S-1011J4B-M6T1U4
S-1011J4B-M6T1U4
    ABLIC(艾普凌科)
    SOT23-6
    IC SUPERVISOR 1 CHANNEL SOT23-6
S-1011J4B-M6T1U4 数据手册
S-1011 Series www.ablic.com www.ablicinc.com HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 © ABLIC Inc., 2014-2015 The S-1011 Series is a high-accuracy voltage detector developed using CMOS technology. The detection voltage is fixed internally, and the accuracy of the S-1011 Series A / C / E / G type is 1.5%. It operates with current consumption of 600 nA typ. Apart from the power supply pin, the detection voltage input pin (SENSE pin) is also prepared in the SENSE detection product, so the output is stable even if the SENSE pin falls to 0 V. The detection signal and release signal can be delayed by setting a capacitor externally, and the detection delay time accuracy is 20% (CN = 3.3 nF, Ta = 25°C), the release delay time accuracy is 20% (CP = 3.3 nF, Ta = 25°C). Output form is Nch open-drain output.  Features  Detection voltage:          Detection voltage accuracy: Detection delay time accuracy: Release delay time accuracy: Current consumption: Operation voltage range: Hysteresis width: Output form: Operation temperature range: Lead-free (Sn 100%), halogen-free 3.0 V to 10.0 V (0.05 V step) (SENSE detection product) 3.6 V to 10.0 V (0.05 V step) (VDD detection product) 1.5% (A / C / E / G type) 20% (CN = 3.3 nF) 20% (CP = 3.3 nF) 600 nA typ. 1.8 V to 36.0 V "Available" (5.0% typ.) / "unavailable" is selectable. Nch open-drain output Ta = 40°C to 85°C  Applications     Power supply monitor for microcomputer and reset for CPU Constant voltage power supply monitor for TV and home appliance etc. Power supply monitor for Blu-ray recorder, notebook PC and digital still camera Industrial equipment, housing equipment  Package  SOT-23-6 1 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Block Diagrams 1. S-1011 Series A / J type (VDD detection product) CP Function Status Voltage detection VDD detection Available Hysteresis width (5.0% typ.) VDD   *1 Delay circuit OUT *1 VREF *1 *1 VSS CN *1. Parasitic diode Figure 1 2. S-1011 Series C / L type (VDD detection product) CP Function Status Voltage detection VDD detection Hysteresis width Unavailable VDD   *1 Delay circuit OUT *1 VREF *1 *1 VSS CN *1. Parasitic diode Figure 2 2 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 3. S-1011 Series E / N type (SENSE detection product) CP SENSE Function Status Voltage detection SENSE detection Available Hysteresis width (5.0% typ.) VDD  *1 *1  Delay circuit OUT *1 VREF *1 *1 VSS CN *1. Parasitic diode Figure 3 4. S-1011 Series G / Q type (SENSE detection product) CP SENSE Function Status Voltage detection SENSE detection Hysteresis width Unavailable VDD  *1 *1  Delay circuit OUT *1 VREF *1 *1 VSS CN *1. Parasitic diode Figure 4 3 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Product Name Structure Users can select the product type and detection voltage value for the S-1011 Series. Refer to "1. Product name" regarding the contents of product name, "2. Function list of product types" regarding the product types, "3. Package" regarding the package drawings and "4. Product name lists" regarding details of the product name. 1. Product name S-1011 x xx - M6T1 U 4 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 M6T1: SOT-23-6, Tape Detection voltage value 30 to A0 (e.g., when the output voltage is 3.0 V, it is expressed as 30. when the output voltage is 10.0 V, it is expressed as A0.) Product type*2 A, C, E, G, J, L, N, Q *1. *2. Refer to the tape drawing. Refer to "2. Function list of product types". Remark 2. Although the detection voltage in the S-1011 Series is 10.0 V max., the detection voltage exceeding 10.0 V with an external resistor can be set. Refer to "2. SENSE pin" in " Operation" for details. Function list of product types Table 1 Product Type A C E G J L N Q 3. Voltage Detection VDD detection VDD detection SENSE detection SENSE detection VDD detection VDD detection SENSE detection SENSE detection Output Logic Active "L" Active "L" Active "L" Active "L" Active "L" Active "L" Active "L" Active "L" Detection Voltage 5.0 V to 10.0 V 5.0 V to 10.0 V 5.0 V to 10.0 V 5.0 V to 10.0 V 3.6 V to 4.95 V 3.6 V to 4.95 V 3.0 V to 4.95 V 3.0 V to 4.95 V Package Table 2 Package Name SOT-23-6 4 Hysteresis Width Available (5.0% typ.) Unavailable Available (5.0% typ.) Unavailable Available (5.0% typ.) Unavailable Available (5.0% typ.) Unavailable Package Drawing Codes Dimension Tape Reel MP006-A-P-SD MP006-A-C-SD MP006-A-R-SD HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 4. Product name lists 4. 1 S-1011 Series A type Voltage detection: VDD detection Hysteresis width: Available (5.0% typ.) Output logic: Active "L" Detection voltage: 5.0 V to 10.0 V Table 3 Detection Voltage 5.0 V  1.5% 6.0 V  1.5% 7.0 V  1.5% 8.0 V  1.5% 9.0 V  1.5% 10.0 V  1.5% Remark 4. 2 SOT-23-6 S-1011A50-M6T1U4 S-1011A60-M6T1U4 S-1011A70-M6T1U4 S-1011A80-M6T1U4 S-1011A90-M6T1U4 S-1011AA0-M6T1U4 Please contact our sales office for products with specifications other than the above. S-1011 Series C type Voltage detection: VDD detection Hysteresis width: Unavailable Output logic: Active "L" Detection voltage: 5.0 V to 10.0 V Table 4 Detection Voltage 5.0 V  1.5% 6.0 V  1.5% 7.0 V  1.5% 8.0 V  1.5% 9.0 V  1.5% 10.0 V  1.5% Remark 4. 3 SOT-23-6 S-1011C50-M6T1U4 S-1011C60-M6T1U4 S-1011C70-M6T1U4 S-1011C80-M6T1U4 S-1011C90-M6T1U4 S-1011CA0-M6T1U4 Please contact our sales office for products with specifications other than the above. S-1011 Series E type Voltage detection: SENSE detection Hysteresis width: Available (5.0% typ.) Output logic: Active "L" Detection voltage: 5.0 V to 10.0 V Table 5 Detection Voltage 5.0 V  1.5% 6.0 V  1.5% 7.0 V  1.5% 8.0 V  1.5% 9.0 V  1.5% 10.0 V  1.5% Remark 4. 4 SOT-23-6 S-1011E50-M6T1U4 S-1011E60-M6T1U4 S-1011E70-M6T1U4 S-1011E80-M6T1U4 S-1011E90-M6T1U4 S-1011EA0-M6T1U4 Please contact our sales office for products with specifications other than the above. S-1011 Series G type Voltage detection: SENSE detection Hysteresis width: Unavailable Output logic: Active "L" Detection voltage: 5.0 V to 10.0 V Table 6 Detection Voltage 5.0 V  1.5% 6.0 V  1.5% 7.0 V  1.5% 8.0 V  1.5% 9.0 V  1.5% 10.0 V  1.5% Remark SOT-23-6 S-1011G50-M6T1U4 S-1011G60-M6T1U4 S-1011G70-M6T1U4 S-1011G80-M6T1U4 S-1011G90-M6T1U4 S-1011GA0-M6T1U4 Please contact our sales office for products with specifications other than the above. 