LM339AN
LM339AN
    L3HARRIS
    DIP-14
    QUAD COMPARATOR
LM339AN 数据手册
Is Now Part of To learn more about ON Semiconductor, please visit our website at www.onsemi.com Please note: As part of the Fairchild Semiconductor integration, some of the Fairchild orderable part numbers will need to change in order to meet ON Semiconductor’s system requirements. Since the ON Semiconductor product management systems do not have the ability to manage part nomenclature that utilizes an underscore (_), the underscore (_) in the Fairchild part numbers will be changed to a dash (-). This document may contain device numbers with an underscore (_). Please check the ON Semiconductor website to verify the updated device numbers. The most current and up-to-date ordering information can be found at www.onsemi.com. Please email any questions regarding the system integration to Fairchild_questions@onsemi.com. ON Semiconductor and the ON Semiconductor logo are trademarks of Semiconductor Components Industries, LLC dba ON Semiconductor or its subsidiaries in the United States and/or other countries. ON Semiconductor owns the rights to a number of patents, trademarks, copyrights, trade secrets, and other intellectual property. A listing of ON Semiconductor’s product/patent coverage may be accessed at www.onsemi.com/site/pdf/Patent-Marking.pdf. ON Semiconductor reserves the right to make changes without further notice to any products herein. ON Semiconductor makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ON Semiconductor assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. Buyer is responsible for its products and applications using ON Semiconductor products, including compliance with all laws, regulations and safety requirements or standards, regardless of any support or applications information provided by ON Semiconductor. “Typical” parameters which may be provided in ON Semiconductor data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. ON Semiconductor does not convey any license under its patent rights nor the rights of others. ON Semiconductor products are not designed, intended, or authorized for use as a critical component in life support systems or any FDA Class 3 medical devices or medical devices with a same or similar classification in a foreign jurisdiction or any devices intended for implantation in the human body. Should Buyer purchase or use ON Semiconductor products for any such unintended or unauthorized application, Buyer shall indemnify and hold ON Semiconductor and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that ON Semiconductor was negligent regarding the design or manufacture of the part. ON Semiconductor is an Equal Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner. www.fairchildsemi.com LM339/LM339A, LM239A, LM2901 Quad Comparator Features Description • Single or Dual Supply Operation • Wide Range of Supply Voltage LM2901, LM339/LM339A, LM239A: 2 ~ 36V (or ±1 ~ ±18V) • Low Supply Current Drain 800μA Typ. • Open Collector Outputs for Wired and Connectors • Low Input Bias Current 25nA Typ. • Low Input Offset Current ±2.3nA Typ. • Low Input Offset Voltage ±1.4mV Typ. • Input Common Mode Voltage Range Includes Ground. • Low Output Saturation Voltage • Output Compatible With TTL, DTL and MOS Logic System The LM339/LM339A ,LM239A, LM2901 consist of four independent voltage comparators designed to operate from single power supply over a wide voltage range. 