SP802SEN-L
SP802SEN-L
    ROCHESTER(罗切斯特)
    SOIC8_150MIL
    IC SUPERVISOR 1 CHANNEL 8SOIC
SP802SEN-L 数据手册
SP690T/S/R, SP802T/S/R, SP804T/S/R, and SP805T/S/R ® 3.0V/3.3V Low Power Microprocessor Supervisory with Battery Switch-Over ■ RESET and RESET Outputs ■ Reset asserted down to VCC = 1V ■ Reset Time Delay - 200ms ■ Watchdog Timer - 1.6 sec timeout ■ 40µA Maximum VCC Supply Current ■ 1µA Maximum Battery Supply Current ■ Power Switching 50mA Output in VCC Mode (1.5Ω) 10mA Output in Battery Mode (15Ω) ■ Battery Can Exceed VCC in Normal Operation ■ Precision Voltage Monitor for Power-Fail or Low-Battery Warning ■ Available in 8 pin SO and DIP packages ■ Pin Compatible Upgrades to MAX690T/S/R, MAX802T/S/R, MAX804T/S/R, MAX805T/S/R DESCRIPTION The SP690T/S/R, SP802T/S/R, SP804T/S/R and SP805T/S/R devices are a family of microprocessor (µP) supervisory circuits that integrate a myriad of components involved in discrete solutions to monitor power-supply and battery-control functions in µP and digital systems. The series will significantly improve system reliability and operational efficiency when compared to discrete solutions. The features of the SP690T/S/R, SP802T/S/R, SP804T/S/R and SP805T/S/R devices include a watchdog timer, a µP reset and backupbattery switchover, and power-failure warning; a complete µP monitoring and watchdog solution. The series is ideal for 3.0V or 3.3V applications in portable electronics, computers, controllers, and intelligent instruments and is a solid match for designs where it is critical to monitor the power supply to the µP and it’s related digital components. Refer to Sipex's SP690A/692A/802L/802M/805L/805M series for similar devices designed for +5V systems. Part Number RESET Active RESET Threshold RESET Accuracy PFI Accuracy Watchdog Input Backup-Battery Switch SP690T/805T LOW/HIGH 3.075V ±75mV ±4% YES YES SP802T/804T LOW/HIGH 3.075V ±60mV ±2% YES YES SP690S/805S LOW/HIGH 2.925V ±75mV ±4% YES YES SP802S/804S LOW/HIGH 2.925V ±60mV ±2% YES YES SP690R/805R LOW/HIGH 2.625V ±75mV ±4% YES YES SP802R/804R LOW/HIGH 2.625V ±60mV ±2% YES YES SP690T/S/R JAN 30-06 SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 1 © 2006 Sipex Corporation ABSOLUTE MAXIMUM RATINGS These are stress ratings only and functional operation of the device at these ratings or any other above those indicated in the operation sections of the specifications below is not implied. Exposure to absolute maximum rating conditions for extended periods of time may affect reliability and cause permanent damage to the device. VCC..................................................................................-0.3V to 6.0V VBATT................................................................................-0.3V to 6.0V All Other Inputs (NOTE 1).................................-0.3V to the higher of VCC or VBATT Continuous Input Current: VCC..................................................................................100mA VBATT..................................................................................20mA GND..................................................................................20mA WDI, PFI...........................................................................20mA Continuous Output Current: RESET, RESET, PFO.........................................................20mA VOUT......................................................................................100mA Power Dissipation per Package: 8pin NSOIC (derate 6.14mW/°C above +70°C)..............500mW 8pin PDIP (derate 11.8mW/°C above +70°C)..............1,000mW Storage Temperature........................................-65°C to +160°C Lead Temperature(soldering,10sec).............................................+300°C ESD Rating........................................................4KV Human Body Model SPECIFICATIONS VCC = 3.17V to 5.50V for the SP690T/SP80_T, VCC = 3.02V to 5.50V for the SP690S/SP80_S, VCC = 2.72V to 5.50V for the SP690R/SP80_R, VBATT = 3.60V, and TA = TMIN to TMAX unless otherwise noted. Typical values taken at TAMB = +25OC. PARAMETERS MIN. Operating Voltage Range, TYP. MAX. 1.0 UNITS CONDITIONS 5.5 Volts 25 40 µA 20 40 µA 0.4 1 µA 0.001 0.5 µA 0.02 µA VCC or VBATTERY, NOTE 1 VCC Supply Current, ISUPPLY VCC Supply Current in Battery Backup Mode VBATTERY Supply Current in Any Mode, NOTE 2 VBATTERY Leakage Current, NOTE 3 VBATTERY Leakage Current, NOTE 4 Output Voltage, VOUT VOUT in Battery-Backup Mode -0.1 VCC - 0.03 VCC - 0.0075 VCC - 0.3 VCC - 0.075 VCC - 0.0015 VCC - 0.0003 0.025 2.40 V 2.50 Battery Switch Threshold, VCC rising, NOTE 7 SP690T/S/R JAN 30-06 excluding IOUT 3.3V > VCC >VBATTERY + 0.2V IOUT = 50mA IOUT = 250µA, VCC > 2.5V