Technical Data 10928
Effective June 2019
MCL2012V1
Multilayer chip inductor
Applications
Product features
Industrial connectivity (IoT)
Wireless communiations
Bluetooth
WiFi
Antenna
Machine-to-machine (M2M)
Mobile phones
Wearable devices
Wireless LAN
Computing/gaming consoles
0805 (2012 metric) package
Low DC resistance, high current
Broadband components
Multilayer monolithic construction yields high
reliability
RF transciever modules
Suitable for wave and reflow soldering
Inductance range from 0.047 uH to 22 uH
Environmental data
Mositure sensitivity level (MSL): 1
Operating temperature range: -40 °C to +85 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
MCL2012V1
Effective June 2019
Product specifications
Part number
OCL
(uH) ±20%
I Rated
(mA) maximum
DCR (Ω)
maximum @ +25°C
SRF
(MHz) minimum
Test frequency
(MHz)
Test voltage
(mV)
MCL2012V1-R047-R
0.047
350
0.15
320
1.0
50
MCL2012V1-R056-R
0.056
350
0.15
320
1.0
50
MCL2012V1-R068-R
0.068
350
0.20
280
1.0
50
MCL2012V1-R082-R
0.082
350
0.20
280
1.0
50
MCL2012V1-R100-R
0.10
350
0.20
235
1.0
50
MCL2012V1-R120-R
0.120
350
0.20
220
1.0
50
MCL2012V1-R150-R
0.150
350
0.20
200
1.0
50
MCL2012V1-R180-R
0.180
300
0.25
185
1.0
50
MCL2012V1-R220-R
0.220
300
0.25
170
1.0
50
MCL2012V1-R270-R
0.270
300
0.25
150
1.0
50
MCL2012V1-R330-R
0.330
300
0.25
145
1.0
50
MCL2012V1-R390-R
0.390
250
0.30
135
1.0
50
MCL2012V1-R470-R
0.470
250
0.30
125
1.0
50
MCL2012V1-R560-R
0.560
200
0.36
115
1.0
50
MCL2012V1-R680-R
0.680
200
0.36
105
1.0
50
MCL2012V1-R820-R
0.820
200
0.36
100
1.0
50
MCL2012V1-1R0-R
1.0
220
0.26
75
1.0
50
MCL2012V1-1R2-R
1.2
220
0.26
65
1.0
50
MCL2012V1-1R5-R
1.5
180
0.30
60
1.0
50
MCL2012V1-1R8-R
1.8
180
0.30
55
1.0
50
MCL2012V1-2R2-R
2.2
150
0.36
50
1.0
50
MCL2012V1-2R7-R
2.7
150
0.36
45
1.0
50
MCL2012V1-3R3-R
3.3
120
0.40
41
1.0
50
MCL2012V1-3R9-R
3.9
120
0.40
38
1.0
50
MCL2012V1-4R7-R
4.7
120
0.40
35
1.0
50
MCL2012V1-5R6-R
5.6
100
0.60
32
1.0
50
MCL2012V1-6R8-R
6.8
100
0.60
29
1.0
50
MCL2012V1-8R2-R
8.2
100
0.65
26
1.0
50
MCL2012V1-100-R
10
100
0.65
24
1.0
50
MCL2012V1-120-R
12
100
0.65
22
1.0
50
MCL2012V1-150-R
15
50
0.75
19
1.0
50
MCL2012V1-180-R
18
50
0.75
18
1.0
50
MCL2012V1-220-R
22
50
0.75
16
1.0
50
1. Test frequency and voltage at +25 °C
2. Resistance to soldering heat: +260 ±5 °C for 10 ± 1 second
3. At low temperature (-40 ±2°C) the inductance change is within ±10%
4. At high temperature (+85 ±2°C) the inductance change is within ±10%
5. Rated I: When rated I is applied to the product, self-temperature rise will be 40 °C or less.
2
www.eaton.com/electronics
6. Part Number Definition: MCL2012V1-xxx-R
MCL2012 = Product code and size
V1= Version indicator
xxx= inductance value in uH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
MCL2012V1
Effective June 2019
Dimensions (mm)
Schematic
Recommended pad layout
B
L
C
Part Number
L
W
T
a
A
B
C
MCL2012V1-xxx-R
2.0 ±0.20
1.2 ±0.20
0.90 ±0.20
0.50 ±0.30
1.6 ±0.10
1.2 ±0.10
04 ±0.10
No part marking
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.2 millimeters unless stated otherwise
Pad layout tolerances are ±0.1 millimeters unless stated otherwise
Do not route traces or vias underneath the inductor
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 4000 parts per 7” diameter reel
W ±0.3
F±0.05
E1±0.10
E2 Min
P0±0.10
P1±0.2
P2±0.1
D0+0.10/-0
A0
B0
T Max
T1 Max
8.00
3.50
1.75
6.25
4.00
4.00
2.00
1.50
1.5±0.20
2.3±0.20
1.10
na
3
MCL2012V1
Effective June 2019
Inductance vs frequency
Q vs frequency
30
80
MCL2012V1-2R2-R
15
MCL2012V1-220-R
10
MCL2012V1-100-R
60
40
MCL2012V1-220-R
MCL2012V1-2R2-R
MCL2012V1-100-R
Q value
Inductance [uH]
25
Frequency [MHz]
Frequency [MHz]
Inductance vs current
Inductance(nH)
100,000
10,000
1,000
100
10
1
Current (mAdc)
MCL2012V1-100-R
MCL2012V1-220-R
MCL2101V1-2R2-R
Temperature rise (℃)
Temperature rise vs current
90
80
70
60
50
40
30
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
Current (Adc)
MCL2112V1-220-R
MCL2012V1-2R2-R
MCL2012V1-100-R
4
1.2
1.3
1.4
1.5
1.6
1.7
MCL2012V1
Effective June 2019
Solder reflow profile
TP
TC -5 °C
tP
Max. ramp up rate = 3° C/s
Max. ramp down rate = 6 °C/s
Temperature
TL
Preheat
A
T smax
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“MCL2012V1-R390-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 4000+0.24061
- 40000+0.23215
- 160000+0.22248
