HCMA1104-R56-R
HCMA1104-R56-R
    EATON(伊顿)
    SMD,11.1x10mm
    固定电感器 Nonstandard 560nH ±20% 25A 1.8mΩ
HCMA1104-R56-R 数据手册
Technical Data 10349 Effective December 2014 Coiltronics HCMA1104 Series Automotive grade high current power inductors Applications • • Product description Body electronics • Central body control module • Vehicle access control system • Headlamps, tail lamps and interior lighting • Heating Ventilation and Air Conditioning controllers (HVAC) • Doors, window lift and seat control Advanced driver assistance systems • Adaptive cruise control (ACC) • Automatic parking control • Collision avoidance system • Car black box system • AEC-Q200 grade 3 qualified • High current carrying capacity • Audio subsystem: head unit and trunk amp • Low core losses • Digital instrument cluster • Magnetically shielded, low EMI • In-Vehicle Infotainment (IVI) and navigation • Frequency range up to 5MHz • Inductance range from 0.20μH to 10μH • Airbag control unit • Current range from 7.5A to 45A • Electronic Stability Control system (ESC) • 11.5x10.3mm footprint surface mount package in a 4.0mm height • Electric parking brake • Powder iron core material • Halogen free, lead free, RoHS compliant • • Infotainment and cluster electronics Chassis and safety electronics Environmental data • Storage temperature range (Component): -55°C to +125°C • Operating temperature range: -55°C to +125°C (ambient + self-temperature rise) • Solder reflow temperature: J-STD-020D compliant HALOGEN Pb HF FREE The Coiltronics brand of magnetics (formerly of the Bussmann Division of Cooper Industries) is now part of Eaton’s Electrical Group, Electronics Division. Coiltronics is now part of Eaton Same great products plus even more. Technical Data 10349 HCMA1104 Series Automotive grade high current, power inductors Effective December 2014 Product specifications OCL1 (μH) ± 20% FLL2 Min. (μH) Irms3 (amps) Isat4, 5 @25°C (amps) DCR (mΩ) @ 20°C typical DCR (mΩ) @ 20°C maximum K-factor6 HCMA1104-R20-R 0.20 0.13 32 45 0.63 0.72 411 HCMA1104-R36-R 0.36 0.23 30 42 1.04 1.20 269 HCMA1104-R45-R 0.45 0.29 29 36 1.07 1.23 219 Part Number7 HCMA1104-R56-R 0.56 0.36 25 32 1.56 1.80 230 HCMA1104-R90-R 0.90 0.58 22 28 2.17 2.50 236 HCMA1104-1R0-R 1.0 0.56 18 28 3.00 3.30 378 HCMA1104-1R5-R 1.5 0.84 16 32 3.80 4.20 310 HCMA1104-2R2-R 2.2 1.23 12 18 6.00 7.00 253 HCMA1104-3R3-R 3.3 1.85 10 16 10.8 11.8 220 HCMA1104-4R7-R 4.7 2.63 8.5 15 17.0 20.0 175 HCMA1104-100-R 10 5.60 7.5 8.5 27.0 30.0 116 1. Open Circuit Inductance (OCL) Test Parameters: 100kHz, 0.25Vrms, 0.0Adc, +25°C. 5. Isat: Peak current for approximately 30% rolloff at +25°C- HCMA1104-1R0-R to HCMA1104-100-R. 2. Full Load Inductance (FLL) Test Parameters: 100kHz, 0.25Vrms, Isat, @ +25°C. 6. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ∆I. Bp-p: (Gauss), K: (K-factor from table), L: (Inductance in µH), ∆I (Peak to peak ripple current in amps). 3. Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed 125°C under worst case operating conditions verified in the end application. 4. Isat: Peak current for approximately 20% rolloff at +25°C- HCMA1104-R20-R to HCMA1104-R90-R. 7. Part Number Definition: HCMA1104-yyy-R - HCMA1104 = Product code and size - yyy= Inductance value in µH, R = decimal point, if no R is present then third character = number of zeros. - “-R” suffix = RoHS compliant Dimensions - mm Recommended pad layout Schematic AXXX wlyy R Part marking: A = automotive grade, xxx = inductance value in µH, R = decimal point, if no R is present, third character = number of zeros, wlyy = date code, R = revision level All soldering surfaces to be coplaner within 0.10 millimeters Tolerances are ±0.3 millimeters unless stated otherwise Color: Grey 2 www.eaton.com/elx HCMA1104 Series Automotive grade high current, power inductors Technical Data 10349 Effective December 2014 AXXX wlyy R Packaging information - mm Supplied in tape and reel packaging, 850 parts per 13” diameter reel. 50 50 40 40 Temperature Rise (°C) Temperature Rise (°C) Temperature rise vs. total loss 30 HCMA1104-R20-R 20 HCMA1104-R45-R 10 HCMA1104-R36-R/ HCMA1104-R56-R HCMA1104-R90-R 0 0.0 0.5 1.0 Total Loss (W) 1.5 30 HCMA1104-1R0-R HCMA1104-1R5-R 20 HCMA1104-3R3-R HCMA1104-4R7-R 10 HCMA1104-2R2-R/ HCMA1104-100-R 0 2.0 0.0 0.5 1.0 1.5 2.0 Total Loss (W) www.eaton.com/elx 3 Technical Data 10349 HCMA1104 Series