5 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 4. 5 S-1011 Series J type Voltage detection: VDD detection Hysteresis width: Available (5.0% typ.) Output logic: Active "L" Detection voltage: 3.6 V to 4.95 V Table 7 Detection Voltage 3.6 V  3.0% 4.2 V  2.5% Remark 4. 6 SOT-23-6 S-1011J36-M6T1U4 S-1011J42-M6T1U4 Please contact our sales office for products with specifications other than the above. S-1011 Series L type Voltage detection: VDD detection Hysteresis width: Unavailable Output logic: Active "L" Detection voltage: 3.6 V to 4.95 V Table 8 Detection Voltage 3.6 V  3.0% 4.2 V  2.5% Remark 4. 7 SOT-23-6 S-1011L36-M6T1U4 S-1011L42-M6T1U4 Please contact our sales office for products with specifications other than the above. S-1011 Series N type Voltage detection: SENSE detection Hysteresis width: Available (5.0% typ.) Output logic: Active "L" Detection voltage: 3.0 V to 4.95 V Table 9 Detection Voltage 3.0 V  3.0% 3.3 V  3.0% 3.6 V  3.0% 4.2 V  2.5% Remark 4. 8 SOT-23-6 S-1011N30-M6T1U4 S-1011N33-M6T1U4 S-1011N36-M6T1U4 S-1011N42-M6T1U4 Please contact our sales office for products with specifications other than the above. S-1011 Series Q type Voltage detection: SENSE detection Hysteresis width: Unavailable Output logic: Active "L" Detection voltage: 3.0 V to 4.95 V Table 10 Detection Voltage 3.0 V  3.0% 3.3 V  3.0% 3.6 V  3.0% 4.2 V  2.5% Remark 6 SOT-23-6 S-1011Q30-M6T1U4 S-1011Q33-M6T1U4 S-1011Q36-M6T1U4 S-1011Q42-M6T1U4 Please contact our sales office for products with specifications other than the above. HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Pin Configurations 1. S-1011 Series A / C / J / L type (VDD detection product) 1. 1 SOT-23-6 Table 11 Top view 6 5 4 1 2 3 Figure 5 Pin No. Symbol Description 1 VDD Voltage input pin NC*1 2 No connection 3 OUT Voltage detection output pin *2 CP 4 Connection pin for release delay capacitor 5 VSS GND pin CN*3 6 Connection pin for detection delay capacitor *1. The NC pin is electrically open. The NC pin can be connected to the VDD pin or the VSS pin. *2. Connect a capacitor between the CP pin and the VSS pin. The release delay time can be adjusted according to the capacitance. Moreover, the CP pin is available even when it is open. *3. Connect a capacitor between the CN pin and the VSS pin. The detection delay time can be adjusted according to the capacitance. Moreover, the CN pin is available even when it is open. 2. S-1011 Series E / G / N / Q type (SENSE detection product) 2. 1 SOT-23-6 Table 12 Top view 6 5 4 1 2 3 Figure 6 Pin No. Symbol Description 1 VDD Voltage input pin 2 SENSE Detection voltage input pin 3 OUT Voltage detection output pin CP*1 4 Connection pin for release delay capacitor 5 VSS GND pin CN*2 6 Connection pin for detection delay capacitor *1. Connect a capacitor between the CP pin and the VSS pin. The release delay time can be adjusted according to the capacitance. Moreover, the CP pin is available even when it is open. *2. Connect a capacitor between the CN pin and the VSS pin. The detection delay time can be adjusted according to the capacitance. Moreover, the CN pin is available even when it is open. 7 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Absolute Maximum Ratings Table 13 (Ta = 25°C unless otherwise specified) Item Symbol Absolute Maximum Rating Unit Power supply voltage VDD  VSS VSS  0.3 to VSS  45 V SENSE pin input voltage VSENSE VSS  0.3 to VSS  45 V CP pin input voltage VCP VSS  0.3 to VDD  0.3  VSS  7.0 V CN pin input voltage VCN VSS  0.3 to VDD  0.3  VSS  7.0 V Output voltage VOUT VSS  0.3 to VSS  45 V Output current IOUT 25 mA Operation ambient temperature Topr 40 to 85 °C Storage temperature Tstg 40 to 125 °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Table 14 Item Condition Board 1 SOT-23-6 ja Junction-to-ambient thermal resistance*1 Board 2 *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Remark 8 Symbol Min.   Typ. 159 124 Refer to " Thermal Characteristics" for details of power dissipation and test board. Max.   Unit °C/W °C/W HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Electrical Characteristics 1. VDD detection product 1. 1 S-1011 Series J / L type Table 15 Item Symbol Condition 3.6 V  VDET(S)  4.15 V Detection voltage*1 VDET 4.2 V  VDET(S)  4.95 V 3.6 V  VDET(S)  4.15 V Hysteresis width VHYS J type 4.2 V  VDET(S)  4.95 V *2 Current consumption Operation voltage ISS VDD Output current IOUT Leakage current ILEAK L type 3.6 V  VDET(S)  4.95 V VDD = VDET  0.1 V, 3.6 V  VDET  4.95 V  Output transistor VDD = 2.9 V Nch *3 VDS = 0.05 V Output transistor VDD = 30.0 V, VOUT = 30.0 V Nch CN = 3.3 nF CP = 3.3 nF (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VDET(S) VDET(S)  0.970 VDET(S) VDET(S)  0.975 VDET VDET  0.010  0.050 VDET VDET  0.020  0.050  0  0.60 1.8  VDET(S)  1.030 VDET(S)  1.025 VDET  0.100 VDET  0.090  1.60 36.0 V 1 V 1 V 1 V 1 V A V 1 2 1 0.33   mA 3   2.0 A 3 ms ms 4 4 k  k  Detection delay time*4 tRESET 8.0 10.0 12.0 Release delay time*5 tDELAY 8.0 10.0 12.0 CP pin discharge RCP VDD = 6.9 V, VCP = 0.5 V 0.52  2.2 ON resistance CN pin discharge RCN VDD = 2.9 V, VCN = 0.5 V 1.0  5.0 ON resistance *1. VDET: Actual detection voltage value, VDET(S): Set detection voltage value *2. Hysteresis width is "unavailable", so release voltage = detection voltage. *3. VDS: Drain-to-source voltage of the output transistor *4. The time period from when the pulse voltage of VDET(S)  0.5 V  VDET(S)  0.5 V is applied to the VDD VOUT reaches VDD / 2, after the power supply voltage (VDD) reaches the release voltage once. *5. The time period from when the pulse voltage of VDET(S)  0.5 V  VDET(S)  0.5 V is applied to the VDD VOUT reaches VDD / 2. pin to when pin to when 9 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 1. 