74HCT11PW-Q100,118
74HCT11PW-Q100,118
    NEXPERIA(安世)
    TSSOP-14
    IC GATE AND 3CH 3-INP 14TSSOP
74HCT11PW-Q100,118 数据手册
74HC11-Q100; 74HCT11-Q100 Triple 3-input AND gate Rev. 4 — 11 August 2021 Product data sheet 1. General description The 74HC11-Q100; 74HCT11-Q100 is a triple 3-input AND gate. Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 1) • Specified from -40 °C to +85 °C and from -40 °C to +125 °C Wide supply voltage range from 2.0 to 6.0 V CMOS low power dissipation High noise immunity Latch-up performance exceeds 100 mA per JESD 78 Class II Level B Input levels: • For 74HC11-Q100: CMOS level • For 74HCT11-Q100: TTL level Complies with JEDEC standards: • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V) ESD protection: • MIL-STD-883, method 3015 exceeds 2000 V • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) 3. Ordering information Table 1. Ordering information Type number Package 74HC11D-Q100 Temperature range Name Description Version -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 -40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74HCT11D-Q100 74HC11PW-Q100 74HCT11PW-Q100 74HC11-Q100; 74HCT11-Q100 Nexperia Triple 3-input AND gate 4. Functional diagram 1 1 1A 2 1B 13 1C 3 2A 4 2B 5 2C 9 3A 10 3B 11 3C 2 1Y 12 2Y 6 3Y 8 12 & 6 13 3 4 5 A 9 10 & C mna792 Logic symbol Fig. 2. Y B 8 11 mna793 Fig. 1. & IEC logic symbol mna794 Fig. 3. Logic diagram for one gate 5. Pinning information 5.1. Pinning 74HC11 74HCT11 1A 1 14 VCC 1B 2 13 1C 2A 3 12 1Y 74HC11 74HCT11 1A 1 14 VCC 1B 2 13 1C 3 12 1Y 2B 4 11 3C 2A 2C 5 10 3B 2B 4 11 3C 2C 5 10 3B 2Y 6 9 2Y 6 9 3A GND 7 8 3Y GND 7 8 3A 3Y 001aal407 Fig. 4. 001aal408 Pin configuration SOT108-1 (SO14) Fig. 5. Pin configuration SOT402-1 (TSSOP14) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A 1, 3, 9 data input 1B, 2B, 3B 2, 4, 10 data input GND 7 ground (0 V) 1C, 2C, 3C 13, 5, 11 data input 1Y, 2Y, 3Y 12, 6, 8 data output VCC 14 supply voltage 74HC_HCT11_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 11 August 2021 © Nexperia B.V. 2021. All rights reserved 2 / 11 74HC11-Q100; 74HCT11-Q100 Nexperia Triple 3-input AND gate 6. Functional description Table 3. Function selection H = HIGH voltage level; L = LOW voltage level; X = don’t care Output Input nA nB nC nY L X X L X L X L X X L L H H H H 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Min Max -0.5 +7 V IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current -0.5 V < VO < VCC + 0.5 V - ±25 mA ICC IGND supply current - 50 mA ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] Conditions [2] Unit The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C. For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC11-Q100 74HCT11-Q100 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 - +125 -40 - +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 74HC_HCT11_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 11 August 2021 © Nexperia B.V. 2021. All rights reserved 3 / 11 74HC11-Q100; 74HCT11-Q100 Nexperia Triple 3-input AND gate 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 VCC = 4.5 V 3.15 2.4 - 1.5 - 3.15 - 1.5 - V - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V 74HC11-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V VI = VIH or VIL HIGH-level output voltage IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V VI = VIH or VIL LOW-level output voltage IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1 - ±1 μA II input leakage current VI = VCC or GND; VCC = 6.0 V ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 2.0 - 20 - 40 μA CI input capacitance - 3.5 - - - - - pF 74HCT11-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH VI = VIH or VIL; VCC = 4.5 V HIGH-level output voltage IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V - 0 0.1 - 0.1 - 0.1 V - - ±0.1 - ±1 - ±1 μA - - 2.0 - 20 - 40 μA IO = -4.0 mA VOL VI = VIH or VIL; VCC = 4.5 V LOW-level output voltage IO = 20 μA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V 74HC_HCT11_Q100 Product data sheet VI = VCC or GND; VCC = 5.5 V All information provided in this document is subject to legal disclaimers. Rev. 4 — 11 August 2021 © Nexperia B.V. 2021. All rights reserved 4 / 11 74HC11-Q100; 74HCT11-Q100 Nexperia Triple 3-input AND gate Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max ΔICC additional per input pin; supply current VI = VCC - 2.1 V; IO = 0 A; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V - 100 360 - 450 - 490 μA CI input capacitance - 3.5 - - - - - pF 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; CL = 50 pF; for test circuit see Fig. 7. Symbol Parameter Conditions 25 °C Min -40 °C to +85 °C -40 °C to +125 °C Unit Typ Max Min