MCQ1V2012-R150-R
MCQ1V2012-R150-R
    EATON(伊顿)
    固定电感器 0805 150nH ±10% 250mA 250mΩ 200MHz 20@25MHz
MCQ1V2012-R150-R 数据手册
Technical Data 11103 Effective June 2020 MCQ1V2012 Multilayer high Q chip inductor Applications • Industrial connectivity (IoT) • Wireless communications • Bluetooth • WiFi • Antenna • Machine-to-machine (M2M) • Mobile phones Product features • Wearable devices • 0805 (2012 metric) package • Wireless LAN • Multilayer monolithic construction yields high reliability • Computing/gaming consoles • Inductance range from 0.047 µH to 4.7 µH • RF transceiver modules • Moisture sensitivity level (MSL): 1 • Broadband components Environmental compliance and general specifications • Operating temperature range: -40 °C to +85 °C (ambient plus self-temperature rise) HALOGEN Pb HF FREE MCQ1V2012 Multilayer high Q chip inductor  Technical Data 11103 Effective June 2020 Product specifications Ls Tolerance (%) Ls1 (µH) Q minimum DCR (Ω) @ +25 °C maximum Test frequency2 (MHz) Test voltage2 (mV) SRF (MHz) minimum Rated I3 maximum (mA)3 MCQ1V2012-R047-R ±10 0.047 25 0.15 50 50 320 300 MCQ1V2012-R056-R ±10 0.056 25 0.15 50 50 320 300 MCQ1V2012-R068-R ±10 0.068 25 0.2 50 50 280 300 MCQ1V2012-R082-R ±10 0.082 25 0.2 50 50 280 300 MCQ1V2012-R100-R ±10 0.10 20 0.2 25 50 235 250 MCQ1V2012-R120-R ±10 0.12 20 0.25 25 50 220 250 MCQ1V2012-R150-R ±10 0.15 20 0.25 25 50 200 250 MCQ1V2012-R180-R ±10 0.18 20 0.3 25 50 185 250 MCQ1V2012-R220-R ±10 0.22 20 0.3 25 50 170 250 MCQ1V2012-R270-R ±10 0.27 20 0.4 25 50 150 250 MCQ1V2012-R330-R ±10 0.33 20 0.4 25 50 145 250 MCQ1V2012-R390-R ±10 0.39 25 0.5 25 50 135 200 MCQ1V2012-R470-R ±10 0.47 25 0.5 25 50 125 200 MCQ1V2012-R560-R ±10 0.56 25 0.6 25 50 115 150 MCQ1V2012-R680-R ±10 0.68 25 0.65 25 50 105 150 MCQ1V2012-R820-R ±10 0.82 25 0.7 25 50 100 150 MCQ1V2012-1R0-R ±10 1.0 35 0.4 10 50 75 50 MCQ1V2012-1R2-R ±10 1.2 35 0.4 10 50 65 50 MCQ1V2012-1R5-R ±10 1.5 35 0.4 10 50 60 50 MCQ1V2012-1R8-R ±10 1.8 35 0.4 10 50 55 50 MCQ1V2012-2R2-R ±10 2.2 35 0.6 10 50 50 50 MCQ1V2012-2R7-R ±10 2.7 35 0.6 10 50 45 50 MCQ1V2012-3R3-R ±10 3.3 35 0.6 10 50 41 50 MCQ1V2012-3R9-R ±10 3.9 35 0.8 10 50 38 50 MCQ1V2012-4R7-R ±10 4.7 35 0.9 10 50 35 30 Part number 4 1. Ls = Inductance 2. Ls and Q test voltage and frequency 3. Rated I: Current rating for an approximate self-temperature rise of 40 °C or less. 2 www.eaton.com/electronics 4. Part Number Definition: MCQ1V2012-xxx-R MCQ1V2012 = Product code and size xxx= inductance