PACKAGE MATERIALS INFORMATION
www.ti.com
30-Dec-2020
TAPE AND REEL INFORMATION
*All dimensions are nominal
Device
SN74LS26DR
Package Package Pins
Type Drawing
SOIC
D
14
SPQ
Reel
Reel
A0
Diameter Width (mm)
(mm) W1 (mm)
2500
330.0
16.4
Pack Materials-Page 1
6.5
B0
(mm)
K0
(mm)
P1
(mm)
9.0
2.1
8.0
W
Pin1
(mm) Quadrant
16.0
Q1
www.ti.com
30-Dec-2020
Device
Package Type
Package Drawing
Pins
SPQ
Length (mm)
Width (mm)
Height (mm)
SN74LS26DR
SOIC
D
14
2500
853.0
449.0
35.0
Pack Materials-Page 2
PACKAGE OUTLINE
J0014A
CDIP - 5.08 mm max height
SCALE 0.900
CERAMIC DUAL IN LINE PACKAGE
PIN 1 ID
(OPTIONAL)
A
4X .005 MIN
[0.13]
.015-.060 TYP
[0.38-1.52]
1
14
12X .100
[2.54]
14X .014-.026
[0.36-0.66]
14X .045-.065
[1.15-1.65]
.010 [0.25] C A B
.754-.785
[19.15-19.94]
8
7
B
.245-.283
[6.22-7.19]
.2 MAX TYP
[5.08]
C
.13 MIN TYP
[3.3]
SEATING PLANE
.308-.314
[7.83-7.97]
AT GAGE PLANE
.015 GAGE PLANE
[0.38]
0 -15
TYP
14X .008-.014
[0.2-0.36]
4214771/A 05/2017
NOTES:
1. All controlling linear dimensions are in inches. Dimensions in brackets are in millimeters. Any dimension in brackets or parenthesis are for
reference only. Dimensioning and tolerancing per ASME Y14.5M.
2. This drawing is subject to change without notice.
3. This package is hermitically sealed with a ceramic lid using glass frit.
4. Index point is provided on cap for terminal identification only and on press ceramic glass frit seal only.
5. Falls within MIL-STD-1835 and GDIP1-T14.
www.ti.com
EXAMPLE BOARD LAYOUT
J0014A
(.300 ) TYP
[7.62]
SEE DETAIL A
SEE DETAIL B
1
14
12X (.100 )
[2.54]
SYMM
14X ( .039)
[1]
8
7
SYMM
LAND PATTERN EXAMPLE
NON-SOLDER MASK DEFINED
SCALE: 5X
.002 MAX
[0.05]
ALL AROUND
(.063)
[1.6]
METAL
( .063)
[1.6]
SOLDER MASK
OPENING
METAL
(R.002 ) TYP
[0.05]
.002 MAX
[0.05]
ALL AROUND
SOLDER MASK
OPENING
DETAIL A
DETAIL B
SCALE: 15X
13X, SCALE: 15X
4214771/A 05/2017
www.ti.com
IMPORTANT NOTICE AND DISCLAIMER
TI PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE
DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, WEB TOOLS, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS”
AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY
IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD
PARTY INTELLECTUAL PROPERTY RIGHTS.
These resources are intended for skilled developers designing with TI products. You are solely responsible for (1) selecting the appropriate
TI products for your application, (2) designing, validating and testing your application, and (3) ensuring your application meets applicable
standards, and any other safety, security, or other requirements. These resources are subject to change without notice. TI grants you
permission to use these resources only for development of an application that uses the TI products described in the resource. Other
reproduction and display of these resources is prohibited. No license is granted to any other TI intellectual property right or to any third
party intellectual property right. TI disclaims responsibility for, and you will fully indemnify TI and its representatives against, any claims,
damages, costs, losses, and liabilities arising out of your use of these resources.
TI’s products are provided subject to TI’s Terms of Sale (www.ti.com/legal/termsofsale.html) or other applicable terms available either on
ti.com or provided in conjunction with such TI products. TI’s provision of these resources does not expand or otherwise alter TI’s applicable
warranties or warranty disclaimers for TI products.
Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265
Copyright © 2020, Texas Instruments Incorporated
很抱歉,暂时无法提供与“SN74LS26D”相匹配的价格&库存,您可以联系我们找货
