74HCT2G00DC
74HCT2G00DC
    NEXPERIA(安世)
    VFSOP8
    IC GATE NAND 2CH 2-INP 8VSSOP
74HCT2G00DC 数据手册
74HC2G00; 74HCT2G00 Dual 2-input NAND gate Rev. 04 — 3 July 2008 Product data sheet 1. General description The 74HC2G00 and 74HCT2G00 are high-speed Si-gate CMOS devices. They provide two 2-input NAND gates. The HC device has CMOS input switching levels and supply voltage range 2 V to 6 V. The HCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V. 2. Features n n n n n n n Wide supply voltage range from 2.0 V to 6.0 V Symmetrical output impedance High noise immunity Low power dissipation Balanced propagation delays Multiple package options ESD protection: u HBM JESD22-A114E exceeds 2000 V u MM JESD22-A115-A exceeds 200 V n Specified from −40 °C to +85 °C and −40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number 74HC2G00DP Package Temperature range Name Description Version −40 °C to +125 °C TSSOP8 plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm SOT505-2 −40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; SOT765-1 body width 2.3 mm −40 °C to +125 °C XSON8U plastic extremely thin small outline package; no leads; SOT996-2 8 terminals; UTLP based; body 3 × 2 × 0.5 mm 74HCT2G00DP 74HC2G00DC 74HCT2G00DC 74HC2G00GD 74HCT2G00GD 74HC2G00; 74HCT2G00 NXP Semiconductors Dual 2-input NAND gate 4. Marking Table 2. Marking code Type number Marking code 74HC2G00DP H00 74HCT2G00DP T00 74HC2G00DC H00 74HCT2G00DC T00 74HC2G00GD H00 74HCT2G00GD T00 5. Functional diagram 1 1 1A 2 1B 5 2A 6 2B 1Y 7 2Y 3 7 B 5 & 3 Y 6 A mna712 Fig 1. & 2 mna099 mna713 Logic symbol Fig 2. IEC logic symbol Fig 3. Logic diagram (one driver) 6. Pinning information 6.1 Pinning 74HC2G00 74HCT2G00 74HC2G00 74HCT2G00 1A 1 8 VCC 1B 2 7 1Y 2Y 3 6 2B GND 4 5 2A 8 VCC 1B 2 7 1Y 2Y 3 6 2B GND 4 5 2A 001aai256 Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8) Fig 5. 74HC_HCT2G00_4 Product data sheet 1 Transparent top view 001aai255 Fig 4. 1A Pin configuration SOT996-2 (XSON8U) © NXP B.V. 2008. All rights reserved. Rev. 04 — 3 July 2008 2 of 13 74HC2G00; 74HCT2G00 NXP Semiconductors Dual 2-input NAND gate 6.2 Pin description Table 3. Pin description Symbol Pin Description 1A, 2A 1, 5 data input 1B, 2B 2, 6 data input GND 4 ground (0 V) 1Y, 2Y 7, 3 data output VCC 8 supply voltage 7. Functional description Table 4. Function table[1] Input Output nA nB L L H L H H H L H H H L [1] nY H = HIGH voltage level; L = LOW voltage level. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Min Max Unit −0.5 +7.0 V IIK input clamping current VI < −0.5 V or VI > VCC + 0.5 V [1] - ±20 mA VO < −0.5 V or VO > VCC + 0.5 V [1] output clamping current - ±20 mA VO = −0.5 V to (VCC + 0.5 V) [1] IO output current ICC - 25 mA supply current [1] - 50 mA IGND ground current [1] −50 - mA Tstg storage temperature −65 +150 °C - 300 mW IOK dynamic power dissipation PD Conditions Tamb = −40 °C to +125 °C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K. For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K. For XSON8 package: above 45 °C the value of Ptot derates linearly with 2.4 mW/K. 74HC_HCT2G00_4 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 04 — 3 July 2008 3 of 13 74HC2G00; 74HCT2G00 NXP Semiconductors Dual 2-input NAND gate 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74HC2G00 Min Typ 74HCT2G00 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature −40 +25 +125 −40 +25 +125 °C ∆t/∆V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 10. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C. Symbol Parameter −40 °C to +85 °C Conditions −40 °C to +125 °C Unit Min Typ Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 V IO = −20 µA; VCC = 2.0 V 1.9 2.0 - 1.9 - V IO = −20 µA; VCC = 4.5 V 4.4 4.5 - 4.4 - V IO = −20 µA; VCC = 6.0 V 5.9 6.0 - 5.9 - V IO = −4.0 mA; VCC = 4.5 V 4.13 4.32 - 3.7 - V IO = −5.2 mA; VCC = 6.0 V 5.63 5.81 - 5.2 - V IO = 20 µA; VCC = 2.0 V - 0 0.1 - 0.1 V IO = 20 µA; VCC = 4.5 V - 0 0.1 - 0.1 V IO = 20 µA; VCC = 6.0 V - 0 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.33 - 0.4 V 74HC2G00 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±1.0 - ±1.0 µA ICC supply current per input pin; VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 10 - 20 µA CI input capacitance - 1.5 - - - pF 74HC_HCT2G00_4 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 04 — 3 July 2008 4 of 13 74HC2G00; 74HCT2G00 NXP Semiconductors Dual 2-input NAND gate Table 7. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C. Symbol Parameter −40 °C to +85 °C Conditions −40 °C to +125 °C Min Typ Max Min Max Unit 74HCT2G00 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL IO = −20 µA; VCC = 4.5 V 4.4 4.5 - 4.4 - V IO = −4.0 mA; VCC = 4.5 V 4.13 4.32 - 3.7 - V LOW-level output voltage VOL VI = VIH or VIL IO = 20 µA; VCC = 4.5 V - 0 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±1.0 - ±1.0 µA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 10 - 20 µA ∆ICC additional supply current per input; VCC = 4.5 V to 5.5 V; VI = VCC − 2.1 V; IO = 0 A - - 375 - 410 µA CI input capacitance - 1.5 - - - pF 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); all typical values are measured at Tamb = 25 °C; for test circuit see Figure 7. Symbol Parameter −40 °C to +85 °C Conditions −40 °C to +125 °C Unit Min Typ Max Min Max VCC = 2.0 V - 25 VCC = 4.5 V - 9 95 - 110 ns 19 - 22 ns - 7 16 - 20 ns VCC = 2.0 V - 18 VCC = 4.5 V - 6 95 - 125 ns 19 - 25 ns - 5 16 - 20 ns - 10 - - - pF 74HC2G00 tpd propagation delay nA and nB to nY; see Figure 6 [1] VCC = 6.0 V tt transition time see Figure 6 [2] VCC = 6.0 V CPD power dissipation VI = GND to VCC capacitance [3] 74HC_HCT2G00_4 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 04 — 3 July 2008 5 of 13 74HC2G00; 74HCT2G00 NXP Semiconductors Dual 2-input NAND gate Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); all typical values are measured at Tamb = 25 °C; for test circuit see Figure 7. Symbol Parameter −40 °C to +85 °C Conditions −40 °C to +125 °C Unit Min Typ Max Min Max 74HCT2G00 propagation delay nA and nB to nY; see Figure 6 tpd [1] VCC = 4.5 V tt transition time CPD power dissipation VI = GND to VCC − 1.5 V capacitance [1] VCC = 4.5 V; see Figure 6 - 12 24 - 29 ns [2] - 6 19 - 22 ns [3] - 10 - - - pF tpd is the same as tPLH and tPHL. [2] tt is the same as tTLH and tTHL. [3] CPD is used to determine the dynamic power dissipation (PD in µW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; Σ(CL × VCC2 × fo) = sum of outputs. 12. Waveforms VI nA, nB input VM VM GND tPHL tPLH VOH nY output 90% VM VM 10% VOL tTHL tTLH 001aae759 Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output load. Fig 6. Propagation delay data input (nA, nB) to data output (nY) and transition time output (nY) Table 9. Measurement points Type Input Output VM VM 74HC2G00 0.5 × VCC 0.5 × VCC 74HCT2G00 1.3 V 1.3 V 74HC_HCT2G00_4 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 04 — 3 July 2008 6 of 13 74HC2G00; 74HCT2G00 NXP Semiconductors Dual 2-input NAND gate VI tW 90 % negative pulse VM 0V VI tf tr tr tf 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC G VI VO RL S1 open DUT RT CL 001aad983 Test data is given in Table 10. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 7. Load circuit for measuring switching times Table 10. Test data Type Input Load VI tr, tf CL RL tPHL, tPLH 74HC2G00 VCC ≤ 6 ns 50 pF 1 kΩ open 74HCT2G00 3V ≤ 6 ns 50 pF 1 kΩ open 74HC_HCT2G00_4 Product data sheet S1 position © NXP B.V. 2008. All rights reserved. Rev. 04 — 3 July 2008 7 of 13 74HC2G00; 74HCT2G00 NXP Semiconductors Dual 2-input NAND gate 13. Package outline TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm D E A SOT505-2 X c HE y v M A Z 5 8 A A2 (A3) A1 pin 1 index θ Lp L 1 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e HE L Lp v w y Z(1) θ mm 1.1 0.15 0.00 0.95 0.75 0.25 0.38 0.22 0.18 0.08 3.1 2.9 3.1 2.9 0.65 4.1 3.9 0.5 0.47 0.33 0.2 0.13 0.1 0.70 0.35 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT505-2 Fig 8. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 02-01-16 --- Package outline SOT505-2 (TSSOP8) 74HC_HCT2G00_4 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 04 — 3 July 2008 8 of 13 74HC2G00; 74HCT2G00 NXP Semiconductors Dual 2-input NAND gate VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D E SOT765-1 A X c y HE v M A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 4 e L detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(2) e HE L Lp Q v w y Z(1) θ mm 1 0.15 0.00 0.85 0.60 0.12 0.27 0.17 0.23 0.08 2.1 1.9 2.4 2.2 0.5 3.2 3.0 0.4 0.40 0.15 0.21 0.19 0.2 0.13 0.1 0.4 0.1 8° 0° Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT765-1 Fig 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 02-06-07 MO-187 Package outline SOT765-1 (VSSOP8) 74HC_HCT2G00_4 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 04 — 3 July 2008 9 of 13 74HC2G00; 74HCT2G00 NXP Semiconductors Dual 2-input NAND gate XSON8U: plastic extremely thin small outline package; no leads; 8 terminals; UTLP based; body 3 x 2 x 0.5 mm B D SOT996-2 A A E A1 detail X terminal 1 index area e1 v w b e L1 1 4 8 5 C C A B C M M y y1 C L2 L X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max A1 b D E e e1 L L1 L2 v w y y1 mm 0.5 0.05 0.00 0.35 0.15 2.1 1.9 3.1 2.9 0.5 1.5 0.5 0.3 0.15 0.05 0.6 0.4 0.1 0.05 0.05 0.1 REFERENCES OUTLINE VERSION IEC SOT996-2 --- JEDEC JEITA --- EUROPEAN PROJECTION ISSUE DATE 07-12-18 07-12-21 Fig 10. Package outline SOT996-2 (XSON8U) 74HC_HCT2G00_4 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 04 — 3 July 2008 10 of 13 74HC2G00; 74HCT2G00 NXP Semiconductors Dual 2-input NAND gate 14. Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 15. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT2G00_4 20080703 Product data sheet - 74HC_HCT2G00_3 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Added type number 74HC2G00GD and 74HCT2G00GD (XSON8U package) 74HC_HCT2G00_3 20060405 Product data sheet - 74HC_HCT2G00_2 74HC_HCT2G00_2 20030212 Product specification - 74HC_HCT2G00_1 74HC_HCT2G00_1 20020710 Product specification - - 74HC_HCT2G00_4 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 04 — 3 July 2008 11 of 13 74HC2G00; 74HCT2G00 NXP Semiconductors Dual 2-input NAND gate 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 16.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com 74HC_HCT2G00_4 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 04 — 3 July 2008 12 of 13 NXP Semiconductors 74HC2G00; 74HCT2G00 Dual 2-input NAND gate 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 5 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2008. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 3 July 2008 Document identifier: 74HC_HCT2G00_4
74HCT2G00DC 价格&库存
很抱歉,暂时无法提供与“74HCT2G00DC”相匹配的价格&库存,您可以联系我们找货