2 S-1011 Series A / C type Table 16 Item Symbol Detection voltage*1 VDET Hysteresis width VHYS Current consumption Operation voltage ISS VDD Output current IOUT Leakage current ILEAK Condition 5.0 V  VDET(S)  10.0 V A type C type*2 VDD = VDET  0.1 V, 5.0 V  VDET  10.0 V  Output transistor VDD = 4.5 V Nch *3 VDS = 0.05 V Output transistor VDD = 30.0 V, VOUT = 30.0 V Nch CN = 3.3 nF CP = 3.3 nF (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VDET(S) VDET(S) VDET(S) V 1  0.985  1.015 VDET VDET VDET V 1  0.030  0.050  0.080  0  V 1  0.60 1.60 A 2 1.8  36.0 V 1 0.5   mA 3   2.0 A 3 ms ms 4 4 k  k  Detection delay time*4 tRESET 8.0 10.0 12.0 Release delay time*5 tDELAY 8.0 10.0 12.0 CP pin discharge RCP VDD = 14.0 V, VCP = 0.5 V 0.30  2.60 ON resistance CN pin discharge RCN VDD = 4.5 V, VCN = 0.5 V 0.63  2.60 ON resistance *1. VDET: Actual detection voltage value, VDET(S): Set detection voltage value *2. Hysteresis width is "unavailable", so release voltage = detection voltage. *3. VDS: Drain-to-source voltage of the output transistor *4. The time period from when the pulse voltage of VDET(S)  1.0 V  VDET(S)  1.0 V is applied to the VDD VOUT reaches VDD / 2, after the power supply voltage (VDD) reaches the release voltage once. *5. The time period from when the pulse voltage of VDET(S)  1.0 V  VDET(S)  1.0 V is applied to the VDD VOUT reaches VDD / 2. 10 pin to when pin to when HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 2. SENSE detection product 2. 1 S-1011 Series N / Q type Table 17 Item Symbol Condition 3.0 V  VDET(S)  4.15 V Detection voltage *1 VDET VDD = 16.0 V 4.2 V  VDET(S)  4.95 V 3.0 V  VDET(S)  4.15 V Hysteresis width VHYS VDD = 16.0 V N type 4.2 V  VDET(S)  4.95 V Q type*2 3.0 V  VDET(S)  4.95 V Current *3 consumption Operation voltage VDD Output current IOUT ISS Leakage current ILEAK *5 VDD = 16.0 V, VSENSE = VDET  0.1 V, 3.0 V  VDET  4.95 V  Output transistor VDD = 5.0 V, VSENSE = 2.9 V Nch *4 VDS = 0.05 V Output transistor VDD = 30.0 V, VOUT = 30.0 V, Nch VSENSE = 30.0 V CN = 3.3 nF CP = 3.3 nF  (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VDET(S) VDET(S)  0.970 VDET(S) VDET(S)  0.975 VDET VDET  0.010  0.050 VDET VDET  0.020  0.050 VDET(S)  1.030 VDET(S)  1.025 VDET  0.100 VDET  0.090 V 1 V 1 V 1 V 1  0  V 1  0.55 1.55 A 2 3.0  36.0 V 1 0.5   mA 3   2.0 A 3 Detection delay time tRESET 8.0 10.0 12.0 ms 4 Release delay time*6 tDELAY 8.0 10.0 12.0 ms 4 SENSE pin resistance RSENSE 6.8  275 M 2 CP pin discharge RCP VDD = 3.0 V, VSENSE = 6.9 V, VCP = 0.5 V 0.72  4.29 k  ON resistance CN pin discharge RCN VDD = 3.0 V, VSENSE = 2.9 V, VCN = 0.5 V 0.72  4.29 k  ON resistance *1. VDET: Actual detection voltage value, VDET(S): Set detection voltage value *2. Hysteresis width is "unavailable", so release voltage = detection voltage. *3. The current flowing through the SENSE pin resistance is not included. *4. VDS: Drain-to-source voltage of the output transistor *5. The time period from when the pulse voltage of VDET(S)  0.5 V  VDET(S)  0.5 V is applied to the SENSE pin to when VOUT reaches VDD / 2, after voltage of 16.0 V is applied to the VDD pin and the SENSE pin input voltage (VSENSE) reaches the release voltage once. *6. The time period from when voltage of 16.0 V is applied to the VDD pin and the pulse voltage of VDET(S)  0.5 V  VDET(S)  0.5 V is applied to the SENSE pin to when VOUT reaches VDD / 2. 11 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 2. 2 S-1011 Series E / G type Table 18 Item Symbol Condition Detection voltage*1 VDET VDD = 16.0 V, 5.0 V  VDET(S)  10.0 V Hysteresis width VHYS VDD = 16.0 V E type G type*2 Current *3 consumption Operation voltage VDD Output current IOUT Leakage current ILEAK ISS VDD = 16.0 V, VSENSE = VDET  0.1 V, 5.0 V  VDET  10.0 V  Output transistor VDD = 5.0 V, VSENSE = 4.5 V Nch *4 VDS = 0.05 V Output transistor VDD = 30.0 V, VOUT = 30.0 V, Nch VSENSE = 30.0 V CN = 3.3 nF CP = 3.3 nF  (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VDET(S) VDET(S) VDET(S) V 1  0.985  1.015 VDET VDET VDET V 1  0.030  0.050  0.080  0  V 1  0.55 1.55 A 2 3.0  36.0 V 1 0.5   mA 3   2.0 A 3 Detection delay time*5 tRESET 8.0 10.0 12.0 ms 4 Release delay time*6 tDELAY 8.0 10.0 12.0 ms 4 SENSE pin resistance RSENSE 26.0  400 M 2 CP pin discharge RCP VDD = 4.5 V, VSENSE = 14.0 V, VCP = 0.5 V 0.30  2.60 k  ON resistance CN pin discharge RCN VDD = 4.5 V, VSENSE = 4.5 V, VCN = 0.5 V 0.63  2.60 k  ON resistance *1. VDET: Actual detection voltage value, VDET(S): Set detection voltage value *2. Hysteresis width is "unavailable", so release voltage = detection voltage. *3. The current flowing through the SENSE pin resistance is not included. *4. VDS: Drain-to-source voltage of the output transistor *5. The time period from when the pulse voltage of VDET(S)  1.0 V  VDET(S)  1.0 V is applied to the SENSE pin to when VOUT reaches VDD / 2, after voltage of 16.0 V is applied to the VDD pin and the SENSE pin input voltage (VSENSE) reaches the release voltage once. *6. The time period from when voltage of 16.0 V is applied to the VDD pin and the pulse voltage of VDET(S)  1.0 V  VDET(S)  1.0 V is applied to the SENSE pin to when VOUT reaches VDD / 2. 12 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Test Circuits R 100 k VDD OUT VDD  VSS V Figure 7  A CP V  Figure 9 VDD Test Circuit 2 (VDD detection product)  V VSS CP CN VSS CP Figure 13  V Test Circuit 1 (SENSE detection product) A OUT SENSE VSS CP CN Test Circuit 2 (SENSE detection product) VDS VDD  V  VSENSE Test Circuit 4 (VDD detection product) VSS CP Figure 12 P.G. CN VDS  Test Circuit 3 (SENSE detection product) R 100 k VDD VDD A V Oscilloscope CN  OUT SENSE R 100 k OUT CP VDD Test Circuit 3 (VDD detection product) VDD CN Figure 10 V Figure 11  A VSS VDD  OUT OUT VSENSE CN VDD VDD A  OUT CP V SENSE Figure 8 VDD VSS  VSENSE Test Circuit 1 (VDD detection product) VDD P.G. VDD  CN R 100 k VDD SENSE  VSS OUT CP Figure 14 Oscilloscope CN Test Circuit 4 (SENSE detection product) 13 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Standard Circuits 1. VDD detection product R 100 k VDD OUT VSS CP CN CP*1 *1. *2. CN*2 The delay capacitor (CP) should be connected directly to the CP pin and the VSS pin. The delay capacitor (CN) should be connected directly