VBATTERY - 0.02 VBATTERY - 0.0045 0.065 2.30 VCC=2.0V,VBATTERY=2.3V, excluding IOUT I = 5mA V VBATTERY - 0.018 VBATTERY - 0.15 Battery Switch Threshold, VCC falling excluding IOUT IOUT = 250µA, VBATTERY = 2.3V IOUT = 1mA, VBATTERY = 2.3V IOUT = 10mA, VBATTERY = 3.3V V VBATTERY - VCC, VSW > VCC > 1.75V, NOTE 5 VBATTERY > VCC, NOTE 6 V Values are identical to the Reset Threshold values at VCC rising SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 2 © 2006 Sipex Corporation SPECIFICATIONS (continued) VCC = 3.17V to 5.50V for the SP690T/SP80_T, VCC = 3.02V to 5.50V for the SP690S/SP80_S, VCC = 2.72V to 5.50V for the SP690R/SP80_R, VBATT = 3.60V, and TA = TMIN to TMAX unless otherwise noted. Typical values taken at TAMB = +25OC. PARAMETERS Reset Threshold, VRST NOTE 8 Reset Timeout Period, tWP RESET, PFO Output Voltage, VOH MIN. TYP. MAX. 3.00 3.00 3.075 3.085 3.15 2 .8 5 2 .8 5 2.925 3 .1 7 3.00 2.935 2.625 3.02 2 .7 0 2.635 2 .7 2 3.00 3.00 3.075 3.085 3 .1 2 3 .1 4 2 .8 8 2 .8 8 2 .9 2 5 2 .9 3 5 3 .0 0 3 .0 2 2 .5 9 2 .5 9 2 .6 2 5 2 .6 3 5 2.70 2.72 140 200 280 VCC - 0.3 VCC - 0.15 2 .5 5 2 .5 5 UNITS CONDITIONS V SP690T/805T, VCC falling SP690T/805T, VCC rising SP690S/805S, VCC falling SP690S/805S, VCC rising SP690R/805R, VCC falling SP690R/805R, VCC rising V SP802T/804T, VCC falling SP802T/804T, VCC rising SP802S/804S, VCC falling SP802S/804S, VCC rising SP802R/804R, VCC falling SP802R/804R, VCC rising ms V ISOURCE = 30µA ISINK = 1.2mA, SP690_/802_ where VCC = VRST minimum RESET, PFO Output Voltage, VOL 0.06 0.30 V RESET, PFO Output Voltage, VOL 0.13 0.30 V VBATTERY = 0V, VCC = 1.0V, ISINK = 40µA 0.30 V ISINK = 1.2mA, SP804_/805_ where VCC = VRST maximum -1 µA VBATTERY = 0V, VCC = VRST minimum, VRESET = 0V or VCC 180 500 µA VCC = 3.3V, VOH = 0V 1.60 2.24 0.06 RESET Output Voltage, VOL RESET Output Leakage Current, NOTE 11 -1 Output Short to GND Current, IOS, PFO and RESET Watchdog Timeout, tWD WDI Input Threshold VIH VIL WDI Input Current PFI Input Threshold PFI Input Current PFI Hysteresis, VPFH SP690T/S/R JAN 30-06 1.12 s VCC < 3.6V µs 1 WDI Pulse Width 0.7 x VCC V µA 0V < VCC < 5.5V V SP690_/805_, VCC VBATT, VOUT remains connected to VCC until VCC drops below VBATT. The VCC-to-VBATT comparator has a small 25mV typical hysteresis to prevent oscillation. NOTE 6: When VBATT > VCC > VSW, VOUT remains connected to VCC until VCC drops below the battery switch threshold, VSW. NOTE 7: VOUT switches from VBATT to VCC when VCC rises above the reset threshold, independent of VBATT. Switchover back to VCC occurs at the exact voltage that causes RESET to go HIGH (on the SP804_ and SP805_ RESET goes LOW). Switchover occurs 200ms prior to reset. NOTE 8: The reset threshold tolerance is wider for VCC rising than for VCC falling to accommodate the 10mV typical hysteresis, which prevents internal oscillation. NOTE 9: SP690_ and SP802_ devices only. NOTE 10: SP804_ and SP805_ devices only. NOTE 11: The leakage current into or out of the RESET pin is tested with RESET asserted (RESET output high impedance). SP690T/S/R JAN 30-06 SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 4 © 2006 Sipex Corporation INTERNAL BLOCK DIAGRAM VBATT 8 VCC 2 BATTERY SWITCHOVER CIRCUIT 1 VOUT SP690T/S/R SP802T/S/R SP804T/S/R SP805T/S/R BATTERY SWITCHOVER COMPARATOR 1.25V RESET GENERATOR RESET / RESET* 7 RESET COMPARATOR 1.25V WDI PFI WATCHDOG TIMER 6 4 PFO 5 POWER-FAIL COMPARATOR 1.25V GND SP690T/S/R JAN 30-06 3 *SP804T/S/R and SP805T/S/R only SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 5 © 2006 Sipex Corporation PINOUT VOUT 1 VCC 2 SP690T/S/R 7 SP802T/S/R 3 SP804T/S/R 6 SP805T/S/R 4 5 GND PFI 8 VBATTERY RESET / RESET* WDI PFO *SP804T/S/R and SP805T/S/R only PIN ASSIGNMENTS Pin 7 for SP690_/802_ only — Active-LOW Reset Output. — Whenever RESET is triggered by a watchdog timeout, it goes LOW for 200ms. It stays LOW whenever VCC is below the reset threshold and remains LOW for 200ms after VCC rises above the reset threshold or when the watchdog triggers a reset. Pin 1 —VOUT — Output Supply Voltage for CMOS RAM. When VCC is above the reset threshold, VOUT connects to VCC through a P-channel MOSFET switch. When VCC falls below the VSW and VBATTERY, VBATTERY connects to VOUT. Connect to VCC if no battery is used. Pin 2 — VCC — +5V Supply Input Pin 7 for SP804_/805_ only — Active-HIGH Open-Drain Reset Output. — The inverse operation of RESET. Pin 3 — GND — Ground reference for all signals Pin 4 — PFI — Power-Fail Comparator Input. When PFI is less than 1.25V or when VCC falls below the VSW, PFO goes LOW, otherwise PFO remains HIGH. Connect to GND if unused. Pin 5 Pin 8 — VBATTERY — Backup-Battery Input. When VCC falls below VSW and VBATTERY, VOUT