value in µH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Technical Data 11103 MCQ1V2012  Multilayer high Q chip inductor Effective June 2020  Mechanical parameters, schematic, pad layout (mm) Recommended pad layout Schematic Part number L W T a F G H MCQ1V2012-xxx-R 2.00 ±0.20 1.20 ±0.20 0.90 ±0.20 0.50 ±0.30 1.60 ref 0.20 ref 1.20 ref Part marking: No marking All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 4000 parts per 7” diameter reel W±0.2 8.00 F±0.1 3.50 E1±0.2 1.75 E2 Min na P0±0.2 4.00 P1±0.2 4.00 P2±0.1 2.00 D0±0.1 1.55 A0 1.5±0.2 B0 2.3±0.2 T 0.95±0.1 T1 Max na www.eaton.com/electronics 3 MCQ1V2012 Multilayer high Q chip inductor  Technical Data 11103 Effective June 2020 Qualification testing No. Test item Sample size (pcs) 1 External visual 72 2 Physical dimension 72 Specification Specification 3 Initial electrical test 72 Specification User spec 4 Solderability 6 +245 °C ±5 °C, dipping 5 ±1s >95% solder coverage 5 Resistance to soldering heat 6 +260 ±5 °C for 10 ±1 s 1. ΔL/L
MCQ1V2012-R150-R
物料型号:MCQ1V2012系列
器件简介: - 尺寸为0805(2012公制) - 采用多层单体结构,具有高可靠性 - 电感范围从0.047μH到4.7μH - 湿度敏感等级(MSL):1
应用信息: - 工业连接(物联网) - 无线通信 - 蓝牙 - WiFi - 天线 - 机器对机器(M2M) - 移动电话 - 可穿戴设备 - 无线局域网 - 计算/游戏控制台 - 宽带组件 - RF收发模块
参数特性: - 工作温度范围:-40°C至+85°C(环境温度加上自身温度上升) - 符合RoHS标准
功能详解: - 提供了详细的产品规格表,包括公差、最小Q值、25°C时的最大直流电阻(DCR)、测试频率、测试电压、最小自谐振频率(SRF)和额定电流
封装信息: - 推荐焊盘布局和原理图 - 无标记的部件编号 - 所有焊接表面在0.1毫米内共面 - 封装信息包括胶带和卷轴包装,每个7英寸直径的卷轴包含4000个部件
资格测试: - 包括外观检查、物理尺寸、初始电气测试、焊接性、耐热性、端子强度、低温暴露、弯曲强度、跌落、振动、高温暴露、偏置湿度、操作寿命和温度循环等测试项目
Ls(电感)与频率的关系和Q值与频率的关系图表提供了不同型号电感器在不同频率下的电感值和Q值表现。
焊接回流曲线:提供了最大10秒的+255℃焊接峰值温度和自然冷却过程。
生命支持政策:Eaton不授权在未经公司官员明确书面批准的情况下,将其任何产品用于生命支持设备或系统。
MCQ1V2012-R150-R 价格&库存
很抱歉,暂时无法提供与“MCQ1V2012-R150-R”相匹配的价格&库存,您可以联系我们找货
MCQ1V2012-R150-R
  • 4000+0.143754000+0.01803
  • 8000+0.135548000+0.01700
  • 12000+0.1309512000+0.01642
  • 20000+0.1254020000+0.01573
  • 28000+0.1218628000+0.01528
  • 40000+0.1182340000+0.01483
  • 100000+0.10940100000+0.01372
  • 200000+0.10317200000+0.01294
  • 400000+0.09730400000+0.01220
库存:5891
MCQ1V2012-R150-R
  • 1+0.853601+0.10870
  • 10+0.2309010+0.02940
  • 100+0.19590100+0.02500
  • 1000+0.162101000+0.02060
  • 2500+0.144602500+0.01840
  • 4000+0.118904000+0.01510
  • 8000+0.110808000+0.01410
库存:5922
MCQ1V2012-R150-R
  • 1+0.879241+0.11025
  • 10+0.2277610+0.02856
  • 100+0.18750100+0.02351
  • 1000+0.154011000+0.01931
库存:5891
MCQ1V2012-R150-R
    • 1+0.04677
    • 200+0.01815
    • 500+0.01750
    • 1000+0.01718