Max Min Max 74HC11-Q100 tpd tt propagation delay transition time nA, nB to nY; see Fig. 6 [1] VCC = 2.0 V - 32 100 - 125 - 150 ns VCC = 4.5 V - 12 20 - 25 - 30 ns VCC = 5.0 V; CL = 15 pF - 9 - - - - - ns VCC = 6.0 V - 10 17 - 21 - 26 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns - 6 13 - 16 - 19 ns - 18 - - - - - pF VCC = 4.5 V - 16 24 - 30 - 36 ns VCC = 5.0 V; CL = 15 pF - 11 - - - - - ns [2] - 7 15 - 19 - 22 ns [3] - 20 - - - - - pF see Fig. 6 [2] VCC = 6.0 V CPD power dissipation per package; capacitance VI = GND to VCC [3] 74HCT11-Q100 tpd propagation delay nA, nB to nY; see Fig. 6 tt transition time CPD power dissipation per package; capacitance VI = GND to VCC - 1.5 V [1] [2] [3] VCC = 4.5 V; see Fig. 6 [1] tpd is the same as tPHL and tPLH. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL x VCC x fo) = sum of outputs. 74HC_HCT11_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 11 August 2021 © Nexperia B.V. 2021. All rights reserved 5 / 11 74HC11-Q100; 74HCT11-Q100 Nexperia Triple 3-input AND gate 10.1. Waveforms and test circuit VI VM nA, nB, nC input GND tPHL VOH tPLH VY nY output VOL VM VX tTHL tTLH 001aal409 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. Input to output propagation delays Table 8. Measurement points Input Type Output VM VM VX VY 74HC11-Q100 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HCT11-Q100 1.3 V 1.3 V 0.1VCC 0.9VCC VI negative pulse VM tf tr tr VI GND VM 10 % GND positive pulse tW 90 % tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions test circuit: RT = termination resistance should be equal to output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. Fig. 7. Test circuit for measuring switching times Table 9. Test data Type Load Input Test VI tr, tf CL 74HC11-Q100 VCC 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HCT11-Q100 3.0 V 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HC_HCT11_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 11 August 2021 © Nexperia B.V. 2021. All rights reserved 6 / 11 74HC11-Q100; 74HCT11-Q100 Nexperia Triple 3-input AND gate 11. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 8. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74HC_HCT11_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 11 August 2021 © Nexperia B.V. 2021. All rights reserved 7 / 11 74HC11-Q100; 74HCT11-Q100 Nexperia Triple 3-input AND gate TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 Fig. 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Package outline SOT402-1 (TSSOP14) 74HC_HCT11_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 11 August 2021 © Nexperia B.V. 2021. All rights reserved 8 / 11 74HC11-Q100; 74HCT11-Q100 Nexperia Triple 3-input AND gate 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT11_Q100 v.4 20210811 Product data sheet - 74HC_HCT11_Q100 v.3 Modifications: • 74HC_HCT11_Q100 v.3 20210108 Product data sheet - 74HC_HCT11_Q100 v.2 Modifications: • • • Section 2 updated. The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 7: Derating values for Ptot total power dissipation have been updated. 74HC_HCT11_Q100 v.2 20130322 Modifications: • 74HC_HCT11_Q100 v.1 20130228 74HC_HCT11_Q100 Product data sheet Product data sheet - 74HC_HCT11_Q100 v.1 Section 2: Removed redundant temperature range. Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 4 — 11 August 2021 - © Nexperia B.V. 2021. All rights reserved 9 / 11 74HC11-Q100; 74HCT11-Q100 Nexperia Triple 3-input AND gate equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 14. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or 74HC_HCT11_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 11 August 2021 © Nexperia B.V. 2021. All rights reserved 10 / 11 74HC11-Q100; 74HCT11-Q100 Nexperia Triple 3-input AND gate Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 2 6. Functional description................................................. 3 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................3 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 5 10.1. Waveforms and test circuit........................................ 6 11. Package outline.......................................................... 7 12. Abbreviations.............................................................. 9 13. Revision history..........................................................9 14. Legal information......................................................10 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 August 2021 74HC_HCT11_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 11 August 2021 © Nexperia B.V. 2021. All rights reserved 11 / 11
74HCT11PW-Q100,118 价格&库存
很抱歉,暂时无法提供与“74HCT11PW-Q100,118”相匹配的价格&库存,您可以联系我们找货
