S-89240BC-K8T2U
S-89240BC-K8T2U
    ABLIC(艾普凌科)
    TMSOP-8_2.9X2.8MM
    IC COMPARATOR CMOS 8TMSOP
S-89240BC-K8T2U 数据手册
S-89230/89240 Series www.ablic.com www.ablicinc.com MINI ANALOG SERIES CMOS COMPARATOR © ABLIC Inc., 2009-2010 Rev.3.0_02 The mini-analog series is a group of ICs that incorporate a general purpose analog circuit in a small package. The S-89230/89240 Series is a CMOS type comparator works on a lower voltage and lower current consumption. These features make this product the ideal solution for small battery-powered portable equipment. This product is a dual comparator (with 2 circuits).  Features  Lower operating voltage than the conventional general-purpose: VDD = 1.8 V to 5.5 V  Low current consumption (per circuit): IDD = 23 A Typ. (S-89230 Series) IDD = 5 A Typ. (S-89240 Series)  Low input offset voltage: 4.0 mV Max.  Output full swing  A dual comparator (with 2 circuits)  Lead-free, Sn 100%, halogen-free*1 *1. Refer to “ Product Name Structure” for details.  Applications     Mobile phones Notebook PCs Digital cameras Digital video cameras  Packages  SNT-8A  TMSOP-8 1 MINI ANALOG SERIES S-89230/89240 Series CMOS COMPARATOR Rev.3.0_02  Block Diagram VDD IN1()  IN1()  OUT1 IN2()  IN2()  OUT2 VSS Figure 1 2 MINI ANALOG SERIES Rev.3.0_02 CMOS COMPARATOR S-89230/89240 Series  Product Name Structure Users can select the product type and package for the S-89230/89240 Series. Refer to “1. Product name” regarding the contents of product name, “2. Package” regarding the package drawings and “3. Product name list” regarding the product type. 1. Product name S-892 x 0 B C  xxxx U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 I8T1 : SNT-8A, Tape K8T2 : TMSOP-8, Tape Number of circuits B :2 Current consumption (per circuit) 3 : IDD = 23 µA 4 : IDD = 5 µA *1. Refer to the tape specifications. 2. Package Package Name SNT-8A TMSOP-8 3. Package PH008-A-P-SD FM008-A-P-SD Drawing Code Tape Reel PH008-A-C-SD PH008-A-R-SD FM008-A-C-SD FM008-A-R-SD Land PH008-A-L-SD  Product name list Table 1 Product name S-89230BC-I8T1U S-89230BC-K8T2U S-89240BC-I8T1U S-89240BC-K8T2U *1. Current consumption (per circuit) Rise propagation delay time*1 Fall propagation delay time*1 Number of circuits 23 A 23 A 5 A 5 A 26 s 26 s 100 s 100 s 4 s 4 s 18 s 18 s 2 circuits 2 circuits 2 circuits 2 circuits Package SNT-8A TMSOP-8 SNT-8A TMSOP-8 The value when VDD = 3.0 V Remark Please select products of environmental code = U for Sn 100%, halogen-free products. 3 MINI ANALOG SERIES S-89230/89240 Series CMOS COMPARATOR Rev.3.0_02  Pin Configurations Table 2 SNT-8A Top view 1 8 2 7 3 6 4 5 Pin No. 1 2 3 4 5 6 7 8 Symbol OUT1 IN1() IN1() VSS IN2() IN2() OUT2 VDD Description Output pin 1 Inverted input pin 1 Non-inverted input pin 1 GND pin Non-inverted input pin 2 Inverted input pin 2 Output pin 2 Positive power supply pin Figure 2 Table 3 TMSOP-8 Top view 1 8 2 7 3 6 4 5 Figure 3 4 Pin No. 1 2 3 4 5 6 7 8 Symbol OUT1 IN1() IN1() VSS IN2() IN2() OUT2 VDD Description Output pin 1 Inverted input pin 1 Non-inverted input pin 1 GND pin Non-inverted