Technical Data 10974
Effective November 2019
MCLA1005V2
Automotive multilayer chip inductor
Applications
ADAS
Infotainment
Wireless communications
Wifi, bluetooth, satellite
Antennas tuning
On board computer
Product features
AEC-Q200 qualified
0402 (1005 metric) package
Multilayer monolithic construction yields high
reliability
Inductance range from 1.0 nH to 330 nH
Moisture sensitivity level (MSL): 1
Environmental data
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
HALOGEN
Pb HF
FREE
MCLA1005V2
Product specifications
Part number
OCL
Tolerance
OCL
(nH)
Q minimum
DCR@ (Ω)
@ +25 °C
maximum
Test frequency
(MHz)
Test voltage
(mV)
SRF (MHz)
minimum
I Rated
(mA)
MCLA1005V2-1R0-R
±0.3nH
1.0
8
0.1
100
50
10000
400
MCLA1005V2-1R1-R
±0.3nH
1.1
8
0.1
100
50
10000
400
MCLA1005V2-1R2-R
±0.3nH
1.2
8
0.1
100
50
10000
400
MCLA1005V2-1R3-R
±0.3nH
1.3
8
0.1
100
50
10000
400
MCLA1005V2-1R5-R
±0.3nH
1.5
8
0.1
100
50
6000
300
MCLA1005V2-1R6-R
±0.3nH
1.6
8
0.12
100
50
6000
300
MCLA1005V2-1R8-R
±0.3nH
1.8
8
0.12
100
50
6000
300
MCLA1005V2-2R0-R
±0.3nH
2.0
8
0.15
100
50
6000
300
MCLA1005V2-2R2-R
±0.3nH
2.2
8
0.15
100
50
6000
300
MCLA1005V2-2R4-R
±0.3nH
2.4
8
0.15
100
50
6000
300
MCLA1005V2-2R7-R
±0.3nH
2.7
8
0.15
100
50
6000
300
MCLA1005V2-3R0-R
±0.3nH
3.0
8
0.2
100
50
6000
300
MCLA1005V2-3R3-R
±0.3nH
3.3
8
0.2
100
50
6000
300
MCLA1005V2-3R6-R
±0.3nH
3.6
8
0.2
100
50
4000
300
MCLA1005V2-3R9-R
±0.3nH
3.9
8
0.2
100
50
4000
300
MCLA1005V2-4R3-R
±0.3nH
4.3
8
0.2
100
50
4000
300
MCLA1005V2-4R7-R
±0.3nH
4.7
8
0.25
100
50
4000
300
MCLA1005V2-5R1-R
±0.3nH
5.1
8
0.25
100
50
4000
300
MCLA1005V2-5R6-R
±0.3nH
5.6
8
0.25
100
50
4000
300
MCLA1005V2-6R2-R
±0.3nH
6.2
8
0.3
100
50
3900
300
MCLA1005V2-6R8-R
±5%
6.8
8
0.3
100
50
3900
300
MCLA1005V2-7R5-R
±5%
7.5
8
0.4
100
50
3700
300
MCLA1005V2-8R2-R
±5%
8.2
8
0.4
100
50
3600
300
MCLA1005V2-9R1-R
±5%
9.1
8
0.4
100
50
3400
300
MCLA1005V2-100-R
±5%
10
8
0.4
100
50
3200
300
MCLA1005V2-120-R
±5%
12
8
0.5
100
50
2700
300
MCLA1005V2-150-R
±5%
15
8
0.5
100
50
2300
300
MCLA1005V2-180-R
±5%
18
8
0.6
100
50
2100
300
MCLA1005V2-200-R
±5%
0.6
100
50
2000
300
MCLA1005V2-220-R
±5%
22
8
0.6
100
50
1900
300
MCLA1005V2-270-R
±5%
27
8
0.7
100
50
1600
300
MCLA1005V2-330-R
±5%
33
8
0.8
100
50
1300
200
MCLA1005V2-390-R
±5%
39
8
1
100
50
1200
200
MCLA1005V2-430-R
±5%
43
8
1.1
100
50
1100
200
MCLA1005V2-470-R
±5%
47
8
1.1
100
50
1000
200
MCLA1005V2-560-R
±5%
56
8
1.2
100
50
750
200
MCLA1005V2-680-R
±5%
68
8
1.4
100
50
750
180
MCLA1005V2-820-R
±5%
82
8
2.4
100
50
750
150
MCLA1005V2-101-R
±5%
100
8
2.6
100
50
700
150
MCLA1005V2-121-R
±5%
120
8
2.8
100
50
600
150
1. Test frequency and voltage is for open circuit inductance (OCL) and Q at +25 °C
2. Rated I: When rated I is applied to the product, self-temperature rise will be 20 °C or less.
2
www.eaton.com/electronics
3. Part Number Definition: MCLA1005V2-xxx-R
MCLA1005V2 = Product code and size
xxx= inductance value in nH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
MCLA1005V2
Part number
OCL
Tolerance
OCL
(nH)
Q minimum
DCR@ (Ω)
@ +25 °C
maximum
Test frequency
(MHz)
Test voltage
(mV)
SRF (MHz)
minimum
I Rated
(mA)
MCLA1005V2-151-R
±5%
150
8
3.2
100
50
550
100
MCLA1005V2-181-R
±5%
180
8
3.7
100
50
500
100
MCLA1005V2-221-R
±5%
220
8
4.0
100
50
450
100
MCLA1005V2-271-R
±5%
270
8
4.5
100
50
400
100
MCLA1005V2-331-R
±5%
330
6
7.0
50
50
350
50
Mechanical parameters, schematic, pad layout (mm)
Recommended pad layout
Schematic
Part Number
L
W
T
A
L1
F
G
H
MCLA1005V2-xxx-R
1.00±0.15
0.50±0.15
0.50±0.15
0.25±0.10
0.50±0.15
0.85 ref
0.15 ref
0.75 ref
Part marking: No marking
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.1 millimeters unless stated otherwise
Dimension L1 is for orientation
Pad layout dimensions are reference only
Traces or vias underneath the inductor is not recommended
3
MCLA1005V2
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 10000 parts per 7” diameter reel
4
W±0.2
8.00
F±0.1
3.50
E1±0.2
1.75
E2 Min
na
P0±0.2
4.00
P1±0.1
2.00
P2±0.1
2.00
D0±0.1
1.55
A0
0.65±0.1
B0
1.15±0.1
T
0.6±0.1
T1 Max
na
MCLA1005V2
Inductance and Q vs frequency
M C L A 1005V 2-1R 0-R
100
10
1
50
500
0.1
5000
F requency ( MMH
Hz)
Ls
Q
M C L A 1005V 2-100-R
100
10
1
50
500
F requency ( MHz)
Ls
5000
Q
M C L A 1005V 2-331-R
10000
1000
100
10
1
0.1
50
500
F requency ( MHz)
Ls
Q
5
MCLA1005V2
Solder reflow profile
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2019 Eaton
All Rights Reserved
Printed in USA
Publication No. 10974 BU-MC19102
November 2019
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“MCLA1005V2-1R8-R”相匹配的价格&库存,您可以联系我们找货