switchesfrom VCC to VBATTERY. When VCC rises above the reset threshold, VOUT reconnects to VCC. VBATTERY may exceed VCC. Connect to VCC if no battery is used. — PFO — Power-Fail Comparator Output. Leave open if unused. Pin 6 — WDI — Watchdog Input. If WDI remains HIGH or LOW for 1.6 seconds, the internal watchdog timer triggers a reset. The internal watchdog timer clears when reset is asserted or WDI sees a rising or falling edge. The watchdog function cannot be disabled. SP690T/S/R JAN 30-06 SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 6 © 2006 Sipex Corporation TYPICAL CHARACTERISTICS (TAMB = 25oC, unless otherwise noted) 10000 40 Battery Supply Current (nA) Supply Current (µA) 1000 35 30 100 10 25 1 20 -60 -40 -20 0 20 40 60 80 100 120 0.1 -60 140 -35 -10 Figure 1. VCC Supply Current vs. Temperature (Normal Mode) 65 90 115 140 30 VBATTERY to VOUT On-Resistance (Ω) 1.26 PFI Threshold (Volts) 40 Figure 2. Battery Supply Current vs. Temperature 1.262 1.258 1.256 1.254 1.252 1.25 1.248 -60 15 Temperature (oC) Temperature (oC) -40 -20 0 20 40 60 80 100 120 25 20 15 10 5 0 -60 140 -40 -20 0 20 Temperature (oC) 40 60 80 100 120 140 Temperature (oC) Figure 3. PFI Threshold vs. Temperature Figure 4. VBATTERY to VOUT ON-Resistance vs. Temperature 3.15 3.5 Reset Threshold (Volts) On Resistance (Ω) 3 2.5 2 1.5 1 3.11 3.09 3.07 0.5 0 -60 3.13 -40 -20 0 20 40 60 80 100 120 3.05 -60 140 Temperature ( C) -35 -10 15 40 65 90 115 140 o Temperature (oC) Figure 5. VCC to VOUT On-Resistance vs. Temperature SP690T/S/R JAN 30-06 Figure 6. Reset Threshold vs. Temperature SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 7 © 2006 Sipex Corporation 14000 10000 Reset Timeout (mS) RESET Output Resistance (Ω) 185 12000 8000 6000 4000 180 2000 0 -60 175 -60 -35 -10 15 40 65 90 115 -40 -20 0 140 20 40 60 80 100 120 140 Temperature (oC) Temperature ( C) o Figure 7. Reset Output Resistance vs. Temperature Figure 8. Reset Timeout vs. Temperature 30 1E-06 Propagation Delay (µs) 26 decade /div 22 18 14 1E-14 10 -60 .0000 V3 .5000/div (V) -40 -20 0 20 40 60 80 100 120 140 5.000 Temperature (oC) Figure 9. Battery Current vs. VCC Voltage Figure 10. Reset-Comparator Propagation Delay vs. Temperature 1000 Voltage Drop (mV) [ VBATTERY - VOUT ] 1000 Voltage Drop (mV) [ VCC - VOUT ] VCC = 4.5V VBATTERY = 0V 100 10 1 1 100 10 1 10 IOUT (mA) 100 1 Figure 11. VCC to VOUT Vs. Output Current SP690T/S/R JAN 30-06 VCC = 0V VBATTERY = 4.5V IOUT (mA) 10 Figure 12. VBATTERY to VOUT Vs. Output Current SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 8 © 2006 Sipex Corporation VCC VBATTERY = 0V TA = +25 C V CC 2V div VCC 2KΩ T 0V RESET RESET RESET 1 0V 330pF 1 sec / div GND Figure 13A. SP690A RESET Output Voltage vs. Supply Voltage Figure 13B. Circuit for the SP690A/802L RESET Output Voltage vs. Supply Voltage VCC VCC V CC 1V div VCC 10KΩ 0V RESET 1 RESET VBATTERY 0V 330pF GND 1 sec /div Figure 14A. SP805L RESET Output Voltage vs. Supply Voltage Figure 14B. Circuit for the SP805 RESET Output Voltage vs. Supply Voltage VCC [ T ] TA = +25 C 1V / div 3.1V V CC 1 2V VCC 10KΩ RESET 3.1V T RESET 0 30pF 10µS / div GND Figure 15B. Circuit for the SP690A/802L RESET Response Time Figure 15A. SP690A RESET Response Time SP690T/S/R JAN 30-06 SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 9 © 2006 Sipex Corporation [ T VCC ] VCC 1V / div V CC 3.1V VCC 1 2V 10KΩ RESET RESET T 0V 330pF GND 10 µs / div Figure 16B. Circuit for the SP805 RESET Response Time Figure 16A. SP805L RESET Response Time +5V PFI 1.3V VCC = +5V TA = +25 C 1.2V V CC= 5V V BATTERY = 0 1KΩ PFI PFO 5V 0V PFO 30pF +1.25V 500ns / div Figure 17B. Circuit for the Power-Fail Comparator Response Time (fall) Figure 17A. Power-Fail Comparator Response Time (fall) +5V 1 1.3V PFI 1.2V VCC = +5V TA = +25 C V CC= 5 V BATTERY = 0 PFI PFO +1.25V 1 2 PFO 30pF 1KΩ T 500ns / div Figure 18A. Power-Fail Comparator Response Time (rise) SP690T/S/R JAN 30-06 Figure 18B. Circuit for the Power-Fail Comparator Response Time (rise) SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 10 © 2006 Sipex Corporation 3.0V or 3.3V VRST VSW VCC 0V 3.0V or 3.3V VBATTERY=3.6V VOUT VSW 0V 3.0V or 3.3V RESET tWP 0V 3.0V or 3.3V RESET* 0V 3.0V or 3.3V PFO VBATTERY=PFI=3.6V IOUT=0mA 0V *SP804T/S/R and SP805T/S/R only; Reset externally pulled up to VCC. Figure 19. Timing Diagram SP690T/S/R JAN 30-06 SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 11 © 2006 Sipex Corporation FEATURES THEORY OF OPERATION The SP690T/S/R, SP802T/S/R, SP804T/S/R and SP805T/S/R devices provide four key functions: 1. A battery backup switch for CMOS RAM, CMOS microprocessors, or other logic. 2. A reset output during power-up, power-down and brownout conditions. 