Automotive grade high current, power inductors Effective December 2014 Core loss HCMA1104-R20-R to HCMA1104-R90-R 10,000 Core Loss vs Bp-p 1MHz 500KHz 300KHz 200KHz Core Loss (mW) 1000 100KHz 50KHz 25KHz 100 10 1 0.1 100 1000 10,000 Bp-p (Gauss) HCMA1104-1R0-R to HCMA1104-100-R 10,000 Core Loss vs Bp-p 1MHz 500KHz 300KHz 200KHz Core Loss (mW) 1000 100KHz 50KHz 25KHz 100 10 1 0.1 4 www.eaton.com/elx 100 1000 Bp-p (Gauss) 10,000 HCMA1104 Series Automotive grade high current, power inductors Technical Data 10349 Effective December 2014 Inductance characteristics HCMA1104-R20-R 100% HCMA1104-R36-R 100% 90% 80% 80% % of OCL % of OCL 90% 70% 70% 60% 60% 50% 50% 40% 40% 0 10 20 30 40 50 60 70 80 90 100 0 IDC (Amps) 20 30 40 50 60 70 80 90 100 IDC (Amps) HCMA1104-R45-R 100% 10 HCMA1104-R56-R 100% 90% 80% 80% % of OCL % of OCL 90% 70% 70% 60% 60% 50% 50% 40% 40% 10 20 30 40 IDC (Amps) 50 60 70 0 80 10 20 30 40 IDC (Amps) 50 60 70 HCMA1104-R90-R 100% 90% 80% % of OCL 0 70% 60% 50% 40% 0 10 20 30 IDC (Amps) 40 50 60 www.eaton.com/elx 5 Technical Data 10349 HCMA1104 Series Automotive grade high current, power inductors Effective December 2014 Inductance characteristics HCMA1104-1R5-R 100% 90% 90% 80% 80% % of OCL % of OCL HCMA1104-1R0-R 100% 70% 70% 60% 60% 50% 50% 40% 40% 0 5 10 15 20 25 30 35 40 0 5 10 15 HCMA1104-2R2-R 90% 90% 80% 80% 70% 60% 50% 50% 2 4 6 8 10 12 14 16 18 20 22 24 26 28 0 2 4 6 8 10 Idc (Amps) 12 14 16 18 20 22 Idc (Amps) HCMA1104-4R7-R HCMA1104-100-R 100% 100% 90% 90% 80% 80% % of OCL % of OCL 35 40% 0 70% 60% 70% 60% 50% 50% 0 2 4 6 8 10 Idc (Amps) 6 30 70% 60% 40% 40% 25 HCMA1104-3R3-R 100% % of OCL % of OCL 100% 20 Idc (Amps) Idc (Amps) www.eaton.com/elx 12 14 16 18 40% 0 2 4 6 8 Idc (Amps) 10 12 14 16 HCMA1104 Series Automotive grade high current, power inductors Technical Data 10349 Effective December 2014 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature 25°C T smax Volume mm3 220°C 220°C Table 2 - Lead (Pb) Free Solder (T c) Tsmin Package Thickness 2.5mm ts Time 25°C to Peak Volume mm3 2000 260°C 245°C 245°C Time Reference JDEC J-STD-020D Profile Feature Preheat and Soak • Temperature min. (Tsmin) Standard SnPb Solder 100°C Lead (Pb) Free Solder 150°C • Temperature max. (Tsmax) 150°C 200°C • Time (Tsmin to Tsmax) (ts) Average ramp up rate Tsmax to Tp Liquidous temperature (TL) Time at liquidous (tL) Peak package body temperature (TP)* Time (tp)** within 5 °C of the specified classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) Time 25°C to Peak Temperature 60-120 Seconds 60-120 Seconds 3°C/ Second Max. 3°C/ Second Max. 183°C 60-150 Seconds 217°C 60-150 Seconds Table 1 Table 2 20 Seconds** 30 Seconds** 6°C/ Second Max. 6°C/ Second Max. 6 Minutes Max. 8 Minutes Max. * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. North America Eaton’s Electrical Group Electronics Division 1225 Broken Sound Parkway NW Suite F Boca Raton, FL 33487-3533 Tel: 1-561-998-4100 Fax: 1-561-241-6640 Toll Free: 1-888-414-2645 Eaton’s Electrical Group Electronics Division P.O. Box 14460 St. Louis, MO 63178-4460 Tel: 1-636-394-2877 Fax: 1-636-527-1607 Europe Eaton’s Electrical Group Electronics Division Burton-on-the-Wolds Leicestershire, LE 12 5th UK Phone: +44 (0) 1509 882 600 Fax: +44 (0) 1509 882 786 Eaton’s Electrical Group Electronics Division Avda Santa Eulalia, 290 Terrassa, Barcelona 08223 Spain Phone: +34-93-736-2813 Fax: +34-93-783-5055 Asia Pacific Eaton’s Electrical Group Electronics Division No.2, #06-01 Serangoon North Avenue 5 Singapore 554911 Tel: +65 6645 9888 Fax: +65 6728 3155 The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton’s Electrical Group Electronics Division 114 Old State Road Ellisville, MO 63021 United States www.eaton.com/elx © 2014 Eaton All Rights Reserved Publication No. 10349 — BU-SB14815 December 2014 Eaton is a registered trademark. All other trademarks are property of their respective owners. www.eaton.com/elx 7
HCMA1104-R56-R 价格&库存
很抱歉,暂时无法提供与“HCMA1104-R56-R”相匹配的价格&库存,您可以联系我们找货
HCMA1104-R56-R
  • 1+11.657291+1.46173
  • 10+9.6045510+1.20433
  • 25+8.8828625+1.11384
  • 50+8.3726950+1.04987
  • 100+7.89422100+0.98987
  • 250+7.30391250+0.91585
库存:150
HCMA1104-R56-R
  • 850+7.29841850+0.91516
  • 1700+6.882831700+0.86305
  • 2550+6.651052550+0.83399
  • 4250+6.370454250+0.79880
  • 5950+6.192325950+0.77647
  • 8500+6.009118500+0.75349
库存:150
