MCLA1608V2-1R2-R
MCLA1608V2-1R2-R
    EATON(伊顿)
    固定电感器 0603 1.2nH ±0.3nH 500mA 50mΩ 10GHz 8@100MHz
MCLA1608V2-1R2-R 数据手册
Technical Data 10976 Effective November 2019 MCLA1608V2 Automotive grade multilayer chip inductor Applications • ADAS • Infotainment • Wireless communications • Wifi, bluetooth, satellite • Antenna tuning • On board computer Product features • AEC-Q200 qualified • 0603 (1608 metric) package • Multilayer monolithic construction yields high reliability • Inductance range from 1.0 nH to 470 nH • Moisture sensitivity level (MSL): 1 Environmental data • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) HALOGEN Pb HF FREE MCLA1608V2 Automotive grade multilayer chip inductor  Technical Data 10976 Effective November 2019 Product specifications Part number OCL Tolerance OCL (nH) Q minimum DCR@ (Ω) @ +25 °C maximum Test frequency (MHz) Test voltage (mV) SRF (MHz) minimum I Rated (mA) MCLA1608V2-1R0-R ±0.3nH 1.0 8 0.05 100 50 10000 500 MCLA1608V2-1R2-R ±0.3nH 1.2 8 0.05 100 50 10000 500 MCLA1608V2-1R5-R ±0.3nH 1.5 8 0.1 100 50 6000 500 MCLA1608V2-1R8-R ±0.3nH 1.8 8 0.1 100 50 6000 500 MCLA1608V2-2R2-R ±0.3nH 2.2 8 0.1 100 50 6000 500 MCLA1608V2-2R7-R ±0.3nH 2.7 10 0.12 100 50 6000 500 MCLA1608V2-3R3-R ±0.3nH 3.3 10 0.15 100 50 6000 500 MCLA1608V2-3R9-R ±0.3nH 3.9 10 0.16 100 50 6000 500 MCLA1608V2-4R7-R ±0.3nH 4.7 10 0.2 100 50 6000 500 MCLA1608V2-5R6-R ±0.3nH 5.6 10 0.25 100 50 5000 500 MCLA1608V2-6R8-R ±5% 6.8 10 0.3 100 50 5000 500 MCLA1608V2-8R2-R ±5% 8.2 10 0.35 100 50 4500 500 MCLA1608V2-100-R ±5% 10 12 0.4 100 50 3500 300 MCLA1608V2-120-R ±5% 12 12 0.45 100 50 3000 300 MCLA1608V2-150-R ±5% 15 12 0.5 100 50 2300 300 MCLA1608V2-180-R ±5% 18 12 0.55 100 50 2200 300 MCLA1608V2-220-R ±5% 22 12 0.6 100 50 2000 300 MCLA1608V2-270-R ±5% 27 12 0.65 100 50 1700 300 MCLA1608V2-330-R ±5% 33 12 0.7 100 50 1500 300 MCLA1608V2-390-R ±5% 39 12 0.7 100 50 1400 300 MCLA1608V2-470-R ±5% 47 12 0.7 100 50 1200 300 MCLA1608V2-560-R ±5% 56 12 0.75 100 50 1100 300 MCLA1608V2-680-R ±5% 68 12 0.85 100 50 900 300 MCLA1608V2-820-R ±5% 82 8 1.0 100 50 800 300 MCLA1608V2-101-R ±5% 100 8 1.2 100 50 700 300 MCLA1608V2-121-R ±5% 120 8 1.4 50 50 600 200 MCLA1608V2-151-R ±5% 150 8 1.6 50 50 500 200 MCLA1608V2-181-R ±5% 180 8 1.9 50 50 400 200 MCLA1608V2-221-R ±5% 220 8 2.4 50 50 350 200 MCLA1608V2-271-R ±5% 270 8 2.6 50 50 350 150 MCLA1608V2-331-R ±5% 330 8 2.8 50 50 350 150 MCLA1608V2-391-R ±5% 390 8 3.2 50 50 300 150 MCLA1608V2-431-R ±5% 430 8 3.4 50 50 280 150 MCLA1608V2-471-R ±5% 470 8 3.6 50 50 250 150 1. Test frequency and voltage are for open circuit inductance (OCL) and Q at +25 °C 2. Rated I: When rated I is applied to the product, self-temperature rise will be 20 °C or less. 2 www.eaton.com/electronics 3. Part Number Definition: MCLA1608V2-xxx-R MCLA1608V2 = Product code and size xxx= inductance value in nH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Technical Data 10976 MCLA1608V2  Automotive grade multilayer chip inductor Effective November 2019  Mechanical parameters, schematic, pad layout (mm) Recommended pad layout Schematic Part Number L W T a F G H MCLA1608V2-xxx-R 1.60±0.20 0.80±0.20 0.80±0.20 0.30±0.20 1.20 ref 0.40 ref 0.90 ref Part marking: No marking All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 4000 parts per 7” diameter reel Boom cover tape Top cover tape Center lines of cavity Boom cover tape Top cover tape Direcon of feed W±0.2 8.00 F±0.1 3.50 E1±0.2 1.75 E2 Min na P0±0.2 4.00 P1±0.2 4.00 P2±0.1 2.00 D0±0.1 1.55 A0 1.1±0.2 B0 1.9±0.2 T 0.95±0.1 T1 Max na www.eaton.com/electronics 3 MCLA1608V2 Automotive grade multilayer chip inductor  Technical Data 10976 Effective November 2019 Inductance and Q vs frequency M C L A 1608V 2-1R 0-R 100 10 1 50 0.1 500 5000 F requency ( MHz) Ls Q M C L A 1608V 2-100-R 1000 100 10 1 50 500 F requency ( MHz) Ls 5000 Q M C L A 1608V 2-471-R 10000 1000 100 10 1 50 500 F requency ( MHz) Ls Q 4 www.eaton.com/electronics Technical Data 10976 MCLA1608V2  Automotive grade multilayer chip inductor Effective November 2019  Solder reflow profile Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2019 Eaton All Rights Reserved Printed in USA Publication No. 10976 BU-MC19104 Novemeber 2019 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
MCLA1608V2-1R2-R 价格&库存
很抱歉,暂时无法提供与“MCLA1608V2-1R2-R”相匹配的价格&库存,您可以联系我们找货
MCLA1608V2-1R2-R
  • 4000+0.285114000+0.03576