3. A reset pulse if the optional watchdog timer has not been toggled within a specified time. 4. A 1.25V threshold detector for power-fail warning, low battery detection, or to monitor a power supply other than 3.3V or 3.0V. The SP690T/S/R, SP802T/S/R, SP804T/S/R and SP805T/S/R devices are microprocessor (µP) supervisory circuits that monitor the power supplied to digital circuits such as microprocessors, microcontrollers, or memory. The series is an ideal solution for portable, battery-powered equipment that requires power supply monitoring. Implementing this series will reduce the number of components and overall complexity. The watchdog functions of this product family will continuously oversee the operational status of a system. The SP690T/S/R, SP802T/S/R, SP804T/S/R and SP805T/S/R devices differ in their resetvoltage threshold levels and are ideally suited for applications in automotive systems, intelligent instruments, and battery-powered computers and controllers. The series is a solid match for designs where it is critical to monitor the power supply to the µP and it’s related digital components. These µP supervisory circuits are not shortcircuit protected. Shorting VOUT to ground excluding power-up transients such as charging a decoupling capacitor - may potentially damage these devices. Decouple both VCC and VBATTERY pins to ground by placing 0.1µF capacitors as close to the device as possible. The operational features and benefits of the SP690T/S/R, SP802T/S/R, SP804T/S/R and SP805T/S/R devices are described in more detail below. Reset Output Regulated +3.3V or +3.0V 0.1µF VCC VCC RESET µP PFO I/O LINE WDI GND PFI SP690T/S/R SP802T/S/R SP804T/S/R SP805T/S/R VOUT R2 RESET is guaranteed to be a logic LOW for 0V < VCC < VRST, provided that VBATTERY is greater than 1V. Without a backup battery, RESET is guaranteed valid for VCC > 1V. Once VCC exceeds the reset threshold, an internal timer keeps RESET low for the reset timeout period. After this period, RESET goes HIGH, as seen in Figure 19. VBATTERY GND BUS CMOS RAM R1 pin 7* NMI The microprocessor's (µP's) reset input starts the µP in a known state. When the µP is in an unknown state, it should be held in reset. The SP690T/S/R, SP802T/S/R, SP804T/S/R and SP805T/S/R devices assert reset during power-up and prevent code execution errors during power-down or brownout conditions. Unregulated DC 3.6V Lithium Battery VCC 0.1µF GND If a brownout condition occurs and VCC dips below the reset threshold, RESET goes LOW. Each time RESET is triggered, it stays low for the reset timeout period. Any time VCC goes below the reset threshold, the internal timer restarts. * RESET for the SP690T/S/R and the SP802T/S/R RESET for the SP804T/S/R and the SP805T/S/R Figure 20. Typical Operating Circuit SP690T/S/R JAN 30-06 SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 12 © 2006 Sipex Corporation Watchdog Input The watchdog timer can also initiate a reset. Refer to the Watchdog Input section. The watchdog circuit monitors the µP's activity. If the µP does not toggle the watchdog input (WDI) within 1.6sec, a reset pulse is triggered. The internal 1.6sec timer is cleared by either a reset pulse or by a transition (LOW-to-HIGH or HIGH-to-LOW) at WDI. If WDI is tied HIGH or LOW, a RESET pulse is triggered every 1.8sec (tWD plus tRS). The SP804T/S/R and SP805T/S/R active-HIGH RESET output is open drain and the inverse of the SP690T/S/R and SP802T/S/R RESET outputs. RESET is also triggered by a watchdog timeout. If WDI remains either high or low for a period that exceeds the watchdog timeout period (1.6 sec), RESET pulses low for 200mS. As long as RESET is asserted, the watchdog timer remains cleared. When RESET comes high, the watchdog resumes timing and must be serviced within 1.6sec. If WDI is tied high or low, a RESET pulse is triggered every 1.8sec (tWD plus tRS). As long as reset is asserted, the timer remains cleared and does not count. As soon as reset is de-asserted, the timer starts counting. Unlike the 5V SP690A series, the watchdog function cannot be disabled. Power-Fail Comparator Reset Threshold The power-fail comparator can be used as an under-voltage detector to signal the failing of a power supply (it is completely separate from the rest of the circuitry and does not need to be dedicated to this function). The PFI input is compared to an internal 1.25V. If PFI is less than VPFT, PFO goes low. The SP690T and SP805T devices are designed for 3.3V systems with a ±5% power-supply tolerance and a 10% system tolerance. Except for watchdog faults, reset will not assert as long as the power supply remains above 3.15V (3.3V - 5%). Reset is guaranteed to assert before the power supply