUTPUT V- Exposed Pad on Underside -INPUT +INPUT (*)Connect to exposed pad to V- ■EQUIVALENT CIRCUIT Ver.2.0 http://www.njr.com/ -1- NJM8190/NJM8191 ■PRODUCT NAME INFORMATION NJM8191 Part Number F (TE1) Package Taping Form F:SOT-23-5 F3:SC-88A KG1:DFN6-G1(ESON6-G1) ■ORDERING INFORMATION PART PACKAGE OUTLINE NUMBER NJM8190F SOT-23-5 NJM8190F3 SC-88A NJM8191F SOT-23-5 NJM8191F3 SC-88A NJM8191KG1 DFN6-G1 RoHS yes yes yes yes yes HALOGENFREE yes yes yes yes yes TERMINAL FINISH Sn2Bi Sn2Bi Sn2Bi Sn2Bi Sn2Bi MARKING A5V 2A A5U 29 8191 WEIGHT (mg) 15 7.5 15 7.5 3.5 MOQ (pcs) 3,000 3,000 3,000 3,000 3,000 ■ABSOLUTE MAXIMUM RATINGS PARAMETER Supply Voltage Differential Input Voltage Input Voltage (1) Output Terminal Input Voltage (2) SYMBOL V+- VVID VIN Vo Short-Circuit Output Current to V-(3) Power Dissipation(Ta=25℃) SOT-23-5(4) SC-88A(4) DFN6-G1(ESON6-G1)(5) Junction Temperature Storage Temperature Range PD Tjmax Tstg RATINGS 36 ±36 V- - 0.3 to V- + 36 V- - 0.3 to V- + 36 Infinite (2-layer / 4-layer) 480 / 650 360 / 490 330 / 1200 UNIT V V V V +150 - 55 to +150 °C °C mW (1) Input voltage is the voltage should be allowed to apply to the input terminal independent of the magnitude of V+. (2) Output voltage is the voltage should be allowed to apply to the output terminal independent of the magnitude of V+. (3) Short-circuits from the output to V+ can cause excessive heating and potential destruction. (4) Short-circuit can cause excessive heating and destructive dissipation. Values are typical. (5) Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 2Layers FR4) Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 4Layers FR4), internal Cu area: 74.2 x 74.2mm (6) Mounted on glass epoxy board. (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 2Layers FR-4, with Exposed Pad) Mounted on glass epoxy board. (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 4Layers FR-4, with Exposed Pad) *For 4Layers: Applying 99.5×99.5mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5 Ver.2.0 http://www.njr.com/ -2- NJM8190/NJM8191 ■THERMAL CHARACTERISTICS PARAMETER SYMBOL Junction-to-ambient thermal resistance SOT-23-5(7) SC-88A(7) DFN6-G1(ESON6-G1) (8) Junction-to-Top of package characterization parameter SOT-23-5(7) SC-88A(7) DFN6-G1(ESON6-G1) (8) VALUE (2-layer / 4-layer) 260 / 195 355 / 260 385 / 110 (2-layer/ 4-layer) 68 / 58 91 / 74 65 / 26 θja ψjt UNIT °C /W °C /W (7) Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 2Layers FR4) Mounted on glass epoxy board. (76.2×114.3×1.6mm:based on EIA/JDEC standard, 4Layers FR4), internal Cu area: 74.2 x 74.2mm (8) Mounted on glass epoxy board. (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 2Layers FR-4, with Exposed Pad) Mounted on glass epoxy board. (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 4Layers FR-4, with Exposed Pad) *For 4Layers: Applying 99.5×99.5mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5 ■POWER DISSIPATION vs. AMBIENT TEMPERATURE Power Dissipation vs. Temperature Power Dissipation vs. Temperature 2-Layer 4-Layer 1400 600 Power Dissipation PD [mW] Power Dissipation PD [mW] 700 SOT-23-5 500 400 SC-88A 300 200 DFN6-G1(ESON6-G1) 100 1200 DFN6-G1(ESON6-G1) 1000 800 SOT-23-5 600 400 200 0 SC-88A 0 0 25 50 75 100 125 Ambient Temperature Ta [ºC] 150 0 25 50 75 100 125 Ambient Temperature Ta [ºC] SYMBOL V+- V- RATINGS 2 to 36 UNIT V Topr - 40 to +125 °C 150 ■RECOMMENDED OPERATING CONDITIONS PARAMETER Supply Voltage Operating Ambient Temperature Ver.2.0 http://www.njr.com/ -3- NJM8190/NJM8191 ■ELECTRICAL CHARACTERISTICS (Unless otherwise specified, V+=5V, V-=0V, RL=OPEN, Ta=25℃) PARAMETER SYMBOL Input Offset Voltage(1) VIO Input Offset Current IIO Input Bias Current (2) IB Common Mode Input Voltage Open-Loop Voltage Gain Supply Current Differential Input Voltage Range(3) Low-level Output Voltage VICM AV ISUPPLY TEST CONDITION Ta=25℃ Ta=-40℃ to 125℃ Ta=25℃ Ta=-40℃ to 125℃ Ta=25℃ Ta=-40℃ to 125℃ V+=30V, Ta=25℃ V+=30V, Ta=-40 to 125℃ V+=15V、RL=15kΩ, Vo=1V to 11V Ta=25℃ Ta=-40 to 125℃ V+=30V,Ta=25℃ V+=30V,Ta=-40 to 125℃ VID VOL Output Sink Current ISINK Output Leakage Current ILEAK Response Time(4) tre Large Signal Response Time tRL VIN+=0V,VIN-=1V,ISINK=4mA, Ta=25℃ VIN+=0V,VIN-=1V,ISINK=4mA, Ta=-40 to 125℃ VIN+=0V,VIN-=1V, Vo=1.5V V+=Vo=30V, VIN+=1V,VIN-=0V, Ta=25℃ V+=Vo=30V, VIN+=1V,VIN-=0V, Ta=-40 to 125℃ RL=5.1kΩ to V+ RL=5.1kΩ to V+ Vref=1.4V,TTL input MIN − − − − − − 0 0 TYP. 0.5 − 0.5 − 20 − − − MAX. 3 4 50 150 250 400 V+-1.5 V+-2.0 UNIT mV mV 50 200 - V/mV − − − − 0.3 − 0.4 − 0.5 0.9 1.2 1.5 mA − − V+ V − 80 400 nA V mV − − 700 6 16 − mA − 0.1 − nA − − 1 µA − 1.3 − µs − 250 − ns (1) VO = 1.4V, RS=0Ω, 5V < V+ < 30V, 0 < VICM
NJM8191F-TE1 价格&库存
很抱歉,暂时无法提供与“NJM8191F-TE1”相匹配的价格&库存,您可以联系我们找货
