EXL1V0703-4R7-R
EXL1V0703-4R7-R
    EATON(伊顿)
    IND_8.4X8MM_SM
    功率电感 ±20% 6.9A 4.7µH 8.40 x 8.00mm 3.10mm 26.7mΩ IND_8.4X8MM_SM
EXL1V0703-4R7-R 数据手册
Technical Data 11193 Effective November 2020 EXL1V0703 High current molded inductor Applications Product features • Voltage Regulator Module (VRM) • Multi-phase regulators • Point-of-load (POL) converters • Desktop and server VRMs and EVRDs • Base station equipment • Laptop and notebook regulators • Battery power systems • Graphics cards • Data networking and storage system • High current carrying capacity • Low DCR, high efficiency • Magnetically shielded, low EMI • Soft saturation Environmental compliance and general specifications • Inductance range from 1 μH to 8.2 μH • • Current range from 5.9 A to 28 A Storage temperature range (Component): -40 °C to +125 °C • 8.7 mm x 8.3 mm footprint surface mount package in a 3.1 mm height • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) • Alloy powder core material • Solder reflow temperature: J-STD-020 (latest revision) compliant • Moisture Sensitivity Level (MSL) 1 HALOGEN Pb HF FREE EXL1V0703 High current molded inductor  Technical Data 11193 Effective November 2020 Product specifications Part number5 OCL1 (μH) ± 20% FLL2 (μH) minimum Irms3 (A) typical +20 °C rise +40 °C rise Isat4 (A) DCR (mΩ) typical @ +25 °C DCR (mΩ) maximum @ +25 °C SRF (MHz) typical EXL1V0703-1R0-R 1.0 0.56 16.1 21.8 28 4.55 5.0 35 EXL1V0703-1R5-R 1.5 0.84 12 15.3 23.5 7.5 8.25 31 EXL1V0703-2R2-R 2.2 1.23 10 13 17 12.4 13.7 28 EXL1V0703-2R7-R 2.7 1.51 9.2 11.4 13.5 14 15.4 23 EXL1V0703-3R3-R 3.3 1.84 8.0 10 13 16.3 18 22 EXL1V0703-4R7-R 4.7 2.63 6.9 9.0 12.2 24.2 26.7 18 EXL1V0703-5R6-R 5.6 3.13 5.3 7.3 11.5 30.1 33.2 16 EXL1V0703-6R8-R 6.8 3.8 4.5 6.8 11 38.6 42.5 14 EXL1V0703-8R2-R 8.2 4.59 3.0 5.9 9.0 44.3 48.73 12 1. Open circuit inductance (OCL) Test parameters: 100 kHz, 0.1 Vrms, 0.0 Adc, +25 °C 2. Full load inductance (FLL) Test parameters: 100 kHz, 0.1 Vrms, Isat, , +25 °C 3. Irms: Heat rated current (Irms) will cause the part temperature rise approximately ΔT of 40 °C. Circuit design, component, PCB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. The part temperature (ambient + temp rise) should not exceed +125 °C under worst case operating conditions. Mechanical parameters, schematic, pad layout (mm) Recommended pad layout 4. Isat: Peak current for approximately 30% rolloff @ +25 °C 5. Part number definition: EXL1V0703-xxx-R EXL1V0703 = Product code and size xxx= inductance value in μH, R= decimal point, If no R is present then third digit equals the number of zeros -R suffix = RoHS compliant 6. Rated operating voltage: 40 V typical Schematic Figure 1. DCR test Part number A B EXL1V0703-xxx-R 8.4 ± 0.3 8 ± 0.3 C 2.9 ± 0.2 D D E F 6.6 ± 0.3 (1R0, 1R5) 6.2 ± 0.3 (2R2 to 8R2) 1.75 ± 0.2 3.15 ± 0.25 Part marking: 0703, xxx= Inductance value in μH (R= Decimal point, if no R is present last digit equals number of zeros), yyyy= Lot code All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ± 0.3 millimeters unless stated otherwise Dimensions of recommended PCB layout are reference only. Pad layout tolerances are ± 0.1 millimeters unless stated otherwise Four terminal kelvin-clip recommended for DCR testing as shown in Figure 1. Traces or vias underneath the inductor is not recommended. 2 www.eaton.com/electronics Technical Data 11193 EXL1V0703 High current molded inductor Effective November 2020  Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 1500 parts per 13” diameter reel (EIA-481 compliant) W ± 0.30 16 F ± 0.1 7.5 E1 ± 0.1 1.75 P0 ± 0.1 4.0 P1 ± 0.1 12 P2 ± 0.1 2.0 D0 + 0.1/-0 1.5 D1 + 0.1/-0 1.5 A0 ± 0.1 8.8 B0 ± 0.1 8.4 K0 ± 0.1 3.3 T ± 0.05 0.35 P0 X 10 ± 0.2 40 Qualification testing No. Test item Reference standards Test condition Acceptable value/range 1 Life MIL-STD-202 Method 108 +125 °C + Irms for 1000 hours a. Appearance b. ΔL/L
EXL1V0703-4R7-R 价格&库存
很抱歉,暂时无法提供与“EXL1V0703-4R7-R”相匹配的价格&库存,您可以联系我们找货
EXL1V0703-4R7-R
    库存:1500
    EXL1V0703-4R7-R
    • 1+7.253091+0.93623
    • 10+5.9982410+0.77426
    • 100+4.93478100+0.63699
    库存:263
    EXL1V0703-4R7-R
      EXL1V0703-4R7-R
      • 1500+4.289761500+0.55373
      • 3000+4.045433000+0.52219
      • 4500+3.909184500+0.50460
      • 7500+3.744227500+0.48331
      • 10500+3.6395110500+0.46979
      • 15000+3.5318015000+0.45589
      库存:263