falls below 3.0V. The power-fail comparator turns off and PFO goes LOW when VCC falls below VSW on power-down. The power-fail comparator turns on as VCC crosses VSW on power-up. If the comparator is not used, connect PFI to ground and leave PFO unconnected. The SP690S and SP805S devices are designed for 3.3V ±10% power supplies. Except for watchdog faults, they are guaranteed not to assert reset as long as the supply remains above 3.0V (3.3V - 10%). Reset is guaranteed to assert before the power supply fails below 2.85V (VCC - 14%). Backup-Battery Switchover The SP690R and SP805R devices are optimized for monitoring 3.0V ±10% power supplies. Reset will not occur until VCC falls below 2.7V (3.0V - 10%), but is guaranteed to occur before the supply falls below 2.55V (3.0V - 15%). In the event of a brownout or power failure, it may be necessary to preserve the contents of RAM. With a backup battery installed at VBATTERY, the devices automatically switch RAM to backup power when VCC fails. The SP802T/S/R and SP804T/S/R devices are respectively similar to the SP690T/S/R and SP805T/S/R devices with tightened reset and power-fail threshold tolerances. This family of µP supervisors (designed for 3.3V and 3V systems) doesn't always connect VBATTERY to VOUT when VBATTERY is greater than VCC. VBATTERY connects to VOUT (through a 15Ω switch) when VCC is below VSW and VBATTERY is greater than VCC. SP690T/S/R JAN 30-06 SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 13 © 2006 Sipex Corporation A) B) 3.0V or 3.3V VCC 1N4148 3.0V or 3.3V VCC 1N4148 VOUT VBATTERY pin 7* 0.1F +5V CONNECT TO STATIC RAM CONNECT TO µP pin 7* 0.1F GND CONNECT TO STATIC RAM VOUT VBATTERY CONNECT TO µP GND * RESET for the SP690T/S/R and the SP802T/S/R RESET for the SP804T/S/R and the SP805T/S/R Figure 21. Using a High Capacity Capacitor as a Backup Power Source Switchover at VSW (2.40V) ensures that batterybackup mode is entered before VOUT gets too close to the 2.0V minimum required to reliably retain data in CMOS RAM. Switchover at higher VCC voltages would decrease backup-battery life. When VCC recovers, switchover is deferred until VCC rises above the reset threshold, VRST, to ensure a stable supply. VOUT is connected to VCC through a 1.5Ω PMOS power switch. Replacing the Backup Battery If VBATTERY is decoupled with a 0.1µF capacitor to ground, the backup battery can be removed while VCC remains valid without danger of triggering RESET/RESET. As long as VCC stays above VSW, battery-backup mode cannot be entered. Adding Hysteresis to the Power-Fail Comparator Using a High Capacity Capacitor as a Backup Power Source The power-fail comparator has a typical input hysteresis of 10mV. This is sufficient for most applications where a power-supply line is being monitored through an external voltage divider (refer to the Monitoring an Additional Power Supply section). Figure 21 shows two ways to use a High Value Capacitor as a backup power source. The High Value Capacitor may be connected through a diode to the 3V input as in Figure 21A or, if a 5V supply is also available, the High Value Capacitor may be charged up to the 5V supply as in Figure 21B allowing a longer backup period. Since VBATTERY can exceed VCC while VCC is above the reset threshold, there are no special precautions when using these µP supervisors with a High Value Capacitor. If additional noise margin is desired, connect a resistor between PFO and PFI as shown in Figure 22A. Select the ratio of R1 and R2 such that PFI sees 1.25V when VIN falls to its trip point (VTRIP). R3 adds the hysteresis and will typically be more than 10 times the value of R1 or R2. The hysteresis window extends both above (VH) and below (VL) the original trip point (VTRIP). Operation Without a Backup Power Source These µP supervisors were designed for battery-backed applications. If a backup power source is not used, connect both VBATTERY and VOUT to VCC. Since there is no need to switch over to any backup power source, VOUT does not need to be switched. A direct connection to VCC eliminates any voltage drops across the switch which may push VOUT below VCC. SP690T/S/R JAN 30-06 SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 14 © 2006 Sipex Corporation VIN VIN A.) B.) R1 R1 VCC VCC PFI PFI + + R2 SP690T/S/R SP802T/S/R SP804T/S/R SP805T/S/R R3 *C1 R2 SP690T/S/R SP802T/S/R SP804T/S/R SP805T/S/R R3 *C1 PFO PFO GND GND TOµP TOµP *OPTIONAL PFO PFO 0V 0V VL VTRIP 0V VH ( ) ( )( )( ) [ ( ) ] R1 + R2 R2 VTRIP = VPFT VH = 0V VIN VPFT + VPFH VL = R1 VPFT R1 VTRIP = VPFT 1 + 1 + 1 R1 R2 R3 VL = R1 - VCC R3 1 + 1 + 1 R1 R2 R3 VTRIP ( [( R1 + R2 R2 ) )( VPFT + VPFH VIN VH ) 1 + 1 + 1 - (VCC - VD) R1 R2 R3 R3 ] WHERE VPFT = 1.25V VPFH = 10mV WHERE VPFT = 1.25V VD = DIOD FORWARD VOLTAGE DROP VPFH = 10mV Figure 22A. Adding Additional Hysteresis to the Power-Fail Comparator. Figure 22B. Shifting the Additional Hysteresis above VPFT The current through R1 and R2 should be at least 1µA to ensure that the 25nA (max over extended temperature range) PFI input current does not shift the trip point. R3 should be larger than 10kΩ so it does not load down the PFO pin. Capacitor C1 adds additional noise rejection. Connecting an ordinary signal diode in series with R3, as in Figure 22B, causes the lower trip point (VL) to coincide with the trip point without hysteresis (VTRIP), so the entire hysteresis window occurs above VTRIP. This method provides additional noise margin without compromising the accuracy of the power-fail threshold when the monitored voltage is falling. It is useful for accurately detecting when a voltage falls past a threshold. VIN 3.0V OR 3.3V VCC VCC R1 R1 SP690T/S/R SP802T/S/R PFI PFI PFO PFO SP804T/S/R SP805T/S/R R2 SP804T/S/R SP805T/S/R R2 SP690T/S/R SP802T/S/R GND GND V- VCC VCC PFO PFO V- VL [( [ ( VTRIP = R2 VTRIP VTRIP 0V )( ) ] ) ] VPFT + VPFH 1 + 1 R1 R2 - VCC R1 VTRIP = VPFT 1 + 1 - VCC VL = R2 VPFT R1 R2 ( ( ) )( ) VH = VPFT + VPFH R3 VIN VH R1 + R2 R2 R1 + R2 R2 WHERE VPFT = 1.25V VPFH = 10mV NOTE: VTRIP IS NEGATIVE Figure 23. Using the Power-Fail Comparator to Monitor an Additional Power Supply SP690T/S/R JAN 30-06 SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 15 © 2006 Sipex Corporation Buffered RESET connects to System Components VCC 1nF Capacitor VOUT TO GND VCC µP Above Line RESET Generated RESET RESET 4.7KΩ GND NO RESET Generated GND Figure 24. Interfacing to Microprocessors with Bidirectional RESET I/O Figure 25. Maximum Transient Duration without Causing a Reset Pulse vs. Reset Comparator Overdrive Monitoring an Additional Power Supply These µP supervisors can monitor either positive or negative supplies using a resistor voltage divider to PFI. PFO can be used to generate an interrupt to the µP, as seen in Figure 23. Figure 25 shows maximum transient duration vs. reset-comparator overdrive, for which reset pulses are not generated. The data was generated using negative-going VCC pulses, starting at 3.3V and ending below the reset threshold by the magnitude indicated (reset comparator overdrive). The graph shows the maximum pulse width a negative-going VCC transient may typically have without causing a reset pulse to be issued. As the amplitude of the transient increases (i.e. goes farther below the reset threshold), the maximum allowable pulse width decreases. Typically, a VCC transient that goes 100mV below the reset threshold and lasts for 40µs or less will not cause a reset pulse to be issued. A 100nF bypass capacitor mounted close to the VCC pin provides additional transient immunity. Interfacing to µPs with Bidirectional Reset Pins Any µPs with bidirectional reset pins, such as the Motorola 68HC11 series, can interface with the SP690_ and the SP802_ RESET outputs. For example, if the RESET output is driven HIGH and the µP wants to pull it LOW, indeterminate logic levels may result. To correct this, connect a 4.7kΩ resistor between the RESET output and the µP reset I/O, as in Figure 24. Buffer the RESET output to other system components. Negative-Going VCC Transients While issuing resets to the µP during power-up, power-down, and brownout conditions, these supervisors are relatively immune to shortduration negative-going V CC transients (glitches). It is usually undesirable to reset the µP when VCC experiences only small glitches. SP690T/S/R JAN 30-06 SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 16 © 2006 Sipex Corporation PACKAGE: PLASTIC DUAL–IN–LINE (NARROW) E1 E D1 = 0.005" min. (0.127 min.) A1 = 0.015" min. (0.381min.) D A = 0.210" max. (5.334 max). C A2 B1 B e = 0.100 BSC (2.540 BSC) Ø L eA = 0.300 BSC (7.620 BSC) ALTERNATE END PINS (BOTH ENDS) DIMENSIONS (Inches) Minimum/Maximum (mm) 8–PIN 14–PIN 16–PIN 18–PIN 20–PIN 22–PIN A2 0.115/0.195 (2.921/4.953) 0.115/0.195 (2.921/4.953) 0.115/0.195 (2.921/4.953) 0.115/0.195 (2.921/4.953) 0.115/0.195 (2.921/4.953) 0.115/0.195 (2.921/4.953) B 0.014/0.022 (0.356/0.559) 0.014/0.022 (0.356/0.559) 0.014/0.022 (0.356/0.559) 0.014/0.022 (0.356/0.559) 0.014/0.022 (0.356/0.559) 0.014/0.022 (0.356/0.559) B1 0.045/0.070 (1.143/1.778) 0.045/0.070 (1.143/1.778) 0.045/0.070 (1.143/1.778) 0.045/0.070 (1.143/1.778) 0.045/0.070 (1.143/1.778) 0.045/0.070 (1.143/1.778) C 0.008/0.014 (0.203/0.356) 0.008/0.014 (0.203/0.356) 0.008/0.014 (0.203/0.356) 0.008/0.014 (0.203/0.356) 0.008/0.014 (0.203/0.356) 0.008/0.014 (0.203/0.356) D 0.355/0.400 0.735/0.775 0.780/0.800 0.880/0.920 0.980/1.060 