14-DIP 1 14-SOP 1 Internal Block Diagram OUT2 1 14 OUT3 OUT1 2 13 OUT4 12 GND VCC 3 - + - + IN1(-) 4 11 IN4(+) IN1(+) 5 10 IN4(-) 9 IN3(+) IN2(-) 6 IN2(+) 7 + - + 8 IN3(-) Rev. 1.0.5 ©2012 Fairchild Semiconductor Corporation LM339/LM339A, LM239A, LM2901 Schematic Diagram VCC Q12 Q14 Q9 D2 Q2 D3 D4 Q3 D1 R2 IN(+) Q4 Q1 OUTPUT IN(-) Q8 Q7 Q5 Q13 Q6 D5 R1 D6 GND Absolute Maximum Ratings Parameter Symbol Value Unit VCC ±18 or 36 V VI(DIFF) 36 V Input Voltage VI -0.3 to +36 V Output Short Circuit to GND - Continuous - PD 570 mW TOPR 0 ~ +70 -40 ~ +85 -25 ~ +85 °C TSTG -65 ~ +150 °C Supply Voltage Differential Input Voltage Power Dissipation Operating Temperature LM339/LM339A LM2901 LM239A Storage Temperature 2 LM339/LM339A, LM239A, LM2901 Electrical Characteristics (VCC = 5V, TA = 25°C, unless otherwise specified) Parameter Symbol Input Offset Voltage VIO Input Offset Current IIO Conditions LM239A/LM339A LM339 Typ. Max. VO(P) =1.4V, RS = 0Ω - 1 2 - 1.4 5 Note1 - - 4.0 - - 9.0 - 2.3 50 - 2.3 50 - - 150 - - 150 - 57 250 - 57 250 - - 400 - - 400 0 - VCC-1.5 0 - VCC-1.5 0 - VCC-2 0 - VCC-2 - 1.1 2.0 - 1.1 2.0 mA 50 200 - 50 200 - V/mV IIN(+) - IIN(-), VCM = 0V Note1 VCM = 0V Input Bias Current IBIAS Input Common Mode Voltage Range VI(R) Supply Current ICC VCC = 5V, RL = ∞ Voltage Gain GV VCC =15V, RL ≥ 15kΩ (for large swing) Note1 VCC = 30V Note1 Min. Typ. Max. Unit Min. mV nA nA V Large Signal Response Time TLRES VI = TTL Logic Swing VREF = 1.4V, VRL = 5V, RL = 5.1kΩ (Note2) - 300 - - 300 - ns Response Time TRES VRL = 5V, RL = 5.1kΩ (Note2) - 1.3 - - 1.3 - μs Output Sink Current ISINK VI(-) ≥ 1V, VI(+) = 0V, VO(P) ≤ 1.5V 6 18 - 6 18 - mA Output Saturation Voltage VSAT VI(-) ≥ 1V, VI(+) = 0V - 140 400 - 140 400 ISINK = 4mA Note1 - - 700 - - 700 VI(-) = 0V VI(+) = 1V VO(P) = 5V - 0.1 - - 0.1 - nA VO(P) = 30V - - 1.0 - - 1.0 μA Note1 - - 36 - - 36 V Output Leakage Current Io(LKG) Differential Voltage VI(DIFF) mV Note: 1. LM339/LM339A : 0 ≤ TA ≤ +70°C LM2901 : -40 ≤ TA ≤ +85°C LM239A : -25 ≤ TA ≤ +85°C 2. These parameters, although guaranteed, are not 100% tested in production. 3 LM339/LM339A, LM239A, LM2901 Electrical Characteristics (Continued) (VCC = 5V, TA = 25°C, unless otherwise specified) Parameter Symbol Input Offset Voltage VIO Input Offset Current IIO Input Bias Current IBIAS Input Common Mode Voltage Range VI(R) Supply Current ICC Voltage Gain GV Conditions LM2901 Min. Typ. Max. - 2 7 - 9 15 - 2.3 50 - 50 200 - 57 250 - 200 500 0 - VCC-1.5 0 - VCC-2 RL =∞, VCC=5V - 1.1 2.0 RL =∞,VCC=30V - 1.6 2.5 25 100 - VI =TTL Logic Swing VREF =1.4V, VRL =5V, RL =5.1kΩ (Note2) - 300 - VO(P) =1.4V, RS = 0Ω Note1 Note1 Note1 LM2901, VCC =30V Note1 VCC =15V, RL ≥ 15kΩ (for large swing) mV nA nA V mA V/mV Large Signal Response Time TLRES Response Time TRES VRL = 5V, RL = 5.1kΩ (Note2) - 1.3 - μs Output Sink Current ISINK VI(-) ≥ 1V, VI(+) =0V, VO(P) ≤ 1.5V 6 18 - mA Output Saturation Voltage VSAT VI(-) ≥ 1V, VI(+) = 0V - 140 400 ISINK =4mA Note1 - - 700 VI(-) = 0V VI(+) = 1V VO(P) = 5V - 0.1 - nA VO(P) = 30V - - 1.0 μA Note1 - - 36 V Output Leakage Current IO(LKG) Differential Voltage VI(DIFF) Note: 1. LM339/LM339A : 0 ≤ TA ≤ +70°C LM2901 : -40 ≤ TA ≤ +85°C LM239A : -25 ≤ TA ≤ +85°C 2. These parameters, although guaranteed, are not 100% tested in production. 4 Unit ns mV LM339/LM339A, LM239A, LM2901 Typical Performance Characteristics Figure 1. Supply Current vs Supply Voltage Figure 2. Input Current vs Supply Voltage Figure 3. Output Saturation Voltage vs Sink Current Figure 4. Response Time for Various Input Overdrive-Negative Transition Figure 5. Response Time for Various Input Overdrive-Positive Transition 5 LM339/LM339A, LM239A, LM2901 Mechanical Dimensions Package Dimensions in millimeters 2.08 ) 0.082 14-DIP 7.62 0.300 3.25 ±0.20 0.128 ±0.008 5.08 MAX 0.200 +0.10 0.25 –0.05 0~15° 6 +0.004 0.010 –0.002 1.50 ±0.10 0.059 ±0.004 #8 2.54 0.100 #7 19.40 ±0.20 0.764 ±0.008 #14 19.80 MAX 0.780 #1 0.46 ±0.10 0.018 ±0.004 ( 6.40 ±0.20 0.252 ±0.008 0.20 0.008 MIN 3.30 ±0.30 0.130 ±0.012 LM339/LM339A, LM239A, LM2901 Mechanical Dimensions (Continued) Package Dimensions in millimeters 14-SOP   $   %           3,1,'   7239,(:   ( 0$; &+$0)(5237,21$/ & $   (     & $///($'7,36  0   (  & $ % (1'9,(: 6,'(9,(: *$8*( 3/$1( 127(681/(6627+(5:,6(63(&,),(' $7+,63$&.$*(5()(5(1&(72-('(&06 9$5,$7,21$% %$//',0(16,216$5(,10,//,0(7(56 &',0(16,216$5((;&/86,9(2)%8556 02/')/$6+$1'7,(%$5(;7586,216 '',0(16,216$1'72/(5$1&(6$63(5$60(
LM339AN 价格&库存
很抱歉,暂时无法提供与“LM339AN”相匹配的价格&库存,您可以联系我们找货
