CD74HC10E
CD74HC10E
    L3HARRIS
    DIP-14
    IC GATE NAND 3CH 3-INP 14DIP
CD74HC10E 数据手册
[ /Title (CD74 HC10, CD74 HCT10 ) /Subject (High Speed CMOS Logic Triple 3-Input NAND Gate) /Autho r () /Keywords (High Speed CMOS Logic Triple 3-Input NAND Gate, High Speed CMOS Logic Triple 3-Input NAND Gate, Harris Semi- CD54HC10, CD74HC10, CD54HCT10, CD74HCT10 Data sheet acquired from Harris Semiconductor SCHS128C High-Speed CMOS Logic Triple 3-Input NAND Gate August 1997 - Revised September 2003 Features Description • Buffered Inputs The ’HC10 and ’HCT10 logic gates utilize silicon gate CMOS technology to achieve operating speeds similar to LSTTL gates with the low power consumption of standard CMOS integrated circuits. All devices have the ability to drive 10 LSTTL loads. The HCT logic family is functionally pin compatible with the standard LS logic family. • Typical Propagation Delay: 8ns at VCC = 5V, CL = 15pF, TA = 25oC • Fanout (Over Temperature Range) - Standard Outputs . . . . . . . . . . . . . . . 10 LSTTL Loads - Bus Driver Outputs . . . . . . . . . . . . . 15 LSTTL Loads Ordering Information • Wide Operating Temperature Range . . . -55oC to 125oC • Balanced Propagation Delay and Transition Times PART NUMBER • Significant Power Reduction Compared to LSTTL Logic ICs TEMP. RANGE (oC) PACKAGE CD54HC10F3A -55 to 125 14 Ld CERDIP • HC Types - 2V to 6V Operation - High Noise Immunity: NIL = 30%, NIH = 30% of VCC at VCC = 5V CD54HCT10F3A -55 to 125 14 Ld CERDIP CD74HC10E -55 to 125 14 Ld PDIP CD74HC10M -55 to 125 14 Ld SOIC • HCT Types - 4.5V to 5.5V Operation - Direct LSTTL Input Logic Compatibility, VIL= 0.8V (Max), VIH = 2V (Min) - CMOS Input Compatibility, Il ≤ 1µA at VOL, VOH CD74HC10MT -55 to 125 14 Ld SOIC CD74HC10M96 -55 to 125 14 Ld SOIC CD74HCT10E -55 to 125 14 Ld PDIP CD74HCT10M -55 to 125 14 Ld SOIC CD74HCT10MT -55 to 125 14 Ld SOIC CD74HCT10M96 -55 to 125 14 Ld SOIC NOTE: When ordering, use the entire part number. The suffix 96 denotes tape and reel. The suffix T denotes a small-quantity reel of 250. Pinout CD54HC10, CD54HCT10 (CERDIP) CD74HC10, CD74HCT10 (PDIP, SOIC) TOP VIEW 1A 1 14 VCC 1B 2 13 1C 2A 3 12 1Y 2B 4 11 3C 2C 5 10 3B 2Y 6 9 3A GND 7 8 3Y CAUTION: These devices are sensitive to electrostatic discharge. Users should follow proper IC Handling Procedures. Copyright © 2003, Texas Instruments Incorporated 1 CD54HC10, CD74HC10, CD54HCT10, CD74HCT10 Functional Diagram 1 14 2 13 1A 1B 2A 2B 2C 2Y GND VCC 1C 3 12 4 11 5 10 6 9 7 8 1Y 3C 3B 3A 3Y TRUTH TABLE INPUTS OUTPUT nA nB nC nY L L L H L L H H L H L H L H H H H L L H H L H H H H L H H H H L H = High Voltage Level, L = Low Voltage Level Logic Symbol nA nY nB nC 2 CD54HC10, CD74HC10, CD54HCT10, CD74HCT10 Absolute Maximum Ratings Thermal Information DC Supply Voltage, VCC . . . . . . . . . . . . . . . . . . . . . . . . -0.5V to 7V DC Input Diode Current, IIK For VI < -0.5V or VI > VCC + 0.5V . . . . . . . . . . . . . . . . . . . . . .±20mA DC Output Diode Current, IOK For VO < -0.5V or VO > VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±20mA DC Output Source or Sink Current per Output Pin, IO For VO > -0.5V or VO < VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±25mA DC VCC or Ground Current, ICC or IGND . . . . . . . . . . . . . . . . . .±50mA Thermal Resistance (Typical, Note 1) θJA (oC/W) E (PDIP) Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 M (SOIC) Package. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86 Maximum Junction Temperature . . . . . . . . . . . . . . . . . . . . . . . 