input pin 2 Inverted input pin 2 Output pin 2 Positive power supply pin MINI ANALOG SERIES Rev.3.0_02 CMOS COMPARATOR S-89230/89240 Series  Absolute Maximum Ratings Table 4 Parameter Power supply voltage Input voltage Output voltage Differential input voltage Output pin current SNT-8A Power dissipation TMSOP-8 Operating ambient temperature Storage temperature PD Topr Tstg When mounted on board [Mounted board] (1) Board size: 114.3 mm  76.2 mm  t1.6 mm (2) Board name: JEDEC STANDARD51-7 Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 700 Power Dissipation (PD) [mW] *1. (Ta =25°C unless otherwise specified) Absolute maximum ratings Unit VSS0.3 to VSS7.0 V VSS0.3 to VSS7.0 V VSS0.3 to VDD0.3 V 7.0 V 20 mA *1 450 mW 650*1 mW 40 to 85 °C 55 to 125 °C Symbol VDD VIN VOUT VIND ISINK 600 TMSOP-8 500 400 SNT-8A 300 200 100 0 0 50 100 150 Ambient Temperature (Ta) [C] Figure 4 Power Dissipation of Package (When Mounted on Board) 5 MINI ANALOG SERIES S-89230/89240 Series CMOS COMPARATOR Rev.3.0_02  Electrical Characteristics Table 5 Parameter Range of operating power supply voltage 1. Symbol Conditions (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit  VDD 1.8  5.5 V  VDD = 5.0 V Table 6 (Ta = 25°C unless otherwise specified) DC Electrical Characteristics (VDD = 5.0 V) Parameter Current consumption (per circuit) Input offset voltage drift Input offset voltage Input offset current Input bias current Common-mode input voltage range Maximum output swing voltage Common-mode input signal rejection ratio Power supply voltage rejection ratio Symbol IDD VIO VIO Ta Conditions Min. Typ. Max. Unit Test Circuit   4 23 5 3 40 9 4 A A mV 5 5 1  10  V/°C 1 S-89230 Series S-89240 Series  Ta = 40°C to 85°C IIO IBIAS     1 1   pA pA   VCMR  0  4.3 V 2 4.9     0.01 V V 3 4 VOH VOL RL = 1.0 M RL = 1.0 M CMRR  60 70  dB 2 PSRR  60 70  dB 1 120 25 5 3.5         A A mA mA 6 6 7 7 Source current ISOURCE VOUT = 0 V Sink current ISINK VOUT = 0.5 V S-89230 Series S-89240 Series S-89230 Series S-89240 Series Table 7 AC Electrical Characteristics (VDD = 5.0 V) Parameter Symbol Rise propagation delay time tPLH Fall propagation delay time tPHL Rise response time tTLH Fall response time tTHL 6 Conditions S-89230 Series S-89240 Series S-89230 Series Overdrive = 100 mV S-89240 Series CL = 15 pF S-89230 Series (Refer to Figure 12) S-89240 Series S-89230 Series S-89240 Series (Ta = 25°C unless otherwise specified) Min.         Typ. 26 100 5 22 3 15 3 15 Max.         Unit s s s s s s s s MINI ANALOG SERIES Rev.3.0_02 2. CMOS COMPARATOR S-89230/89240 Series VDD = 3.0 V Table 8 (Ta = 25°C unless otherwise specified) DC Electrical Characteristics (VDD = 3.0 V) Parameter Current consumption (per circuit) Input offset voltage drift Input offset voltage Input offset current Input bias current Common-mode input voltage range Maximum output swing voltage Common-mode input signal rejection ratio Power supply voltage rejection ratio Symbol IDD VIO VIO Ta Conditions Min. Typ. Max. Unit Test Circuit   4 23 5 3 40 9 4 A A mV 5 5 1  10  V/°C 1 S-89230 Series S-89240 Series  