to the CN pin and the VSS pin. Figure 15 2. SENSE detection product R 100 k VDD SENSE VSS OUT CP CN CP*1 *1. *2. CN*2 The delay capacitor (CP) should be connected directly to the CP pin and the VSS pin. The delay capacitor (CN) should be connected directly to the CN pin and the VSS pin. Figure 16 Caution 14 The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Explanation of Terms 1. Detection voltage (VDET) The detection voltage is a voltage at which the output in Figure 21 or Figure 22 turns to "L" (VDD detection product: VDD, SENSE detection product: VSENSE). The detection voltage varies slightly among products of the same specification. The variation of detection voltage between the specified minimum (VDET min.) and the maximum (VDET max.) is called the detection voltage range (Refer to Figure 17, Figure 19). Example: In VDET = 5.0 V product, the detection voltage is either one in the range of 4.925 V  VDET  5.075 V. This means that some VDET = 5.0 V product have VDET = 4.925 V and some have VDET = 5.075 V. 2. Release voltage (VDET) The release voltage is a voltage at which the output in Figure 21 or Figure 22 turns to "H" (VDD detection product: VDD, SENSE detection product: VSENSE). The difference of detection voltage and release voltage is 5.0% typ. The release voltage varies slightly among products of the same specification. The variation of release voltage between the specified minimum (VDET min.) and the maximum (VDET max.) is called the release voltage range (Refer to Figure 18, Figure 20). The range is calculated from the actual detection voltage (VDET) of a product. In the S-1011 Series C / G / L / Q type, the release voltage (VDET) is the same value as the actual detection voltage (VDET) of a product. Example: In VDET = 6.0 V product, the release voltage is either one in the range of 6.0873 V  VDET  6.5772 V. This means that some VDET = 6.0 V product have VDET = 6.0873 V and some have VDET = 6.5772 V. 15 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series VDD Detection voltage Release voltage VDET max. Detection voltage range VDET min. VDET max. Release voltage range VDET min. VDD VOUT VOUT tRESET Figure 17 tDELAY Detection Voltage (VDD detection product) Figure 18 Release Voltage (VDD detection product) VSENSE Detection voltage Release voltage VDET max. Detection voltage range VDET min. VDET max. Release voltage range VDET min. VSENSE VOUT VOUT tRESET Figure 19 tDELAY Detection Voltage (SENSE detection product) R 100 k VDD OUT VDD  V Figure 21 3. VSS Figure 20 CP CN  V Test Circuit of Detection Voltage and Release Voltage (VDD detection product) Release Voltage (SENSE detection product) R 100 k VDD VDD VSENSE Figure 22  V SENSE OUT VSS CN CP  V Test Circuit of Detection Voltage and Release Voltage (SENSE detection product) Hysteresis width (VHYS) The hysteresis width is the voltage difference between the detection voltage and the release voltage (the voltage at point B  the voltage at point A = VHYS in Figure 24 and Figure 28). Setting the hysteresis width between the detection voltage and the release voltage, prevents malfunction caused by noise on the input voltage. 4. Feed-through current The feed-through current is a current that flows instantaneously to the VDD pin at the time of detection and release of a voltage detector. 16 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Operation 1. Basic operation 1. 1 S-1011 Series A / J type (1) When the power supply voltage (VDD) is the release voltage (VDET) or higher, the Nch transistor is turned off to output VDD ("H") when the output is pulled up. (RB  RC )  VDD . Since the Nch transistor (N1) is turned off, the input voltage to the comparator is RA  RB  RC (2) Even if VDD decreases to VDET or lower, VDD is output when VDD is higher than the detection voltage (VDET). When VDD decreases to VDET or lower (point A in Figure 24), the Nch transistor is turned on. And then VSS ("L") is output from the OUT pin after the elapse of the detection delay time (tRESET). RB  VDD . At this time, N1 is turned on, and the input voltage to the comparator is RA  RB (3) The output is unstable when VDD decreases to the IC's minimum operation voltage or lower. VDD is output when the output is pulled up. (4) VSS is output by increasing VDD to the minimum operation voltage or higher. Even if VDD exceeds VDET, VSS is output when VDD is lower than VDET. (5) When VDD increases to VDET or higher (point B in Figure 24), the Nch transistor is turned off. And then VDD is output from the OUT pin after the elapse of the release delay time (tDELAY) when the output is pulled up. VDD R 100 k RA VDD   *1 OUT Delay circuit RB *1 VREF N1 Nch RC VSS *1 CP CP *1.  V *1 CN CN Parasitic diode Figure 23 Operation of S-1011 Series A / J Type (1) (2) Hysteresis width VDD (4) B A (VHYS) (3) (5) Release voltage (VDET) Detection voltage (VDET) Minimum operation voltage VSS VDD Output from OUT pin VSS Remark tRESET tDELAY When VDD is the minimum operation voltage or lower, the output voltage from the OUT pin is unstable in the shaded area. Figure 24 Timing Chart of S-1011 Series A / J Type 17 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 1. 2 S-1011 Series C / L type (1) When the power supply voltage (VDD) is the release voltage (VDET) or higher, the Nch transistor is turned off to output VDD ("H") when the output is pulled up. (RB  RC )  VDD . At this time, the input voltage to the comparator is RA  RB  RC (2) When VDD decreases to the detection voltage (VDET) or lower (point A in Figure 26), the Nch transistor is turned on. And then VSS ("L") is output from the OUT pin after the elapse of the detection delay time (tRESET). (3) The output is unstable when VDD decreases to the IC's minimum operation voltage or lower. VDD is output when the output is pulled up. (4) VSS is output by increasing VDD to the minimum operation voltage or higher. (5) When VDD increases to VDET or higher (point B in Figure 26), the Nch transistor is turned off. And then VDD is output from the OUT pin after the elapse of the release delay time (tDELAY) when the output is pulled up. VDD R 100 k RA VDD   *1 OUT Delay circuit RB *1 VREF Nch RC VSS *1 CP CP *1.  