NJM12903
SINGLE SUPPLY DUAL COMPARATOR
■ GENERAL DESCRIPTION
The NJM12903 is a single-supply dual voltage comparator,
which can operate from 2V supply. The features are low input
offset voltage, low input bias current and low current
consumption.
The NJM12903 compare the input signal to 0V (ground) due
to the Darlington PNP input stage. In addition, small packages
TVSP, VSP and SSOP are available. The NJM12903 is suitable
for any kind of signal comparator.
■ FEATURES
● Operating Voltage
● Open Collector Output
● Bipolar Technology
● Package Outline
■ PACKAGE OUTLINE
NJM12903RB1
(MSOP8(TVSP8))
NJM12903R
(MSOP8(VSP8))
NJM12903M
( DMP8 )
NJM12903V
( SSOP8 )
NJM12903E
( SOP8 )
+2V~+14V
DIP8, SIP8, DMP8, SSOP8
NJM12903D
SOP8 JEDEC 150mil
( DIP8 )
MSOP8 (VSP8) MEET JEDEC MO-187-DA
MSOP8 (TVSP8) MEET JEDEC MO-187-DA / THIN TYPE
NJM12903L
( SIP8 )
■ PIN CONFIGURATION
( Top View )
1
2
8
PIN FUNCTION
1. A OUTPUT
7
A
A
3
B
4
2. A −INPUT
B
3. A +INPUT
6
5
NJM12903D/NJM12903M
NJM12903E/NJM12903V
NJM12903R/NJM12903RB1
4. GND
1
2
3
4
5
6
NJM12903L
7
8
5. B +INPUT
6. B −INPUT
7. B OUTPUT
8. V
■ EQUIVALENT CIRCUIT ( 1/2 Shown )
V+
INPUT
OUTPUT
INPUT
GND
Ver.2014-11-27
-1-
NJM12903
■ ABSOLUTE MAXIMUM RATINGS( Ta=25˚C )
PARAMETER
SYMBOL
RATING
UNIT
Supply Voltage
V
15
V
Differential Input Voltage
VID
14 (note1)
V
Common Mode Input Voltage
VIC
-0.3~+14 (note1)
V
Power Dissipation
PD
Operating Temperature Range
Storage Temperature Range
Topr
Tstg
DIP8 500
DMP8 300
EMP8 300
SSOP8 250
MSOP8(VSP8/TVSP8) 320
SIP8 800
-40~+85
-50~+125
mW
°C
°C
(Note1) For supply voltage less than 14V, the maximum input voltage is equal to the supply voltage.
■ ELECTRICAL CHARACTERISTICS( V+=5V,Ta=25˚C unless otherwise specified )
PARAMETER
SYMBOL
TEST CONDITION
MIN.
TYP.
MAX.
UNIT
2
14
V
1
4
mV
Operating Voltage
VOPR
Input Offset Voltage
VIO
Input Offset Current
IIO
5
50
nA
Input Bias Current
IB
30
200
nA
Large Signal Voltage Gain
AV
106
dB
Common Mode Input Voltage Range
VICM
Response Time
tR
-2-
Rs=0Ω,Vo≈1.4V
RL=15kΩ
0~3.5
V
RL=5.1kΩ
0.5
μs
Output Sink Current
ISINK
VIN+=0V,VIN-=1V,Vo=1.5V
6
10
mA
Output Saturation Voltage
VSAT
VIN+=0V,VIN-=1V,ISINK=3mA
80
300
mV
Output Leakage Current
ILEAK
VIN+=1V,VIN-=0V,Vo=5V
0.1
1
μA
Supply Current
ICC
0.4
1
mA
Ver.2014-11-27
NJM12903
■ TYPICAL CHARACTERISTICS
Supply Current vs. Supply Voltage
Ta=25ºC
0.8
1.6
1.4
Supply Current Icc [mA]
0.7
0.6
0.5
0.4
0.3
0.2
1.2
1
0.8
V+=+14V
V+=+5V
0.6
0.4
V =+2V
0.2
0.1
4
6
8
10 12
Supply Voltage V [V]
14
-50
16
Input Offset Voltage vs. Supply Voltage
-25
50
75
100
Ambient Temperature Ta [ºC]
125
Input Offset Voltage vs. Temperature (Supply Voltage)
Ta=25ºC
2.5
2.5
2
Input Offset Voltage VIO [mV]
Supply Current vs. Temperature (Supply Voltage)
1.5
1
0.5
-1
-1.5
-2
2
1.5
V =+2V, +5V, +14V
1
0.5
-1
-1.5
-2
4
6
8
10 12
14
16
-50
-25
50
75
100
125
Input Bias Current vs. Temperature (Supply Voltage)
V =+5V
120
4
Input Bias Current IB [nA]
5
3
2
1
-2
-3
100
80
V =+14V
60
V =+5V
40
V =+2V
Ver.2014-11-27
2.8
3
3.2
3.4
3.6
Input Voltage Vin [V]
3.8
4
-50
-25
50
75
100
125
-3-
NJM12903
Output Saturation Voltage vs. Output Sink Current
(Temperature)
V =+5V
Input Bias Current vs. Supply Voltage
Ta=25ºC
10
Output Saturation Voltage Vsat [V]
80
Input Bias Current Ib [nA]
70
60
50
40
30
4
6
8
10 12
14
16
Ta=25ºC
0.1
0.001
0.01
100
Output Saturation Voltage Vsat [mV]
200
180
Vsat [mV]
0.1
1
10
Output Sink Current Isink [mA]
Output Saturation Voltage vs. Supply Voltage
(Supply Voltage)
(Isink=3mA)
160
140
120
Ta=85ºC
0.01
Output Saturation Voltage vs. Temperature
200
Ta=-40ºC
1
V =+2V, +5V, +14V
100
80
60
40
160
140
Isink=6mA
120
100
80
60
40
Isink=3mA
-25
50
75
100
Ambient TemperatureTa [ºC]
125
Pulse Response
4
6
8
10 12
14
16
Pulse Response
Vout
1V/div
0.5μs/div
Over Drive 50mV
Vout
Vout
1V/div
0.5μs/div
Over Drive 50mV
Vin
100mV/div
0.5μs/div
Voltage V [V]
VoltageV [V]
Over Drive 5mV
Vout
Over Drive 5mV
Vin
Vin
100mV/div
0.5μs/div
Vin
Time t [μs]
Time t [μs]
[CAUTION]
The specifications on this data book are only given for information,
without any guarantee as regards either mistakes or omissions. The
application circuits in this data book are described only to show
representative usages of the product and not intended for the
guarantee or permission of any right including the industrial rights.
-4-
Ver.2014-11-27
很抱歉,暂时无法提供与“NJM12903RB1-TE1”相匹配的价格&库存,您可以联系我们找货