Ta = 40°C to 85°C IIO IBIAS     1 1   pA pA   VCMR  0  2.3 V 2 2.9     0.01 V V 3 4 VOH VOL RL = 1.0 M RL = 1.0 M CMRR  60 70  dB 2 PSRR  60 70  dB 1 120 25 5 3.5         A A mA mA 6 6 7 7 Source current ISOURCE VOUT = 0 V Sink current ISINK VOUT = 0.5 V S-89230 Series S-89240 Series S-89230 Series S-89240 Series Table 9 AC Electrical Characteristics (VDD = 3.0 V) Parameter Symbol Rise propagation delay time tPLH Fall propagation delay time tPHL Rise response time tTLH Fall response time tTHL Conditions S-89230 Series S-89240 Series S-89230 Series Overdrive = 100 mV S-89240 Series CL = 15 pF S-89230 Series (Refer to Figure 12) S-89240 Series S-89230 Series S-89240 Series (Ta = 25°C unless otherwise specified) Min.         Typ. 26 100 4 18 2 10 2 10 Max.         Unit s s s s s s s s 7 MINI ANALOG SERIES S-89230/89240 Series 3. CMOS COMPARATOR Rev.3.0_02 VDD = 1.8 V Table 10 (Ta = 25°C unless otherwise specified) DC Electrical Characteristics (VDD = 1.8 V) Parameter Current consumption (per circuit) Input offset voltage drift Input offset voltage Input offset current Input bias current Common-mode input voltage range Maximum output swing voltage Common-mode input signal rejection ratio Power supply voltage rejection ratio Symbol IDD VIO VIO Ta Conditions Min. Typ. Max. Unit Test Circuit   4 23 5 3 40 9 4 A A mV 5 5 1  10  V/°C 1 S-89230 Series S-89240 Series  Ta = 40°C to 85°C IIO IBIAS     1 1   pA pA   VCMR  0  1.1 V 2 1.7     0.01 V V 3 4 VOH VOL RL = 1.0 M RL = 1.0 M CMRR  60 70  dB 2 PSRR  60 70  dB 1 100 20 5 3.5         A A mA mA 6 6 7 7 Source current ISOURCE VOUT = 0 V Sink current ISINK VOUT = 0.5 V S-89230 Series S-89240 Series S-89230 Series S-89240 Series Table 11 AC Electrical Characteristics (VDD = 1.8 V) Parameter Symbol Rise propagation delay time tPLH Fall propagation delay time tPHL Rise response time tTLH Fall response time tTHL 8 Conditions S-89230 Series S-89240 Series S-89230 Series Overdrive = 100 mV S-89240 Series CL = 15 pF S-89230 Series (Refer to Figure 12) S-89240 Series S-89230 Series S-89240 Series (Ta = 25°C unless otherwise specified) Min.         Typ. 18 87 3.5 15 1.2 6 1.2 6 Max.         Unit s s s s s s s s MINI ANALOG SERIES Rev.3.0_02 CMOS COMPARATOR S-89230/89240 Series  Test Circuit (Per Circuit) 1. Power supply voltage rejection ratio, input offset voltage  Power supply voltage rejection ratio (PSRR) Input offset voltage (VIO) VDD  VOUT  VIN The input offset voltage (VIO) is defined as VIN − VDD / 2 when VOUT is changed by changing VIN to VDD / 2 level. The power supply voltage rejection ratio (PSRR) can be calculated by following expression, with the value of VIO measured at each VDD. Measurement conditions: When VDD = 1.8 V: VDD = VDD1, VIO = VIO1 When VDD = 5.0 V: VDD = VDD2, VIO = VIO2 VDD / 2 PSRR = 20 log VDD1  VDD2 VIO1  VIO2 Figure 5 2. Common-mode input signal rejection ratio, common-mode input voltage range  Common-mode input signal rejection ratio (CMRR) The common-mode input signal rejection ratio (CMRR) can be calculated by the following expression, with the offset voltage (VIO) set as VIN1 − VIN2 after VOUT is changed by changing VIN1. VDD   VIN1 VIN2 Figure 6 VOUT Measurement conditions: When VIN2 = VCMR Max.: VIN2 = VINH, VIO = VIO1 When VIN2 = VDD/2: VIN2 = VINL, VIO = VIO2 CMRR = 20 log VINH  VINL VIO1 VIO2  Common-mode input voltage range (VCMR) Varying VIN2, the range of VIN2 that satisfies the common-mode input signal rejection ratio (CMRR) is the common-mode input voltage range (VCMR). 