V *1 CN CN Parasitic diode Figure 25 Operation of S-1011 Series C / L Type (1) Detection voltage (VDET) (2) A (3) (4) B (5) Release voltage (VDET) VDD Minimum operation voltage VSS VDD Output from OUT pin VSS tRESET tDELAY Remark 1. When VDD is the minimum operation voltage or lower, the output voltage from the OUT pin is unstable in the shaded area. 2. The release voltage is set to the same value as the detection voltage, since there is no hysteresis width. Figure 26 18 Timing Chart of S-1011 Series C / L Type HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 1. 3 S-1011 Series E / N type (1) When the power supply voltage (VDD) is the minimum operation voltage or higher, and the SENSE pin voltage (VSENSE) is the release voltage (VDET) or higher, the Nch transistor is turned off to output VDD ("H") when the output is pulled up. (RB  RC )  VSENSE Since the Nch transistor (N1) is turned off, the input voltage to the comparator is . RA  RB  RC (2) Even if VSENSE decreases to VDET or lower, VDD is output when VSENSE is higher than the detection voltage (VDET). When VSENSE decreases to VDET or lower (point A in Figure 28), the Nch transistor is turned on. And then VSS ("L") is output from the OUT pin after the elapse of the detection delay time (tRESET). RB  VSENSE . At this time, N1 is turned on, and the input voltage to the comparator is RA  RB (3) Even if VSENSE further decreases to the IC's minimum operation voltage or lower, the output from the OUT pin is stable when VDD is minimum operation voltage or higher. (4) Even if VSENSE exceeds VDET, VSS is output when VSENSE is lower than VDET. (5) When VSENSE increases to VDET or higher (point B in Figure 28), the Nch transistor is turned off. And then VDD is output from the OUT pin after the elapse of the release delay time (tDELAY) when the output is pulled up. SENSE VDD R 100 k RA VDD   *1 *1 VSENSE RB VREF *1 N1 Nch RC VSS *1 CP CP *1. OUT Delay circuit  V *1 CN CN Parasitic diode Figure 27 Operation of S-1011 Series E / N Type (1) (2) (3) (4) (5) B Hysteresis width A (VHYS) Release voltage (VDET) Detection voltage (VDET) VSENSE Minimum operation voltage VSS VDD Output from OUT pin VSS tRESET Figure 28 tDELAY Timing Chart of S-1011 Series E / N Type 19 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 1. 4 S-1011 Series G / Q type (1) When the power supply voltage (VDD) is the minimum operation voltage or higher, and the SENSE pin voltage (VSENSE) is the release voltage (VDET) or higher, the Nch transistor is turned off to output VDD ("H") when the output is pulled up. (RB  RC )  VSENSE At this time, the input voltage to the comparator is . RA  RB  RC (2) When VSENSE decreases to the detection voltage (VDET) or lower (point A in Figure 30), the Nch transistor is turned on. And then VSS ("L") is output from the OUT pin after the elapse of the detection delay time (tRESET). (3) Even if VSENSE further decreases to the IC's minimum operation voltage or lower, the output from the OUT pin is stable when VDD is minimum operation voltage or higher. (4) Even if VSENSE increases, VSS is output when VSENSE is lower than VDET. (5) When VSENSE increases to VDET or higher (point B in Figure 30), the Nch transistor is turned off. And then VDD is output from the OUT pin after the elapse of the release delay time (tDELAY) when the output is pulled up. SENSE VDD R 100 k RA VDD   *1 *1 VSENSE OUT Delay circuit RB *1 VREF Nch RC VSS *1 CP CP *1.  V *1 CN CN Parasitic diode Figure 29 Operation of S-1011 Series G / Q Type (1) Detection voltage (VDET) (2) A (3) (4) B (5) Release voltage (VDET) VSENSE Minimum operation voltage VSS VDD Output from OUT pin Remark tRESET tDELAY The release voltage is set to the same value as the detection voltage, since there is no hysteresis width. Figure 30 20 VSS Timing Chart of S-1011 Series G / Q Type HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 2. SENSE pin 2. 1 Error when detection voltage is set externally The detection voltage for the S-1011 Series is 10.0 V max., however, in the SENSE detection product with VDET = 10.0 V, the detection voltage can be set externally by connecting a node that was resistance-divided by the resistor (RA) and the resistor (RB) to the SENSE pin as shown in Figure 31. For conventional products without the SENSE pin, external resistor cannot be too large since the resistance-divided node must be connected to the VDD pin. This is because a feed-through current will flow through the VDD pin when it goes from detection to release, and if external resistor is large, problems such as oscillation or larger error in the hysteresis width may occur. In the S-1011 Series, RA and RB in Figure 31 are easily made larger since the resistance-divided node can be connected to the SENSE pin through which no feed-through current flows. However, be careful of error in the current flowing through the internal resistance (RSENSE) that will occur. Although RSENSE in the S-1011 Series is large (the S-1011 Series E / G type: 26 M min., the S-1011 Series N / Q type: 6.8 M min.) to make the error small, RA and RB should be selected such that the error is within the allowable limits. 2. 2 Selection of RA and RB In Figure 31, the relation between the external setting detection voltage (VDX) and the actual detection voltage (VDET) is ideally calculated by the equation below. VDX = VDET  (1  RA RB ) ··· (1) However, in reality there is an error in the current flowing through RSENSE. When considering this error, the relation between VDX and VDET is calculated as follows. RA RB || RSENSE ) RA  = VDET  1  RB  RSENSE   RB  RSENSE   RA RA  VDET = VDET  (1  R )  R B SENSE VDX = VDET  (1  ··· (2) RA . By using equations (1) and (2), the error is calculated as VDET  R SENSE The error rate is calculated as follows by dividing the error by the right-hand side of equation (1). RA || RB RA  RB  100 [%] = R  100 [%] RSENSE  (RA  RB) SENSE ··· (3) As seen in equation (3), the smaller the resistance values of RA and RB compared to RSENSE, the smaller the error rate becomes. 