150oC Maximum Storage Temperature Range . . . . . . . . . .-65oC to 150oC Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . . 300oC (SOIC - Lead Tips Only) Operating Conditions Temperature Range (TA) . . . . . . . . . . . . . . . . . . . . . -55oC to 125oC Supply Voltage Range, VCC HC Types . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2V to 6V HCT Types . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .4.5V to 5.5V DC Input or Output Voltage, VI, VO . . . . . . . . . . . . . . . . . 0V to VCC Input Rise and Fall Time 2V . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1000ns (Max) 4.5V. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 500ns (Max) 6V . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 400ns (Max) CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 1. The package thermal impedance is calculated in accordance with JESD 51-7. DC Electrical Specifications TEST CONDITIONS PARAMETER SYMBOL VI (V) High Level Input Voltage VIH - Low Level Input Voltage VIL 25oC IO (mA) VCC (V) -40oC TO 85oC -55oC TO 125oC MIN TYP MAX MIN MAX MIN MAX UNITS 2 1.5 - - 1.5 - 1.5 - V 4.5 3.15 - - 3.15 - 3.15 - V 6 4.2 - - 4.2 - 4.2 - V 2 - - 0.5 - 0.5 - 0.5 V 4.5 - - 1.35 - 1.35 - 1.35 V 6 - - 1.8 - 1.8 - 1.8 V -0.02 2 1.9 - - 1.9 - 1.9 - V -0.02 4.5 4.4 - - 4.4 - 4.4 - V -0.02 6 5.9 - - 5.9 - 5.9 - V - - - - - - - - - V HC TYPES High Level Output Voltage CMOS Loads VOH - VIH or VIL High Level Output Voltage TTL Loads Low Level Output Voltage CMOS Loads VOL VIH or VIL Low Level Output Voltage TTL Loads Input Leakage Current II VCC or GND - - -4 4.5 3.98 - - 3.84 - 3.7 - V -5.2 6 5.48 - - 5.34 - 5.2 - V 0.02 2 - - 0.1 - 0.1 - 0.1 V 0.02 4.5 - - 0.1 - 0.1 - 0.1 V 0.02 6 - - 0.1 - 0.1 - 0.1 V - - - - - - - - - V 4 4.5 - - 0.26 - 0.33 - 0.4 V 5.2 6 - - 0.26 - 0.33 - 0.4 V - 6 - - ±0.1 - ±1 - ±1 µA 3 CD54HC10, CD74HC10, CD54HCT10, CD74HCT10 DC Electrical Specifications (Continued) TEST CONDITIONS SYMBOL VI (V) ICC VCC or GND 0 High Level Input Voltage VIH - Low Level Input Voltage VIL High Level Output Voltage CMOS Loads VOH PARAMETER Quiescent Device Current 25oC IO (mA) VCC (V) -40oC TO 85oC -55oC TO 125oC MIN TYP MAX MIN MAX MIN MAX UNITS 6 - - 2 - 20 - 40 µA - 4.5 to 5.5 2 - - 2 - 2 - V - - 4.5 to 5.5 - - 0.8 - 0.8 - 0.8 V VIH or VIL -0.02 4.5 4.4 - - 4.4 - 4.4 - V -4 4.5 3.98 - - 3.84 - 3.7 - V 0.02 4.5 - - 0.1 - 0.1 - 0.1 V 4 4.5 - - 0.26 - 0.33 - 0.4 V ±0.1 - ±1 - ±1 µA HCT TYPES High Level Output Voltage TTL Loads Low Level Output Voltage CMOS Loads VOL VIH or VIL Low Level Output Voltage TTL Loads Input Leakage Current Quiescent Device Current Additional Quiescent Device Current Per Input Pin: 1 Unit Load II VCC and GND 0 5.5 - ICC VCC or GND 0 5.5 - - 2 - 20 - 40 µA ∆ICC (Note 2) VCC - 2.1 - 4.5 to 5.5 - 100 360 - 450 - 490 µA NOTE: 2. For dual-supply systems theoretical worst case (VI = 2.4V, VCC = 5.5V) specification is 1.8mA. HCT Input Loading Table INPUT UNIT LOADS All 0.6 NOTE: Unit Load is ∆ICC limit specified in DC Electrical Specifications table, e.g. 360µA max at 25oC. Switching Specifications Input tr, tf = 6ns PARAMETER SYMBOL TEST CONDITIONS tPLH, tPHL CL = 50pF 25oC -40oC TO 85oC -55oC TO 125oC VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS 2 - - 100 - 125 - 150 ns 4.5 - - 20 - 25 - 30 ns 6 - - 17 - 21 - 26 ns 5 - 8 - - - - - ns HC TYPES Propagation Delay, Input to Output (Figure 1) Propagation Delay, Data Input to Output Y tPLH, tPHL CL = 15pF 4 