9 MINI ANALOG SERIES S-89230/89240 Series 3. CMOS COMPARATOR Rev.3.0_02 Maximum output swing voltage (VOH) VDD  Maximum output swing voltage (VOH) Test conditions: VDD  0.1 V 2 VDD VIN2 =  0.1 V 2 VIN1 =  VOH  RL = 1 M RL VIN1 VIN2 Figure 7 4. Maximum output swing voltage (VOL) VDD  Maximum output swing voltage (VOL) Test conditions: RL   VIN1 VIN2 Figure 8 10 VDD  0.1 V 2 VDD VIN2 =  0.1 V 2 VIN1 = VOL RL = 1 M MINI ANALOG SERIES Rev.3.0_02 5. CMOS COMPARATOR S-89230/89240 Series Current consumption VDD  Current consumption (IDD) Test conditions: VIN = VSS VIN = VCMR Max. A  VOUT  VIN1 VIN2 Figure 9 6. Source current  Source current (ISOURCE) VDD Test conditions: VOUT = 0 V VDD  0.5 V 2 VDD VIN2 =  0.5 V 2 VIN1 =   VIN1 A VOUT VIN2 Figure 10 7. Sink current VDD VOUT  Sink current (ISINK) Test conditions: VOUT = 0.5 V A   VIN1 VDD  0.5 V 2 VDD VIN2 =  0.5 V 2 VIN1 = VIN2 Figure 11 11 MINI ANALOG SERIES S-89230/89240 Series 8. CMOS COMPARATOR Rev.3.0_02 Propagation time, response time tR = tF = 20 ns VCMR Max. tPHL 100 mV Overdrive VIN () = VDD / 2 VIN () 100 mV Overdrive VSS ( = 0 V) tPLH tTHL VOUT VDD  0.9 VDD / 2 VDD  0.1 tTLH Figure 12 12 MINI ANALOG SERIES Rev.3.0_02 CMOS COMPARATOR S-89230/89240 Series  Precautions  Do not apply an electrostatic discharge to this IC that exceeds performance ratings of the built-in electrostatic protection circuit.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 13 MINI ANALOG SERIES S-89230/89240 Series CMOS COMPARATOR Rev.3.0_02  Characteristics (Typical Data) 1. Current consumption (per circuit, IDD) vs. Power supply voltage (VDD) (1) S-89230 Series (2) S-89240 Series IDDVDD, VSS = 0 V 6 20 5 15 Ta = −40°C 25°C 85°C IDD [μA] IDD [μA] IDDVDD, VSS = 0 V 25 10 5 4 3 25°C 2 1 0 0 0 1 2 3 4 5 0 6 1 2 VDD [V] 2. 85°C Ta = −40°C 3 VDD [V] 4 5 6 Output current characteristics Source current (ISOURCE) vs. Power supply voltage (VDD) 2. 1 (1) S-89230 Series (2) S-89240 Series ISOURCEVDD, VOUT = 0 V, VSS = 0 V 400 80 300 60 200 Ta = −40°C 25°C ISOURCE [μA] ISOURCE [μA] ISOURCEVDD, VOUT = 0 V, VSS = 0 V 85°C 100 0 Ta = −40°C 40 25°C 85°C 20 0 0 1 2 3 4 5 0 6 1 2 VDD [V] 3 VDD [V] 4 5 6 2. 2 Sink current (ISINK) vs. Power supply voltage (VDD) (1) S-89230 Series (2) S-89240 Series ISINKVDD, VOUT = 0.5 V, VSS = 0 V ISINKVDD, VOUT = 0.5 V, VSS = 0 V 15.0 15.0 Ta = −40°C 10.0 12.5 25°C ISINK [mA] ISINK [mA] 12.5 7.5 5.0 85°C 2.5 5.0 85°C 0 0 1 2 3 VDD [V] 4 5 6 25°C Ta = −40°C 7.5 2.5 0 14 10.0 0 1 2 3 VDD [V] 4 5 6 MINI ANALOG SERIES Rev.3.0_02 CMOS COMPARATOR S-89230/89240 Series Output voltage (VOUT) vs. Source current (ISOURCE) 2. 