1.145/1.155 (9.017/10.160) (18.669/19.685) (19.812/20.320) (22.352/23.368) (24.892/26.924) (29.083/29.337) E 0.300/0.325 (7.620/8.255) 0.300/0.325 (7.620/8.255) 0.300/0.325 (7.620/8.255) 0.300/0.325 (7.620/8.255) 0.300/0.325 (7.620/8.255) 0.300/0.325 (7.620/8.255) E1 0.240/0.280 (6.096/7.112) 0.240/0.280 (6.096/7.112) 0.240/0.280 (6.096/7.112) 0.240/0.280 (6.096/7.112) 0.240/0.280 (6.096/7.112) 0.240/0.280 (6.096/7.112) L 0.115/0.150 (2.921/3.810) 0.115/0.150 (2.921/3.810) 0.115/0.150 (2.921/3.810) 0.115/0.150 (2.921/3.810) 0.115/0.150 (2.921/3.810) 0.115/0.150 (2.921/3.810) Ø 0°/ 15° (0°/15°) 0°/ 15° (0°/15°) 0°/ 15° (0°/15°) 0°/ 15° (0°/15°) 0°/ 15° (0°/15°) 0°/ 15° (0°/15°) SP690T/S/R JAN 30-06 SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 17 © 2006 Sipex Corporation PACKAGE: PLASTIC SMALL OUTLINE (SOIC) (NARROW) E H h x 45° D A Ø e B A1 DIMENSIONS (Inches) Minimum/Maximum (mm) SP690T/S/R JAN 30-06 L 8–PIN 14–PIN 16–PIN A 0.053/0.069 (1.346/1.748) 0.053/0.069 (1.346/1.748) 0.053/0.069 (1.346/1.748) A1 0.004/0.010 (0.102/0.249 0.004/0.010 (0.102/0.249) 0.004/0.010 (0.102/0.249) B 0.014/0.019 (0.35/0.49) 0.013/0.020 (0.330/0.508) 0.013/0.020 (0.330/0.508) D 0.189/0.197 (4.80/5.00) 0.337/0.344 0.386/0.394 (8.552/8.748) (9.802/10.000) E 0.150/0.157 (3.802/3.988) 0.150/0.157 (3.802/3.988) 0.150/0.157 (3.802/3.988) e 0.050 BSC (1.270 BSC) 0.050 BSC (1.270 BSC) 0.050 BSC (1.270 BSC) H 0.228/0.244 (5.801/6.198) 0.228/0.244 (5.801/6.198) 0.228/0.244 (5.801/6.198) h 0.010/0.020 (0.254/0.498) 0.010/0.020 (0.254/0.498) 0.010/0.020 (0.254/0.498) L 0.016/0.050 (0.406/1.270) 0.016/0.050 (0.406/1.270) 0.016/0.050 (0.406/1.270) Ø 0°/8° (0°/8°) 0°/8° (0°/8°) 0°/8° (0°/8°) SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 18 © 2006 Sipex Corporation ORDERING INFORMATION Model Temperature Range Package Types SP690TCN......................................................0°C to +70°C......................................................8-Pin NSOIC SP690TCP......................................................0°C to +70°C.........................................................8-Pin PDIP SP690TEN.....................................................-40°C to +85°C....................................................8-Pin NSOIC SP690TEP.....................................................-40°C to +85°C.......................................................8-Pin PDIP SP690SCN......................................................0°C to +70°C......................................................8-Pin NSOIC SP690SCP......................................................0°C to +70°C.........................................................8-Pin PDIP SP690SEN.....................................................-40°C to +85°C....................................................8-Pin NSOIC SP690SEP.....................................................-40°C to +85°C.......................................................8-Pin PDIP SP690RCN......................................................0°C to +70°C......................................................8-Pin NSOIC SP690RCP......................................................0°C to +70°C.........................................................8-Pin PDIP SP690REN.....................................................-40°C to +85°C....................................................8-Pin NSOIC SP690REP.....................................................-40°C to +85°C.......................................................8-Pin PDIP SP802TCN........................................................0°C to +70°C....................................................8-Pin NSOIC SP802TCP........................................................0°C to +70°C.......................................................8-Pin PDIP SP802TEN.......................................................-40°C to +85°C..................................................8-Pin NSOIC SP802TEP.......................................................-40°C to +85°C.....................................................8-Pin PDIP SP802SCN........................................................0°C to +70°C....................................................8-Pin NSOIC SP802SCP........................................................0°C to +70°C.......................................................8-Pin PDIP SP802SEN.......................................................-40°C to +85......................................................8-Pin NSOIC SP802SEP.......................................................