21 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series Also, the relation between the external setting hysteresis width (VHX) and the hysteresis width (VHYS) is calculated by equation below. Error due to RSENSE also occurs to the relation in a similar way to the detection voltage. VHX = VHYS  (1  RA RB ) ··· (4) A RA VDX VDET VDD SENSE OUT RSENSE RB Figure 31 VSS Detection Voltage External Setting Circuit Caution 1. When externally setting the detection voltage, perform the operation with VDET = 10.0 V product. Contact our sales office for details. 2. If the current flowing through RB is set to 1 A or less, the error may become larger. 3. If the parasitic resistance and parasitic inductance between VDX  point A and point A  VDD pin are larger, oscillation may occur. Perform thorough evaluation using the actual application. 4. If RA and RB are large, the SENSE pin input impedance becomes higher and may cause a malfunction due to noise. In this case, connect a capacitor between the SENSE pin and the VSS pin. 22 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 3. Delay circuit The delay circuit has a function that adjusts the detection delay time (tRESET) from when the power supply voltage (VDD) or SENSE pin voltage (VSENSE) reaches the detection voltage (VDET) or lower to when the output from OUT pin inverts. It also has a function that adjusts the release delay time (tDELAY) from when the power supply voltage (VDD) or SENSE pin voltage (VSENSE) reaches the release voltage (VDET) to when the output from OUT pin inverts. tRESET is determined by the delay coefficient, the delay capacitor (CN) and the detection delay time when the CN pin is open (tRESET0), and the tDELAY is determined by the delay coefficient, the delay capacitor (CP) and the release delay time when the CP pin is open (tDELAY0). They are calculated by the equation below. tRESET [ms] = Delay coefficient  CN [nF]  tRESET0 [ms] tDELAY [ms] = Delay coefficient  CP [nF]  tDELAY0 [ms] Table 19 Operation Temperature Ta = 85°C Ta = 25°C Ta = 40°C Min. Delay Coefficient Typ. Max. 2.41 2.41 2.40 2.85 2.86 2.83 3.32 3.30 3.25 Table 20 Operation Temperature Ta = 40°C to 85°C Caution 1. 2. 3. Detection Delay Time when CN Pin is Open (tRESET0) Typ. 0.35 ms Release Delay Time when CP Pin is Open (tDELAY0) Typ. 0.35 ms Mounted board layout should be made in such a way that no current flows into or flows from the CN pin or CP pin since the impedance of the CN pin and CP pin are high, otherwise correct delay time cannot be provided. There is no limit for the capacitance of CN and CP as long as the leakage current of the capacitor can be ignored against the built-in constant current value (approximately 300 nA). The leakage current may cause error in delay time. When the leakage current is larger than the built-in constant current, no detect or release takes place. The above equation will not guarantee successful operation. Determine the capacitance of CN and CP through thorough evaluation including temperature characteristics in the actual usage conditions. When using an X8R equivalent capacitor, refer to the "2. Detection delay time (tRESET) vs. Temperature (Ta)", "3. Detection delay time (tRESET) vs. Power supply voltage (VDD)", "5. Release delay time (tDELAY) vs. Temperature (Ta)" and "6. Release delay time (tDELAY) vs. Power supply voltage (VDD)" in " Reference Data" for details. 23 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Usage Precautions 1. Feed-through current during detection and release In the S-1011 Series, the feed-through current flows at the time of detection and release. For this reason, if the input impedance is high, oscillation may occur due to voltage drop caused by the feed-through current. When using the S-1011 Series in configurations like those shown in Figure 32 and Figure 33, it is recommended that input impedance be set to 1 k or less. Determine the impedance through thorough evaluation including temperature characteristics. RA VDD RA VDD VDD VDD OUT VBAT VBAT VSS Figure 32 24 OUT SENSE CP VSS CN VDD Detection Product Figure 33 CP CN SENSE Detection Product HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 2. Power on and shut down sequence SENSE detection products monitor SENSE pin voltage (VSENSE) while power is being supplied to the VDD pin. Apply power in the order, the VDD pin then the SENSE pin. In addition, when shutting down VDD pin, shut down the SENSE pin first, and shut down the VDD pin after the detection delay time (tRESET) has elapsed. VDD VDET VSENSE VDET(S) tDELAY tRESET VOUT Figure 34 Falling power (reference) Figure 35 shows the relation between VDD amplitude (VP-P) and input voltage falling time (tF) where the release status can be maintained when the VDD pin (VDD detection product) sharply drops to a voltage equal to or higher than the detection voltage (VDET) during release status. S-1011A50 Ta = 40C to 85C 40.0 30.0 VP-P [V] 3. 20.0 10.0 0.0 0.1 1 tF [s] 10 Figure 35 tF VIH*1 VDET VP-P VIL*2 VDD VDET VSS *1. *2. VIH = 36.0 V VIL = VDET(S)  1.0 V Figure 36 Caution VDD Pin Input Voltage Waveform Figure 35 shows the input voltage conditions which can maintain the release status. If the voltage whose VP-P and tF are larger than these conditions is input to the VDD pin (VDD detection product), the OUT pin may change to a detection status. 