3 (1) S-89230 Series VOUTISOURCE, VDD = 1.8 V, VSS = 0 V VOUTISOURCE, VDD = 3.0 V, VSS = 0 V 2.0 3.0 25°C VOUT [V] VOUT [V] 1.5 85°C 1.0 25°C 2.5 0.5 85°C 2.0 1.5 1.0 0.5 Ta = −40°C 0 Ta = −40°C 0 0 50 100 150 200 ISOURCE [μA] 250 300 0 350 50 100 150 200 ISOURCE [μA] 250 300 350 VOUTISOURCE, VDD = 5.0 V, VSS = 0 V 5.0 25°C VOUT [V] 4.0 85°C 3.0 2.0 1.0 Ta = −40°C 0 0 50 100 150 200 ISOURCE [μA] 250 300 350 85°C 1.0 VOUTISOURCE, VDD = 3.0 V, VSS = 0 V 3.0 0.5 25°C 2.5 VOUT [V] VOUT [V] (2) S-89240 Series VOUTISOURCE, VDD = 1.8 V, VSS = 0 V 2.0 25°C 1.5 2.0 85°C 1.5 1.0 0.5 Ta = −40°C 0 Ta = −40°C 0 0 10 20 30 40 ISOURCE [μA] 50 60 70 0 10 20 30 40 ISOURCE [μA] 50 60 70 VOUTISOURCE, VDD = 5.0 V, VSS = 0 V 5.0 VOUT [V] 4.0 25°C 3.0 2.0 85°C 1.0 Ta = −40°C 0 0 10 20 30 40 ISOURCE [μA] 50 60 70 15 MINI ANALOG SERIES S-89230/89240 Series CMOS COMPARATOR Rev.3.0_02 Output voltage (VOUT) vs. Sink current (ISINK) 2. 4 (1) S-89230 Series VOUTISINK, VDD = 1.8 V, VSS = 0 V VOUTISINK, VDD = 3.0 V, VSS = 0 V 2.0 3.0 25°C 25°C 2.5 85°C VOUT [V] VOUT [V] 1.5 1.0 0.5 2.0 85°C 1.5 1.0 Ta = −40°C 0.5 Ta = −40°C 0 0 0 5 10 15 20 ISINK [mA] 25 0 30 5 10 15 20 ISINK [mA] 25 30 VOUTISINK, VDD = 5.0 V, VSS = 0 V 5.0 25°C VOUT [V] 4.0 3.0 85°C 2.0 1.0 Ta = −40°C 0 0 5 10 15 20 ISINK [mA] 25 30 (2) S-89240 Series VOUTISINK, VDD = 1.8 V, VSS = 0 V VOUTISINK, VDD = 3.0 V, VSS = 0 V 2.0 3.0 25°C 85°C 1.0 0.5 0 85°C 1.5 1.0 Ta = −40°C 0 0 5 10 15 20 ISINK [mA] 25 30 VOUTISINK, VDD = 5.0 V, VSS = 0 V 5.0 25°C 4.0 VOUT [V] 2.0 0.5 Ta = −40°C 3.0 85°C 2.0 1.0 Ta = −40°C 0 0 16 25°C 2.5 VOUT [V] VOUT [V] 1.5 5 10 15 20 ISINK [mA] 25 30 0 5 10 15 20 ISINK [mA] 25 30 1.97±0.03 8 7 6 5 3 4 +0.05 1 0.5 2 0.08 -0.02 0.48±0.02 0.2±0.05 No. PH008-A-P-SD-2.1 TITLE SNT-8A-A-PKG Dimensions No. PH008-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 2.25±0.05 4.0±0.1 2.0±0.05 ø0.5±0.1 0.25±0.05 0.65±0.05 4.0±0.1 4 321 5 6 78 Feed direction No. PH008-A-C-SD-2.0 TITLE SNT-8A-A-Carrier Tape No. PH008-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PH008-A-R-SD-1.0 TITLE SNT-8A-A-Reel No. PH008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 0.52 2.01 2 0.52 0.2 0.3 1. 2. 1 (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) 1. 2. 3. 4. 0.03 mm SNT 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package (1.96 mm to 2.06mm). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. 1. 2. (0.25 mm min. / 0.30 mm typ.) (1.96 mm ~ 2.06 mm) TITLE No. PH008-A-L-SD-4.1 SNT-8A-A -Land Recommendation PH008-A-L-SD-4.1 No. ANGLE UNIT mm ABLIC Inc. 2.90±0.2 8 5 1 4 0.13±0.1 0.2±0.1 0.65±0.1 No. FM008-A-P-SD-1.2 TITLE TMSOP8-A-PKG Dimensions No. FM008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 2.00±0.05 4.00±0.1 4.00±0.1 1.00±0.1 +0.1 1.5 -0 1.05±0.05 0.30±0.05 3.25±0.05 4 1 5 8 Feed direction No. FM008-A-C-SD-2.0 TITLE TMSOP8-A-Carrier Tape FM008-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part 13±0.2 (60°) (60°) No. FM008-A-R-SD-1.0 TITLE TMSOP8-A-Reel No. FM008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-89240BC-K8T2U 价格&库存
很抱歉,暂时无法提供与“S-89240BC-K8T2U”相匹配的价格&库存,您可以联系我们找货