CD54HC10, CD74HC10, CD54HCT10, CD74HCT10 Switching Specifications Input tr, tf = 6ns PARAMETER Transition Times (Figure 1) Input Capacitance Power Dissipation Capacitance (Notes 3, 4) (Continued) SYMBOL TEST CONDITIONS tTLH, tTHL CL = 50pF 25oC -40oC TO 85oC -55oC TO 125oC VCC (V) MIN TYP MAX MIN MAX MIN MAX UNITS 2 - - 75 - 95 - 110 ns 4.5 - - 15 - 19 - 22 ns 6 - - 13 - 16 - 19 ns CI - - - - 10 - 10 - 10 pF CPD - 5 - 24 - - - - - pF HCT TYPES Propagation Delay, Input to Output (Figure 2) tPLH, tPHL CL = 50pF 4.5 - - 24 - 30 - 36 ns Propagation Delay, Data Input to Output Y tPLH, tPHL CL = 15pF 5 - 9 - - - - - ns Transition Times (Figure 2) tTLH, tTHL CL = 50pF 4.5 - - 15 - 19 - 22 ns Input Capacitance Power Dissipation Capacitance (Notes 3, 4) CI - - - - 10 - 10 - 10 pF CPD - 5 - 28 - - - - - pF NOTES: 3. CPD is used to determine the dynamic power consumption, per gate. 4. PD = VCC2 fi (CPD + CL) where fi = input frequency, CL = output load capacitance, VCC = supply voltage. Test Circuits and Waveforms tr = 6ns tf = 6ns 90% 50% 10% INPUT GND tTLH GND tTHL 90% 50% 10% INVERTING OUTPUT 3V 2.7V 1.3V 0.3V INPUT tTHL tPHL tf = 6ns tr = 6ns VCC tTLH 90% 1.3V 10% INVERTING OUTPUT tPHL tPLH FIGURE 5. HC AND HCU TRANSITION TIMES AND PROPAGATION DELAY TIMES, COMBINATION LOGIC tPLH FIGURE 6. HCT TRANSITION TIMES AND PROPAGATION DELAY TIMES, COMBINATION LOGIC 5 PACKAGE OPTION ADDENDUM www.ti.com 6-Feb-2020 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) 5962-8984301CA ACTIVE CDIP J 14 1 TBD Call TI N / A for Pkg Type -55 to 125 5962-8984301CA CD54HCT10F3A CD54HC10F ACTIVE CDIP J 14 1 TBD Call TI N / A for Pkg Type -55 to 125 CD54HC10F CD54HC10F3A ACTIVE CDIP J 14 1 TBD Call TI N / A for Pkg Type -55 to 125 8403801CA CD54HC10F3A CD54HCT10F3A ACTIVE CDIP J 14 1 TBD Call TI N / A for Pkg Type -55 to 125 5962-8984301CA CD54HCT10F3A CD74HC10E ACTIVE PDIP N 14 25 Green (RoHS & no Sb/Br) NIPDAU N / A for Pkg Type -55 to 125 CD74HC10E CD74HC10M ACTIVE SOIC D 14 50 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HC10M CD74HC10M96 ACTIVE SOIC D 14 2500 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HC10M CD74HC10MG4 ACTIVE SOIC D 14 50 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HC10M CD74HCT10E ACTIVE PDIP N 14 25 Green (RoHS & no Sb/Br) NIPDAU N / A for Pkg Type -55 to 125 CD74HCT10E CD74HCT10M ACTIVE SOIC D 14 50 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HCT10M CD74HCT10M96 ACTIVE SOIC D 14 2500 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HCT10M CD74HCT10M96G4 ACTIVE SOIC D 14 2500 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HCT10M CD74HCT10MT ACTIVE SOIC D 14 250 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 HCT10M (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. Addendum-Page 1 Samples PACKAGE OPTION ADDENDUM www.ti.com 6-Feb-2020 (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
CD74HC10E
物料型号: - CD54HC10F3A - CD54HCT10F3A - CD74HC10E - CD74HC10M - CD74HC10MT - CD74HC10M96 - CD74HCT10E - CD74HCT10M - CD74HCT10MT - CD74HCT10M96
器件简介: 这些芯片是高速CMOS逻辑三输入与非门,具有缓冲输入、低功耗、宽工作温度范围(-55°C至125°C)和平衡的传播延迟与转换时间等特点。HC类型工作电压为2V至6V,HCT类型工作电压为4.5V至5.5V。
引脚分配: 所有设备都具备驱动10个LSTTL负载的能力,HCT逻辑系列与标准LS逻辑系列在功能上引脚兼容。
参数特性: - 典型传播延迟:在5V供电、15pF负载和25°C时为8ns - 扇出能力:标准输出可驱动10个LSTTL负载,总线驱动器输出可驱动15个LSTTL负载 - 显著降低与LSTTL逻辑集成电路相比的功耗
功能详解: 这些芯片使用硅门CMOS技术,实现了类似于LSTTL门的运行速度,同时保持了标准CMOS集成电路的低功耗。
应用信息: 这些芯片适用于需要高速和低功耗逻辑功能的场合。
封装信息: 提供多种封装选项,包括CERDIP、PDIP和SOIC,具体封装类型和数量在文档中有详细说明。
CD74HC10E 价格&库存
很抱歉,暂时无法提供与“CD74HC10E”相匹配的价格&库存,您可以联系我们找货