25 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 4. Detection delay time accuracy (reference) Figure 37 and Figure 38 show the relation between VDD amplitude (VP-P) and input voltage falling time (tF) where the arbitrarily set detection delay time accuracy can be maintained when the VDD pin (VDD detection product) sharply drops. S-1011A50 S-1011A50 Ta = 40C to 85C 40.0 40.0 30.0 30.0 VP-P [V] VP-P [V] Ta = 40C to 85C 20.0 10.0 20.0 10.0 0.0 0.0 0.1 1 tF [s] Figure 37 0.1 10 CN = 3.3 nF 1 tF [s] Figure 38 10 CN = 100 nF tF VIH*1 VDET VP-P VDD VDET VIL*2 3.0 V VSS *1. *2. VIH = 36.0 V VIL = VDET(S)  1.0 V (3.0 V min.) Figure 39 Caution 26 VDD Pin Input Voltage Waveform Figure 37 and Figure 38 show the input voltage conditions which can maintain the detection delay time accuracy. If the voltage whose VP-P and tF are larger than these conditions is input to the VDD pin (VDD detection product), the desired detection delay time may not be achieved. HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series VDD drop during release delay time (reference) Figure 40 and Figure 41 show the relation between pulse width (tPW ) and VDD lower limit (VDROP) where a release signal can be output after the normal release delay time has elapsed when the VDD pin (VDD detection product) instantaneously drops to the detection voltage (VDET) or lower and then increases to the release voltage (VDET) or higher during release delay time. S-1011A50 Ta = 40C to 85C, CP = CN = 3.3 nF, 10000 S-1011AA0 Ta = 40C to 85C, CP = CN = 3.3 nF, 10000 1000 tPW [s] 1000 tPW [s] 5. Inhibited Area 100 10 Inhibited Area 100 10 1 1 0.0 0.5 1.0 1.5 0.0 2.0 0.5 VDROP [V] Figure 40 1.0 VDROP [V] 1.5 2.0 Figure 41 tF*1 tPW tR*1 16 V VDD VDET VDROP tDELAY  0.8 tDELAY VOUT *1. tR = tF = 10 s Figure 42 Caution 1. 2. VDD Pin Input Voltage Waveform Figure 40 and Figure 41 show the input voltage conditions when a release signal is output after the normal release delay time has elapsed. When this is within the inhibited area, release may erroneously be executed before the delay time completes. When the VDD pin voltage is within the inhibited areas shown in Figure 40 and Figure 41 during release delay time, input 0 V to the VDD pin then restart the S-1011 Series. 27 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Precautions  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit.  Because the SENSE pin has a high impedance, malfunctions may occur due to noise. Be careful of wiring adjoining SENSE pin wiring in actual applications.  When designing for mass production using an application circuit described herein, the product deviation and temperature characteristics of the external parts should be taken into consideration. ABLIC Inc. shall not bear any responsibility for patent infringements related to products using the circuits described herein.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 28 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Characteristics (Typical Data) 1. Detection voltage (VDET), Release voltage (VDET) vs. Temperature (Ta) VDET 5.30 5.20 5.10 VDET 5.00 4.90 2. 1. 2 SENSE detection product S-1011E50 5.40 VDET, VDET [V] VDET, VDET [V] 1. 1 VDD detection product S-1011A50 5.40 0 25 Ta [C] 50 VDET 5.30 5.20 5.10 VDET 5.00 4.90 40 25 VDD = 16.0 V 75 85 40 25 0 25 Ta [C] 50 75 85 Detection voltage (VDET), Release voltage (VDET) vs. Power supply voltage (VDD) 2. 1 SENSE detection product VDET, VDET [V] S-1011E50 5.40 VDET 5.30 5.20 Ta = 25C Ta = 85C Ta = 40C 5.10 5.00 VDET 4.90 0.0 3. 6.0 12.0 18.0 24.0 VDD [V] 30.0 36.0 Current consumption (ISS) vs. Power supply voltage (VDD) 3. 1 VDD detection product VDD = 0 V  36.0 V ISS [µA] S-1011A50 1.50 Ta = +85°C 1.00 0.50 0.00 3. 2 Ta = +25°C Ta = −40°C 0.0 6.0 12.0 18.0 24.0 VDD [V] SENSE detection product 30.0 36.0 Ta = −40°C 1.00 S-1011E50 1.50 Ta = +25°C ISS [µA] ISS [µA] S-1011E50 VDD = 0 V  36.0 V, VSENSE = VDET  0.1 V (during detection) 1.50 0.50 VDD = 0 V  36.0 V, VSENSE = VDET  0.1 V (during release) 1.00 Ta = −40°C 0.50 Ta = +85°C 0.00 0.0 6.0 12.0 18.0 24.0 VDD [V] 30.0 36.0 Ta = +25°C 0.00 Ta = +85°C 0.0 6.0 12.0 18.0 24.0 VDD [V] 30.0 36.0 29 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 4. Current consumption (ISS) vs. Temperature (Ta) 4. 1 VDD detection product 4. 2 S-1011A50 S-1011E50 VDD = VDET  0.1 V 1.00 0.50 5. 40 25 0.50 25 Ta [C] 50 75 85 40 25 0 25 Ta [C] 50 75 85 Current consumption during detection delay (ISS) vs. Temperature (Ta) 5. 1 VDD detection product VCN = 0.2 V 2.00 1.00 0.00 6. 5. 2 40 25 25 Ta [C] 50 VDD = 16.0 V, VCN = 0.2 V 2.00 1.00 0.00 0 SENSE detection product S-1011E50 3.00 ISS [A] ISS [A] S-1011A50 3.00 75 85 40 25 0 25 Ta [C] 50 75 85 Current consumption during release delay (ISS) vs. Temperature (Ta) 6. 1 VDD detection product 6. 2 VCP = 0.2 V 2.00 1.00 0.00 40 25 25 Ta [C] 50 75 85 VDD = 16.0 V, VCP = 0.2 V 2.00 1.00 0.00 0 SENSE detection product S-1011E50 3.00 ISS [A] ISS [A] S-1011A50 3.00 30 1.00 0.00 0 VDD = 16.0 V, VSENSE = VDET  0.1 V 1.50 ISS [A] ISS [A] 1.50 0.00 SENSE detection product 40 25 0 25 Ta [C] 50 75 85 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 7. Nch transistor output current (IOUT) vs. VDS 7. 1 SENSE detection product S-1011E50 S-1011E50 VDD = VSENSE = 4.5 V, Ta = 40°C 30.0 VDD = VSENSE = 4.5 V, Ta = 25°C 30.0 20.0 VDD = 36.0 V VDD = 16.0 V IOUT [mA] IOUT [mA] VDD = 36.0 V VDD = 3.0 V 10.0 0.0 20.0 VDD = 16.0 V VDD = 3.0 V 10.0 0.0 0.0 0.1 0.2 0.3 0.4 VDS [V] 0.5 0.6 0.0 0.1 0.2 0.3 0.4 VDS [V] 0.5 0.6 S-1011E50 VDD = VSENSE = 4.5 V, Ta = 85°C IOUT [mA] 30.0 VDD = 36.0 V 20.0 VDD = 16.0 V VDD = 3.0 V 10.0 0.0 0.0 0.2 0.3 0.4 VDS [V] 0.5 0.6 Nch transistor output current (IOUT) vs. Power supply voltage (VDD) 8. 1 VDD detection product IOUT [mA] S-1011A50 2.0 8. 2 VDS = 0.05 V 1.5 1.0 Ta = −40°C Ta = +25°C Ta = +85°C 0.5 0.0 0.0 5.0 10.0 1.5 1.0 Ta = +25°C 0.5 15.0 VDD [V] Remark SENSE detection product S-1011E50 VSENSE = 4.5 V, VDS = 0.05 V 2.5 Ta = −40°C 2.0 IOUT [mA] 8. 0.1 0.0 Ta = +85°C 0.0 6.0 12.0 18.0 24.0 VDD [V] 30.0 36.0 VDS: Drain-to-source voltage of the output transistor 31 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 9. Minimum operation voltage (VOUT) vs. Power supply voltage (VDD) 9. 1 VDD detection product S-1011A50 Pull-up to VDD, Pull-up resistance: 100 k 6.0 S-1011A50 Pull-up to 16.0 V, Pull-up resistance: 100 k 20.0 4.0 3.0 2.0 1.0 0.0 9. 2 Ta = −40°C Ta = +25°C Ta = +85°C VOUT [V] VOUT [V] 5.0 0.0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 VDD [V] S-1011E50 VDD = 3.0 V, Pull-up to 16.0 V, Pull-up resistance: 100 k 20.0 2.0 Ta = +85°C 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 VSENSE [V] VOUT [V] VOUT [V] 3.0 Ta = −40°C Ta = +25°C 1.0 32 Ta = −40°C Ta = +25°C Ta = +85°C SENSE detection product 5.0 0.0 10.0 5.0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 VDD [V] S-1011E50 VDD = 3.0 V, Pull-up to VDD, Pull-up resistance: 100 k 6.0 4.0 15.0 15.0 10.0 5.0 0.0 Ta = −40°C Ta = +25°C Ta = +85°C 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 VSENSE [V] HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 10. Dynamic response vs. Output pin capacitance(COUT) (CP pin, CN pin; open) 10. 