-40°C to +85°C.....................................................8-Pin PDIP SP802RCN........................................................0°C to 0°C........................................................8-Pin NSOIC SP802RCP........................................................0°C to+70°C...................................................... 8-Pin PDIP SP802REN.......................................................-40°C to +85°C..................................................8-Pin NSOIC SP802REP.......................................................-40°C to +85°C.....................................................8-Pin PDIP SP804TCN.......................................................0°C to +70°C.....................................................8-Pin NSOIC SP804TCP.......................................................0°C to +70°C........................................................8-Pin PDIP SP804TEN......................................................-40°C to +85°C...................................................8-Pin NSOIC SP804TEP......................................................-40°C to +85°C......................................................8-Pin PDIP SP804SCN.......................................................0°C to +70°C.....................................................8-Pin NSOIC SP804SCP.......................................................0°C to +70°C........................................................8-Pin PDIP SP804SEN......................................................-40°C to +85°C...................................................8-Pin NSOIC SP804SEP......................................................-40°C to +85°C......................................................8-Pin PDIP SP804RCN.......................................................0°C to +70°C.....................................................8-Pin NSOIC SP804RCP.......................................................0°C to +70°C........................................................8-Pin PDIP SP804REN......................................................-40°C to +85°C...................................................8-Pin NSOIC SP804REP......................................................-40°C to +85°C......................................................8-Pin PDIP SP805TCN........................................................0°C to +70°C....................................................8-Pin NSOIC SP805TCP........................................................0°C to +70°C.......................................................8-Pin PDIP SP805TEN.......................................................-40°C to +8C.................................................. ..8-Pin NSOIC SP805TEP.......................................................-40°C to +85°C.....................................................8-Pin PDIP SP805SCN........................................................0°C to+70°C.....................................................8-Pin NSOIC SP805SCP........................................................0°C to +70°C.......................................................8-Pin PDIP SP805SEN.......................................................-40°C to +85°C..................................................8-Pin NSOIC SP805SEP.......................................................-40°C to +85°C.....................................................8-Pin PDIP SP805RCN........................................................0°C to +70°C....................................................8-Pin NSOIC SP805RCP........................................................0°C to +70°C.......................................................8-Pin PDIP SP805REN.......................................................-40°C to +85°C..................................................8-Pin NSOIC SP805REP.......................................................-40°C to +85°C.....................................................8-Pin PDIP Please consult the factory for pricing and availability on a Tape-On-Reel option. SP690T/S/R JAN 30-06 SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 19 © 2006 Sipex Corporation Corporation SIGNAL PROCESSING EXCELLENCE Sipex Corporation Headquarters and Sales Office 22 Linnell Circle Billerica, MA 01821 TEL: (978) 667-8700 FAX: (978) 670-9001 e-mail: sales@sipex.com Sales Office 233 South Hillview Drive Milpitas, CA 95035 TEL: (408) 934-7500 FAX: (408) 935-7600 Sipex Corporation reserves the right to make changes to any products described herein. Sipex does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights nor the rights of others. SP690T/S/R JAN 30-06 SP690T/S/R, 802/T/S/R, 804T/S/R, 805T/S/R Low Power Microprocessor Supervisory 20 © 2006 Sipex Corporation
SP802SEN-L 价格&库存
很抱歉,暂时无法提供与“SP802SEN-L”相匹配的价格&库存,您可以联系我们找货
