Technical Data 10148
Effective June 2017
Supersedes August 2013
FP1208
High frequency, high current power inductors
Applications
Multi-phase regulators
Voltage Regulator Modules (VRMs)
Desktop and server VRMs and EVRDs
Data networking and storage systems
Graphics cards and battery power systems
Point-of-Load modules
DCR Sensing circuits
Environmental data
Product features
12.1x8.0x8.0mm maximum surface mount
package
Ferrite core material
Controlled DCR for sensing circuits
Inductance range from 150nH to 250nH
Current range from 44 to 85 Amps
Halogen free, lead free, RoHS compliant
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
Effective June 2017
Product Specifications
Part
Number 8
FP1208R1-R15-R
FP1208R1-R18-R
FP1208R1-R21-R
FP1208R1-R23-R
FP1208R1-R25-R
OCL 1
(nH)±10%
150
180
210
230
250
FLL min.
(nH)
114
137
160
176
191
2
Irms 3
(Amps)
50
Isat 1 4
(Amps)
85
72
65
61
55
1. Open Circuit Inductance (OCL) Test Parameters: 100kHz, 0.1Vrms, 0.0Adc@25°C
2. Full Load Inductance (FLL) Test Parameters: 100kHz, 0.1Vrms, Isat1
3. Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is
necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of
other heat generating components will affect the temperature rise. It is recommended that the
temperature of the part not exceed 125°C under worst case operating conditions verified in
the end application.
4. Isat1: Peak current for approximately 20% rolloff @ 25°C
Isat 2 5
(Amps)
79
66
57
53
48
Isat 3 6
(Amps)
72
63
55
50
44
DCR
(mΩ) @ 20°C
0.29±5%
K-factor
283
283
283
283
283
5. Isat2: Peak current for approximately 20% rolloff @ 85°C
6. Isat3: Peak current for approximately 20% rolloff @ 125°C
7. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L
* ∆I * 10-3. Bp-p:(Gauss), K: (K-factor from table), L: (Inductance in nH),
∆I (Peak to peak ripple current in Amps).
8. Part Number Definition: FP1208Rx-Rxx-R:
- FP1208= Product code and size
- Rx= DCR indicator
- Rxx= Inductance value in µH
- “-R” suffix = RoHS compliant
Dimensions- mm
DCR measured from point “a” to point “b”
Part marking: 1208Rx (Rx= DCR indicator), Rxx = Inductance value in uH (R= decimal point) wwllyy= date
code, r= revision level
Tolerances are +/- 0.15 millimeters unless stated otherwise.
PCB tolerances are +/- 0.10 millimeters unless stated otherwise.
All soldering surfaces to be be coplanar within 0.1 millimeters.
Packaging information - mm
Supplied in tape and reel packaging, 500 parts on a 13” diameter
2
www.eaton.com/electronics
reel.
7
FP1208
Effective June 2017
Temperature rise vs total loss
50
Temperature Rise (°C)
40
30
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
Total Loss (W)
Core loss vs Bp-p
10
Core Loss (W)
1
0.1
0.01
0.001
100
1000
10000
Bp-p (Gauss)
Inductance characteristics
% of OCL vs % of I
sat 1
100%
% of OCL
80%
-40°C
60%
+25°C
40%
+85°C
20%
0%
+125°C
0%
20%
40%
60%
80%
100%
120%
140%
% of I sat 1
3
FP1208
Effective June 2017
Solder Reflow Profile
TP
TC -5°C
Temperature
TL
25°C
Preheat
A
T smax
Table 1 - Standard SnPb Solder (Tc)
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
t
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
Package
Thickness
2.5mm
ts
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 10148 BU-SB13927
June 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“FP1208R1-R25-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.596631+1.33017
- 10+8.7186710+1.09443
- 100+7.16697100+0.89965
- 国内价格 香港价格
- 500+11.22536500+1.40909
- 1000+10.586051000+1.32884
- 1500+10.229621500+1.28410
- 2500+9.797962500+1.22992
- 3500+9.523993500+1.19552
- 5000+9.242195000+1.16015