1 VDD detection product Ta = 40°C tPHL 1 0.1 tPLH 0.01 0.001 0.00001 0.001 0.01 0.0001 Output pin capacitance [F] 0.1 tPHL 1 0.1 tPLH 0.01 0.001 0.00001 0.001 0.01 0.0001 Output pin capacitance [F] 0.1 Ta = 85°C S-1011A50 10 Response time [ms] Ta = 25°C S-1011A50 10 Response time [ms] Response time [ms] S-1011A50 10 tPHL 1 0.1 tPLH 0.01 0.001 0.00001 0.001 0.01 0.0001 Output pin capacitance [F] 1 s 0.1 1 s VIH*1 Input voltage VIL*2 tPHL OUT tPLH VDD VDD1 Output voltage *1. *2. R 100 k VDD VDD1  50% VDD1  50%  VSS V CP  CN VDD1 V VIH = 36.0 V VIL = 3.0 V Figure 43 Caution Test Condition of Response Time Figure 44 Test Circuit of Response Time The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. 33 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Reference Data 1. Detection delay time (tRESET) vs. CN pin capacitance (CN) (Without output pin capacitance) 1. 1 VDD detection product tRESET [ms] S-1011A50 1000 100 10 Ta = 40C 1 0.1 0.01 2. Ta = 85C Ta = 25C 0.1 1 10 CN [nF] 100 1000 Detection delay time (tRESET) vs. Temperature (Ta) 2. 1 VDD detection product S-1011A50 CN = 3.3 nF 12.0 tRESET [ms] 10.0 8.0 6.0 4.0 2.0 0.0 40 25 0 25 Ta [C] 50 75 85 1 s VIH*1 Input voltage VIL*2 OUT tRESET VDD VDD VDD  50% Output voltage R 100 k VDD  VSS CP  CN V V CN VSS *1. *2. VIH = VDET(S)  1.0 V VIL = VDET(S)  1.0 V Figure 45 Caution 34 Test Condition of Detection Delay Time Figure 46 Test Circuit of Detection Delay Time The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series Detection delay time (tRESET) vs. Power supply voltage (VDD) 3. 1 SENSE detection product CN = 3.3 nF S-1011E50 12.0 tRESET [ms] 3. Ta = +25°C 11.0 Ta = +85°C 10.0 9.0 Ta = −40°C 8.0 0.0 6.0 12.0 18.0 24.0 VDD [V] 30.0 36.0 1 s VIH*1 Input voltage VIL*2 tRESET VDD VDD  V OUT SENSE VSS CP  CN V VDD  50% Output voltage R 100 k VDD VSENSE CN VSS *1. *2. VIH = VDET(S)  1.0 V VIL = VDET(S)  1.0 V Figure 47 Caution Test Condition of Detection Delay Time Figure 48 Test Circuit of Detection Delay Time The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. 35 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series 4. Release delay time (tDELAY) vs. CP pin capacitance (CP) (Without output pin capacitance) 4. 1 VDD detection product tDELAY [ms] S-1011A50 1000 100 10 Ta = 40C 1 0.1 0.01 5. Ta = 85C Ta = 25C 0.1 1 10 CP [nF] 100 1000 Release delay time (tDELAY) vs. Temperature (Ta) 5. 1 VDD detection product S-1011A50 CP = 3.3 nF 12.0 tDELAY [ms] 10.0 8.0 6.0 4.0 2.0 0.0 40 25 0 25 Ta [C] 50 75 85 1 s VIH*1 Input voltage VIL*2 OUT tDELAY VDD VDD VDD  50% Output voltage R 100 k VDD  VSS CP  CN V V CP VSS *1. *2. VIH = VDET  1.0 V VIL = VDET  1.0 V Figure 49 Caution 36 Test Condition of Release Delay Time Figure 50 Test Circuit of Release Delay Time The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series Release delay time (tDELAY) vs. Power supply voltage (VDD) 6. 1 SENSE detection product CP = 3.3 nF S-1011E50 12.0 tDELAY [ms] 6. Ta = 25C Ta = 85C 11.0 10.0 9.0 Ta = 40C 8.0 0.0 6.0 12.0 18.0 24.0 VDD [V] 30.0 36.0 1 s VIH*1 Input voltage VIL*2 tDELAY VDD VDD  V OUT SENSE VSS CP  CN V VDD  50% Output voltage R 100 k VDD VSENSE CP VSS *1. *2. VIH = VDET  1.0 V VIL = VDET  1.0 V Figure 51 Caution Test Condition of Release Delay Time Figure 52 Test Circuit of Release Delay Time The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. 37 HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Application Circuit Examples 1. Microcomputer reset circuits In microcomputers, when the power supply voltage is lower than the minimum operation voltage, an unspecified operation may be performed or the contents of the memory register may be lost. When power supply voltage returns to the normal level, the microcomputer needs to be initialized. Otherwise, the microcomputer may malfunction after that. Reset circuits to protect microcomputer in the event of current being momentarily switched off or lowered. Using the S-1011 Series which has the low minimum operation voltage, the high-accuracy detection voltage and the hysteresis width, reset circuits can be easily constructed as seen in Figure 53 and Figure 54. VDD VDD1 VDD OUT VSS CP CN VDD1 VSENSE Microcomputer VDD SENSE OUT VSS CP CN Microcomputer GND Figure 53 Caution 38 Example of Reset Circuit (VDD detection product) GND Figure 54 Example of Reset Circuit (SENSE detection product) The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. HIGH-WITHSTAND VOLTAGE BUILT-IN DELAY CIRCUIT (EXTERNAL DELAY TIME SETTING) VOLTAGE DETECTOR Rev.1.2_02 S-1011 Series  Thermal Characteristics 1. SOT-23-6 Tj = 125C max. Power dissipation (PD) [W] 1.0 0.8 0.6 0.2 Figure 55 Board 1 Board 1 0.63 W 0.4 0 1. 1 Board 2 0.81 W 0 50 100 150 Ambient temperature (Ta) [C] Power Dissipation of Package (When Mounted on Board) *1 76.2 mm Table 21 114.3 mm Item Thermal resistance value (ja) Size Material Number of copper foil layer 1 2 Copper foil layer 3 4 Thermal via Figure 56 Specification 159C/W 114.3 mm  76.2 mm  t1.6 mm FR-4 2 Land pattern and wiring for testing: t0.070 mm   74.2 mm  74.2 mm  t0.070 mm  1. 2 Board 2*1 76.2 mm Table 22 114.3 mm Item Thermal resistance value (ja) Figure 57 *1. Size Material Number of copper foil layer 1 2 Copper foil layer 3 4 Thermal via Specification 124C/W 114.3 mm  76.2 mm  t1.6 mm FR-4 4 Land pattern and wiring for testing: t0.070 mm 74.2 mm  74.2 mm  t0.035 mm 74.2 mm  74.2 mm  t0.035 mm 74.2 mm  74.2 mm  t0.070 mm  The board is same in SOT-23-3, SOT-23-5 and SOT-23-6. 39 2.9±0.2 1.9±0.2 6 0.95 4 5 1 2 3 +0.1 0.15 -0.05 0.95 0.35±0.15 No. MP006-A-P-SD-2.1 TITLE SOT236-A-PKG Dimensions No. MP006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 6 Feed direction No. MP006-A-C-SD-3.1 TITLE SOT236-A-Carrier Tape No. MP006-A-C-SD-3.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP006-A-R-SD-2.1 TITLE SOT236-A-Reel No. MP006-A-R-SD-2.1 ANGLE QTY UNIT mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-1011J4B-M6T1U4 价格&库存
很抱歉,暂时无法提供与“S-1011J4B-M6T1U4”相匹配的价格&库存,您可以联系我们找货
